Staro 05.07.2022., 08:58   #1081
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
Thermalright HR-09 2280 PRO & HR-09 2280
http://www.thermalright.com/product/hr-09-2280/
http://www.thermalright.com/product/hr-09-2280-pro/
M.2 2280 SSD , M.2 2280 PRO , M.2 2280 ARGB
http://www.thermalright.com/product/m-2-2280-ssd/
http://www.thermalright.com/product/m-2-2280-pro/
http://www.thermalright.com/product/m-2-2280-argb/
Thermalright M.2 hladnjaci ... ovi gornji me podjecaju na one chipset hladnjake koje smo stavlja li na DFI-Ultra D ploce
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 13.07.2022., 06:27   #1082
Ninja_Zg
Ninja_Zg's Avatar
Datum registracije: Aug 2013
Postovi: 268
Moze preporuka sto jeftinijeg NVMe diska koji bi isao u eksterno USB 3.1 Gen 2 kuciste? 1 ili 2TB? Po mogucnosti nesto sad na Prime dayu?
Dakle ne bas najjeftnije DRAMless govno, ali mi ni ne treba Samsung 980 Pro s obzirom da brzine idu do 1000mb/s
Bitan mi je i sustained writing jer ce se gore kopirati video fajle, ali i editirati s njega kad sam u pokretu.
Dakle sto vise muzike za sto manje para.
Ninja_Zg je offline   Reply With Quote
Staro 13.07.2022., 11:48   #1083
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,596
Staro 13.07.2022., 12:41   #1084
Postovi: 23,535
Na toj listi ima i gotovih složenaca kao Crucial X6,
SK hynix Gold P31 2TB PCIe NVMe Gen3 M.2 2280 izgleda odličan, čak predobar za zamišljenu namjenu ...
Staro 13.07.2022., 14:52   #1085
Ninja_Zg
Ninja_Zg's Avatar
Postovi: 268
Hvala!
Staro 13.07.2022., 19:04   #1086
Dottore
Dottore's Avatar
Postovi: 7,660
Autor Nikky Pregled postova
Na redditu samo pohvale o tom Gold P31. Kod nas nema dostupnog
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 14.07.2022., 21:29   #1087
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Autor Ninja_Zg Pregled postova
Do pred 5-10 dana se mogao naći 2TB Adata 8200Pro ili Kingston KC2500 za cca 1350kn... no vidim da su nestali, ima samo Kingston izlistan po toj cijeni u Mikronisu, no stoji da se treba nazvat za raspoloživost...ergo, vjerojatno nema ni toga, ali možeš ih probat kontaktirat. Ako ima, KC2500 za tu cijenu je top.
Od ovih ostalih 2TB po takvim cijenama sve DRAMLess (što, vjerujem, nije neka sreća za vanjski USB drive).
Staro 14.07.2022., 22:13   #1088
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 363
porez na budale su hladnjaci za m2 ssdove. za svaki m2 ssd nvme dovoljan je hladnjak koji je dobije na ploci. komad lima i thermal pad sasvim dostatno odradi svoj posao. sve ovo gore prikazano je nepotrebna budalastina da treba platiti pola vrijednosti ssda za ukrasni komad lima i 5 posto nize temperature od onih sa hladnjakom od ploce.
Taproot7 je offline   Reply With Quote
Staro 02.09.2022., 04:01   #1089
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,596
SSD Pricing Could Tumble as NAND Prices Predicted to Drop by 35%
I to samo u 3Q, do kraja godine 50%!
Bit će dobrih dealova za BF
Staro 05.09.2022., 19:03   #1090
jucca
jucca's Avatar
Postovi: 1,692
Autor Taproot7 Pregled postova
Kod mene na Z690, 12600k i 3070, cak i nema neke razlike i bez hladnjaka tvornickog. Iako se disk (980 PRO) nakazi ispod grafe. Igram uglavnom sim racing igre u VR tako da komp bude zabijen na 80-100% . Zakuha mi dobrano sobu, ali disk je i dalje relativno hladan. Kuciste je Chieftec Silenzio, sa 4x120mm na 700-900rpm, sa dobrim protokom zraka tako da vjerovatno i to igra ulogu.
Sent from my SM-S908B using Tapatalk
Staro 05.09.2022., 21:59   #1091
Dottore
Dottore's Avatar
Postovi: 7,660
Autor kopija Pregled postova
Pozlatili ti prsti!
"daj mi 2Tb"
Staro 24.09.2022., 17:40   #1092
zig
zig's Avatar
Datum registracije: Jan 2010
Postovi: 389
Gledam uzet danas/sutra 980 PRO 1tb, pa se sad nadovezujem na vas, dal onda uzimat nekakav hladnjak za to ili ne ?
Dakle, gledam uzet običnu verziju bez hladnjaka, ali mi je sad ova priča malo otvorila upitnike.
Taj ssd će mi služit isključivo za igre.
zig je offline   Reply With Quote
Staro 24.09.2022., 18:55   #1093
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,482
Ja sam se isto mislija dali uzet ali nemas potrebe pogotovo ako je za igre ,meni je cak tik ispod grafe i nema problema sa
temp. i trotlanjem max je 68/69c kad nesto duze vremena pribaciva.
Kad sam ga tek uzeo onda sam iz šuca prebaciva 400 gb. i zabrinulo me tih 90c tad ali uzet u obzir da su bile one litnje vrucine klima nije radila...mislim da iskreno nema potrebe za igre ako bas zelis stavi koliko vidim nisu nesto ni skupi hladnjaci.(vrteci unazad topic imas par kandidata)
Zadnje izmijenjeno od: Tajl3r. 24.09.2022. u 19:41.
Staro 24.09.2022., 19:27   #1094
Postovi: 33,992
Ako ga mislite uzeti, imate ga sada na akciji na Amazonu. Požurite dok akcija još traje.
http://forum.pcekspert.com/showpost....postcount=3915
Staro 24.09.2022., 21:59   #1095
jucca
jucca's Avatar
Postovi: 1,692
Autor zig Pregled postova
Razlika mozda 7-8 stupnjeva. Tu negdje. Sa tvornickim coolerom od maticne.
Uzeo sam i ja 980 PRO u prosloj akciji kad je bila prije mjesec dana na Amazonu.
Ispod grafe stoji (3070), koju poprilično lozim (VR, sim-racing).
BTW, kad sam skidao hladnjak sa starog M2 Corsaira potrgao sam "čipove", tako da pazi sa onom žvakom.
Nikakva sila, niti se vidjelo ikakvo ostecenje, ali ocito se zvaka prejako zalijepi, pa je moguc ovakav defekt. SSD je postao necitljiv.
Tako da nemam bas neka dobra iskustva sa M2 hladnjacima
Staro 28.09.2022., 16:47   #1096
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
M.2 NVMe SSD - specifikacije, pitanja, rasprava, review, firmware update,...
Meni se naljepnica od 970 Pro uhvatila za thermal pad od M.2 hladnjaka. Kada sam skinuo hladnjak povukao mi je i naljepnicu sa sobom, a time i garanciju
SSD radi normalno.
Staro 29.09.2022., 06:56   #1097
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 289
Ako SDD nije tvornički došao s hladnjakom onda ti on ni netreba vjerojatno.
BinaryJesus je offline   Reply With Quote
Staro 29.09.2022., 10:03   #1098
Postovi: 23,535
Da, ako te nije briga hoće li prokuhati i crknuti.
Staro 29.09.2022., 21:17   #1099
medo
medo's Avatar
Postovi: 3,714
Autor BinaryJesus Pregled postova
Ako ti ona stvar nije došla s kondomom onda ti ne treba vjerojatno
Staro 30.09.2022., 09:51   #1100
nepalac
Datum registracije: Feb 2022
Lokacija: EU
Postovi: 834
Pa zato postoji jamstvo pa nek crkava.
Uostalom, zašto bi proizvođač pravio proizvod koji će crknuti od pregrijavanja?
Valjda su ga istestirali u svi mogućim uvjetima i zaključili da hladnjak nije potreban.
Jedino ako baš ne piše u nekakvom manualu da je potreban i da se preporuča, što čisto sumnjam.
Ja osobno hladnjak ne bi stavljao, pogotovo kad vidim ove probleme sa ljepljenjem hladnjaka za njega, najbolje da si poništim jamstvo od 5 godina, ali svatko zna svoje...
Zadnje izmijenjeno od: nepalac. 30.09.2022. u 09:57.
Staro 30.09.2022., 10:13   #1101
Postovi: 23,535
Jesu testirali, u kontroler ugradili mehanizam kontrole temperature .... pa kad se ugrije onda uspori rad a ti se nerviraš ... ovi koji se nalaze na mobo ispod (vruće) grafe su u "pednosti" po tom pitanju.
U vezi skidanja hladnjaka i potencijalnog oštećenja (da odvališ neki smd element) jest problem.
Srećom pa većina skompletira PC / Lap i nešto mijenja jedino kad nešto crkne
Staro 30.09.2022., 12:19   #1102
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,069
Na 980 Pro definitivno staviti hladnjak, na sporije modele tipa 970 Evo mislim da ne treba, ali opet to ovisi o lokaciji gdje se ugrađuje SSD. Nije isto jel je laptop ili desktop u pitanju, ili kakav je airflow kućišta.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 30.09.2022., 12:27   #1103
nino
nino's Avatar
Postovi: 12,613
Autor nepalac Pregled postova
Jel ti bolje od Zamzunga znas?
Eto, isti proizvod, ali jedan tvornicki dolazi sa hladnjakom. Koji je razlog? Izgled? Performance?
Opcenito je malo "glupa" izjava kolege da "Ako SDD nije tvornički došao s hladnjakom onda ti on ni netreba vjerojatno" i onda se ti nadovezes sa jos gorom izjavom.
Definitivno stoji, sto hladnije to bolje. Osobno sam uvezao mozda medju prvima u Hr Samsungov prvi nvme model, mislim da je 941 bio, bez hladnjaka, 256GB sa cijenom oko 2k kn.
Od tada mi ih je hrpa prosla kroz ruke, sto kroz testove, sto kroz ugradjivanja.
Bilo je modela koji su se dobrano grijali, doduse, nije bilo posljedica ali onda sam na jedan Corsairov stavio aftermarket cooler, mislim od Silverstone-a i smanjio temp na 50%. Tocne brojeve neznam sad, ali nakon toga vise ni ne gledam temperature ssd-ova.
Staro 30.09.2022., 13:19   #1104
nepalac
Lokacija: EU
Postovi: 834
Autor nino Pregled postova
Ja svakako ne znam ali eto očito ti znaš, jer po tvome, samsung radi grešku što ga prodaje bez hladnjaka, trebaš ih upozoriti na to.
Znači jedino što možemo zaključiti je da nema posljedica bez hladnjaka osim što se jače grije.
Kako rekoh, samsung je taj koji radi testove prije puštanja u prodaju, da su njima crkavali od prevelike temp. onda bi hladnjak dolazio na svakom modelu.
Pošto ne dolazi onda ni ne treba.
Ponavljam, to je samo moje mišljenje, a i samsungovo, i osobno koristim proizvod onako kako je došao u kutiji.
Ako ćeš ti keljiti na njega i vodeno hlađenje to su opet tvoji tjuninzi pc-a, ne znam tko ti brani da pojačavaš hlađenje kako god znaš za bilo koju komponentu
Staro 30.09.2022., 13:22   #1105
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,482
Slusaj reka ti je nikky gori kad se zagrije trotla i uspori ,ja ne korstim hladnjak ali bi da mogu (ispod grafe mi je i ne korstim sam ssd toliko)
Staro 30.09.2022., 13:29   #1106
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,249
A nitko od vas koji kazete da ne treba hladnjak se nije upitao da je razlog zasto dolaze bez hladnjaka taj da ga mozes smjestit na ploci koja ima vec svoj hladnjak? 🤓 ili na laptopu isto?
Nego, od svih nvme diskova sto sam koristio svaki je profitirao od dodatnog hladnjaka. Jednostavno izbjegnes throttle koji brutalno iritira.
Btw, nemas sta slomit na disku ako si imalo normalan. Stavis thermal padove, pritegnes hladnjak i vozi.
Staro 30.09.2022., 13:32   #1107
nepalac
Lokacija: EU
Postovi: 834
Autor Tajl3r Pregled postova
Osobno na svom 980 pro nisam primjetio nikakvo usporavanje, možda mu se čak i smanje performanse ali ja nisam primjetio u radu.
Možda nisam power user, šta ja znam.
Staro 30.09.2022., 13:37   #1108
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,482
Pa o tome se radi ja i ti nismo.
Staro 30.09.2022., 14:32   #1109
nepalac
Lokacija: EU
Postovi: 834
Rijetko tko i je, barem prema Samsungu.
Evo što kažu na svom sajtu:
Do I need a heat sink for optimal performance of the Samsung NVMe M.2 SSD?
Samsung NVMe™ SSDs rarely require a heat sink, yet maintain optimal performance thanks to Samsung’s advanced design and manufacturing capabilities coupled with an integrated, heat dissipating thermal label. In rare instances of extreme workloads (transfer of several hundreds of GB), performance may be throttled through Samsung’s dynamic thermal throttling algorithm to protect the SSDs integrity.
Please be aware, however, that an external heat source such as a high-powered graphics card, or CPU placed in close proximity to a Samsung NVMe™ SSD, can adversely affect airflow around a Samsung NVMe™ SSD which may lead to performance degradation. Therefore, please ensure there is appropriate airflow around your Samsung NVMe™ SSD.
https://semiconductor.samsung.com/co.../faqs/nvmessd/
Staro 30.09.2022., 17:20   #1110
SPLiFF
SPLiFF's Avatar
Postovi: 2,106
Sad sam u 2 navrata prebacivao po 1 veći folder s jednog SSD-a na drugi. Oba su nvme gen3 spojeni direkt u MBO.
Brzina krene sa 800-1000MB/s i onda nakon nekih 30-40GB padne na 70MB/s i tu ostane do kraja.
U folderima su samo jpg i mov.
Je li tu riječ o nekom pregrijavanju, pa se automatski smanji brzina? Nemam hladnjake na diskovima.
