Staro 14.02.2023., 11:12   #11521
Dottore
Dottore's Avatar
Postovi: 7,696
Autor Neo-ST Pregled postova
Jel ovaj Samsung Wallet itko instalirao i jel mu radi ?
Ne radi još. Osim ako imaš DBT ili BTU regiju pa omogućava.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 14.02.2023., 11:28   #11522
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,779
Koga boli oversharpening kod slikanja na S23U neka si instalira Camera Assistant app sa Galaxy Store-a od Good locka i postavi Softening iliti ga "ublažavanje slike" na medium/srednje.
Tada radi dosta dobre slike, skoro ko Gcam.
Tu imate primjere sve 3 vrijednosti: https://www.reddit.com/r/S23Ultra_Ph...levels_camera/
Kome treba GCam za test pogledajte tu: https://www.dpreview.com/forums/thread/4697013
Staro 14.02.2023., 12:58   #11523
FerrZG
FerrZG's Avatar
Datum registracije: Oct 2016
Postovi: 171
Dali je dostupan Good Lock na Galaxy Store-u kod nas?
Ja ga trenutno ne vidim na S10e/One UI 4.1
FerrZG je offline   Reply With Quote
Staro 14.02.2023., 13:15   #11524
9800pro
9800pro's Avatar
Postovi: 1,779
Autor FerrZG Pregled postova
Nemam pojma, znam da sam ga imao na A52s, probaj.
Ali ako pitaš za ovaj camera assistant app on radi solo.
Staro 14.02.2023., 13:17   #11525
d0X
Kostolomac
d0X's Avatar
Postovi: 1,533
Autor GreenLife Pregled postova
Svaka čast onima koji osjete tu razliku. Ajde za delay to i ja vidim, ali nisam imao problema sa npr. Note 10+ i Sony 1000xm3 sluškama, sve je bilo ok.
Vjerojatno si koristio Sonyjev LDAC po defaultu koji ima visok bitrate i malu latenciju pri gledanju videa. Imam iste sluške
PSN Steam
Staro 14.02.2023., 14:44   #11526
Neo-ST
Neo-ST's Avatar
Postovi: 8,526
Autor xlr Pregled postova
Ne radi s nasim karticama ni karticama dostupnim kod nas (curve, revolut...), nema smisla ni pokusavati. Nekad je radilo na curve kartici dok su izdavali UK kartice, radilo mi je i na samsung satovima i mobu.
Edit: Dottore je u pravu, moras prvo imati mob/sat sa firmwareom zemlje koja podrzava samsung pay. Ja sam imao kanadski mob te uk i it satove. Samsung pay nije dostupan u hr firmwareu. I uz sve to trebas i karticu iz podrzane zemlje. Jednom kad sve uparis onda normalno radi u hr.
Nemam mob sa tim firmwareom niti namjeravam prčkat po novom mobu.
S obzirom da Samsung Pay ne radi u nas, postoji li neki app u koji se može dodati virtualna kartica i provlačiti mob po našim POS aparatima preko NFC-a ?
Naglasak na virtualna, ova koju koristim još ne postoji u fizičkom obliku pa zato.
Probao GPay, neće.
Staro 14.02.2023., 14:47   #11527
Postovi: 10,219
Gpay sa virtualnom revolut karticom radi, ali pitanje je sto ti koristis? Za Gpay postoji lista podrzanih kartica za hr:
https://support.google.com/wallet/answer/12149853
Staro 14.02.2023., 16:21   #11528
delavi
Datum registracije: Apr 2020
Postovi: 978
PBZ i ZABA samo. Ostali imamo osjećaj gdje živimo.
Staro 14.02.2023., 16:33   #11529
glpcha
Datum registracije: Feb 2017
Postovi: 69
I Erste, samo nije na ovom popisu.
glpcha je offline   Reply With Quote
Staro 14.02.2023., 16:37   #11530
Postovi: 10,219
I pbz card kreditne vise bibtrebale biti tu... Ma lista je veca, sad i ja gledam malo bolje. Nekad je visa gold bila na popisu, ne znam gdje je nestala.
Staro 14.02.2023., 17:15   #11531
Dottore
Dottore's Avatar
Postovi: 7,696
U zadnje vrijeme Samsung Wallet ( bivši Pay) polako proširuje regiju , ali opet nema još KROATIEN dostupnog. Budem okačio link kad dođem doma na PC.
Kad malo bolje pogledaš , za test sam iskoristio pokusnog kunića stari S7 i ubacio DBT regiju i dosupan je Samsung pay bez obzira na umetnute SIM kartice. Isto sam probao na BTU.
A kako već imam S21 Ultru sa SLO regijom koju je tvornički dostupan S.Pay , ali ne reagira. Nije dostupan na listi i odmah zaključiš nepotreban bloatware koju ne podržava regiju.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 14.02.2023., 17:54   #11532
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
sve pbz, zaba kartice rade, i kredite i debitne, probao...PBZ se moralo zvati, nešto nije išlo iz prve, zabu je bez problema odmah prihvatio.
Staro 14.02.2023., 21:23   #11533
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Danas sam vidio slike sa S23.
Ja ne znam kome mogu bit dobre te slike. Teski oversharpen,oversaturation...
Toliko razlicito od stvarnosti da je to strasno...
I jos me prijateljica instagramusa uvjerava da su im bolje slike nego na mom a7r4 i da je taj mobitelcic ubojica DSLRa.
Valjda je to danas u modi,bijeg od stvarnosti pa makar preko slika
Poslano sa mog XQ-CT54 koristeći Tapatalk
Amd_Shill je offline   Reply With Quote
Staro 14.02.2023., 21:53   #11534
locks
Datum registracije: Mar 2010
Lokacija: Vukovar
Postovi: 3,634
Samo si malo ljubomoran 😁
Staro 14.02.2023., 21:57   #11535
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,854
Danas bio u avenue mallu, s23 ultra vs pixel 7.
Pustio malog sa lanca i slikavao ga.
Ukratko, vodene bojice i mutna lica.
Sad znam zasto se ne slikaju sa samsungom pokretne osobe pri reviewima.
Slike fiksnih stvari su super, ali to moze i samsung s8.
Ukratko, preskok.
Pokusa sam prebaciti slike na svoj mob, ali nije radilo, a mali nije prestrpljiv.
Ivo_Strojnica je online   Reply With Quote
Staro 14.02.2023., 22:34   #11536
Neo-ST
Neo-ST's Avatar
Postovi: 8,526
Autor Amd_Shill Pregled postova
Pa kakav si ti to profić kad ne znaš da ima expert raw opcija u kojoj nema ništa od toga, lijepo se poigraš u Lightroom-u i voila 😀
Sent from my SM-S918B using Tapatalk
Staro 15.02.2023., 07:51   #11537
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Tko je vidio malo se potruditi oko fotografije.
Mozda je bio ukljucen hdr ili onaj njihov mod za prepoznavanje stvari?
Sto se tice fotografije u pokretu, sjecam se da je na iPhone 5 to dobro radilo na otvorenom prostoru.
iPhone je uvijek okidao najvise dobrih fotki, opalis i znas da ce biti ok.
Samsung se fura za vecinu atraktivnije fotografije i svaku moras pogledati je li dobra da ne moras ponovo fotkati (govorim o auto modu).
Zadnje izmijenjeno od: robee. 15.02.2023. u 11:52.
robee je offline   Reply With Quote
Staro 15.02.2023., 09:42   #11538
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Ma kakav profic.
Zaboravio sam da svaka instagramusa treba uz Samsung jos i subscription na LR
Staro 15.02.2023., 10:13   #11539
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Autor robee Pregled postova
Samsung se fura na vecini atraktivnije fotografije i svaku moras pogledati je li dobra da ne moras ponovo fotkati (govorim o auto modu).
Plus, postoji Camera Assistant (GoodLock modul) u kojem se da fino poštelati da kamera prioritizira brzinu okidanja naspram kvalitete slike i sl. Za one kojima slike ispadaju pretjerano izoštrene također postoji postavka... Sudeći po recenzijama, ove opcije zaista rade, barem na S22/S23 seriji... Nisam još osobno testirao.
Name:	Screenshot_20230215_090959_Camera Assistant.jpg‎
ID:	26046   Click image for larger version
Name:	Screenshot_20230215_091018_Camera Assistant.png‎
Staro 15.02.2023., 10:32   #11540
Kizo
Kizo's Avatar
Postovi: 99
Ivo je u pravu, point n shoot za stvari u pokretu ne daje baš najoštriji rezultat, tradicionalna boljka samsunga, tako da se tu treba malo poigrati.
Npr. u zatvorenom, ali dobro osvjetljenje, u istim uvjetima 50MP mode će slikati s ISO50 1/50s, dok 12MP će biti ISO160 1/180s što je već puno bolje za djecu/mačke/pese. Isključivanje HDRa dodatno poboljšava stvari kao i spomenuti Camera Assistant app gdje će prioritet na brzinu okidati manje slika radi bracketinga.
Naravno u pro modu se može staviti fiksno shutter speed, a ostaviti ISO i sve ostalo na automatski. Radi isto ok tako.
Kizo je offline   Reply With Quote
Staro 15.02.2023., 10:40   #11541
vlatko27
vlatko27's Avatar
Postovi: 772
Autor Sn4k3 Pregled postova
Ja taj Camera Assistant nemam na Galaxy Store, imam tipa Sound Assistant, na mom S21 FE.
vlatko27 je online   Reply With Quote
Staro 15.02.2023., 10:41   #11542
Zero Cool ZG
Datum registracije: Aug 2021
Postovi: 257
Ja recimo nisam pretjerano zahtjevan korisnik, ali cesto slikam klince i zelim sto kvalitetnije fotke jer ih ponekad razvijam na A4. S druge strane zelim mob na kojem otvorim fotic u auto modu i okidam fotke koje ispadaju ok. Po ovoj diskusiji na kraju sa S23 nema sanse da to dobijem.
Mozda da pricekam Xiaomi 13 😬
Zero Cool ZG je offline   Reply With Quote
Staro 15.02.2023., 11:27   #11543
Dottore
Dottore's Avatar
Postovi: 7,696
Nečeš ni usrećiti sa Šaomijem.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 15.02.2023., 11:35   #11544
Kizo
Kizo's Avatar
Postovi: 99
Ne želim opravdavati samsung, ali nezahtjevni korisnici koji "samo žele u auto modu okidati fotke koje ispadaju ok" za njih nije ultra. Bolje uložiti pare u neki iphone.
Staro 15.02.2023., 11:48   #11545
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Autor vlatko27 Pregled postova
Nećeš ga naći na Galaxy Store jer nažalost naša regija još nije službeno podržana od strane Samsunga, barem što se tiče GoodLock aplikacije. Navodno bi trebala biti u bliskoj budućnosti, ali ništa konkretno ne znam. S druge strane, kako je GoodLock u biti samo launcher za sve te module, možeš instalirati 3rd party launcher poput NiceLock-a ili još bolje FineLock (IMO bolji izbor, nema reklama, pregledniji je, pregršt opcija...). Kad instaliraš launcher, kroz njega možeš skinuti sve dostupne module, aplikacija te preusmjeri na apkmirror odakle skineš apk... Nakon instalacije modul se pojavi u launcheru.
Name:	Screenshot_20230215_104808_Fine Lock.png‎
Staro 15.02.2023., 11:58   #11546
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Autor Zero Cool ZG Pregled postova
Iz osobnog iskustva za takve stvari je dobar iPhone ako mozes provariti iOS i sva moguca ogranicenja uz previsoku cijenu.
Ja nisam mogao
Staro 15.02.2023., 12:05   #11547
Ivo_Strojnica
PRO
Postovi: 4,854
Meni Pixel odlican za tu namjenu.
Staro 15.02.2023., 12:17   #11548
vlatko27
vlatko27's Avatar
Postovi: 772
Čini se da je Camera Assistant samo za S22,S23. Instalirao preko finelock, kaže device not supported
Staro 15.02.2023., 12:18   #11549
Zero Cool ZG
Postovi: 257
Ja nisam mogao
Na iphoneu 13 sam godinu dana, ali nije to za mene. Ne mogu prihvatiti neke stvari, njihovu logiku, zakljucanost platforme…
Pixel 7 je igri, malo me poljuljalo ovo sto ljudi prijavljuju probleme za pucanjem stakla kamere, ispadanjem tipki i navodno los fingerprint.
Staro 15.02.2023., 12:49   #11550
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Ista stvar je i kod mene. Od Apple-a vise nista ni na silu. Radje koja trzava animacija na S10 ali barem ga mogu podesiti do sitnih detalja.
