Staro 07.08.2023., 22:39   #2611
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,227
Imas RescueZillu, gui za CloneZillu pa probaj s njim.
Staro 11.08.2023., 17:33   #2612
strikoo
strikoo's Avatar
Postovi: 960
trazio sam alternativu za tmux i screen
https://zellij.dev/
brutalica
strikoo je offline   Reply With Quote
Staro 12.08.2023., 12:23   #2613
medo
#erase startup-config
medo's Avatar
Postovi: 3,695
Mali update: nakon flashanja Orico PCIe kartice (VL805 USB chip) UASP radi k'o podmazan:
Code:
# dd if=/dev/sde of=/dev/null bs=4M status=progress
195693641728 bytes (196 GB, 182 GiB) copied, 498 s, 393 MB/s
Ovo je Samsung 870 EVO 4TB u zatvorenom Orico USB-C -> SATA kućištu koje također ima ViA chip. dd ide zabetonirano 393MB/s a SSD se ne grije puno:
Code:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.2.0-26-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       284
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       122
177 Wear_Leveling_Count     0x0013   099   099   000    Pre-fail  Always       -       2
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   055   053   000    Old_age   Always       -       45
195 Hardware_ECC_Recovered  0x001a   200   200   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x003e   100   100   000    Old_age   Always       -       0
235 Unknown_Attribute       0x0012   099   099   000    Old_age   Always       -       18
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       13257598466
252 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1
Staro 14.08.2023., 09:08   #2614
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,814
Jel imao tko prilike igrat se sa alternativama OpenVas-u? Htio bih postaviti sustav na noge koji ce kao i OpenVas skenirat server (pozeljno agentless) da mogu agirat na sigurnosne updejtove OS-a (konkretno je OpenSuse / SLES) u pitanju. Dosad sam imao na privatnoj masini OpenVas + aktualni Image OS-a ali zelim prebaciti sve na radnu stanicu u uredu - i tu me hebe Firewall (da poslao ticket bla bla ali ekipa koja iza toga stoji vidi rsync kao nekaj kaj samo "hackeri" koriste (da, znam da i mene zaboli mozak kad se sjetim originalne izjave)). Da, znam da zypper ima elegantno rijesenje za to - problem je da to kaj koristimo nije cisti Suse/Sles i koristimo preko 300 posebno patchanih paketa i zypper upgrade ne dolazi u obzir s obzirom da bi skrsio vazne stvari dok si reko keks. Dakle trazim neki nacin da vidim koje sigurnosne propuste imam na sustavu, da ih mogu analizirat. Skinut updejtove i patchat je drugi par rukava al taj dio sam pokrio odavno.
P.S.- mora bit free naravno jer gornji management ne zeli iskesirat lovu za nekaj "normalno" pa se moram ovak zahebavat:
Code:
Updating NVTs....
/usr/bin/greenbone-nvt-sync
rsync: [Receiver] failed to connect to feed.community.greenbone.net (45.135.106.143): Connection timed out (110)
rsync: [Receiver] failed to connect to feed.community.greenbone.net (2a0e:6b40:20:106:20c:29ff:fe7f:d2ae): Network is unreachable (101)
rsync error: error in socket IO (code 10) at clientserver.c(138) [Receiver=3.2.3]
/usr/bin/greenbone-nvt-sync success
Updating GVMD_DATA...
/usr/sbin/greenbone-feed-sync --type GVMD_DATA
/usr/sbin/greenbone-feed-sync --type GVMD_DATA success
Updating SCAP data...
/usr/sbin/greenbone-feed-sync --type SCAP
/usr/sbin/greenbone-feed-sync --type SCAP success
Updating CERT data...
/usr/sbin/greenbone-feed-sync --type CERT
/usr/sbin/greenbone-feed-sync --type CERT success
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / FreeBSD 14.3
Staro 20.08.2023., 09:52   #2615
No123
Lokacija: Grad na Dravi
Postovi: 580
Jel bi bežični miš Logitech M705 radio na opeSUSE Tumbleweed, da ne kupujem bez veze ako neće radit, našao sam da radi na Chrome OS, a to je isto linux?
No123 je offline   Reply With Quote
Staro 20.08.2023., 10:05   #2616
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
Nisam naletio na misa koji ne radi na Linuxu.
P.S. Chrome OS nije Linux.
Staro 20.08.2023., 10:20   #2617
No123
Postovi: 580
Ok,tnx.
Staro 20.08.2023., 13:45   #2618
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Ne, nego su Windowsi.
https://www.zdnet.com/article/8-thin...os-or-windows/
Programer
Staro 20.08.2023., 14:06   #2619
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
Autor Bubba Pregled postova
Ok drugi put kava prije reakcija na forumu nakon noci prezderavanja i rakije Kernel = Linux. Ostalo je ustogljeni Linux
Staro 21.08.2023., 07:45   #2620
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,767
Prešao na Linux Mint po drugi puta na kućnom računalu. Prvi puta tamo negdje 2017 pa se vratio na Win10 oko 2019.
Nekako mi se čini da ima puno manje mušica nego prije. Sve radi sa stvarno minimalno podešavanja. Čak je i sve brže nego na Win10, iako to može biti do 3-4 godina stare win instalacije.
Klinci su oduševljeni što se Minecraft pokreće za valjda 5 sekundi u odnosu na barem 60+ sekundi na win. Meni Civ VI koji jedini igram već duže vrijeme radi od prve. Samo instalirao Steam i skinuo. Svi ostali osnovni programi koje koristim kući postoje na linuxu ili je već došlo kao dio OS-a.
Uglavnom, vrlo pozitivno iskustvo s aspekta kućnog korisnika.
Staro 21.08.2023., 08:38   #2621
Dr. Strange
Datum registracije: Aug 2020
Postovi: 892
Autor Libertus Pregled postova
Linux mint ima malo konzervativnu politiku, tj pazljivo migriraju na nove stvari, sto moze biti i prednost ovisi sta zelis. Rezultat toga je ultra stabilnost, a i to je vjerojatno najbolja distribucija za Windows korisnike, sve sto moze imati graficko sucelje ima, out of the box imas i sve drivere, tako da se i najveci noob moze snaci u toj Linux distribuciji, najbezbolniji ulazak u Linux svijet.
Staro 21.08.2023., 09:50   #2622
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,767
To mi i treba. Računalo uz mene koriste žena i djeca, a oni ni ne primjećuju da se nešto bitno desilo jer je 99% korištenja Firefox + Minecraft. Najveća panika je bila da li ćemo uspjeti prenijeti Minecraft svjetove na novu instalaciju (jesmo).
Staro 21.08.2023., 10:02   #2623
c-shadow
c-shadow's Avatar
Postovi: 3,472
Ja sam se nedavno nakon dugo godina prebacio s xubuntu na Mint jer su *buntu zakakili sa snap-om. Konzervativna politika mi sasvim odgovara.
Ženi sam na laptop stavio Mint XFCE i ne buni se
Kćerka veli da se Minecraft na winblowsima dugo loada, svašta je natrpala, hrpu modova, launcheri razni... ali ne bi se kladio da se na mintu nešto puno brže loada, za java verziju očekivao bi da bude otprilike isto. Ali djecu radi igrica moram držati na windowsima
Gledam kako Mint razvija LMDE, meni se čini da se oni pokušavaju malo pomalo odvojiti od ubuntu i vezati direktno na Debian.
Staro 21.08.2023., 10:33   #2624
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
Prije 3 godine mi je bio Daily Driver...cist OK OS. Zavisi s kojeg stajalista gledas > ako znas sto i kako > Debian i bok. Pure, Vanilla i najbolja solucija za sve od workstationa do servera - pa cak i za desktop. Jedini razlog zakaj i dalje primarno Fedoru vrtim da mi se neda trenutno sve krsit jer mi je primarni OS katica za sve od pornjave do gejmanja i dev cickarija.
Staro 21.08.2023., 11:24   #2625
c-shadow
c-shadow's Avatar
Postovi: 3,472
Meni je to daily driver već godinama, xcfe i jubuntu ispod, sada mint, čisto radi jednostavnosti instalcije i održavanja jer sam s debian paketnim upoznat za razliku od RHa i derivata. A ionako sve bitno mi je u virtualkama raznim.
A i na ono govno od novog gnometa me nitko ne može natjerati
Ja sam malo stariji i oldschool pa me jako iritiraju te novotarije gdje uspijevaju zakenjati GUI programa, sve su manje ergonomični i prilagođeni valjda nekoj ekipi koja po tabletu nabada prstima, a ne radi mišem na većem ekranu kao ja.
Staro 21.08.2023., 12:39   #2626
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
Iskreno...meni Gnome pase. Po defaultu je ultra okrljasten - dodam extenzije koje zelim i mozak na pasu. KDE faze imam ali uvijek sam se vracao na Gnome. Najbolje radi sa Waylandom i sucelje nije prenatrpano opcijama ko KDE. XFCE sam najduze ganjao al nekako me sve to proslo i poceo sam opet biti sucker za eye candy
P.S.- APT i DNF se ne razlikuju tak puno , brzo bi se prilagodio Ja sam u ranije dane radio distro hopping na tjednoj bazi, volio sam experimentirat. Da razlikuju se al u sustini sve je to isto meni - daj mi vim,bash i tmux i ja sretan
Staro 21.08.2023., 13:15   #2627
c-shadow
c-shadow's Avatar
Postovi: 3,472
Baš taj eye candy mi ništa ne znači, ja sam generacija odrasla na DOSu i NC :-)
Bemti, na faksu smo učili internalije DOSa u sklopu kolegija oper. sustava.
Ovo pišem kao krajnji korisnik xfce sučelja jer ne tipkam u vimu niti privantno niti profesionalno....
Ako ćemo već oko GUIa, xfceu je falio bolji file manager i thunar je u zadnjoj verziji (koju je Mint dobio tek prelaskom na 21.2) dobio dosta novih stvari:
- search po dorektorijima/datotekama. Pravo čudo da u 2023 postoji file manager koji to nema
- copy proces je poboljšan, sad ima pauzu, background i ostale "napredne" fičure koji su drugi file manageri imali pred 15 godina
- restore tabova na startupu
- undo operacija
- split view
- itd.
Dosada je čak i winblows exploder bio upotrebljivi nego thunar.
xfce je i dalje ružan za današnje pojmove, ali ima jako spori razvoj i stabilan je što mi osobno odgovara.
Staro 21.08.2023., 13:21   #2628
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,041
Meni novi gnome nije legao pa koristim Matu. Čak sam nedavno skužio da instaliram jedan paket pa Gnome programi dobiju isto titlebar kakav ima Mate.
Staro 21.08.2023., 13:58   #2629
c-shadow
c-shadow's Avatar
Postovi: 3,472
Apropo egonomije u modernim sučeljima...
Primjer, simple scan, GTK aplikacija za skeniranje, praktički jedina jednostavna i da je "just works" ako se ne koristi KDE ili neka egzota od sučelja/aplikacije.
Koristim taj program već dugo i iz generacije u generaciju je sve lošiji, ovo je zadnja verzija:
- tipka scan je gore lijevo
- save je okomita strelica gore desno
- za novi dokument tipka je dolje lijevo
- crop i ovih par gumbi su iz nekog nepoznatog razloga dolje na sredini
Sad kad pokrećem skeniranje, kliknem mišem gore lijevo, za spremiti prolazim mišem cijeli ekran do gore desno za spremiti. Za novi dokument idem dijagonalno preko ekrana dolje lijevo.
To je jako puno šetanja mišem preko cijelog ekrana. U starijim verzijama bio je standardni toolbar i svi gumbići jedan kraj drugoga.
E, da, ako ste mislili da nakon pokretanja zeleni gumb "Scan" ima fokus pa da se samo stisne enter, varate se
Ostaje ili dobiti sindrom karpalnog tunela ili naučiti napamet još jedan set key shortcuta
Pokušavam shvatiti za koga, za kakvo sučelje i kakav način upravljanja su developeri ovo napravili?
Staro 21.08.2023., 15:03   #2630
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
To nastane kad se jednostavnost preagresivno forsira. Ona druga strana "mac-like" jednostavnosti, pisanoj za idiote.
P.S.- meni pase
Staro 21.08.2023., 20:43   #2631
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,401
To je mislim default skener aplikacija na KDE - DEL za brisanje stranice, CTRL+S za spremanje Poštediš si miša.
Staro 21.08.2023., 20:51   #2632
Dr. Strange
Postovi: 892
Masu ljudi mi je došlo sa starim laptopima koji nisu sposobni optimalno vrtiti Windowse i instalirao sam im Mint, zadovoljni su, ne primjećuju neku veliku razliku osim što im je laptop brži , modificirao sam malo sučelje, zamjenio start ikonu s onom Windowsom tako da im bude što sličnije iskustvo. Za 2 god ističe Windows 10 podrška, a masu računala neće moći migrirati na Windowse 11 zbog vrlo striktnih zahtjeva, i to je idealna prilika za Linux, osim ako Microsoft ne napravi neku posebnu verziju za takva računala.
Staro 22.08.2023., 07:01   #2633
No123
Postovi: 580
Jučer nakon "zypper dup" Švabo mi se zbleso, sad me na početku pita lozinku iako je namješteno na auto login i kad upišem lozinku kaže mi da je neispravna, čini mi se da je to sve radi NVIDIA drivera i kako da ja sad njega maknem da ostane samo onaj od linuxa nouveau? I da maknem NVIDIA repos? I neće instalirati glibc-32bit.
Staro 22.08.2023., 07:43   #2634
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
Autor No123 Pregled postova
Kao osoba koja dnevno radi sa OpenSuse i SLES sustavima - nekaj si gadno usro I ne - nema to veze sa Nvidia repo. Zypper dup sluzi samo za upgrade distre (npr za Leap 15.4 na 15.5). Od verzije 42.3 radi cist solidno i rijetko nastanu problemi. zypper up je normalan update systema. Problemi kod Zyppera nastanu kad se mijenjaju repozitoriji paketa pa moras imat Vendor Change opciju na umu (--allow-vendor-change) i sve najprije testirat (zypper dup --download-only). Ako zelis OpenSuse na Desktopu koristiti moja ti je preporuka Tumbleweed - rolling release, noviji paketi (Leap je vise ala Debian Stable ili Rocky Linux). Od reposa dodas Packman i vozi misko. E sad da bi rijesili tvoj problem moram znati sto si vrtio i sto si htio napraviti te kako. Ako ti dode boot do Login Managera (koji i koje graficko sucelje si instalirao?) ne vjerujem da je do nvidia drivera. Da se kernel modul nije ispravno kompilirao nebi ni do Login Managera dosao. Kod tebe se vjerojatno nekaj u PAM modulima skrsilo kod upgrejda sustava pa autentifikacija kod logina ne sljaka vise. Ili prava na tvom Home ne stimaju. Si probao login u konzoli (ctrl+alt+f1)? Zakaj ti glibc paket nije htio azurirat, koju gresku ti je javilo?
P.S.- OpenSuse i SLES inace imaju dosta dobru dokumentaciju online:
https://en.opensuse.org/Main_Page
https://documentation.suse.com/
Zadnje izmijenjeno od: tomek@vz. 22.08.2023. u 08:01.
Staro 22.08.2023., 08:00   #2635
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,041
Za skeniranje koristim XSane i dalje, samo šteta kaj nije sve jednom prozoru nego su razbacani.
Čak razmišljam Vue kupiti ali...
Staro 22.08.2023., 08:00   #2636
No123
Postovi: 580
Imam Tumbleweed, repos od nvidie mi se sam pojavio, ja ga nisam stavio. Kad se diže normalno dođe do onog prozorčića gdje trebam upisati lozinku i kada ju upišem kaže mi da ne valja mada je ispravna. Probao sam maknuti repos od nividie ali mi ne da, javi neku grešku, sad nisam kod kuće pa ne znam što napiše.
Staro 22.08.2023., 13:39   #2637
No123
Postovi: 580
Instalira ja Španjolca, Void linux i sve radi ka vurica.
Staro 22.08.2023., 15:41   #2638
tomek@vz
tomek@vz's Avatar
Postovi: 4,814
Bitno je shvacat greske koje ti OS izbaci. Al "whatever floats your boat"
Staro 22.08.2023., 20:49   #2639
mkey
Lokacija: tu
Postovi: 3,401
To je "I am a bus" pristup rješavanju problema
Volim ga primijenjivati kada se identificiram kao autobus.
Staro 23.08.2023., 07:10   #2640
No123
Postovi: 580
Ja samo znam da mi se već na par distri sve zblesalo kad sam instalirao NVIDIA driver.
