Staro 19.03.2022., 00:02   #2251
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Jel to ugašen youtube vanced?
Ima li neka alternativa youtubeu bez reklama i da radi sa ugašenim ekranom?
Imaš Newpipe ili Newpipe+SponsorBlock. Ali radit će ti Vanced još neko vrijeme, rečeno je čak do dvije godine.
PSN Steam
Staro 19.03.2022., 10:18   #2252
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Autor d0X Pregled postova
Imam da mi se javio problem sa poslužiteljem - 400
Resetiro mob, internet konekcija i dalje danima isto. Obični yt radi
Vanceda više nema na linku da ga probam ponovo instalirati
The popular Vanced YouTube app is being discontinued, after a legal threat from Google. The creators of Vanced have revealed the project will be shut down in the coming days, with download links set to be removed.
Tek kad se vratiš na obični youtube shvatis koji je to sumrak - nema kraja reklamama, nemožes minimize appa napravit, ne radi s ugašenim ekranom...
Staro 19.03.2022., 13:10   #2253
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
PSN Steam
Staro 19.03.2022., 13:18   #2254
buljaka
Datum registracije: Aug 2014
Postovi: 2,929
"Vanced Manager has a built in setting to change the download server. Download Vanced Manager from Apkmirror, run it, open the three-dot menu, tap About, tap on the Vanced Team box a few times to unlock Dev options. Go back to main screen, open the three-dot menu again, tap Settings, tap the cog on the top right, tap Channel URL, change the URL from https://api.vancedapp.com/api/v1 to https://mirror.codebucket.de/vanced/api/v1 and bam, it works."
Staro 19.03.2022., 19:29   #2255
Manuel Calavera
Postovi: 14,584
Thnx dečki, proradila je ova šema sa promjenom linka za vanced
Inače nije loš ni ovaj newpipe, jedino što nisam vidio da se može spojit na accout, te ima nekakav zastoj od sekudnu-dvije kad se ugasi ekran, al radi kad se ugasi, reklama nema, može minimize...
Staro 19.03.2022., 20:07   #2256
Prezime
Datum registracije: Aug 2013
Postovi: 4,327
Nisi dobro gledao
Staro 01.05.2022., 17:05   #2257
5ar
5ar's Avatar
Postovi: 125
Huawei Y6 2018, mobitel ima 16GB interne memorije i Android 8, na njemu je instaliran Whatsapp, Chrome, 24sata i hrpa onih aplikacija koje dođu s njim i ne mogu ih obrisati. Problem mi je što ima slobodnih oko 500MB i stalno se borim s njim oko toga. Imam unutra 64GB SD karticu, ali ne pomaže previše jer sam samo galeriju uspio natjerati da sprema fotke na SD. Ima li načina da natjeram SD karticu da radi kao internal storage na ovoj verziji Androida i da time riješim taj problem s memorijom? Bi li pomoglo rootanje pa da onda brišem ove aplikacije koje u startu dođu s njim?
Ima li netko iskustva s premalom internom memorijom i kako to riješiti osim kupnjom drugog uređaja?
5ar je offline   Reply With Quote
Staro 01.05.2022., 19:40   #2258
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,230
Probat stavit custom rom ili rootat, ako se uopce ista od tog moze. Potrazi na xda forumu.
Staro 06.05.2022., 15:41   #2259
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,407
Poštovani kolege, trebao bi na jednom androidu instalirati jednu aplikaciju, ulogirati se u nju i onda nekako napraviti backup te aplikacije na drugi android, znate li koji način za to, znači da prebacim samo jednu aplikaciju s jednog mobitela na drugi ili ću morati raditi backup cijelog moba s jednog na drugi?
Hala Madrid!
Staro 06.05.2022., 16:10   #2260
dadoremix
dadoremix's Avatar
Postovi: 4,693
a zasto ne instaliras i na drugi i opet se logiras ?
ili su kakve nečasne mjere u igri
dadoremix je online   Reply With Quote
Staro 06.05.2022., 18:39   #2261
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,535
Mozda taj mobitel nema Google play ili tako nesto. Anyway, moze se napraviti app backup sa SystemPanel 2
A moze se i rucno:
https://gist.github.com/AnatomicJC/e...6dd2351eb977c1
Ja sam rucno prebacio samo app sa jednog uredjana na drugi.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 09.05.2022., 09:05   #2262
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,407
Ma radi se o tome da trebam testirati kad se prebaci app s jednog moba na drugi hoće li se prebaciti samo base podaci ili svi podaci koji su spremljeni na trenutnom mobu. Radi se o mBanking aplikaciji i trebala bi se prebaciti samo base aplikacija.
Hala Madrid!
Staro 14.05.2022., 11:30   #2263
spawn
spawn's Avatar
Postovi: 8,401
Mbanking ne mozes prebacivati.
Staro 14.05.2022., 14:46   #2264
jucca
jucca's Avatar
Postovi: 1,689
Meni je kad sam prelazio sa P10 na P30 uredno prebacio sve. Uključujući aktivirani mBanking.
Ali se promjenilo u međuvremenu?
Sent from my SM-G986B using Tapatalk
Staro 17.05.2022., 18:43   #2265
spawn
spawn's Avatar
Postovi: 8,401
Ne znam kako je bilo prije, danas ne prolazi. Ja sam probao cak sa p30pro na p30 i nije proslo. Erste i pbz u pitanju
Staro 24.05.2022., 10:50   #2266
golfw12
golfw12's Avatar
Postovi: 424
ukratko, koristim P30 pro i viber/whatsapp na hr broju, i sad imam potrebu za drugim simom od stranom operatera (u švici sam), uzo sam swisscom karticu na bonove i sve je mobitel prepoznao i radi (poziv,net)
ali ono što neradi ili neznam namjestit je viber i whatsapp jer kolko sam skužio te aplikacije mogu imati samo jedan broj vezan za njih koji je trenutno tmobile, a sad bi trebao odjaviti se sa tmobile brojem i prijaviti se s swisscom brojem na ta 2 računa ako ih želim koristit
ili postoji neka druga opcija tipa da imam 2 vibera/whatsappa na telefonu ali da je jedan viber domači s hr kontaktima a drugi viber sa ch kontaktima
ono što neželim ali je najvjerojatnije i sve sudeći najjednostavnije rješenje -još jedan telefon na kojem si napravim strani račun i koristim viber/whatsapp
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 24.05.2022., 11:53   #2267
Postovi: 33,950
Ne možeš imati 2 Viber/WA accounta na istom mobu. Navodno bi neki od budućih Androida (13?) to trebao mogućiti.
Najjednostavnije bi ti bilo napraviti nove accounte sa novim brojem.
Staro 24.05.2022., 12:21   #2268
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Autor golfw12 Pregled postova
Nisam nikad koristio Huawei, ali čini mi se da je App Twin nešto kao Parallel Space. Vidi imaš li tu funkciju.
https://www.clove.co.uk/blogs/news/h...huawei-p30-pro
@coconut, može se. Xiaomi ima nativnu podršku na MIUI (Dual Apps), a ima i Parallel Space na Google Playu za ostale Androide. Huawei, koliko vidim, ima ili je imao taj App Twin.
PSN Steam
Staro 24.05.2022., 13:07   #2269
golfw12
golfw12's Avatar
Postovi: 424
d0X kralju
to tražim App Twin!!
Uspio sam napraviti samo s whatsappom klonirani app!
imam sad dupli whatsapp s ikonom 2 u čošku
3
nažalost viber mi ne nudi u applikaciji blizanac -prijevod me ubio
2
HDD: 256 GB M.2 SSD
PSU: HP 90W
Staro 24.05.2022., 13:22   #2270
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Aplikacija blizanac, odlično
PSN Steam
Staro 19.08.2022., 11:20   #2271
chief_wolfinjo
Bok,
Molim savjet vezano za bateriju mobitela. Nekak se brzo prazni, ali i brzo puni. Pa me zanima kako kalibrirati bateriju ako je naravno moguce.
Hvala
Staro 19.08.2022., 12:55   #2272
Postovi: 10,035
Obrisati batterystats.bin fajl? lol,jk
Koji je uopce mob i koji ti je root status?
Ne bih rekao da mozes ista previse napraviti, ali eto, sibni vise info cisto da zaposlimo mozgove
Staro 19.08.2022., 16:54   #2273
chief_wolfinjo
mobitel je LG Zero - Android 6.0
baterija je do neki dan bila izvan svih očekivanja. npr...
napunim mobitel, i doslovce za dva dana baterija padne
sa 100% na 95%
ali se mobitel ne koristi puno jer služi kao drugi mobitel.
i sad odjednom napunim mobitel na 100% i doslovce za par sati
padne na 85%.... a korištenje sve isto
Staro 19.08.2022., 17:48   #2274
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Neka app ti zdere bateriju. Pogledaj koja pod, well, battery usage details
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 20.08.2022., 07:55   #2275
chief_wolfinjo
moguće
budem danas to provjerio detaljnije
Staro 20.08.2022., 10:41   #2276
Postovi: 10,035
Ne znam nis o tom mobu i jos je prilicno star pa je pitanje sto se fizicki/kemijski dogadja u samoj bateriji. Krenuo bih od nekog reseta ili okrivio neku od automatski updejtanih appova (khm, google, khm).
Staro 23.08.2022., 17:29   #2277
chief_wolfinjo
uspio sam rješiti problem zahvaljujući vama.
aplikacija za vremensku prognozu je cuclao bateriju, od kada je izbrisan
program. sve radi kako treba po pitanju baterije
Staro 06.09.2022., 17:42   #2278
dzajko
dzajko's Avatar
Lokacija: Ehhhh
Postovi: 498
Jeli postoji mogucnost privremenoga zaustavljanja obavijesti određene app. Konkretno se radi o Wap Business, mogu li za tu aplikaciju iskljuciti obavijesti van radnog vremena?
dzajko je offline   Reply With Quote
Staro 06.09.2022., 17:49   #2279
Postovi: 10,035
Moze se Taskerom:
https://www.reddit.com/r/tasker/comm...ific_app_on_a/
Ili jednostavno rucno ubijes notifikacije za taj app kad si gotov s poslom pa ih upalis ujutro.
Staro 13.09.2022., 17:55   #2280
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,944
Jedno brzinsko, ima li (glupo pitanje) kakav app za androida da se pretvori cijeli mob u nadzornu IP kameru, poželjno s oblakom... vidio sam ima appova da omogućavaju streaming sa kamera, ali gledam neko punokrvno rješenje pa ne vidim... da iskoristim stari mob...
