Staro 11.08.2022., 22:25   #1
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Cool ReVanced for Android
Pokrenete builder, otvorit će vam prozor u browseru odakle dalje samo klikate dok ne završi proces.
Na kraju dobijete patchani apk kojeg prebacite na mob i instalirate, to je to.
Globalno popularna Vanced app je dobila svog nasljednika.
Trenutno ju je malo komplicirano instalirati jer treba manualno, ali radi se na installeru i websiteu.
Uputstva za instalaciju: https://github.com/revanced/revanced-documentation
Reddit: https://www.reddit.com/r/revancedapp/
Github: https://github.com/revanced
Telegram: https://t.me/app_revanced
Discord: http://revanced.app/discord
Twitter: https://twitter.com/revancedapp
EDIT 16.09.2022:
ReVanced Manager je vani: https://github.com/revanced/revanced-manager/releases/
Kako patchati Youtube s njim:
https://twitter.com/ng642727/status/1570499359623761921
EDIT 09.10.2022:
Od sada možete jednostavnije patchati aplikacije, pomoću ovog builder programa:
https://github.com/reisxd/revanced-builder
Ako koristite Windowse, skinete odavde revanced-builder-win.exe file: https://github.com/reisxd/revanced-b...eleases/latest
Instalirajte 64bit free verziju Azul Zulu JDK-a: https://www.azul.com/downloads/?pack...wnload-openjdk
Zadnje izmijenjeno od: Neo-ST. 09.10.2022. u 12:21.
Staro 11.08.2022., 22:57   #2
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,489
Previše komplicirano:
Code:
Make sure your phone is connected
adb shell exit
If you plan to use the root variant, check if you have root access
adb shell su -c exit
Copy the ADB device name
adb devices
Run the CLI
# Non-Root
java -jar revanced-cli-all.jar \
 -a some.apk \
 -c \
 -d device-name \
 -o revanced.apk \
 -b revanced-patches.jar
# Root
# In the case of YouTube you want to exlude the patch 'microg-support' with the option '-e'. The option '-e' allows you to exclude patches (e.g. -e 'microg-support' -e amoled ...)
 -a some.apk \
 -c \
 -d device-name \
 -o revanced.apk \
 -b revanced-patches.jar \
 -e microg-support \
 --mount
A lot of patches require the integrations which you can merge by adding the -m flag and passing the integrations file as the argument. If you need the list of patches available, pass in -l.
If you specified an ADB device the application should now open on your device and the CLI will show logs until the app is closed.
Staro 12.08.2022., 01:01   #3
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,858
Super mi je kako je sve relativno.
Meni primjerice, je to simple skroz.
Previše Linuxa u zivotu...
Staro 12.08.2022., 07:47   #4
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,245
Ocito nije...ja kad vidim da za ovako jednostavnu pizdariju moram u shell na Adroidu - ne. Zivot je prekratak
Staro 12.08.2022., 08:11   #5
strikoo
strikoo's Avatar
Postovi: 1,011
Vanced jos radi. Strpimo se malo pa ce i ovo biti "simple"
Zadnje izmijenjeno od: strikoo. 12.08.2022. u 08:21.
strikoo je offline   Reply With Quote
Staro 12.08.2022., 10:43   #6
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,635
Sigurno da ima puno pcekspertaša kojima je ovo jednostavno, ali generalno ovo baš i nije za mainstream
No yt premium za 5 accounta je 2 eur-a a vanced na smart tv baš i ne ide tako da....
Staro 12.08.2022., 11:10   #7
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Autor Exy Pregled postova
Za TV postoji SmartTube 😉
Staro 12.08.2022., 11:17   #8
Postovi: 10,228
Iako imam premium yt, na tvu je obavezno Smarttube. Once you go black...
Staro 12.08.2022., 12:07   #9
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,737
Autor strikoo Pregled postova
Da, tko ima apk od zadnjeg vanced managera jos uvijek moze instalirati tako da nema zurbe za ovo
A za tv da, smarttube je must have
Staro 12.08.2022., 12:20   #10
Prki
Prki's Avatar
Postovi: 1,317
Autor vacs Pregled postova
Može se još uvijek i skinuti manager bez problema.
Staro 12.08.2022., 13:26   #11
pero000
pero000's Avatar
Lokacija: zlatar bistrica
Postovi: 178
Smarttube je samo za android tv?
Ne vidim verziju za npr. samsung tv....
Gygabyte p35ds3
Core2Duo e8400
Sapphire 5770 FLEX
Transcend 800MhZ 2x2 gb
Segate 320GB
Chieftec A80 CTG-500-80P
Thermaltake V3 Black
LG W1934S 19"
pero000 je offline   Reply With Quote
Staro 12.08.2022., 14:42   #12
Exy
Exy's Avatar
Postovi: 2,635
Nema, samo na TV-ima sa Androidom i android boxevima. Bar koliko ja znam.
Pošto imam Samsunga jednostavnije mi je bilo riješiti premium nego se gnjaviti sa work aroundima, 2 eur mjesečno je smiješno a stavio sam pola familije da i oni imaju.
Staro 12.08.2022., 15:01   #13
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 715
X
Ima par načina za instalirat i sve je tip top.
Ne kužim šta ljudima znači update takve app kad sve i sa zadnjom verzijom radi bez problema.
Revolver3844 je offline   Reply With Quote
Staro 12.08.2022., 15:37   #14
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,753
Odlična vijest! No kao što su mnogi drugi rekli, dok Vanced još radi i dok se instalacija ne pojednostavni - IMO nema smisla osim ako se netko ne želi poigrati...
Staro 15.09.2022., 22:52   #15
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
We have officially released an official Alpha version of the ReVanced Manager
Staro 16.09.2022., 09:06   #16
Postovi: 34,050
Na S22 mi svako malo javi pop-up da se app crasha.
Staro 16.09.2022., 12:15   #17
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Autor coconut Pregled postova
Vidim da je nova verzija vani pa probaj.
How to patch:
Zadnje izmijenjeno od: Neo-ST. 16.09.2022. u 13:03.
Staro 26.09.2022., 14:41   #18
tiki66
tiki
tiki66's Avatar
Postovi: 2,754
Meni prije par dana nije radilo pa sam se danas išao pozabaviti.
Updateao sam Patcher na najnoviju verziju. Važno je da je verzija Youtubea točno ona koju patcher traži (u mom slučaju 17.36.37). Pošto sam ja imao noviju verziju, morao sam u Postavke od mobitela, Aplikacije, naći Youtube aplikaciju i onda stisnuti Unistall updates. Jednom kad je vraćena tvornička Youtube aplikacija, treba otići na internet i naći točno tu verziju aplikacije (google youtube apk pa skinut sa nekih od dostupnih stranica, npr. apkpure i slično). Nakon što sam ručno instalirao tu verziju, patchao je bez problema te aplikacija radi.
Staro 26.09.2022., 15:05   #19
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Također, ako želite biti logirani, morate skinit i instalirati Vanced MicroG.
Tj. mislim da ga morate svakako imati, inače će vam se Youtube crashati.
https://github.com/TeamVanced/VancedMicroG/releases
Staro 27.09.2022., 09:18   #20
Postovi: 34,050
Meni je taj MicroG radio probleme. Svako malo mi je S22 kod paljenja/resetiranja javljao da se MicroG crashao.
Staro 27.09.2022., 14:08   #21
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Inače tko nije skužio, sa ReVanced patcherom možete patchati i ostale aplikacije poput Reddita, Twittera, itd.
Bitno je pratiti točnu proceduru da bi to funkcioniralo.
Recimo da želite patchati Reddit koji vam je već instaliran na mobu:
1. Uninstall
2. Skinit Reddit apk sa apkmirror, međutim paziti da skidate običan apk, ne bundle. Često to znači da ćete morati skinit malo stariju verziju.
3. Instalirate apk, ne pokrećete je
4. U patcheru odaberete Reddit i stavite kvačice šta želite patchati
5. Pokrenete patch. Kad završi ne klikati install
6. Sa home tipkom izađete i odete u svoje settingse, apps, i pronađete Reddit kojeg uninstalirate
7. Vratite se natrag u patcher i sada kliknite install
To je to.
Staro 27.09.2022., 14:15   #22
Dottore
Dottore's Avatar
Postovi: 7,696
I Tiktok isto.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 27.09.2022., 14:24   #23
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,577
Kaj dobiš sa patchanim redditom?
Staro 27.09.2022., 14:28   #24
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Autor Juice Pregled postova
Staro 27.09.2022., 15:02   #25
Revolver3844
Lokacija: SB
Postovi: 715
A koja je poanta tog re-vanced ak stari ima za skinuti i sve radi kao i do sad?
Koja je uopće poanta updateanja takve aplikacije?
Koliko se sjećam update je znao samo sjebat stvari, ovak, reklama nema, radi log in, sve fluidno, radi u pozadini i šta više treba čovjek.
Staro 27.09.2022., 15:12   #26
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,511
argentinski premium za 15kn misecno
Tajl3r je online   Reply With Quote
Staro 27.09.2022., 16:39   #27
Revolver3844
Lokacija: SB
Postovi: 715
Autor Tajl3r Pregled postova
Ja sam probao i svaki put me baci na punu cijenu.
Promijenim IP adresu sa VPN i ne pomaže.
Očito nešto krivo radim.
Staro 28.09.2022., 09:32   #28
tiki66
tiki
tiki66's Avatar
Postovi: 2,754
Autor Neo-ST Pregled postova
Postoji li neki popis aplikacija koje se daju patchati?
Autor Revolver3844 Pregled postova
Zato jer za sad radi, a u budućnosti možda (ili vjerojatno) više ne bude radilo. Vanced se više ne razvija, i sad mi se provuče jedna reklama u preporučenim videima, a kasnije tko zna što će biti.
Možda jedan dan upališ Vanced i samo ti izbaci poruku ova verzija Youtubea više nije podržana, skini najnoviju, a onda si nagrabusio.
Staro 28.09.2022., 14:02   #29
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Autor tiki66 Pregled postova
https://github.com/revanced/revanced...main/README.md
Staro 09.10.2022., 12:11   #30
Neo-ST
Neo-ST's Avatar
Postovi: 8,547
Od nedavno možete jednostavnije patchati aplikacije, pomoću ovog builder programa:
