Staro 16.08.2004., 23:52   #1
elvis
elvis's Avatar
Datum registracije: Aug 2003
Lokacija: %
Postovi: 465
AMD konfiguracija ~6500 kn
MBO: EpoX 8RDA3+, nF2 400, DDR, sound o/b, Dual LAN, FW, S-ATA (683,00 kn - Links)
CPU: Athlon XP Barton 2600+, 1917MHz, 512kB c., FSB 333 (635,29 kn - Diskont24)
COOLER: Arctic-Cooling Copper Silent 2 TC rev 2.0 SE (112,32 kn - Links)
RAM: 2*256MB DDR PC3200, 400MHz, G.E.I.L Value (894,56 kn - Links)
HDD: 120GB Seagate, 8MB c., 7200, SATA (713,26 kn - Info-gama)
GRAFIČKA: Gigabyte Radeon 9600 Pro, 128MB DDR, DVI, TV-out (1014,05 kn - Ve-mil)
CD/DVD: CD-RW/DVD LiteOn 48x/24x/48x/16x (258,68 kn - MDS)
FDD: 1.44MB, 3.5", Samsung (42,08 kn - Diskont24)
KUĆIŠTE: Chenbro Gaming Bomb (290,62 kn - Links)
PSU: Chieftec Delta 350W, 12cm, ATX2 (380,89 kn - Links)
MONITOR: 17" Samsung SM797DF, 96kHz, 0.20mm, Dynaflat (1287,19 kn - HG Spot)
MIŠ: Logitech B58, optički (98,32 kn - Links)
TIPKOVNICA: Logitech Deluxe (74,13 kn - Links)
6553,49 kn
===U konfiguraciju nisu uključeni modem, zvučnici, printer i slične periferije zbog različitih potreba/uvjeta/želja===
Zadnje izmijenjeno od: elvis. 29.08.2004. u 23:12.
elvis je offline   Reply With Quote
Staro 29.08.2004., 23:04   #2
elvis
elvis's Avatar
Lokacija: %
Postovi: 465
IZMJENA 29.08.2004.
MBO: EpoX 8RDA3+, nF2 400, DDR, sound o/b, Dual LAN, FW, S-ATA (664,76 kn - Ve-mil)
RAM: 2*256MB DDR PC3200, 400MHz, Supertalent CL2 (714,80 kn - Ve-mil)
HDD: 120GB Seagate, 8MB c., 7200, SATA (690,87 kn - Diskont24)
GRAFIČKA: PowerColor Radeon 9600 Pro, 128MB DDR, DVI, TV-out (919,76 kn - Links)
CD/DVD: Nec ND-2510, 8x, Dual Layer DVD+-RW, (598,00 kn - Links)
6509,03 kn
Staro 03.10.2004., 15:52   #3
elvis
elvis's Avatar
Lokacija: %
Postovi: 465
MBO: EpoX 8RDA3+, nF2 400, DDR, sound o/b, Dual LAN, FW, S-ATA (647,71 kn - Diskont24)
CPU: Athlon XP Barton 2600+, 1917MHz, 512kB c., FSB 333 (713,75 kn - Ve-mil)
COOLER: Cooltek CT8C-48 Cu, s.A/370/478/754 (180,05 kn - Links)
RAM: 2*256MB DDR PC3200, 400MHz, CL2, SuperTalent (756,54 kn - Ve-mil)
HDD: 120GB Seagate, 8MB c., 7200, SATA (691,41 kn - Diskont24)
GRAFIČKA: Sapphire ATI Radeon 9600 Pro Advantage, 128MB DDR, DVI (769,24 kn - Links)
DVD/RW: DVD+-R/RW NEC ND-2510, 8x Dual Layer (558,14 kn - Diskont24)
FDD: 1.44MB, 3.5", Sony (39,63 kn - Diskont24)
PSU: Chieftec Delta 350W, 12cm, ATX2 (321,18 kn - Links)
TIPKOVNICA: Logitech Deluxe (69,0 kn - Links)
DOD.VENT.: Enermax 8FAB, 80mm (69,10 kn - Links)
6493,61 kn
Staro 18.11.2004., 04:46   #4
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
ja bi stavio 2500+ , Spire Falcon Rock 2 , 80GB SATA, 9550 128Mb 128bit....i onda bi gore stalo 2x512Mb nekog najjeftinijeg rama
Staro 08.06.2005., 13:01   #5
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
za 6500 se moze slozit pristojna 64 bit konfa
pa evo imam jos 2 sata do skole...i idem malo pomoc,objasnit i pokazat kako onima kojima treba
pa ajmo:
cijene su jako pale,oc je prakticki za investiciju od 3000 kuna za jednog amd 64 i dobrom plocom jeftin,jak,brz,i najvaznije moguc za nadogradnju...pa s tim dobis proc koji ide bez problema na 3 ghz(da napomenem to je preko 5000+) i radi kojih 8000 MB/s
a ovo bi bile komponente(samo cu radit kantu dakle + monitor i periferije,dvd,dvd rw ne smatram periferijama nego muss,barem dvd combo)
CPU AMD Athlon64 3200+, 2.0GHz, 64bit, L2 cache 512kB, socket 939, BUS 800MHz, winchester 1250 kuna info gama
mbo dfi lan party ut nf4 sli-d, ddr, zvuk, s-ata, fw, 2xg-lan, pci-e, s. 939 links 1436kn
Arctic Cooling Freezer 64, Socket 754/939/940 137 adm trade
2x DDR RAM 512Mb PC3200 , 400MHz, SuperTalent , CL2, 3 godine jamstva, pasivni hladnjak adm trade 1000kn
hdd 160.0 gb hitachi, serial ata ii 8 mb cache, 7200, deskstar gst t7k250 adm 658
Gainward GeForce 6600 GT, 256Mb, Dvi, Tv out, Pci-e 1615 m-computers
kucište coolermaster centurion 5, silver, cac t05, midi, bez ps links 333kn
dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk links 389kn
dvd rom toshiba 16x 48x, black, sd-m191t, bulk links 157kn
napajanje tagan 420w, super silent, tg420-u02 i-xeye, aut.reg.brzine, atx2 v2.0 600 kuna links
6600 kuna sve skupa...naravno ak ti netreba dvd njega izbacis...kuciste podrzava a venta 120 i 80 mm ventovi,koji zatvaraju tunel koji doslovno sve provjetrava...razlika izmedu dream weawa(isto kuler master po 900 kuna) i centuriona 5 je 1° dakle jako dobro napravljeno
ako sam negdje nes zaboravio,ili pogrijesio...ispravite me
blup
mc_fish je offline   Reply With Quote
Staro 11.08.2005., 01:32   #6
E.T.
E.T.'s Avatar
Postovi: 2,458
Dakle update:
MBO: mbo gigabyte k8nf-9, nforce4, zvuk, g- lan, s-ata, fw, pci-e s. 939 (696Kn Links)
CPU: AMD Athlon64 3000+TRAY, 1.8GHz 64bit,L2 cache 512kB,socket 939, 800MHz,0,9µ, Venice (989Kn Info-gamma)
COOLER: ARCTIC COOLING, Freezer 64 (socket 754/939/940) (157Kn Links)
RAM:2xDDR 512MB(1Gb) PC3200, CL2, SuperTalent (922 Kn - Ve-mil)
HDD:HDD 80.0 GB HITACHI, Serial ATA II 3.0, 8 MB cache, 7200, Deskstar GST 7K80 (426Kn - Links)
GRAFIČKA:vga pci-e leadtek px6600gt td, geforce pcx 6600gt, 128mb, dvi, tv (1337Kn - Links )
DVD-RW: DVD+RW/-RW/RAM LG GSA-4163BB, Dual Layer, 16x, bulk (365Kn - Ve-mil)
FDD: 1.44MB, 3.5", Sony (40 kn - Diskont24)
KUĆIŠTE:Chieftec midi tower BG-01B-B-SL, bez PS (359 Kn - Ve-Mil )
PSU:napajanje chieftec 410w, 12cm vent., atx2 ver 2.0 (342 Kn - Links)
MONITOR:Mon. LG T710B 17" ezFlatron(788 Kn - Links)
MIS:Logitech B58 crni, opt.miš s kotačićem, USB/PS2 OEM (94 Kn - Ve-mil)
TIPKOVNICA: Logitech Deluxe Keyboard, black, HR, OEM, PS2 / 967447-0xxx (65 Kn - Ve-mil )
UK=6580Kn
Zu bi dobro dosli jos jedan Toshiba DVD za oko 150Kn i eventualno umjesto LG monitora Samsung 795MB (933Kn) ali financije to nisu dopustile..
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 22.08.2005., 16:28   #7
Dawar
OMG, thats the funky shit
Dawar's Avatar
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Amd Athlon64 2800+, Fsb 800Mhz, Socket 754 (738kn Nitel)
Cooler ZALMAN CNPS7000B-AlCu, socket A/370/478/754/939
232,13 217,32
MBO ASUS K8N4-E Deluxe, nForce4 4x, DDR, zvuk, S-ATA, LAN, PCI-E, s. 754
776,36 726,81 (links)
Leadtek GeForce 6600 GT, 128Mb, Dvi, Tv out, Pci-e (1307kn Info-Sim)
SuperTalent DDR 1Gb, 400Mhz, Dimm 184pin (861kn Info-Sim)
Hitachi 160GB, 7200Rpm, Sata150, 8Mb Cache, S-ATA (646kn Tri Trade-ADM)
Samsung SM795NF, 17", 1600x1200@68 Hz (889kn Analogbit)
Kućište,AHC,ET-5,ALIEN,ATX,midi,crno/žuto
293,90 278,91 (MAXMODUS)
Napajanje CHIEFTEC 410W, 12cm vent., ATX2 ver 2.0
364,64 341,37(LINKS)
Tipkovnica + miš Logitech EX 100
335,08 313,69(LINKS)
DVD ROM TEAC 16x 48x, black, DV-516D, bulk
218,94 204,97(LINKS)
Sve ukupno je oko 6520kn
Dawar je offline   Reply With Quote
Staro 22.08.2005., 17:14   #8
Apollo
Cmdr. Lee Adama
Apollo's Avatar
Postovi: 47
Samo mali prijedlog za plocu. Epox 8NPAJ bi trenutno bila najbolja nf4-4x ploca za s754. U VeCe-Milu.
Apollo je offline   Reply With Quote
Staro 22.08.2005., 17:23   #9
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
hahahahahhahahahahahahahhahahaha
epox je tolko pao s kvalitetom da s emoze svrstat u matsonic asrok itd kategoriju...epox nejde u moju konfu dugooo jos...katastrofa kaj su poceli radit...a najbolja s754 ploca je jos uvijek dfi lanpparty nf 3
blup
Staro 22.08.2005., 17:39   #10
Apollo
Cmdr. Lee Adama
Apollo's Avatar
Postovi: 47
Ccccc... Samo ti pljuj po Epoxu. Imali su veliki zajeb sa jednom serijom ploca gdje su stavili kineske kondice ali od tad samo japanski idu gore. Cak dobis garanciju da su japanci gore. )) A nF4U ploca im je jako dobra kolko reviewi kazu. Mislim Epox je uvijek bio zakon za OC. Zato sam ga preporucio. U vezi DFIja se slazem, al da malo upotrijebis vezu oci-mozak shvatio bi da je rijec od PCIe s754 plocama. ))
Staro 22.08.2005., 18:03   #11
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ne smijem se i nije jedna serija neg sve...to ak su poravili ok...pogledat cu...ps nisu bili samo konici u banani...vec i zavojnice, regulacija itditd...
blup
Staro 03.09.2005., 23:25   #12
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Imao Epox KT333, pa sad Nforce4, ne kužim o kakvim problemima se priča je su obje ploče ultra stabilne
Staro 04.09.2005., 13:09   #13
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
extremni klokovi su tabu...a to je lose tj nemres izvuc sve iz proca a i kondici su za q...epox nije vise za entuzijaste!!!
blup
Staro 04.09.2005., 15:12   #14
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Ja sam svoj xp1700+ prilično dizao na EP-8K3A+ ploči, sve negdje do 13x166MHz.
Ovu novu doduše nisam isprobavao, nisam više toliki ljubitelj OC-a, a i ne treba mi zasad (ali vjerojatno hoću jednog dana, pa javim ovdje dokle ide )
jedino se slažem za kondenzatore, na obje ploče su Sanyo, a ta firma mi nekako nikad nije bila srcu prirasla
Staro 04.09.2005., 15:40   #15
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
tako je al nije to jedino kvaliteta komponenata je podbacila...to je za stok i to je to...jer bi ju ince ubilo(a nisam ni siher da ju nebi stok)
ma stari epox je mrcina...i volim taj zeleni pcb ipak sam partyaner...al nove ne spasava niti pcb
blup
Staro 21.11.2005., 13:33   #16
windfucker
..i ja imao sr... sa Epoxovim driverima na CD-u,zezali mi SATA instalaciju...ne samo da im je hardware upitan...al'dobroooo,nekaaa...
Staro 04.12.2005., 12:52   #17
sholky
sholky's Avatar
Postovi: 263
Slazem jednom frendu konfiguraciju u ovom cjenovnom rangu, i imam nekoliko pitanja...
Konf. bi izgledala:
Athlon 64 3000+, venice jezgra
Gigabyte K8N-SLI
2x 512 MB Kingmax 433 MHz SuperRam
Maxtor 160 GB hdd
Pioneer dvr-110BK przilica
AG Neovo F-417 monitor
To plus shit kuciste, tipkovnica i mis dode ravno 6500 kn u Ve-Milu
E sad pitanja:
1. Na Gigabyteovom siteu na listi podrzanih procesora za ovu plocu nema Athlona 3000+ sa venice jezgrom!!!
Je li to neki njihov propust ili stvarno taj proc nece radit s tom plocom?
:confused:
2. KingMax memorija i Gigabyte ploca, slazu li se??
Da ne ispadne da je memorija ispravna, ali ne radi najbolje s tom plocom...
3. Monitor - u Ve-milu ima milijun 17 incnih lcda za 2k kn, ovaj sam vec vidio na djelu i izgleda ok, iako je stariji model. Je li neki drugi mozda bolji (za istu cijenu)?
sholky je offline   Reply With Quote
Staro 04.12.2005., 21:55   #18
E.T.
E.T.'s Avatar
Postovi: 2,458
1. Stvar propusta jer na tu plocu idu i X2 procesori...
2. Ne bi trebao imati problema..alternativno mozes uzeti:
-2xDDR 512MB PC3200 (400MHz), CL2, SuperTalent
IMHO bolji izbor ali i 100Kn(2x50) skuplji
3. Ne, ne i nikako ne...osim ako trazis uredski monitor,a i tada ne! A i samo ti ime kaze AG NEovo
Igranje na ovom monitoru je nanosenje boli!
Rezime ponude 17" LCD-a iz ve-mila u pogledu igranja (jer za office su svi vise manje ok a za profesionalni rad ici ispod 3k Kn je malo neozbiljno):
Najbolji izbor je: Samsung LCD SM730BF 17", DVI za 2673 Kn
Poslje njega LG-jevi konkurentne cijene, pa zatim Samsung SM710N pa tek onda AG Neovo i Acer koji imaju uzasan kut gledanja i po svojim karakteristikama ne mogu parirati LG-u i Samsungu!
Staro 16.12.2005., 21:35   #19
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
molim vas može li mi netko prokomentirati konfiguraciju i možda sugerirati bolju opciju.
molim vas preporučite mi jednu dobru matičnu ploču a da joj se cijena kreće oko 1000kn.
Je li dobra grafička Leadtek PX6600GT TD
Leadtek Win Fast A6600GT (GeCube Radeon x800gt)
Seagate Barracuda 120GB NCQ 7200 okr/min 8MB cache S-ATA150
Nec DVD RW +/- ND 3550ABL dual crni
AMD Athlon 64 3200+ Venice, 512KB, Socket 939 BOX
Samsung 17" SM795DF Dyna Flat
FDD 1.44 MB ALPS/NEC
CODEGEN midi tower 6216-CA, 400W P4, USB+FAN, crno-srebrno,
MB GIGABYTE K8N-SLI, Socket 939, NVIDIA nForce4 SLI, (Foxconn NF4UK8AA)
DDR 512 MB 184 pin, PC3200, 400MHz, GoodRAM
LOGITECH Deluxe Keyboard, black, HR, OEM
LOGITECH b 58 mouse optical black, 3-button s kotačićem USB&PS/2 B58
Creative Labs Live! 24-bit zvučna kartica, bulk
LOGITECH zvučnici S-100, 2-set, crni, OEM
CPU AMD Athlon64 BOX 3200+sck939 // MB Gigabyte K8N-SLI s939 nForce4 SLI // Powercolor Radeon x800gt // 2x256 MB RAM // HDD Seagate 120 GB s-ata150 // DVD+RW/-RW NEC ND-3550ABL // Codegen midi tower 6205L-CA, 400W // Mon. Samsung SM793DF 17" DynaFlat // ASUS TV TUNER My Cinema P7131H Dual
blondie je offline   Reply With Quote
Staro 18.12.2005., 10:58   #20
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
preporucam ti SAMSUNG 730BF Matisse,
SAMSUNG 730BF Matisse, 17" TFT, 1280x1024, 300cd/m2, 600:1, 160°/160°, Response time 4ms (G to G) Worlds record breaking response time, the fastest monitor ever, Silver/Black, MagicTune, MagicBright 2, Analog/Digital, TCO'99, LS17BIDKSV The best monitor for gaming and multimedia.........2548 kn
Staro 11.01.2006., 09:57   #21
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Molim savjet uz konfu
Našao sam u Info-gami sljedeću konfu :
MB Socket 754
AMD Athlon64 3000+
512MB DDR RAM
VGA 256MB 9600PRO
HDD 160GB
ATX MIDI Tower 316-08, 400W
FDD 1.44MB
56K modem
Sound + LAN o/b
DVD±R/RW
Cijena je 3.193,00 kn
To mi treba za frendovog sina, naravno za igranje. Vrijedi li to tih para?
Staro 11.01.2006., 10:12   #22
atha
atha's Avatar
Postovi: 9,069
vrijedi, i sa 9600pro se da igrati, ali to ti je bez monitora i periferije opcenito.
___________
Just atha
x
Staro 11.01.2006., 10:26   #23
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Hvala za mišljenje, ostalo ionako ima od stare konfe. Idem dalje nastaviti šorati se sa Švabama U COD2
Staro 11.01.2006., 10:28   #24
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Mislim da bi nešto sa PCI-E ipak bilo dugotrajnije rješenje
Staro 11.01.2006., 18:42   #25
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Re: Molim savjet uz konfu
MB Socket 754
AMD Athlon64 3000+
512MB DDR RAM
VGA 256MB 9600PRO
HDD 160GB
FDD 1.44MB
56K modem
Sound + LAN o/b
DVD±R/RW
Kompjuter je OK, ali preporučam jaču grafičku, makar nauštrb npr diska, procesora ili pržilice, jer ako je komp za igru, onda mali neće bit prezadovoljan trzanjem. 9600 pro sa 256MB u pravilu ima sporiju memoriju!
Staro 12.02.2006., 17:40   #26
logoutster
Postovi: 1
Možete mi složiti konfu do 6000 kn, za ured i gaming. U cijenu, molim, nemojte uključiti monitor i druge periferije. AMD, po mogućnosti. Hvala
logoutster je offline   Reply With Quote
Staro 13.02.2006., 18:52   #27
E.T.
E.T.'s Avatar
Postovi: 2,458
Mozda nesto ovako:
-MB Epox 9NPA+ Ultra, s939, nForce4 Ultra, SATA, GLAN, FW
794 Kn
- CPU AMD Athlon 64 3000+ BOX, 512kb cache, socket 939
1250 Kn
-Powercolor Radeon X850XT PCIE, 256MB, TV out, DVI
2038 Kn
-2xDDR 512MB PC3200 (400MHz), A-Data,V-Data
701 Kn
-HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB
662 Kn
-DVD+RW/-RW/RAM LG GSA-4167BLB, Dual Layer, 16x, black, bulk
330 Kn
-NOVATRON midi tower CX9, srebrno-crno, bez PS
179 Kn
-Power Supply FORTRON 400W, ATX 2.0, HQ, PFC, 12cm fan
321 Kn
UK=6271 Kn
