Staro 09.02.2006., 19:38   #1
blozer
Doktor znanosti!
blozer's Avatar
Lokacija: Zg,Peščenica/borongaj
Postovi: 1,311
Question MB Gigabyte K8N51GMF9, s939 ili MB Albatron K8NF4X, s939, nForce4-4x
Ja sam inace naklonjeniji Gigabyte-u....Ali sto vi kazete?...
Prva ploca
Gotovina:530,18 kn
Opis
Model GA-K8N51GMF-9
Podržani procesori AMD Athlon64 X2/ 64 FX/ 64
Chipset NVIDIA® GeForce™ 6100 and NVIDIA nForce™ 430
Memorija 4 x DDR400/333/266 -184pin
Dual Channel podrška
4 GB maksimalno
Utori 1 x PCI-Express X 16 slot
1 x PCI-Express X 1 slots
2 x PCI slots (PCI 2.3 compliant)
I/O interni konektori 4 X Serial ATA 3.0Gb/s
2 x UDMA ATA 133/100/66 Bus Master IDE connectors
1 x FDD connector
2 x USB 2.0/1.1 connectors (4 porta)
1 x IEEE 1394b connector (1 port)
2 x cooling fan pin headers
S/P DIF in/out connector
CD in
1 x Com port connector
I/O eksterni konektori 4 x USB 2.0/1.1 ports
1 x RJ45 ports
Audio (4 x Line-out/ 1 x Line-in/ 1 x MIC) connector
PS/2 Keyboard/ Mouse
1 x IEEE1394 port
1 x LPT
1 x VGA port
1 x S-Video port (TV- out)
Napajanje ATX power connector and ATX 12V connector
Dimenzije Micro-ATX form factor (24.4 x 24.4 cm)
Ostalo VIA VT 6307 IEEE1394 controller
CICADA8201 Gigabit LAN PHY chip
Realtek ALC880 Audio Codec
2. ploča
MB Albatron K8NF4X, s939, nForce4-4x, SATA, LAN
Gotovina:486,78 kn
Opis
Model K8NF4X
Podržani procesori Socket 939 AMD Athlon™64 / Athlon™64 FX /Athlon™64 X2 Dual Core Processor
800/1000+ MHz FSB
Chipset Chip : nForec4 4X ( Single chip)
LAN Chip : Broadcom MCSAC131 (PHY) 10/100
Audio Chip : Realtek ALC655
I/O Chip: Winbond Smart I/O W83627THF
Memorija 4 × DDR400/333/266
Max. 4GB
Utori 1 x PCI Express x 16
3 x PCI Express x 1
IDE / SATA konektori 2 ATA133 Channels
4 Serial ATA150 Channels
I/O interni konektori 1 x Floppy Connector
4 x USB 2.0/1.1 header
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header (1 fan rotation detection function)
2 x System fan headers
2 x 5 pin system panel header (Intel spec)
1 x 3 pin Power LED header
1 x Front audio header (Intel spec)
1 x ABS header
I/O eksterni konektori PS/2 keyboard/mouse
2 x USB(2.0/1.1)
RJ45
1 x Com (serial)
1 x Parallel
1 x RCA
1x Line-in/Line-out(Speaker Out)
Napajanje ATX (24-pinski konektor), ATX12V
Dimenzije ATX (293 x 198 mm)
Ostalo Zero Jumper Design
Adjustable CPU frequency by 1 MHz increment, Adjustable Vcore,,VMemory for overclocking.
Watch Dog Timer (auto-reset system when it can not handle overclock configurations)
Special design for CPU Over Temperature Protection. (OTP)
I sto kazete koja je bolja??
Hocu sto manje para potrositi pa ciljam na jeftinije (
ali kvalitetno)...
A posto gigabyte-ica ima integriranu grafu.. nebi morao pare i na to trositi...I kaj velite??
blozer je offline   Reply With Quote
Staro 10.02.2006., 07:45   #2
stiv haris
stiv haris's Avatar
Lokacija: ri
Postovi: 42
ako se ne misliš ozbiljnije igrat i ne zanima te klokanje bolji izbor ti je gigabajtica......
opremljenija je, ima sata2, fajrvajr i giga lan, i integriranu grafu....
s druge strane albatronka se izvrsno kloka........
stiv haris je offline   Reply With Quote
Staro 10.02.2006., 10:32   #3
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Provjeren!
psf[i]-[Tomek] je offline   Reply With Quote
Staro 10.02.2006., 10:47   #4
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Re: MB Gigabyte K8N51GMF9, s939 ili MB Albatron K8NF4X, s939, nForce4-4x
ali kvalitetno)...
A posto gigabyte-ica ima integriranu grafu.. nebi morao pare i na to trositi...I kaj velite?? [/B]
Gigabyte, zvuči lijepo, dobro, jeftino, ali...
pročitaj
Staro 10.02.2006., 11:23   #5
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,910
Gigabyte je smece,ja sam svoju morao reklamirati,albatron definitvno
Staro 10.02.2006., 15:43   #6
flajpan
flajpan's Avatar
Postovi: 1,796
Uglavnom je šrot, ali ako ti se posreći možeš dobit neku koja će radit kak treba. Bolje dodaj 150-200kn pa kupi poštenu matičnu.
Staro 10.02.2006., 17:28   #7
Thoroughbred B
Lokacija: RI
Postovi: 4,910
Tako je,ali fakat sam citao na netu kada sam osobno imao problem s K8NSC Nforce 3 da jako puno ljudi ima velike probleme s maticnom.
Albatron NF4 radi kao zmaj,nacitao sam se hvaljenja o ploci pa sam na kraju i kupio jednu,tj preporucio je dobrom frendu,znam skocit do njega tu i tamo i ploca je rock stable i bez ikakvih simptoma bolesti,a mali sempron je uspjesno klokan na 2500Mhz,sve u svemu Albatron je napravio odlicnu plocu za tu cijenu!
Staro 11.02.2006., 01:24   #8
Wild Boy
Lokacija: Beograd
Postovi: 6
A koliko samo ljudi ima problema sa DFI plocama...
Ne mozes samo na osnovu svog slucaja i slucaja nekolicine ljudi reci da je Gigabyte smece...kada napises zasto je neka ploca smece onda napises i zasto to mislis da covek ne ostane u zabludi...a ja iz mog iskustva mogu kazem da sam Gigabyte plocama vise nego zadovoljan
Wild Boy je offline   Reply With Quote
Staro 11.02.2006., 01:32   #9
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
problem je u tome kaj ploce kao takve nisu smece, al BIOS-i su jako lose napravljeni i tim cine ploce losima...
Ne govorim, al osim sto je tu na forumu bilo prica o tome, o gigabytu i njihovim biosima, sam sam se uvjerio u 2-3 ploce na kojima nije memorija radila normalno...ponekad radi, al u vecini slucajeva radi sporije neg sto treba...
Staro 11.02.2006., 12:16   #10
Thoroughbred B
Lokacija: RI
Postovi: 4,910
Upisi u google K8NSC Nforce 3 problem,ili vidi po stranim forumima koliko ljudi ima problema s navedenom plocom,ne kazem za ostale ploce,ali K8NSC je totalni antireklamni proizvod
Staro 12.02.2006., 00:32   #11
flajpan
flajpan's Avatar
Postovi: 1,796
Zato sam i dao link da čovjek i sam vidi, iz iskustva drugih ljudi, zašto ta ploča nije dobra. Sam sam naručio jednu Gigabyte, ali se nadam da će radit dobro, no to ću tek saznati za oko mjesec dana. Radi se o ovoj ploči
Staro 12.02.2006., 00:42   #12
Thoroughbred B
Lokacija: RI
Postovi: 4,910
bravo,upravo tu plocu hvalim
