Staro 15.04.2023., 16:08   #6511
the.elles.d
Datum registracije: Jul 2010
Postovi: 545
Autor strikoo Pregled postova
Imas revanced manager na githubu
pa sam specas YT
Nudi 50+ opcija. Ima li ikava lista što poklikati da bude kao yt vanced?
the.elles.d je offline   Reply With Quote
Staro 16.04.2023., 09:45   #6512
D.O.M.I.
D.O.M.I.'s Avatar
Datum registracije: Jul 2009
Postovi: 279
Prekjučer mi crko Vanced pa sam napravio sve po ovim uputama i ReVanced dela bez greške.
https://www.reddit.com/r/revancedapp...e_for_dummies/
D.O.M.I. je offline   Reply With Quote
Staro 16.04.2023., 17:07   #6513
Dottore
Dottore's Avatar
Postovi: 7,653
Vjerujema da neki nisu ažurirali na zadnji MicroG pa je javilo problem.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 16.04.2023., 22:46   #6514
axo
Datum registracije: Sep 2017
Postovi: 1,428
Autor D.O.M.I. Pregled postova
Zahvaljujem
Staro 17.04.2023., 20:13   #6515
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,185
pozdrav.
dali postoji neka aplikacija kojom mogu neke aplikacije disable-ati privremeno. mob nije root-an (Xiaomi A2). nekad davno na rootanim mobovima sam koristio titanium.
imam FX file manager instaliran na mobu i vidim da ima neku mogucnost "disable package", ali i baci ogromno upozorenje za to. jel to cemu?
disable-ao bi viber, signal, sykpe, whatsapp, google authenticator i aquamail.
Staro 17.04.2023., 20:31   #6516
Postovi: 10,077
Koliko cesto moras/zelis paliti/gasiti te appove? Sve to mozes s kompa preko adb komandi, ali je bezveze ako to radis vise od jednom dnevno.
https://www.xda-developers.com/unins...t-root-access/
Mozes ti napraviti i bat skriptu na kompu pa umjesto da upisujes x naredbi, lijepo spojis mob, pokrenes skriptu i disejbla ti appove. S drugom skriptom/setom naredbi ih upalis.
Staro 17.04.2023., 20:32   #6517
geronimo_2
geronimo_2's Avatar
Postovi: 4,185
ma ne. rjetko. to mi je backup mob, ap ikad zatreba ko sto je sad trenutno jer sam glavni mob spickao. al taj mob koriste i drugi ukucani pa kad ga njima dam u ruke zelim ove appove disable.
edit: ovo navedeno gore u FX-u sma probao i nemere, isto treba root :-(
koja glupost da nema u opcijama od moba da te neke non system app mozes temp disable. glupost.
a nemam vremana sad ic kopat satima i danima kako root-at taj mob samo da to mogu napravit.
Zadnje izmijenjeno od: geronimo_2. 17.04.2023. u 20:58.
Staro 19.04.2023., 04:26   #6518
Postovi: 33,973
Postoji li neki downloader manager koji podržava premium accounte (k2s, rapidgator & co.) slično JDownloaderu na Winsima?
Staro 20.04.2023., 10:53   #6519
nepalac
Datum registracije: Feb 2022
Lokacija: EU
Postovi: 827
Evo i meni Vanced prestao raditi, ne može otvoriti ni jedan video.
Morat ću se pozabavit s tim ReVancedom.
NewPipe mi je ok ali više mi paše Vanced sučelje pa ćemo vidjeti.
Staro 20.04.2023., 11:38   #6520
xXTheLuka1998xX
xXTheLuka1998xX's Avatar
Datum registracije: Feb 2015
Postovi: 353
Autor nepalac Pregled postova
Revanced sam i ja instalirao po ovom linku gore,ima istu ikonicu ko klasični yt ,al sve iste funkcionalnosti ko vanced.
Poslano sa mog SM-G996B koristeći Tapatalk
xXTheLuka1998xX je offline   Reply With Quote
Staro 20.04.2023., 22:54   #6521
nepalac
Lokacija: EU
Postovi: 827
Instalirao sam i ja ReVanced ali odmah uočavam jedan problem.
Aplikacija mi ne pamti pretragu.
Nisam logiran i ne želim biti, ali na starom Vancedu sve što sam pretraživao bi mi ostalo, a to mi je dosta korisno.
Pa ako netko zna riješenje...
P.S. I ne, nisam pauzirao povijest pretrage u postavkama.
Staro 21.04.2023., 09:32   #6522
okarm
Postovi: 772
instalirao i ja revanced, sve radi ok ali imam jedan problem koji nisam imao s vanced appom. imam galaxy sat i sada svaki put kad na mobu gledam nesto na revanced ili yt appu, na satu mi se aktivira music app i mogu upravljati s videom kojeg gledam.
problem je sto cak ako i to ne koristim on je aktivan u pozadini i brutalno trosi bateriju. pokusavao sam naci neku opciju koju bih iskljucio ali bez uspjeha. tako da trenutno na mobu imam iskljucen bt ako gledam yt.
okarm je online   Reply With Quote
Staro 21.04.2023., 13:43   #6523
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
da li stvarno whatsapp pop obavijesti nisu moguće na androidu 10? probao sam nekoliko googlanih savjeta ali i dalje kaže da ništa od obavijesti na desetki. kako je to moguće?
divovski kompjuteri
tomasini_ je offline   Reply With Quote
Staro 21.04.2023., 14:18   #6524
axo
Postovi: 1,428
Microg zadnjih 7 dana koristi 1.4 %, revanced 1.1 al baš i ne gledam na mobu yt i to na a53 5g.
Uključen BTW stalno, 120hz na revancedu itd.
Staro 29.04.2023., 11:50   #6525
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,819
Ata ce ti 120 na revancedu ako nema videa priko 60
Meni na revancedu ne radi automatsko pauziranje videa nakon x min, osim ako nije upaljen ekran, na premiumu mi to radi
Staro 29.04.2023., 12:14   #6526
AndroiOs
AndroiOs's Avatar
Datum registracije: Jan 2018
Lokacija: KA
Postovi: 573
A pusti ti to
Mora revanced ispast pametniji izbor od nas glupih koji plaćamo premium koji je naravno bolji i ispravniji
Poslano sa mog SM-G991B koristeći Tapatalk
AndroiOs je offline   Reply With Quote
Staro 29.04.2023., 12:53   #6527
nepalac
Lokacija: EU
Postovi: 827
Ne bih youtube plaćao ni da košta 1 lipu.
Moj izbor, najviše zato što ne želim uopće koristit YT dok sam logiran, a ni ne želim uopće biti vezan za google usluge više nego što moram.
Tako da ne kužim čemu stalno isticanje kako postoji neki indijski/turski/kirgistanski YT account za 1.4$... who gives s fuck - neću plaćati.
Dakle, ReVanced je zakon, ima neke mušice ali popeglat će se to, većinom radi savršeno...
Staro 29.04.2023., 15:57   #6528
Postovi: 10,077
Bolje spomenuti kirgistanski primijum nego da se netko lud zaleti i plati hrvatski primijum
Staro 29.04.2023., 20:02   #6529
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,604
Imam ReVanced i stari Vanced koji rade kako treba. Da plaćam korporacijama koje se valjaju u novcima, ne pada mi na pamet, pa makar bilo i 1 cent...
Staro 01.05.2023., 12:59   #6530
Deamon101
Deamon101's Avatar
Postovi: 682
Pozdrav svima i sretan Prvi maj. te obljetnica Bljeska.
Zna li netko kako obrisati sms poruka sve odjednom?
Aplikacija dopušta samo selektiranje, pa brisanje, a poruka ima 5 godina
Hvala svima.
edit > uspio preko Honor suite.
Zadnje izmijenjeno od: Deamon101. 01.05.2023. u 14:44.
Deamon101 je offline   Reply With Quote
Staro 23.05.2023., 08:42   #6531
Buger
Postovi: 4,390
Gdje skidate zadnju verziju Youtube Revanceda? Vidim da ima više stranica..
Staro 23.05.2023., 08:46   #6532
strikoo
strikoo's Avatar
Postovi: 964
Autor Buger Pregled postova
github revanced manager i sam zbildaš
strikoo je offline   Reply With Quote
Staro 23.05.2023., 08:48   #6533
Buger
Postovi: 4,390
Ajd mi ovo zbildaš objasni
Staro 23.05.2023., 10:25   #6534
locks
Lokacija: Vukovar
Postovi: 3,604
Ja skinem gotov apk, instaliram i sve radi....
Staro 23.05.2023., 11:14   #6535
Neo-ST
Neo-ST's Avatar
Postovi: 8,360
Autor locks Pregled postova
Samo pazi odakle skidaš, da netko ne uvali trojan u taj apk, pa i njega instaliraš...
Staro 23.05.2023., 11:27   #6536
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,245
Ma kakvo bildanje, skini i instaliraj
https://revancedextended.com/
Staro 29.05.2023., 15:21   #6537
okarm
Postovi: 772
ono sto sam ja primjetio je da revanced zdere bateriju puno vise od starod vanceda.
Staro 29.05.2023., 19:33   #6538
Dottore
Dottore's Avatar
Postovi: 7,653
Na koji revanced misliš? Do sada nisam primjetio brzo trošenje.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 20.06.2023., 19:08   #6539
c-shadow
c-shadow's Avatar
Postovi: 3,478
Preporuke za dobar android file manager?
Uvjet mi je da ima dobru podršku za konekcije na ssh i samba server.
Poželjno da je s 2 panela
Koristio sam godinama x-plore međutim šteka u oba zahtjeva i izgleda da autor ne misli to ažurirati.
Staro 20.06.2023., 19:27   #6540
Postovi: 10,077
Root explorer ako su ti tabovi oke. Probao preci na x-plore i fx ali nikako. Na tvu mi je xplore top, na mobu ipak root explorer
