Staro 07.02.2006., 00:26   #1
gbabic
doktor
gbabic's Avatar
Datum registracije: Sep 2004
Postovi: 73
Minimalna konfa za UT2004
Instalirao sam UT2004 i igra mi nevjerojatno trza na ovom mom kompu iz siga uz 640*480 i details low. Pa u čemu je problem, nije moguće da nemogu pokrenuti igru iz 2004.godine s kompom starim manje od godinu dana.
gogo
Gogo
http://seelo.blog.hr
___________________________
Abit NF7ver2.0, AMD Barton 2500+
512MB DDR
Sapphire AdvantageR9600Pro 128mb
gbabic je offline   Reply With Quote
Staro 07.02.2006., 00:31   #2
E.T.
E.T.'s Avatar
Postovi: 2,458
Nemoguce meni je radilo sasvim ok na:
-MSI Via KT333
-AMD Barton 2600+
-2x256MB DDR333
-Ti 4200 64mb
-80MB WD ATA133 7200rpm
A takoder igrao sam na sasvim Ok postavkama na laptopu sa Sempronom 3100, 256MB DDR, X300SE
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 07.02.2006., 00:53   #3
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Na kutiji piše:
CPU: Pentium or AMD 1.0GHz
Memory: 256 MB on Win XP
Video: Radeon 8000 or superior, GeForce2 or superior
psf[i]-[Tomek] je offline   Reply With Quote
Staro 07.02.2006., 01:13   #4
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Igrao na P3 667MHz, 384SD-RAM, Radeon 9000Pro 128DDR na high i nesto na low, 800x600, sa 25-30 fps... Isto ko i COD, COD UO i COD2 dx7 na tom kompu...
Tebi fakat nebi smjelo stekat na kom kompu...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 07.02.2006., 02:22   #5
gbabic
doktor
gbabic's Avatar
Postovi: 73
a znam i ja da nebi trebalo štekati, ali eto.
gogo
seelo.blog.hr
Gogo
512MB DDR
Staro 07.02.2006., 12:15   #6
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
gogo blogeru, aj malo smanji sig. Može?
Staro 07.02.2006., 14:26   #7
reboot
Lokacija: Zgb
Postovi: 1,108
meni je isto odlicno radilo na laptopu. 128 shared grafike, 512 rama i AMD 1.6 turion.
zapravo to je jedna od najboljih grafika koju sam vidio na svojem laptopu.
reboot je offline   Reply With Quote
Staro 09.02.2006., 13:38   #8
gbabic
doktor
gbabic's Avatar
Postovi: 73
Odinstalirao stare drivere, stavio nove Catalyst 5.13, maknuo rezidualne programe, povećao virtualnu memoriju na 1536mb... i dalje trza čim se pojave likovi na sceni. Ne trza konstantno nego taman onda kad nekog naciljam i poželim ga ubiti, onda mi se izmakne nišan i najčešće završim mrtav.
Gogo
512MB DDR
Staro 09.02.2006., 16:05   #9
S][R_KILL@LOT
Power Ranger
S][R_KILL@LOT's Avatar
Postovi: 58
otvori task manager pa reci koliko procesa imaš upaljenih...
i namjesti si detalje tekstura u igri na medium...
MSI i865 NEO2 - F1SR2
Pentium 4 2,6 HT @ 3,54ghz (273 FSB) - Coolermaster JET 4
2x512mb RAM DDR 433 Kingmax 2.5-3-3-6
Gigabyte 6800NU 16/6@ 415/880 - moddan Heatpipe pasivnjak
Hiper 4S525 PSU - 525W - Triple Fan
www.hcl.hr
S][R_KILL@LOT je offline   Reply With Quote
Staro 11.02.2006., 13:35   #10
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
1027x768 @ high details
pogledajte konfu tržnica=>procjena PIII konfa
sa 30fps ziher (još k tome grafa nije clockana)
terminator je offline   Reply With Quote
Staro 12.02.2006., 18:01   #11
gbabic
doktor
gbabic's Avatar
Postovi: 73
iman 46 aktivnih procesa, ali mislim da nije u njima problem, već sam pokuša pogasiti sve šta se pogasiti da. texture su mi na low.
Gogo
512MB DDR
Staro 12.02.2006., 18:26   #12
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
pa puno je to... ja imam 27 sa uključenom operom, winampom i trillianom
Staro 12.02.2006., 18:29   #13
Hrconja
Hrconja's Avatar
Postovi: 1,626
omg, to ti je do veze onda
al ako i u SP tako lagaš, problem je u windowsima.
Reinstall maybe?
Hrconja je offline   Reply With Quote
