Staro 14.01.2022., 10:05   #12811
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Autor deda.cro Pregled postova
Tih deklariranih 866 je teoretski max. u idealnim okolnostima. U stvarnosti ćeš postizati nekih 70% deklariranog maxa. Što dalje od routera i što više prepreka na putu od kompa do routera, to manje.
Glede ovog, odgovorili mi iz TP-Linka. Dost brzo čak.
Hello
The advertised 1.3 Gbps is the Link Speed or Negotiated speed on the physical layer, and actual 5Ghz Wi-Fi speed could be 40%-60% of the Link speed and also limited by speed comes from router. How to check the associated/link speed on a wireless client.
Archer T9UH adapter supports 802.11ac, and to get the 1.3Gbp= 3*433Mbps maximum Wi-Fi Link speed on 5Ghz, it needs to work at 3* MIMO & 80Mhz.
From your router model spec, it seems Fritz box modem supports 2* MIMO, so at best you should get 2*433Mbps WiFi link speed on 5Ghz.
If the link speed is 866Mbps, then your actual speed seems to be reasonable.
If Link speed does not reach 866Mbps, try to adjust Router 5Ghz settings to 80Mhz and see if that helps improve 5Ghz link speed.
Hope this helps clear things up.
p3r02d3r0 je offline   Reply With Quote
Staro 17.01.2022., 17:33   #12812
definho
definho's Avatar
Datum registracije: Nov 2010
Lokacija: /
Postovi: 171
prešao bih na A1, do kraja ugovora s Optimom ima jos 9 mjeseci, u 10. mjesecu 2022. ističe trenutni ugovor. koji je postupak prelaska na A1, hoće li prihvatiti otplatu penala ili generalno ništa ne mogu do 10. mjeseca, a da je isplativo?
Respect the Raise...!
definho je offline   Reply With Quote
Staro 18.01.2022., 11:18   #12813
Ante001
Datum registracije: Jun 2017
Postovi: 126
Autor definho Pregled postova
A gle mozes otic a penale ces morat platit sad s njima moras vidijet koliko, kod A1 pogledaj medu njihovim ponudama sto nude prije nego sto budes pregovarao, uglavnom ti ide 239kn za trio paket s time da kao novi korisnik imas pravo na promociju prvih 6 mjeseci za 1kn i cini mi se da nude 500kn bon u millera .
Jos im pise pod promociju na 6 mjeseci za nove korisnike
Ako korisnik u prvih 6 mjeseci trajanja promotivne ponude dodatno koristi i Osnovni TV paket i/ili Telefon
uslugu, navedeni korisnik ostvaruje pogodnost korištenja i tih usluga bez plaćanja mjesečne naknade, pri
čemu se navedena pogodnost primjenjuje maksimalno 6 mjeseci od datuma sklapanja ugovora za osnovnu
Internet uslugu, bez obzira na datum uključenja Osnovni TV paket i/ili Telefon usluge. Pojašnjenja radi,
isključenjem Osnovnog TV paketa i/ili Telefon usluge unutar prvih 6 mjeseci obveznog trajanja ugovora za
osnovnu Internet uslugu, primjena promotivne ponude na navedene isključene usluge se ne produljuje te
je nije moguće nastaviti koristiti u slučaju naknadnog uključenja Osnovnog TV paketa i/ili Telefon usluge.
Korištenjem Osnovnog TV paketa i/ili Telefon usluge bez plaćanja mjesečne naknade korisnik može
ostvariti pogodnost mjesečnog popusta u maksimalnom iznosu od 90 kn za Osnovni TV paket i 10 kn za
Telefon uslugu, pri čemu se dodijeljeni iznos popusta u pojedinom mjesecu obračunava razmjerno broju
dana korištenja navedenih usluga u tom mjesecu.
Ante001 je offline   Reply With Quote
Staro 18.01.2022., 16:38   #12814
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Pitanjce. Kolko vas ovdje ima Fritza 6660 u bridge modu i kaj ste dobili s time?
Odnosno, zašto je bio razlog za bridge, i koji je bio rezultat? I koji router imate u bridgeu?
Hvala!
Staro 24.01.2022., 17:42   #12815
Ziiky
Ziiky's Avatar
Postovi: 2,881
Upravo su me mamili na produljenje ugovora uz zadržavanje dosadašnje pretplate od 239kn. Nude povećanje brzine na 200/20 + 1 dodatni paket za tv + laptop onda2 za dodatnih 40kn mjesecno.
Dal mogu izvući štogod bolje?
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 24.01.2022., 18:03   #12816
Ante001
Postovi: 126
Autor Ziiky Pregled postova
Evo pa procitaj https://ssc.a1.hr/documents/10307706...=1629363679606
Staro 24.01.2022., 19:14   #12817
WindEmperor
Datum registracije: Aug 2011
Postovi: 124
Jesu prestali nuditi 1Gbps preko kabela?
Vidim tu u temi netko kaze da im fali Frizboxa pa su trenutno ugasili ponudu, ali proslo je vec nekolino mjeseci i dalje 1Gbps nedostupan na adresama gdje je prije bilo dostupno.
WindEmperor je online   Reply With Quote
Staro 24.01.2022., 19:57   #12818
Marko :)
Datum registracije: Feb 2016
Lokacija: Unknown
Postovi: 721
Autor WindEmperor Pregled postova
Nisu. Ponuda još uvijek stoji u cjeniku što znači je dostupna i da ti je moraju dati na zahtjev.
https://ssc.a1.hr/documents/10307706...04.01.2022.pdf
Marko :) je offline   Reply With Quote
Staro 24.01.2022., 20:31   #12819
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,063
Autor Marko :) Pregled postova
Aj napiši na kojoj je to stranici cjenika jer isti ima 778 stranica
Staro 25.01.2022., 02:43   #12820
Marko :)
Lokacija: Unknown
Postovi: 721
Autor bertone Pregled postova
140. stranica. Ali možeš i upisat u tražilicu mozaik fiksna ponuda i doć ćeš do ponude.
Staro 25.01.2022., 10:33   #12821
bertone
bertone's Avatar
Postovi: 2,063
Hvala
Staro 25.01.2022., 11:51   #12822
p3r02d3r0
p3r02d3r0's Avatar
Postovi: 522
Nisu. Meni 1Gbps nije ni bio raspoloživ preko weba, ali sam ih pitao telefonski može li, i rekli da može.
Staro 25.01.2022., 12:52   #12823
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Ima li netko sa foruma da radi u A1 da mi se javi i da sebi piše jednu prodaju (o mobilnoj tarifi je riječ)? Hvala
žmnpp
Staro 30.01.2022., 18:04   #12824
AndroiOs
AndroiOs's Avatar
Datum registracije: Jan 2018
Lokacija: KA
Postovi: 599
imam tri broja na pretplatu a1 i sad prelazim s tcoma na fiksni i internet a1...bez tv-a
koliko bi to sve skupa bilo popusta u mozaiku...30 kn? 40 ?
AndroiOs je online   Reply With Quote
Staro 30.01.2022., 18:18   #12825
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,489
Nije ti jeftinije uzeti Bonbon? 55kn 3000min, 300 sms i 6Gb (+ prenosiš Gb iz prethodnog mj)
Staro 30.01.2022., 19:37   #12826
Marko :)
Lokacija: Unknown
Postovi: 721
Autor AndroiOs Pregled postova
Slagalica paketa ti je ovdje:
https://www.a1.hr/privatni/mozaik/slagalica-paketa
Staro 30.01.2022., 19:58   #12827
SPLiFF
SPLiFF's Avatar
Postovi: 2,114
Autor Ag008 Pregled postova
Kako to možeš dobiti za 55kn?
Staro 30.01.2022., 20:09   #12828
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Autor SPLiFF Pregled postova
link
Trenutno i mene zanima jel ovo još uvijek vrijedi...
njuskalo je offline   Reply With Quote
Staro 30.01.2022., 20:10   #12829
Lika091
Lika091's Avatar
Lokacija: Zagreb - Brinje
Postovi: 843
Pretplata i aktiviranje kombinacije za 55kn.
Još uvijek vrijedi. Požurite
Poslano sa mog SM-A528B koristeći Tapatalk
Staro 31.01.2022., 16:06   #12830
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Ne vrijedi više, cura je danas provjerila. Kažu da nemaju akcije koja nije na web-u. Tako da tko je jamio jamio...
edit: ovih zadnjih par postova nema veze s A1, možda prebacit u bonbon temu?
Zadnje izmijenjeno od: njuskalo. 31.01.2022. u 16:59.
Staro 31.01.2022., 16:41   #12831
Ag008
Ag008's Avatar
Postovi: 7,489
Ima ta ponuda
Na pisani zahtjev moraju aktivirati jer u cjeniku je još aktivna
Staro 31.01.2022., 17:04   #12832
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Ima ta ponuda
Di u cjeniku? Ja ne vidim. Jel ima još neki cjenik osim ovdje?
Staro 31.01.2022., 17:49   #12833
Ag008
Ag008's Avatar
Postovi: 7,489
Staro 31.01.2022., 23:33   #12834
jucca
jucca's Avatar
Postovi: 1,703
Jel probao ko mjenjati rezoluciju na Kaonu 4K (4020)?
Izgleda da sam uoravo ubio jednoga.
Promjenio umjesto 4K na 1080 tako da mi TV radi upscale, i nakon toga ne mogu gledati bilo koji program duze od 5-10sekundi, nakon cega izleti ova greska.
CS resetiranjem nije nista uspio, pa sad cekam tehnicara za zamjenu STB.a
Sent from my SM-G986B using Tapatalk
Staro 02.02.2022., 23:28   #12835
jucca
jucca's Avatar
Postovi: 1,703
Autor jucca Pregled postova
Da quotam sam sebe.
Jucer zamjenjen STB, promjenio rezoluciju ispred tehnicara na 1080p da usprobamo, i to je radilo do veceras kad sam isao ukljuciti HDMI CEC, i ponovo ubio uredjaj. Vrti program par sekundi i onda izbaci gore navedenu geesku 🙈
Jel radi ovo kome? Znaci 1080p i HDMI CEC ukljucen?
Staro 02.02.2022., 23:30   #12836
bertone
bertone's Avatar
Postovi: 2,063
A da si uzmeš cam modul i izbaciš STB iz setup-a?
Staro 02.02.2022., 23:38   #12837
jucca
jucca's Avatar
Postovi: 1,703
Nema gledanja u rikverc onda, a mislim da ni VOD ne radi.
Staro 03.02.2022., 00:12   #12838
Postovi: 8,226
Ako mu je to prvi uređaj, onda ne daju modul.
Staro 03.02.2022., 12:31   #12839
bertone
bertone's Avatar
Postovi: 2,063
Pa ovako ne gledaš ništa
Autor Pupo Pregled postova
Pa tako je svima, nitko nije mogao uzeti cam modul, a da mu nisu dali i STB.
Nek si uzme modul pa će prek TV-a gledati programe trenutno, a STB nek ubija svaki drugi dan ako hoće,... ovako gleda crni ekran
Staro 04.02.2022., 00:54   #12840
jucca
jucca's Avatar
Postovi: 1,703
Rjeseno.
Postoji bug u firmeareu, koji ce biti rjesen u sliedecoj nadogradnji, gdje ce biti maknuta ova dolje postavka:
Postavke -> ostale postavke -> kvaliteta -> najbolje moguće
Kad se to odabere, propusta se sav "promet", pa kad se petlja po HDMI postavkama, ocito prodje neka komanda koja zblesi uredjaj. Vjerovatno ne sa svim TV/daljincima.
