Staro 11.04.2017., 14:55   #1
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Nvidia Quadro/RTX series
Samo kratak info, prije izvjesnog vremena ubacio sam dva fantasticna nVidia produkta, low-end Quadroice bazirane na Pascalu, P400 (najslabija) verzija, puta dva. Cijenom su mi bile i vise nego pogodne, ne trose skoro nista, i ne cuju se kada ne treba. 3x mini DP, gutaju i DP, i DVI (pa samim time i HDMI), i VGA.
Samo malo podataka, fotki i slicno.
Code:
hashcat (v3.40) starting in benchmark mode...
* Device #1: Not a native Intel OpenCL runtime, expect massive speed loss
             You can use --force to override this but do not post error reports if you do so
* Device #2: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES
             See the wiki on how to disable it: https://hashcat.net/wiki/doku.php?id=timeout_patch
* Device #3: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES
nvmlDeviceGetPowerManagementLimit(): Not Supported
OpenCL Platform #1: Advanced Micro Devices, Inc.
* Device #1: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz, skipped
OpenCL Platform #2: NVIDIA Corporation
* Device #2: Quadro P400, 512/2048 MB allocatable, 2MCU
* Device #3: Quadro P400, 512/2048 MB allocatable, 2MCU
Hashtype: MD4
Speed.Dev.#2.....:  2477.6 MH/s (54.07ms)
Speed.Dev.#3.....:  2537.5 MH/s (52.73ms)
Speed.Dev.#*.....:  5015.2 MH/s
Hashtype: MD5
Speed.Dev.#2.....:  1448.5 MH/s (92.54ms)
Speed.Dev.#3.....:  1484.5 MH/s (90.22ms)
Speed.Dev.#*.....:  2933.0 MH/s
Hashtype: Half MD5
Speed.Dev.#2.....:   958.8 MH/s (69.91ms)
Speed.Dev.#3.....:   979.8 MH/s (68.32ms)
Speed.Dev.#*.....:  1938.6 MH/s
Hashtype: SHA1
Speed.Dev.#2.....:   531.1 MH/s (63.08ms)
Speed.Dev.#3.....:   545.0 MH/s (61.40ms)
Speed.Dev.#*.....:  1076.1 MH/s
Hashtype: SHA256
Speed.Dev.#2.....:   206.2 MH/s (80.94ms)
Speed.Dev.#3.....:   211.6 MH/s (78.76ms)
Speed.Dev.#*.....:   417.8 MH/s
Hashtype: SHA384
Speed.Dev.#2.....: 69899.6 kH/s (59.85ms)
Speed.Dev.#3.....: 71274.8 kH/s (58.65ms)
Speed.Dev.#*.....:   141.2 MH/s
Hashtype: SHA512
Speed.Dev.#2.....: 70650.4 kH/s (59.15ms)
Speed.Dev.#3.....: 73033.5 kH/s (57.21ms)
Speed.Dev.#*.....:   143.7 MH/s
Hashtype: SHA-3(Keccak)
Speed.Dev.#2.....: 57256.0 kH/s (73.06ms)
Speed.Dev.#3.....: 58897.1 kH/s (70.92ms)
Speed.Dev.#*.....:   116.2 MH/s
Hashtype: SipHash
Speed.Dev.#2.....:  1896.7 MH/s (70.62ms)
Speed.Dev.#3.....:  1951.1 MH/s (68.53ms)
Speed.Dev.#*.....:  3847.9 MH/s
Hashtype: Skip32
Speed.Dev.#2.....:   396.0 MH/s (42.16ms)
Speed.Dev.#3.....:   421.0 MH/s (39.66ms)
Speed.Dev.#*.....:   816.9 MH/s
Hashtype: RipeMD160
Speed.Dev.#2.....:   315.9 MH/s (52.82ms)
Speed.Dev.#3.....:   320.7 MH/s (51.32ms)
Speed.Dev.#*.....:   636.5 MH/s
Hashtype: Whirlpool
Speed.Dev.#2.....: 16698.8 kH/s (125.49ms)
Speed.Dev.#3.....: 17245.2 kH/s (121.42ms)
Speed.Dev.#*.....: 33944.0 kH/s
Hashtype: GOST R 34.11-94
Speed.Dev.#2.....: 15845.2 kH/s (132.27ms)
Speed.Dev.#3.....: 16316.1 kH/s (128.31ms)
Speed.Dev.#*.....: 32161.3 kH/s
Hashtype: GOST R 34.11-2012 (Streebog) 256-bit
Speed.Dev.#2.....:  3311.2 kH/s (312.83ms)
Speed.Dev.#3.....:  3416.5 kH/s (303.09ms)
Speed.Dev.#*.....:  6727.6 kH/s
Hashtype: GOST R 34.11-2012 (Streebog) 512-bit
Speed.Dev.#2.....:  3314.6 kH/s (312.51ms)
Speed.Dev.#3.....:  3419.2 kH/s (302.86ms)
Speed.Dev.#*.....:  6733.7 kH/s
Hashtype: DES (PT = $salt, key = $pass)
Speed.Dev.#2.....:  1322.2 MH/s (50.44ms)
Speed.Dev.#3.....:  1362.6 MH/s (48.95ms)
Speed.Dev.#*.....:  2684.8 MH/s
Hashtype: 3DES (PT = $salt, key = $pass)
Speed.Dev.#2.....: 38603.4 kH/s (54.24ms)
Speed.Dev.#3.....: 39880.5 kH/s (52.38ms)
Speed.Dev.#*.....: 78483.9 kH/s
Hashtype: phpass, MD5(Wordpress), MD5(phpBB3), MD5(Joomla)
Speed.Dev.#2.....:   454.7 kH/s (70.54ms)
Speed.Dev.#3.....:   475.2 kH/s (67.92ms)
Speed.Dev.#*.....:   929.9 kH/s
Hashtype: scrypt
Speed.Dev.#2.....:    57169 H/s (17.23ms)
Speed.Dev.#3.....:    58609 H/s (16.67ms)
Speed.Dev.#*.....:   115.8 kH/s
Hashtype: PBKDF2-HMAC-MD5
Speed.Dev.#2.....:   503.0 kH/s (63.43ms)
Speed.Dev.#3.....:   518.9 kH/s (61.71ms)
Speed.Dev.#*.....:  1021.9 kH/s
Hashtype: PBKDF2-HMAC-SHA1
Speed.Dev.#2.....:   222.5 kH/s (60.58ms)
Speed.Dev.#3.....:   228.4 kH/s (58.87ms)
Speed.Dev.#*.....:   450.9 kH/s
Hashtype: PBKDF2-HMAC-SHA256
Speed.Dev.#2.....:    81696 H/s (45.39ms)
Speed.Dev.#3.....:    84643 H/s (83.97ms)
Speed.Dev.#*.....:   166.3 kH/s
Hashtype: PBKDF2-HMAC-SHA512
Speed.Dev.#2.....:    30476 H/s (62.56ms)
Speed.Dev.#3.....:    31386 H/s (60.69ms)
Speed.Dev.#*.....:    61861 H/s
Hashtype: Skype
Speed.Dev.#2.....:   851.0 MH/s (78.77ms)
Speed.Dev.#3.....:   874.4 MH/s (76.56ms)
Speed.Dev.#*.....:  1725.3 MH/s
Hashtype: WPA/WPA2
Speed.Dev.#2.....:    27359 H/s (74.44ms)
Speed.Dev.#3.....:    28183 H/s (72.29ms)
Speed.Dev.#*.....:    55542 H/s
Hashtype: IKE-PSK MD5
Speed.Dev.#2.....:   114.4 MH/s (73.16ms)
Speed.Dev.#3.....:   119.7 MH/s (69.99ms)
Speed.Dev.#*.....:   234.0 MH/s
Hashtype: IKE-PSK SHA1
Speed.Dev.#2.....: 52769.0 kH/s (78.94ms)
Speed.Dev.#3.....: 54724.6 kH/s (76.38ms)
Speed.Dev.#*.....:   107.5 MH/s
Hashtype: NetNTLMv1-VANILLA / NetNTLMv1+ESS
Speed.Dev.#2.....:  1433.4 MH/s (93.54ms)
Speed.Dev.#3.....:  1476.4 MH/s (90.77ms)
Speed.Dev.#*.....:  2909.7 MH/s
Hashtype: NetNTLMv2
Speed.Dev.#2.....:   107.6 MH/s (77.82ms)
Speed.Dev.#3.....:   110.7 MH/s (75.56ms)
Speed.Dev.#*.....:   218.4 MH/s
Hashtype: IPMI2 RAKP HMAC-SHA1
Speed.Dev.#2.....:   114.3 MH/s (73.29ms)
Speed.Dev.#3.....:   117.1 MH/s (71.48ms)
Speed.Dev.#*.....:   231.4 MH/s
Hashtype: Kerberos 5 AS-REQ Pre-Auth etype 23
Speed.Dev.#2.....: 19158.7 kH/s (54.47ms)
Speed.Dev.#3.....: 20104.2 kH/s (104.11ms)
Speed.Dev.#*.....: 39262.8 kH/s
Hashtype: Kerberos 5 TGS-REP etype 23
Speed.Dev.#2.....: 19133.2 kH/s (54.55ms)
Speed.Dev.#3.....: 20077.4 kH/s (104.26ms)
Speed.Dev.#*.....: 39210.5 kH/s
Hashtype: DNSSEC (NSEC3)
Speed.Dev.#2.....:   223.0 MH/s (74.84ms)
Speed.Dev.#3.....:   230.4 MH/s (72.31ms)
Speed.Dev.#*.....:   453.5 MH/s
Hashtype: PostgreSQL Challenge-Response Authentication (MD5)
Speed.Dev.#2.....:   389.0 MH/s (86.08ms)
Speed.Dev.#3.....:   401.2 MH/s (83.43ms)
Speed.Dev.#*.....:   790.2 MH/s
Hashtype: MySQL Challenge-Response Authentication (SHA1)
Speed.Dev.#2.....:   155.0 MH/s (53.97ms)
Speed.Dev.#3.....:   160.1 MH/s (52.12ms)
Speed.Dev.#*.....:   315.2 MH/s
Hashtype: SIP digest authentication (MD5)
Speed.Dev.#2.....:   130.1 MH/s (64.38ms)
Speed.Dev.#3.....:   134.0 MH/s (62.40ms)
Speed.Dev.#*.....:   264.1 MH/s
Hashtype: SMF > v1.1
Speed.Dev.#2.....:   453.1 MH/s (73.95ms)
Speed.Dev.#3.....:   465.4 MH/s (71.88ms)
Speed.Dev.#*.....:   918.5 MH/s
Hashtype: vBulletin < v3.8.5
Speed.Dev.#2.....:   456.2 MH/s (73.46ms)
Speed.Dev.#3.....:   469.5 MH/s (71.26ms)
Speed.Dev.#*.....:   925.7 MH/s
Hashtype: vBulletin > v3.8.5
Speed.Dev.#2.....:   316.3 MH/s (52.74ms)
Speed.Dev.#3.....:   325.3 MH/s (51.20ms)
Speed.Dev.#*.....:   641.6 MH/s
Hashtype: IPB2+, MyBB1.2+
Speed.Dev.#2.....:   327.7 MH/s (50.90ms)
Speed.Dev.#3.....:   336.2 MH/s (49.50ms)
Speed.Dev.#*.....:   663.9 MH/s
Hashtype: WBB3, Woltlab Burning Board 3
Speed.Dev.#2.....: 89235.4 kH/s (93.83ms)
Speed.Dev.#3.....: 91825.6 kH/s (91.09ms)
Speed.Dev.#*.....:   181.1 MH/s
Hashtype: OpenCart
Speed.Dev.#2.....:   140.3 MH/s (59.70ms)
Speed.Dev.#3.....:   144.1 MH/s (58.03ms)
Speed.Dev.#*.....:   284.4 MH/s
Hashtype: Joomla < 2.5.18
Speed.Dev.#2.....:  1446.5 MH/s (92.68ms)
Speed.Dev.#3.....:  1489.0 MH/s (89.97ms)
Speed.Dev.#*.....:  2935.5 MH/s
Hashtype: PHPS
Speed.Dev.#2.....:   456.7 MH/s (73.37ms)
Speed.Dev.#3.....:   470.0 MH/s (71.21ms)
Speed.Dev.#*.....:   926.7 MH/s
Hashtype: Drupal7
Speed.Dev.#2.....:     3739 H/s (67.66ms)
Speed.Dev.#3.....:     3856 H/s (65.61ms)
Speed.Dev.#*.....:     7594 H/s
Hashtype: osCommerce, xt:Commerce
Speed.Dev.#2.....:   849.4 MH/s (78.84ms)
Speed.Dev.#3.....:   873.5 MH/s (76.62ms)
Speed.Dev.#*.....:  1722.9 MH/s
Hashtype: PrestaShop
Speed.Dev.#2.....:   565.2 MH/s (59.29ms)
Speed.Dev.#3.....:   580.4 MH/s (57.65ms)
Speed.Dev.#*.....:  1145.5 MH/s
Hashtype: Django (SHA-1)
Speed.Dev.#2.....:   452.9 MH/s (73.95ms)
Speed.Dev.#3.....:   465.7 MH/s (71.85ms)
Speed.Dev.#*.....:   918.6 MH/s
Hashtype: Django (PBKDF2-SHA256)
Speed.Dev.#2.....:     4100 H/s (50.60ms)
Speed.Dev.#3.....:     4237 H/s (49.05ms)
Speed.Dev.#*.....:     8337 H/s
Hashtype: Mediawiki B type
Speed.Dev.#2.....:   421.9 MH/s (79.44ms)
Speed.Dev.#3.....:   434.3 MH/s (77.13ms)
Speed.Dev.#*.....:   856.2 MH/s
Hashtype: Redmine Project Management Web App
Speed.Dev.#2.....:   183.1 MH/s (91.14ms)
Speed.Dev.#3.....:   188.6 MH/s (88.38ms)
Speed.Dev.#*.....:   371.8 MH/s
Hashtype: PunBB
Speed.Dev.#2.....:   183.1 MH/s (91.16ms)
Speed.Dev.#3.....:   188.6 MH/s (88.43ms)
Speed.Dev.#*.....:   371.7 MH/s
Speed.Dev.#2.....:  1447.3 MH/s (92.62ms)
Speed.Dev.#3.....:  1487.0 MH/s (89.98ms)
Speed.Dev.#*.....:  2934.3 MH/s
Hashtype: MSSQL(2000)
Speed.Dev.#2.....:   546.9 MH/s (61.24ms)
Speed.Dev.#3.....:   562.4 MH/s (59.50ms)
Speed.Dev.#*.....:  1109.3 MH/s
Hashtype: MSSQL(2005)
Speed.Dev.#2.....:   546.5 MH/s (61.31ms)
Speed.Dev.#3.....:   562.5 MH/s (59.49ms)
Speed.Dev.#*.....:  1109.0 MH/s
Hashtype: MSSQL(2012)
Speed.Dev.#2.....: 67866.2 kH/s (61.64ms)
Speed.Dev.#3.....: 69676.9 kH/s (59.98ms)
Speed.Dev.#*.....:   137.5 MH/s
Hashtype: MySQL323
Speed.Dev.#2.....:  3165.3 MH/s (84.71ms)
Speed.Dev.#3.....:  3262.1 MH/s (82.08ms)
Speed.Dev.#*.....:  6427.4 MH/s
Hashtype: MySQL4.1/MySQL5
Speed.Dev.#2.....:   248.0 MH/s (67.27ms)
Speed.Dev.#3.....:   254.8 MH/s (65.43ms)
Speed.Dev.#*.....:   502.8 MH/s
Hashtype: Oracle H: Type (Oracle 7+)
Speed.Dev.#2.....: 67205.6 kH/s (62.06ms)
Speed.Dev.#3.....: 68921.7 kH/s (60.41ms)
Speed.Dev.#*.....:   136.1 MH/s
Hashtype: Oracle S: Type (Oracle 11+)
Speed.Dev.#2.....:   529.6 MH/s (63.26ms)
Speed.Dev.#3.....:   546.2 MH/s (61.26ms)
Speed.Dev.#*.....:  1075.8 MH/s
Hashtype: Oracle T: Type (Oracle 12+)
Speed.Dev.#2.....:     7506 H/s (67.94ms)
Speed.Dev.#3.....:     7707 H/s (66.18ms)
Speed.Dev.#*.....:    15212 H/s
Hashtype: Sybase ASE
Speed.Dev.#2.....: 19181.3 kH/s (53.92ms)
Speed.Dev.#3.....: 19626.6 kH/s (52.67ms)
Speed.Dev.#*.....: 38807.9 kH/s
Hashtype: EPiServer 6.x < v4
Speed.Dev.#2.....:   457.9 MH/s (73.19ms)
Speed.Dev.#3.....:   465.8 MH/s (71.86ms)
Speed.Dev.#*.....:   923.8 MH/s
Hashtype: EPiServer 6.x > v4
Speed.Dev.#2.....:   185.9 MH/s (89.79ms)
Speed.Dev.#3.....:   189.3 MH/s (88.13ms)
Speed.Dev.#*.....:   375.2 MH/s
Hashtype: md5apr1, MD5(APR), Apache MD5
Speed.Dev.#2.....:   684.8 kH/s (94.01ms)
Speed.Dev.#3.....:   697.8 kH/s (92.17ms)
Speed.Dev.#*.....:  1382.7 kH/s
Hashtype: ColdFusion 10+
Speed.Dev.#2.....:   121.1 MH/s (69.21ms)
Speed.Dev.#3.....:   122.6 MH/s (68.29ms)
Speed.Dev.#*.....:   243.6 MH/s
Hashtype: hMailServer
Speed.Dev.#3.....:   189.3 MH/s (88.11ms)
Hashtype: SHA-1(Base64), nsldap, Netscape LDAP SHA
Speed.Dev.#2.....:   535.7 MH/s (62.48ms)
Speed.Dev.#3.....:   546.3 MH/s (61.24ms)
Speed.Dev.#*.....:  1082.1 MH/s
Hashtype: SSHA-1(Base64), nsldaps, Netscape LDAP SSHA
Speed.Dev.#2.....:   535.6 MH/s (62.49ms)
Speed.Dev.#3.....:   545.6 MH/s (61.22ms)
Speed.Dev.#*.....:  1081.2 MH/s
Hashtype: SSHA-256(Base64), LDAP {SSHA256}
Speed.Dev.#2.....:   208.0 MH/s (80.21ms)
Speed.Dev.#3.....:   212.0 MH/s (78.58ms)
Speed.Dev.#*.....:   420.0 MH/s
Hashtype: SSHA-512(Base64), LDAP {SSHA512}
Speed.Dev.#2.....: 71706.9 kH/s (58.33ms)
Speed.Dev.#3.....: 73173.3 kH/s (57.08ms)
Speed.Dev.#*.....:   144.9 MH/s
Hashtype: LM
Speed.Dev.#2.....:  1331.4 MH/s (50.10ms)
Speed.Dev.#3.....:  1358.9 MH/s (48.99ms)
Speed.Dev.#*.....:  2690.3 MH/s
Hashtype: NTLM
Speed.Dev.#2.....:  2492.5 MH/s (53.74ms)
Speed.Dev.#3.....:  2540.2 MH/s (52.67ms)
Speed.Dev.#*.....:  5032.6 MH/s
Hashtype: Domain Cached Credentials (DCC), MS Cache
Speed.Dev.#2.....:   724.5 MH/s (92.52ms)
Speed.Dev.#3.....:   737.1 MH/s (90.77ms)
Speed.Dev.#*.....:  1461.6 MH/s
Hashtype: Domain Cached Credentials 2 (DCC2), MS Cache 2
Speed.Dev.#2.....:    22367 H/s (71.31ms)
Speed.Dev.#3.....:    22907 H/s (69.84ms)
Speed.Dev.#*.....:    45274 H/s
Hashtype: MS-AzureSync PBKDF2-HMAC-SHA256
Speed.Dev.#2.....:   783.8 kH/s (69.42ms)
Speed.Dev.#3.....:   803.7 kH/s (67.87ms)
Speed.Dev.#*.....:  1587.6 kH/s
Hashtype: descrypt, DES(Unix), Traditional DES
Speed.Dev.#2.....: 65275.8 kH/s (63.99ms)
Speed.Dev.#3.....: 66420.0 kH/s (62.63ms)
Speed.Dev.#*.....:   131.7 MH/s
Hashtype: BSDiCrypt, Extended DES
Speed.Dev.#2.....:   102.4 kH/s (105.83ms)
Speed.Dev.#3.....:   104.4 kH/s (103.91ms)
Speed.Dev.#*.....:   206.8 kH/s
Hashtype: md5crypt, MD5(Unix), FreeBSD MD5, Cisco-IOS MD5
Speed.Dev.#2.....:   685.9 kH/s (93.95ms)
Speed.Dev.#3.....:   697.9 kH/s (92.23ms)
Speed.Dev.#*.....:  1383.7 kH/s
Hashtype: bcrypt, Blowfish(OpenBSD)
Speed.Dev.#2.....:     1030 H/s (30.14ms)
Speed.Dev.#3.....:     1053 H/s (29.46ms)
Speed.Dev.#*.....:     2083 H/s
Hashtype: sha256crypt, SHA256(Unix)
Speed.Dev.#2.....:    25854 H/s (62.61ms)
Speed.Dev.#3.....:    26386 H/s (61.36ms)
Speed.Dev.#*.....:    52239 H/s
Hashtype: sha512crypt, SHA512(Unix)
Speed.Dev.#2.....:    11094 H/s (74.29ms)
Speed.Dev.#3.....:    11329 H/s (72.76ms)
Speed.Dev.#*.....:    22423 H/s
Hashtype: OSX v10.4, v10.5, v10.6
Speed.Dev.#2.....:   456.5 MH/s (73.42ms)
Speed.Dev.#3.....:   466.3 MH/s (71.80ms)
Speed.Dev.#*.....:   922.8 MH/s
Hashtype: OSX v10.7
Speed.Dev.#2.....: 63220.5 kH/s (66.20ms)
Speed.Dev.#3.....: 64304.7 kH/s (64.92ms)
Speed.Dev.#*.....:   127.5 MH/s
Hashtype: OSX v10.8+
Speed.Dev.#2.....:      873 H/s (67.77ms)
Speed.Dev.#3.....:      898 H/s (66.31ms)
Speed.Dev.#*.....:     1771 H/s
Hashtype: AIX {smd5}
Speed.Dev.#2.....:   685.1 kH/s (93.94ms)
Speed.Dev.#3.....:   697.6 kH/s (92.12ms)
Hashtype: AIX {ssha1}
Speed.Dev.#2.....:  3177.0 kH/s (72.84ms)
Speed.Dev.#3.....:  3239.7 kH/s (71.40ms)
Speed.Dev.#*.....:  6416.7 kH/s
Hashtype: AIX {ssha256}
Speed.Dev.#2.....:  1143.5 kH/s (53.71ms)
Speed.Dev.#3.....:  1168.1 kH/s (52.58ms)
Speed.Dev.#*.....:  2311.6 kH/s
Hashtype: AIX {ssha512}
Speed.Dev.#2.....:   460.3 kH/s (67.42ms)
Speed.Dev.#3.....:   469.1 kH/s (65.92ms)
Speed.Dev.#*.....:   929.4 kH/s
Hashtype: Cisco-PIX MD5
Speed.Dev.#2.....:  1070.5 MH/s (62.58ms)
Speed.Dev.#3.....:  1091.9 MH/s (61.35ms)
Speed.Dev.#*.....:  2162.4 MH/s
Hashtype: Cisco-ASA MD5
Speed.Dev.#2.....:  1091.0 MH/s (61.43ms)
Speed.Dev.#3.....:  1111.0 MH/s (60.25ms)
Speed.Dev.#*.....:  2202.0 MH/s
Hashtype: Cisco-IOS SHA256
Speed.Dev.#2.....:   208.2 MH/s (80.17ms)
Speed.Dev.#3.....:   212.2 MH/s (78.57ms)
Speed.Dev.#*.....:   420.4 MH/s
Hashtype: Cisco $8$
Speed.Dev.#2.....:     4156 H/s (50.04ms)
Speed.Dev.#3.....:     4218 H/s (49.06ms)
Speed.Dev.#*.....:     8374 H/s
Hashtype: Cisco $9$
Speed.Dev.#2.....:      886 H/s (576.93ms)
Speed.Dev.#3.....:      905 H/s (565.10ms)
Speed.Dev.#*.....:     1791 H/s
Hashtype: Juniper Netscreen/SSG (ScreenOS)
Speed.Dev.#2.....:   842.4 MH/s (79.56ms)
Speed.Dev.#3.....:   859.7 MH/s (77.86ms)
Speed.Dev.#*.....:  1702.1 MH/s
Hashtype: Juniper IVE
Speed.Dev.#2.....:   684.8 kH/s (93.98ms)
Speed.Dev.#3.....:   698.0 kH/s (92.07ms)
Speed.Dev.#*.....:  1382.8 kH/s
Hashtype: Android PIN
Speed.Dev.#2.....:   370.4 kH/s (87.33ms)
Speed.Dev.#3.....:   378.0 kH/s (85.47ms)
Speed.Dev.#*.....:   748.5 kH/s
Hashtype: Citrix NetScaler
Speed.Dev.#2.....:   495.5 MH/s (67.61ms)
Speed.Dev.#3.....:   505.5 MH/s (66.28ms)
Speed.Dev.#*.....:  1001.0 MH/s
Hashtype: RACF
Speed.Dev.#2.....:   179.6 MH/s (93.32ms)
Speed.Dev.#3.....:   184.5 MH/s (90.73ms)
Speed.Dev.#*.....:   364.1 MH/s
Hashtype: GRUB 2
Speed.Dev.#2.....:     3058 H/s (67.66ms)
Speed.Dev.#3.....:     3132 H/s (66.32ms)
Speed.Dev.#*.....:     6191 H/s
Hashtype: Radmin2
Speed.Dev.#2.....:   534.4 MH/s (62.71ms)
Speed.Dev.#3.....:   546.4 MH/s (61.22ms)
Speed.Dev.#*.....:  1080.8 MH/s
Hashtype: SAP CODVN B (BCODE)
Speed.Dev.#2.....:   175.7 MH/s (94.96ms)
Speed.Dev.#3.....:   178.8 MH/s (93.23ms)
Speed.Dev.#*.....:   354.5 MH/s
Hashtype: SAP CODVN F/G (PASSCODE)
Speed.Dev.#2.....: 76288.3 kH/s (109.84ms)
Speed.Dev.#3.....: 77884.3 kH/s (107.55ms)
Speed.Dev.#*.....:   154.2 MH/s
Hashtype: SAP CODVN H (PWDSALTEDHASH) iSSHA-1
Speed.Dev.#2.....:   415.4 kH/s (77.83ms)
Speed.Dev.#3.....:   423.5 kH/s (76.26ms)
Speed.Dev.#*.....:   838.9 kH/s
Hashtype: Lotus Notes/Domino 5
Speed.Dev.#2.....: 14385.8 kH/s (143.79ms)
Speed.Dev.#3.....: 14503.5 kH/s (144.50ms)
Speed.Dev.#*.....: 28889.4 kH/s
Hashtype: Lotus Notes/Domino 6
Speed.Dev.#2.....:  4764.0 kH/s (109.91ms)
Speed.Dev.#3.....:  4861.6 kH/s (107.62ms)
Speed.Dev.#*.....:  9625.6 kH/s
Hashtype: Lotus Notes/Domino 8
Speed.Dev.#2.....:    45594 H/s (71.07ms)
Speed.Dev.#3.....:    46485 H/s (69.70ms)
Speed.Dev.#*.....:    92080 H/s
Hashtype: PeopleSoft
Speed.Dev.#2.....:   552.0 MH/s (60.69ms)
Speed.Dev.#3.....:   562.5 MH/s (59.47ms)
Speed.Dev.#*.....:  1114.5 MH/s
Hashtype: PeopleSoft PS_TOKEN
Speed.Dev.#2.....:   217.4 MH/s (76.78ms)
Speed.Dev.#3.....:   221.4 MH/s (75.29ms)
Speed.Dev.#*.....:   438.8 MH/s
Hashtype: 7-Zip
Speed.Dev.#2.....:      625 H/s (49.15ms)
Speed.Dev.#3.....:      653 H/s (95.37ms)
Speed.Dev.#*.....:     1278 H/s
Hashtype: WinZip
Speed.Dev.#2.....:    75944 H/s (49.01ms)
Speed.Dev.#3.....:    77390 H/s (48.06ms)
Speed.Dev.#*.....:   153.3 kH/s
Hashtype: RAR3-hp
Speed.Dev.#2.....:     2487 H/s (51.21ms)
Speed.Dev.#3.....:     2578 H/s (49.33ms)
Speed.Dev.#*.....:     5065 H/s
Hashtype: RAR5
Speed.Dev.#2.....:     2512 H/s (50.04ms)
Speed.Dev.#3.....:     2570 H/s (48.98ms)
Speed.Dev.#*.....:     5082 H/s
Hashtype: AxCrypt
Speed.Dev.#2.....:     7716 H/s (215.85ms)
Speed.Dev.#3.....:     7903 H/s (211.04ms)
Speed.Dev.#*.....:    15620 H/s
Hashtype: AxCrypt in memory SHA1
Speed.Dev.#2.....:   514.1 MH/s (65.13ms)
Speed.Dev.#3.....:   524.9 MH/s (63.80ms)
Speed.Dev.#*.....:  1039.0 MH/s
Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit
Speed.Dev.#2.....:    18724 H/s (51.93ms)
Speed.Dev.#3.....:    19111 H/s (50.90ms)
Speed.Dev.#*.....:    37834 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit
Speed.Dev.#2.....:    28810 H/s (61.42ms)
Speed.Dev.#3.....:    29390 H/s (60.22ms)
Speed.Dev.#*.....:    58199 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit
Speed.Dev.#2.....:     2382 H/s (211.55ms)
Speed.Dev.#3.....:     2441 H/s (206.38ms)
Speed.Dev.#*.....:     4823 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode
Speed.Dev.#2.....:    35678 H/s (48.85ms)
Speed.Dev.#3.....:    36387 H/s (47.91ms)
Speed.Dev.#*.....:    72064 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit
Speed.Dev.#2.....:       31 H/s (53.17ms)
Speed.Dev.#3.....:       31 H/s (52.12ms)
Speed.Dev.#*.....:       62 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit
Speed.Dev.#2.....:       31 H/s (67.16ms)
Speed.Dev.#3.....:       62 H/s (65.82ms)
Speed.Dev.#*.....:       93 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit
Speed.Dev.#2.....:        0 H/s (213.33ms)
Speed.Dev.#3.....:        0 H/s (208.71ms)
Speed.Dev.#*.....:        0 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode
Speed.Dev.#2.....:       93 H/s (53.19ms)
Speed.Dev.#3.....:       93 H/s (52.15ms)
Speed.Dev.#*.....:      186 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit
Speed.Dev.#2.....:       62 H/s (53.25ms)
Speed.Dev.#3.....:       62 H/s (52.14ms)
Speed.Dev.#*.....:      124 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit + boot-mode
Speed.Dev.#2.....:      186 H/s (53.24ms)
Speed.Dev.#3.....:      186 H/s (52.09ms)
Speed.Dev.#*.....:      372 H/s
Hashtype: Android FDE <= 4.3
Speed.Dev.#2.....:    56209 H/s (71.96ms)
Speed.Dev.#3.....:    57411 H/s (70.51ms)
Speed.Dev.#*.....:   113.6 kH/s
Hashtype: Android FDE (Samsung DEK)
Speed.Dev.#2.....:    20298 H/s (49.02ms)
Speed.Dev.#3.....:    20761 H/s (47.94ms)
Speed.Dev.#*.....:    41060 H/s
Hashtype: eCryptfs
Speed.Dev.#2.....:      928 H/s (66.52ms)
Speed.Dev.#3.....:      962 H/s (65.21ms)
Speed.Dev.#*.....:     1890 H/s
Hashtype: MS Office <= 2003 MD5 + RC4, oldoffice$0, oldoffice$1
Speed.Dev.#2.....: 15138.0 kH/s (69.09ms)
Speed.Dev.#3.....: 15438.3 kH/s (67.63ms)
Speed.Dev.#*.....: 30576.4 kH/s
Hashtype: MS Office <= 2003 MD5 + RC4, collision-mode #1
Speed.Dev.#2.....: 21390.5 kH/s (97.77ms)
Speed.Dev.#3.....: 22107.0 kH/s (94.63ms)
Speed.Dev.#*.....: 43497.5 kH/s
Hashtype: MS Office <= 2003 SHA1 + RC4, oldoffice$3, oldoffice$4
Speed.Dev.#2.....: 20085.4 kH/s (104.20ms)
Speed.Dev.#3.....: 20547.2 kH/s (101.77ms)
Speed.Dev.#*.....: 40632.5 kH/s
Hashtype: MS Office <= 2003 SHA1 + RC4, collision-mode #1
Speed.Dev.#2.....: 22165.4 kH/s (94.51ms)
Speed.Dev.#3.....: 22632.7 kH/s (92.42ms)
Speed.Dev.#*.....: 44798.2 kH/s
Hashtype: Office 2007
Speed.Dev.#2.....:     8994 H/s (74.23ms)
Speed.Dev.#3.....:     9153 H/s (72.81ms)
Speed.Dev.#*.....:    18147 H/s
Hashtype: Office 2010
Speed.Dev.#2.....:     4483 H/s (74.27ms)
Speed.Dev.#3.....:     4553 H/s (72.80ms)
Speed.Dev.#*.....:     9035 H/s
Hashtype: Office 2013
Speed.Dev.#2.....:      622 H/s (66.16ms)
Speed.Dev.#3.....:      625 H/s (64.81ms)
Speed.Dev.#*.....:     1247 H/s
Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4)
Speed.Dev.#2.....: 22742.7 kH/s (91.99ms)
Speed.Dev.#3.....: 23266.0 kH/s (89.89ms)
Speed.Dev.#*.....: 46008.7 kH/s
Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4) + collider-mode #1
Speed.Dev.#2.....: 24669.3 kH/s (84.89ms)
Speed.Dev.#3.....: 25201.8 kH/s (82.99ms)
Speed.Dev.#*.....: 49871.1 kH/s
Hashtype: PDF 1.4 - 1.6 (Acrobat 5 - 8)
Speed.Dev.#2.....:  1111.7 kH/s (57.00ms)
Speed.Dev.#3.....:  1134.8 kH/s (55.71ms)
Speed.Dev.#*.....:  2246.4 kH/s
Hashtype: PDF 1.7 Level 3 (Acrobat 9)
Speed.Dev.#2.....:   207.7 MH/s (80.32ms)
Speed.Dev.#3.....:   212.1 MH/s (78.57ms)
Speed.Dev.#*.....:   419.8 MH/s
Hashtype: PDF 1.7 Level 8 (Acrobat 10 - 11)
Speed.Dev.#2.....:     2390 H/s (356.64ms)
Speed.Dev.#3.....:     2480 H/s (343.69ms)
Speed.Dev.#*.....:     4870 H/s
Hashtype: Password Safe v2
Speed.Dev.#2.....:    20188 H/s (24.34ms)
Speed.Dev.#3.....:    19148 H/s (25.96ms)
Speed.Dev.#*.....:    39336 H/s
Hashtype: Password Safe v3
Speed.Dev.#2.....:    81584 H/s (49.86ms)
Speed.Dev.#3.....:    83242 H/s (48.85ms)
Speed.Dev.#*.....:   164.8 kH/s
Hashtype: Lastpass
Speed.Dev.#2.....:   157.5 kH/s (51.02ms)
Speed.Dev.#3.....:   159.4 kH/s (50.38ms)
Speed.Dev.#*.....:   316.9 kH/s
Hashtype: 1Password, agilekeychain
Speed.Dev.#2.....:   223.8 kH/s (71.42ms)
Speed.Dev.#3.....:   229.8 kH/s (69.70ms)
Speed.Dev.#*.....:   453.6 kH/s
Hashtype: 1Password, cloudkeychain
Speed.Dev.#2.....:      742 H/s (67.54ms)
Speed.Dev.#3.....:      777 H/s (66.16ms)
Speed.Dev.#*.....:     1519 H/s
Hashtype: Bitcoin/Litecoin wallet.dat
Speed.Dev.#2.....:      309 H/s (66.54ms)
Speed.Dev.#3.....:      311 H/s (65.21ms)
Speed.Dev.#*.....:      620 H/s
Hashtype: Blockchain, My Wallet
Speed.Dev.#2.....:  5500.4 kH/s (23.63ms)
Speed.Dev.#3.....:  5639.9 kH/s (23.20ms)
Speed.Dev.#*.....: 11140.3 kH/s
Hashtype: Keepass 1 (AES/Twofish) and Keepass 2 (AES)
Speed.Dev.#2.....:     9148 H/s (152.05ms)
Speed.Dev.#3.....:     9353 H/s (148.80ms)
Speed.Dev.#*.....:    18500 H/s
Hashtype: ArubaOS
Speed.Dev.#2.....:   457.6 MH/s (73.23ms)
Speed.Dev.#3.....:   465.9 MH/s (71.77ms)
Speed.Dev.#*.....:   923.5 MH/s
Started: Fri Mar 24 15:59:50 2017
Stopped: Fri Mar 24 16:15:15 2017
Programer
Staro 11.04.2017., 15:18   #2
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,057
To je uvod u review ili ... ?
Staro 09.03.2023., 18:19   #3
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,144
Jucer pitam u generalnoj temi za mini DP adaptere na DVI/VGA koje trebam NVS i Quadro, jer nisam mogao naci kutiju, pa malocas sam sebi odgovaram u istoj.
Te me iznenadi da ime Quadro proizvoda nestade iz oznacavanje Pro Nvidia kartica. Sve isto samo bezlicne oznake.
Detaljnije : Nvidia Quadro is Gone - No More Quadro - Quadro is Retired!
Znam, nije ispod cekica, ali nisam uopce znao do danas, te je bas bezveze potez.
NVIDIA confirmed to drop Quadro designation The main reason is that currently NVIDIA graphics are starting to be used in more and more segments. The number of graphics cards of the company for computing tasks have increased in quantity very noticeably.
Dobri komentari : More On NVIDIA Quadro Brand Retirement: Embracing the Graphics and Compute Overlap
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 09.03.2023. u 18:32.
Staro 10.03.2023., 18:54   #4
C128
Postovi: 207
Tko kaže da nema više Quadro?
https://quadro.com.hr/web/en/brand/3-quadro
Ima svega od TV-a do Toaster-a.
Možda je NVidia izgubila pravo na navedeni brand, kao i Toblerone na Matherhorn.
C128 je offline   Reply With Quote
Staro 11.03.2023., 12:57   #5
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,824
Dakle, među tim komentarima spomenuto je da su svojedobno na tržištu bile Nvidijine grafičke kartice kojima si mogao prelemiti jedan otpornik s pozicije 1-2 na poziciju 2-3 i imao si Quardo umjesto "klasične" grafičke kartice. Tako da s jedne strane ispada da su radili isti proizvod za dvije različite namjene koja je ovisila o jednom otporniku i softverskoj podršci kroz drajvere. Današnje "klasične" grafičke kartice su ionako dovoljno snažne za bilo kakvu CAD/CAM/3D upotrebu i zato i postoje Nvidia Studio drajveri. U potpunosti shvaćam Nvidijinu nevoljkost da održava Quadro na životu kad im je to nepotreban trošak, što s marketinške strane, što sa strane proizvodnje ako moraju jedan otpotnik lemiti da drugoj poziciji pa onda to još pakirati u drugačiju kutiju s natpisom Quadro. Da postoji neka veća hardverska razlika u cijeloj priči, onda bih to bilo na njihovu štetu.
Sinac je online   Reply With Quote
Staro 11.03.2023., 22:00   #6
Postovi: 23,517
Zaboravljaš:
- naravno da je lakše za proizvodnju kada je razlika samo pozicija otpornika i eventualno drugi bios
- po defaultu su profi Quadro kartice x puta skuplje
Staro 12.03.2023., 08:15   #7
Sinac
Sinac's Avatar
Postovi: 2,824
Jesu skuplje, ali koja korist kad im je pala prodaja. Ne gledaš samo trošak proizvodnje u cijeloj priči, gledaš konačnu zaradu.
EDIT= Da nadopunim: Što Nvidia radi s neprodanim Quadro karticama? Snizi cijenu ako je u pitanju starija generacija? Transportira natrag u tvornicu da ih preprave u klasične gamerske kartice i prepakiraju u drugu ambalažu? Koliki je gubitak novca u svemu tome?
Zadnje izmijenjeno od: Sinac. 12.03.2023. u 09:23.
Staro 12.03.2023., 08:49   #8
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,772
Ni meni nije ni najmanje cudno da su ih maknuli. Jos jedan razlog je sto je lakse zamagljivati brojeve na investor callovima, bez da netko analizira podjele izmedju mininga, gaminga, AI-ja i slicnog.
Staro 12.03.2023., 11:35   #9
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Pa nije da su nestale. Sta nisu samo rebrandirane?
https://www.nvidia.com/en-us/design-...ktop-graphics/
Staro 12.03.2023., 12:27   #10
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,144
Autor Sinac Pregled postova
Zivot je brz, paznja nam je razbacana na sto strana, a onda se desi i pored postavljenih citata, da ne procitamo sto pise
Nije Quadro umirovljena kao linija proizvoda, vec je samo naziv Quadro maknut kao (do sada) prepoznatljivi naziv. Identicne kartice su samo izgubile ima Quadro u oznacavanju. No, ako se pogleda u ponude po webu, pa cak i (pojedinih) nasih trgovcaca i dalje se koriste naziv Quadro kao kategorija. Navika je razumljiva. U drugi dio o pretvorbi necu, jer cemo otici u tri nove teme.
Velim, datumski me mimoisla promjena pa sam pozelio komentirat.
Nvidia Architecture Generation
Staro 12.03.2023., 13:05   #11
Sinac
Sinac's Avatar
Postovi: 2,824
Autor Visage Pregled postova
/CUT
Kolega Visage, jesam li išta drugo napisao u svom postu? Nvidia je maknula Quadro kao brand jer više nije imao smisla, nije se Nvidia mogla natjecati sama sa sobom u tom CAD/CAM/3D dijelu kad je ionako RTX serija već i po prodaji zamijenila Quadro još dok je bio prisutan na tržištu pri pojavi prve RTX serije grafičkih kartica, ne samo poslovnih nego i gamerskih. U detaljnu razliku u hardveru između gamerskih i poslovnih kartica neću ulaziti jer svi ionako gledaju samo omjer cijena/performanse. Onome kome treba specijalizirana grafička kartica za jednu ili dvije poslovne aplikacije koje koristi platit će ih i pet puta više ako ima veće performanse, odnosno brže obavi posao i neće gledati ima li Quadro, gamersku RTX karticu ili poslovnu RTX karticu. Hoće li biti grafička s 12 Gb memorije ili 48 Gb memorije, znači li to ikome išta? Mislim da ne jer ionako u konačnici gledaš performanse. U istom cjenovnom rangu koji ti je dostupan uzet ćeš onu grafičku karticu koja ima bolje performanse za tvoje potrebe, zar ne?
Zadnje izmijenjeno od: Sinac. 12.03.2023. u 14:14.
Staro 12.03.2023., 15:54   #12
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,144
Kolega Sinac,
ma na ide posebno tebi, ostali su se nadovezali, pa sam tebe prvog citirao.
Velim, vjerovao netko u Quadro selekciju, testiranje, drivere... ali te karte ostaju u identicnom procesu validacije i cijene, samo su makli ime. Takve odluke su (meni blesave) no vidjene cesto u industriji danas, ali dobro...
Staro 12.03.2023., 16:02   #13
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,398
Meni nije jasno: koje je to prednosti donosio quadro za CAM pred klasičnim/ekvivalntnim grafičkim karticama?
Staro 12.03.2023., 16:55   #14
Sinac
Sinac's Avatar
Postovi: 2,824
Kolega Sinac,
Aha, sorry, krivo sam shvatio da je to kritika meni.
Autor mkey Pregled postova
Quadro kartice imaju optimizirane drajvere za CAD/CAM/3D pa čak i 2D aplikacije koji omogućuju višestruko brži rad u pojedinim dijelovima (ne svim) izvođenja programa nego klasične grafičke kartice. To se pogotovo odnosi na pomicanje slike (pan) i skrolanje, zumiranje, rotaciju itd. gdje je bitna brzina ponovnog iscrtavanja ekrana jer Quadro kartice znaju to izvesti višestruko brže nego njihov generacijski pandan među klasičnim grafičkim karticama. Obrati pažnju da nisam isticao razliku u hardveru, to je siva zona za koju ćeš naći različite informacije jer službene nisu dostupne i Nvidija ih skriva ko zmija noge.
Zadnje izmijenjeno od: Sinac. 12.03.2023. u 17:00.
Staro 12.03.2023., 17:01   #15
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Za autocad imas brdo pluginova koji iz pointclud-a rade as-built solid modele. Ja sam prije dobivao takve modele i high end gtx kartice (tipa 1080ti) kakvu sam ja koristio su se gusile u takvim .dwg-ovima, makar su imali svega par mb. S druge strane, ta ista kartica je bila sposobna vrtiti point cloud od stotina milijuna tocaka.
Staro 12.03.2023., 20:47   #16
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,144
Aha, sorry, krivo sam shvatio da je to kritika meni..
Baci oko na tekst, pa onda kontroverzu komentara ispod, koju uvijek izaziva tema. Slicne rasprava je prije izazivala Radeon / FirePro tematika. Evo, bas gledam, nisam ni znao da se FirePro isto preimenovala, te je sad Radeon Pro.
Staro 12.03.2023., 21:07   #17
Sinac
Sinac's Avatar
Postovi: 2,824
Slažem se sa svim navedenim, uz opasku da to vrijedi samo za novije verzije Quadro/RTX grafičkih kartica jer se tu počela pojavljivati arhitektura koja već zalazi u područje koje nije čisti CAD/CAM/3D, ono s neuralnim mrežama već ulazi u područje AI-a. I znam da je tu Nvidija počela s Tesla karticama koje su opet bile posebno namijenjene čistim kalkulacijama, koja god da im je bila znanstvena svrha. S novom generacijom grafičkih procesora nema čistog razgraničenja područja primjene, zato su i ugasili Teslu i Quadro preimenovali u Nvidia Data Center GPUs i RTX. I neću se čuditi ako za godinu-dvije ostane samo jedan novi brand profesionalnih grafičkih kartica koji pokriva oba segmenta koje su pokrivale i Tesla i Quadro grafičke kartice.
I opet ponavljam, uz sve dijagrame mi ne znamo koja je zapravo realna razlika između klasične i profi kartice zasnovane na istom grafičkom procesoru.
Ako pogledamo napredak grafičkih kartica, sjetimo se da je prije RTX serije bio san imati gamersku grafičku karticu koja ray tracing izvodi on-fly u igrama.
Staro 12.03.2023., 21:59   #18
mkey
Lokacija: tu
Postovi: 3,398
Ako stvarno pričamo samo o razlici u optimizaciji drivera onda se to dosta dobro uklapa u moje iskustvo s ponašanjem nvidije te moje mišljenje o istom.
Staro 13.03.2023., 00:11   #19
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Jedina hardverska razlika je bila u tome što su Quadro kartice ponekad imale više VRAM-a, sve ostalo je isto GeForce modelima. Quadro su dolazile s "certificiranim" driverima za neke programe koji su to znali iskoristiti i zato su bile brže.
Staro 13.03.2023., 00:49   #20
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Autor MadBoY Pregled postova
Sjećam se da sam soft-modao staru Nvidia 6800 u Quadro 4000 i dobivao bolje performanse u OpenGL igrama.
PSN Steam
Staro 13.03.2023., 01:38   #21
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
ECC memorija na Quadricama je isto nezanemariva razlika
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 13.03.2023., 09:49   #22
rendula
Postovi: 5,772
Aha, znaci samo se ime mijenja, ali i dalje ce biti drukcije i imenom i izvedbom od geforcea. Onda, ono, koga briga
Staro 13.03.2023., 20:59   #23
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,550
Pa da, sve ostaje isto, nije vise quadro nego je RTX Axxx , tipa RTX A6000
Full lineup: https://www.nvidia.com/en-us/design-...ktop-graphics/
Staro 14.03.2023., 11:34   #24
Postovi: 33,946
Bilo bi zanimljivo kada bi netko napravio usporedbu gamerske grafe i RX pandana, kako u igrama tako i u profi programima pa da vidimo imaju li one uopće smisla i da li performanse opravdavaju znatno višu cijenu.
Staro 14.03.2023., 16:48   #25
Sinac
Sinac's Avatar
Postovi: 2,824
Autor coconut Pregled postova
https://www.cgdirector.com/pro-vs-consumer-gpus/
Za profi aplikacije - definitivno da. Za mješovitu upotrebu - definitivno ne.
Staro 15.03.2023., 08:01   #26
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,550
U ovom clanku je vidiljivo apsolutno nista osim HW usporebe i mogucih scenarija. Kolega je pitao direkta usporedba u primjeni, ne rekla kazala (osim multiple monitor setupa).
Staro 15.03.2023., 08:44   #27
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
ima materijala na yt-u:
https://www.youtube.com/watch?v=HEagFvmjW4w
https://www.youtube.com/watch?v=EDwNZXVGR3w
https://www.youtube.com/watch?v=xtN9dX0oWzY
Zaključak: ovisno o aplikaciji koja se koristi, Za allroundere definitivno nije.
