Staro 31.12.2022., 18:04   #1
pasara
Postovi: 200
Prodesk 600 g1 sff
Bok.Kod klinca u sobi komp stoji ohoho, i evo sada ga idem upalit i nece pa nece.Promijenio sam par kablova od napajanja,ali opet nista.Znaci,komp nije bio paljen ni jednom u zadnjih,pa sigurno 10 mj.Ja sumnjam u napajanje,ali kako da to provjerim ili mozda netko ima drugu ideju sta bi moglo biti.Unaprijed hvala i lp
pasara je offline   Reply With Quote
Staro 31.12.2022., 21:10   #2
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
A što se dogodi kad stisneš "power"? Jel se zavrti koji vent? Ima kakav beep ili POST code?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 31.12.2022., 21:48   #3
pasara
Postovi: 200
Ama bas nista.
Staro 31.12.2022., 22:10   #4
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,793
Najjednostavnije je da prikopcas drugo napajnje - ako je standardni ATX 20/24pin+4pin/8pin EPS. Ak je ono HP rijesenje onda ce to ici malo teze - testirat multimetrom eventualno. Ako i s drugim napajanjem ne radi - nemas srece.
Edit: https://www.google.com/search?q=Prod...KavXUfIYQdxMPM
Nemas srece. Specijalan HP konstrukt.
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / Fedora Workstation 42
Staro 01.01.2023., 02:25   #5
domy_os
domy_os's Avatar
Postovi: 18,846
Provjeri CMOS bateriju, ne mora odmah biti napajanje.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 01.01.2023., 09:19   #6
pasara
Postovi: 200
Samo sam je izvadio i vratio,ali opet nista.Moram vidjet jel imam neku drugu.Hvala.
Sretna vam Nova godina.
Staro 01.01.2023., 13:40   #7
pasara
Postovi: 200
Izvadio bateriju,stavio drugu,izvadio ram-e,izvadio graficku i opet nista.Mislim u taj komp mi se neda ulagat,ali sin ga uopce ne zeli koristit,pa sam ga se odlucio rijesit.Ima ssd,hdd,jaci procesor,graficku low profile 2gb.Mozda je maticna,mozda je napajanje,a mozda su u sumi.
P.s Ako netko ima napajanje za ovaj komp i zivi u Zg neka mi se javi,ako ga zeli posuditi da isprobam da nije ono krepalo.
Zadnje izmijenjeno od: pasara. 01.01.2023. u 16:55.
Staro 03.01.2023., 17:29   #8
pasara
Postovi: 200
Netko,bilo sta,od cega bi krenuo.Po meni jedino maticna ili napajanje.
Staro 03.01.2023., 18:18   #9
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 940
Autor pasara Pregled postova
Provjeri napajanje sa spajalicom https://help.corsair.com/hc/en-us/ar...r-Supply-Unit-
dinos3 je offline   Reply With Quote
Staro 03.01.2023., 18:39   #10
pasara
Postovi: 200
To nije takvo napajanje.
To je original hp napajanje.
https://www.cpumedics.com/hp-d12-240...-800-z230-sff/
Testirao napajanje i ono radi.
https://www.youtube.com/watch?v=dj9MusAUlDE
Zadnje izmijenjeno od: pasara. 03.01.2023. u 18:53.
Staro 04.01.2023., 11:01   #11
chief_wolfinjo
rekao bih da je problem u matičnoj:
https://community.spiceworks.com/top...not-turning-on
Staro 04.01.2023., 13:32   #12
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,821
Ako napajanje radi, blinkanje prednje ledice bi trebalo pokazivati grešku ...
Ajd upali i pregledaj umjesto zvučnih signala LED signale, isto tako ima dugih i kratkih ...
Staro 04.01.2023., 18:30   #13
pasara
Postovi: 200
Autor Nbdy32 Pregled postova
Nema nikakvih signala,ni svjetlosnih,ni zvucnih ni dimnih
Staro 05.01.2023., 11:29   #14
Nbdy32
Postovi: 2,821
Ahahaah, lijepo si ovo sročio ...
Hmmmm, znam da moj blinka, isti model ...
Esade, daj mi slikni konektore od napajanja pogotovo onaj mali ...
Mislim da je raspored pinova krivi na njemu ...
Staro 05.01.2023., 17:21   #15
pasara
Postovi: 200
Slika
Samo su 3 konektora od napajanja
Staro 09.01.2023., 10:33   #16
Nbdy32
Postovi: 2,821
E taj raspored žica na tom di je zelena crvena .... bijela ...
Staro 09.01.2023., 11:32   #17
Postovi: 23,513
Već je dokumentiran taj HP custom igrokaz > https://superuser.com/questions/8696...-an-hp-prodesk
vjerojatno ima još negdje po internetu,
ukratko, psu daje +12V and -12V rails a sve ostale napone se generira na mobo,
da bude zabavnije (čitaj: teže za ubaciti std. napajanje ako zanemarimo da je i SFF formata), psu fan se kontrolira preko mobo (P2 konektor) ... lako moguće da mobo ide u shutdown ako ne detektira fan ...
Zbog tih custom igrokaza su SFF malci nezgodni za krpanje ako se nema lager "njihovih" dijelova.
Staro 09.01.2023., 15:43   #18
Nbdy32
Postovi: 2,821
Ma P2 konektor, kod njega mogu biti okrenuti pinovi i zato ne želi upaliti komp ...
Staro 09.01.2023., 17:23   #19
pasara
Postovi: 200
Ma najnormalnije je radio.Jos sam ga nadogradio sa jacim procesorom i radio je kod klinca,ma sigurno godinu dana.Igrao je fortnite i samo ga je prosla volja.Komp je ugasen i stajao je kod klinca u sobi i nitko ga nije ni taknuo osim prasine.
Staro 09.01.2023., 17:47   #20
Postovi: 23,513
Umro zbog neuzvraćene ljubavi
Staro 10.01.2023., 05:15   #21
chief_wolfinjo
ma vjerojatno je matična neispravna. treba ju ispitati.
možda kondenzator ili sl.
Staro 10.01.2023., 17:36   #22
pasara
Postovi: 200
A pogledao sam,nijedan nije napuhnut ili da bi se vidjela bilo kakva promjena na maticnoj koja bi upucivala na njezinu neispravnost.Ipak mi taj komp nije toliko vazan da ga nosim na popravak i bespotrebno bacam novce.Mislio sam da cu mozda to sam rijesiti,ali kako situacija stoji,mislim da ce ici u dijelove.Lp
