Staro 12.03.2022., 11:37   #2011
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,837
stigla mi 34" iiyama.. nisam jos spojio, ipak nema pivot tj kad se okrene, ne moze stajati okomito nego nakoso jer donji dio udara u stalak.. narucen X1-3d nosac pa cu ga onda namontirat.. ugl izgleda predobro, taman ono sto mi treba od vertikalne radne povrsine.. nadam se samo da ce nosac izdrzati, svasta sam citao po netu
Staro 12.03.2022., 12:44   #2012
Postovi: 10,185
Volio bih cuti dojmove nakon sto ga malo testiras, tnx
Staro 17.03.2022., 23:09   #2013
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,457
Autor Disco Pregled postova
Prvi negativni review i potencijalni problem
[heise German] Alienware monitor with QD-OLED tested: Samsung's display technology is screwed up
Edit - iz komentara:
It is a software problem, not a hardware problem. There are already workarounds for it but in the end Microsoft and Apple need to adapt the new RGB layout within their operating system. Linux doesn't have this problem.
''Pixel is made out of a 3-color triangle (red green blue) on this display, instead of 3 rectangular strips (as on LCD). Windows and MacOS doesn't know how to properly render UI on this layout (because it expects LCD layout), so it looks wrong.''
updejt - komentari:
How is it Windows'/Mac's problem?
The image to be rendered goes through so many layers. It's a simple Bitmap or w/e when it goes to the GPU, gets translated into pixels on the framebuffer in RGB24 format or w/e, goes to the display which has its own CPU controlling the display.
Surely someone, somewhere, at any point in that chain controls the individual subpixels making up a pixel. Surely it doesn't punch through all the way to the operating system. That would be hugely inefficient. Surely, right?
Edit: I don't know where you got your quote from. This one is from the article:
Ein Blick aufs Bildschirmmenü (OSD) beweist, dass das Problem nicht etwa an einer Farbunterabtastung liegt, bei der der Zuspieler nur reduzierte Bildinformationen an den Monitor schickt. Selbst im OSD ohne angeschlossenen Zuspieler gerät die eigentlich weiße Schrift bunt.
Rough translation: Even without any source (i.e. no PC or anything else connected), the on-screen menu has the same effect. Meaning that it's not a Windows issue, or a Mac issue, but a display issue.
Zadnje izmijenjeno od: Old.machine. 17.03.2022. u 23:52.
Old.machine je offline   Reply With Quote
Staro 20.03.2022., 15:19   #2014
John Creasy
Lokacija: Beograd
Postovi: 2,837
Autor xlr Pregled postova
Iiyama G-Master GB3461WQSU-B1
Arctic X1-3D
monitor je namontiran i u upotrebi zadnjih par dana.. što se tiče same Iiyame, oduševljen sam.. nijedan mrtvi piksel, kutovi gledanja odlični.. spojen je preko mini DP, odmah je bio naštiman na 144hz.. imao sam problema sa scalingom aplikacija koje koristim, ali to je do njih, softverski to treba riješiti - malo se kolju Quadro P620 i intel igpu 630 tj problem je u igpu podršci za multiple monitor setup
e sad, monitor je odličan ali nosač X1-3D je li-la.. testirali su ga svi s manjim dijagonalama i vjerujem da tu drži kako spada, ali s ovom mrcinom se ne može nositi.. monitor je stavljen vertikalno, i s obzirom na težinu i dijagonalu ne može opet stajati okomito nego ga baca unazad premda je onaj prihvat gdje se steže skroz zategnut.. moram staviti neku daščicu iza donjeg dijela da ga drži pravo pod 90 stupnjeva.. i još jedna zamjerka za stalak, prišarafi se s četiri jadna šarafića s većom glavom, nadam se da glave na šarafima neće popustit i da mi monitor odvali od stol.. imam dva SBOX LCD-352/2V dodatna nosača, puno su bolje izvedeni..
Staro 22.03.2022., 13:05   #2015
sti
Lokacija: Lawl
Postovi: 1,380
Bocnuo Alienware OLED AW3423DW
Prelazim sa TN-a, dakle iz jedne krajnosti u drugu
Netko je na Redditu slikao kako izgleda crna boja :
https://www.reddit.com/r/ultrawidema...m_source=share
Zadnje izmijenjeno od: sti. 22.03.2022. u 14:08. Razlog: naveden model
Staro 22.03.2022., 13:39   #2016
d0X
Kostolomac
d0X's Avatar
Postovi: 1,525
Uživaj! I ja planiram uzeti jednoga, za 5-6 godina kad budu 4k kn
PSN Steam
d0X je online   Reply With Quote
Staro 22.03.2022., 14:00   #2017
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,925
Autor sti Pregled postova
Novi Alienware OLED ? AW3423DW ?
Kupljen u HR ili ?
Matta je offline   Reply With Quote
Staro 22.03.2022., 14:06   #2018
sti
Lokacija: Lawl
Postovi: 1,380
Hvala, a cijena bi trebala ići dole kako se yieldovi poboljšavaju i više proizvođača počne kupovati panel od Samsunga.
Također, Linus Tech Tips je dao neki poluinsajderski info kako Samsung uopće nema škarta ako reže motherglass u ovoj veličini (34") i može dobiti 18 panela po motherglassu. Zato cijena nije 3 tisuće € kako su svi predviđali kad je monitor najavljujen.
@Matta - da, kupljen u Švabiji preko Dell.de. Rasprodan momentalno, ali isplati se pratiti zalihe.
Staro 22.03.2022., 14:20   #2019
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Ajde fino, čekam dojmove.
BTW, izgleda malo čudno oko ovog dijamanta i kursora na toj slici sa reddita (podsjeća na FALD glow, nadam se da je samo do kompresije tj do šugave kamere s kojom je slikano):
Cijena 1300€ ili je niža?
Slobodno me dodajte na PSN
Staro 22.03.2022., 14:34   #2020
John Creasy
Lokacija: Beograd
Postovi: 2,837
"i don't know, that photo looks kinda grey on my gaming IPS display...... /s"
prvi komentar na redditu, slažem se totalno, i na mom IPS panelu ta crna ne izgleda baš kao crna :P
Staro 22.03.2022., 14:46   #2021
sti
Lokacija: Lawl
Postovi: 1,380
@Disco, to je do post-processinga kamere, baš je neka šugava. Cijena je sa kodom za popust kojeg sam imao preko "corporate benefits" 1065€
@John Creasy, dobro da ja gledam s mobitela (Oled) umjesto sa gaming TN-a, inače ga ne bi kupio
Staro 22.03.2022., 14:52   #2022
John Creasy
Lokacija: Beograd
Postovi: 2,837
znaci i tebi stiglo 25% corporate popusta .. ne smijem ni gledat dell ponudu, doci cu u napast
Staro 26.03.2022., 11:14   #2023
slavonac90
slavonac90's Avatar
Postovi: 1,527
Narode koristi li itko Samsung LS28AG700NUXEN i kakvi su dojmovi? Jednostavno mi se neda čekati da počnu dolaziti novi 2.1 hdmi modeli i ovaj mi je ušao u prihvatljivi budžet za 4900 kn, pa sam ga upravo naručio u Santa Domenici. Koristiti će se primarno za gaming na ps5 i paralelno za PC (dekstop i neki laganiji gaming koliko rtx 2060 to dopusti, FHD rezolucija pretežito). Jednostavno nema ništa jeftinije u ponudi, famozni m32u kojega gledam već pola godine mi je jednsotavno preskup, a 28 iča verzija je preko 6000 kn također. Nadam se da nisam napravio zajeb
Zadnje izmijenjeno od: slavonac90. 26.03.2022. u 11:25.
slavonac90 je offline   Reply With Quote
Staro 27.03.2022., 10:35   #2024
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Autor slavonac90 Pregled postova
Po Rtingsu je to dosta dobar monitor:
https://www.rtings.com/monitor/revie...sey-g7-s28ag70
EDIT: E sada vidim da se razlikuju u nazivu, pa nisam siguran da je to isti monitor.
Zadnje izmijenjeno od: Disco. 27.03.2022. u 10:40.
Staro 27.03.2022., 11:58   #2025
slavonac90
slavonac90's Avatar
Postovi: 1,527
Isti je, to su varijacije u oznakama samo, ovisno o regiji, barem sam tako pročitao na netu. Rtings mi je glavno mjerilo što se tiče ekrana, a vidio sam i još par recenzija gdje je monitor dosta dobro prošao. Sve u svemu se ne čini loš izbor, pogotovo s obzirom na ponudu i cijenu. Uspoređuju ga sa Gigabyte m28u, a koji je 1000 kn skuplji,a i slabo je dobavljiv kod nas. Prvi izbor mi je bio m32u zbog veće dijagonale, ali cijena je ipak prevagnula. Sve u svemu naspram trenutnog AOC 27G2U mora biti nebo i zemlja za PS 5. Malo me brine za desktop dijagonala od 28 incha u 4k, ali sa upscalingom bi trebalo ok biti ako se ne varam. PC igre će se i dalje vrlo vjerojatno igrati u FHD rezoluciji, tu i tamo neka igra u1440p, jer rtx 2060 obična ni ne može više pružiti. Uglavnom stigne za koji dan pa se javim sa dojmovima.
Staro 28.03.2022., 16:52   #2026
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Staro 28.03.2022., 17:13   #2027
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,840
OLED kao monitor....kako riješavaju burn-in?
vječno pitanje.
Staro 28.03.2022., 18:52   #2028
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
vječno pitanje.
A ono, imaš 3g tvorničku garanciju od burn-ina...ali preskup je to monitor da bi ga npr bacio nakon 3-4 godine.
Pogledaj video.
Staro 29.03.2022., 00:27   #2029
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 29.03.2022., 06:57   #2030
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Imam ja sve 3 verzije Vite (OLED,LCD,PSTV), OLED imam od mislim 2014-e, OK u zadnje vrijeme ju i ne palim baš, ali nikakav burn-in nisam primjetio (inače, razlika u ekranima između OLED i LCD Vite je OGROMNA kad ih se stavi jednu kraj druge, LCD izgleda grozno...dok kad ih se gleda odvojeno, LCD izgleda sasvim pristojno). Doduše mene bole oči od jakog brightnessa, pa mi je isti na svim ekranima/uređajima namješten na niske vrijednosti. Ista stvar i sa samsung mobitelima koji su imali AMOLED. Moji svi kao novi, dok sam u dućanima vidio izložbene koji su bili satrani od burn-ina...pa eto, očito ipak treba malo pazit, tj ne napucavat brightness na 100% i puštat statični ekran predugo. Ako niš drugo, kad god idem negdje ja uvijek zaključam windowse sa win+L kombinacijom i bok (profesionalna deformacija ), ekran se gasi nakon 10ak sekundi.
Staro 29.03.2022., 22:51   #2031
slavonac90
slavonac90's Avatar
Postovi: 1,527
Stigao mi danas Samsung Odysey g7 LS28AG700 i nakon višesatnog testiranja mogu reći da je monitor ispunio očekivanja, osim jedne stvari, a nju ću ostaviti za kraj.
Krenuti ću od dijagonale od 28 inča za koju sam bio skeptičan da će biti premala za 4k, ali to ipak nije slučaj. Odlično mi paše 4k na udaljenosti oko pola metra kada sam pozicioniran za mišem i tipkovnicom naslonjen u stolici da se osjećam ugodno. Oštrina na ovoj dijagonali je jednostavno odlična,pustio par 4k videa i izgleda bolesno dobro,boje su odlične inače i out of box je dosta dobro kalibriran, ali sam promjenio nešto sitno po kalibraciji s RTING-sa i čine mi se boje nešto bolje nego na AOC-u koji sam do sada koristio. Što se tiče podrške za PS 5, dobio sam ono što sam tražio, punu podršku za 2.1 hdmi koji radi out of box bez ikakvih updejtanja. Igrati se na ovom monitoru je jednostavno odlično, responzivan je,nema ghostinga,boje na nivou, sve u svemu ja zadovoljan. Prmjetio sam da čak da i ovaj fake HDR 400 izgleda dobro dok se igram na ps 5, Forbidden West mi bez HDR-a ima nekako manje žive boje, pa sam ga ostavio upaljenog za sada, iako dosta ljudi kaže da je taj hdr 400 drek, a meni opet izgleda bolje s tim nego bez...do sada nisam imao priliku probati HDR pa ne znam. Na kompu mi naravno ugašen, samo ga na ps5 upalio. Ergonomija monitoru je odlična, spušta se gore/dolje, lijevo/desno, tilt i ima pivot. RGB osvjetljenje je isto zanimljiva stvarčica, sve u svemu monitor je pravi bombončić.
E sad ono što me u ovoj cijeloj prič pati je dosta izražen backlight, kao da AOC koji sam koristio nije imao baš toliko probijanja, a razlika u cijeni nebo i zemlja. Kakva je situacija s reklamacijom i povratkom u takvim situacijama i ima li smisla uopće vraćati ili ću opet naletiti vrlo vjerojatno na takav ako je do serije?
Evo dvije slikice na linkovima da vidite o čemu pričam. Nisam siguran jesam tolika pciajzla jer znam da sam ga platio puno ili je to jednostavno za reklamaciju?
https://postimg.cc/qh5fTK8D
https://postimg.cc/sM9t2qYh
Staro 29.03.2022., 23:08   #2032
Blue Spirit
Postovi: 2,195
Sumnjam da ces ista postici sa reklamacijom jer je IPS bleed "feature" IPS panela koji je do neke mjere više ili manje izražen.
Tehnicki monitor je ispravan.
Nisi imao srece sa lutrijom panela.
Vrati ga natrag ako si ga platio internet barkarstvom / preko webshopa , imaš pravo vratit ga bez navođenja razloga i dobit povrat novca te uzni isti takav iz druge trgovine.
Staro 30.03.2022., 09:20   #2033
slavonac90
slavonac90's Avatar
Postovi: 1,527
Uzeo sam ga u Santa Domenici koja ga jedino trenutno ima ispod 5000 kn pa sam mislio eventualno tražiti kod njih drugi ekran, jer se može desiti i u drugoj trgovini ista stvar, a platiti ću ga više nego ovdje. Ne znam ni sam iskreno šta da radim...u normalnom radu, gamingu i sl. to se uopće ne primjeti, samo kada je crn ekran i to po noći, cijelo popodne ga koristio jučer i skonto sam to tek navečer. Sad jbg, s obzirom na cijenu ja sam očekivao da neće imati mane, ali da, znam da je kod svih IPS panela navedeni problem izražen, iako na AOC 27G2U se nije toliko vidjelo. Mrtvih piksela nema uopće, eto jedina mana je taj bleed.
Staro 30.03.2022., 09:27   #2034
Postovi: 10,185
Naviknut ces se i prestati primjecivati. Namjesti da ti ekran ide u standby nakon x min, a ne da ti radi blank crni screensaver pa ti nece svijetliti soba. Been there... IPS-ovi.
Staro 30.03.2022., 09:41   #2035
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Da, to je lutrija i može te strefiti i gori primjerak, IPS glow i bleed su nažalost normalna stvar.
Na više mjesta sam čitao da je ekipa tako promjenila i po 3-4 monitora i svaki pu dobivali i gore...
Staro 30.03.2022., 09:53   #2036
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Tocno to, a ovaj njegov nije ni tolko los primjerak tako da lako moze naletit na gori. A opet ic drugi put mijenjat, sterat ce ga ovi u ducanu u neku stvar..
Staro 30.03.2022., 10:03   #2037
slavonac90
slavonac90's Avatar
Postovi: 1,527
Iskreno, ni ne mijenja mi se, jer je stvarno odličan monitor, pa dok dođe novi, i prolazit natezanja mi se neda. A opet gledam s druge strane, nije jeftin pa da vidim kakva su vaša mišljenja što napraviti, jer iskreno ni sam ne znam jel mi to problem ili ne.
Aoc koji je koštao 2000 kn je izgleda bio dobar pimjerak, jer tamo nisam zamjećivao bleed ,a koristio ga godinu dana...na ovom odmah prvi dan, čim je mrak pao ubolo u oči dok je bio u igri crni ekran prilikom loadinga, i naravno vrag neda mira pa sam testirao dodatno s tim crnim ekranima po youtube i bleed je prisutan, što se vidi i sa fotki.
Danas poslije posla ga još malo istestiram, poigram se pa odlučim hoću li se upuštati u natezanja ili jednostavno zanemariti, a nekako mi se čini da će ipak biti ovo drugo.
Staro 30.03.2022., 10:05   #2038
Mladenxy
Mladenxy's Avatar
Postovi: 4,424
Slikano kamerom koja još pojača efekt u odnosu što stvarno vidiš očima, po meni ovo je standard za IPS, nikakav problem. Normalna stvar.
Staro 30.03.2022., 10:52   #2039
spawn
spawn's Avatar
Postovi: 8,459
Ja imam još veći bleed na benq 144hz monitoru, ne obraćam više pažnju jer mi je ok za oči dok radim na njemu. Jedino ne znam zašto kad ga isključim na dugmić i dalje ima bleed dokle god je spojen u utičnicu. Ali više ni to ne gledam
Staro 30.03.2022., 11:05   #2040
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,333
Mene zanima neš drugo, vidim da si na nV. Dakle upali si integer scaling u driverima i naravno prebaci scaling sa display-a na GPU i pliz mi reci kako ti onda igre izgledaju u FHD rezi. Jer navodno bi to na ovaj način trebalo izgledati identično kao da je taj monitor nativno FHD. Naime, 4k monitori su savršeni za integer scaling FHD reze jer je točno 4 puta viša reza.
Malo sam to napisao zbrda-zdola, ali si valjda shvatio. Baš me zanima jer bi to IMHO bila win-win situacija, igre an FHD ako stvaro izgledaju kako treba, a sve ostalo na 4k.
