Staro 18.11.2021., 08:57   #5311
Postovi: 34,001
Ujedno ukidaju polugodišnje update i prebacuju se na godišnje
https://blogs.windows.com/windowsexp...r-2021-update/
Staro 18.11.2021., 19:49   #5312
tiki66
tiki
tiki66's Avatar
Postovi: 2,746
Autor coconut Pregled postova
Odlično. Očekivao sam da će im nakon izlaska 11-ice splasnuti volja za desetkom, što je po meni i bolje jer manje će biti updateova koji imaju mogućnosti sprtljati pol sistema.
Staro 18.11.2021., 20:15   #5313
Dottore
Dottore's Avatar
Postovi: 7,664
Win 10 21H2 je vani
https://www.microsoft.com/en-us/soft...load/windows10
MS Windows 10 November 2021 Update https://go.microsoft.com/fwlink/?LinkID=799445
MediaCreationTool21H2: https://go.microsoft.com/fwlink/?LinkId=691209
What’s New in Windows 10’s November 2021 Update
https://www.howtogeek.com/714485/wha...g-winter-2021/
Hvala, ažurirao na USB.
Staro 19.11.2021., 15:24   #5314
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
jel ima jos neko problema sa sleepom od apdejta prije ovog?
znaci ako mi laptop (asus zenbook), ode u sleep, vise se ne moze dici, power button svijetli, a ekran mrtav... i onda ga moram ugasit i ponovno upalit. ni zadnji apdejt to nije rjesio. a prije zadnja 2 apdejta radilo najnormalnije...
slow is smooth, smooth is fast...
santos je offline   Reply With Quote
Staro 23.11.2021., 17:17   #5315
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,625
When BleepingComputer asked Naceri why he publicly disclosed the zero-day vulnerability, we were told he did it out of frustration over Microsoft's decreasing payouts in their bug bounty program.
"Microsoft bounties has been trashed since April 2020, I really wouldn't do that if MSFT didn't take the decision to downgrade those bounties," explained Naceri.
Naceri is not alone in his concerns about what researchers feel is the reduction in bug bounty awards.
Under Microsoft's new bug bounty program one of my zerodays has gone from being worth $10,000 to $1,000
New Windows zero-day with public exploit lets you become an admin
kopija je online   Reply With Quote
Staro 24.11.2021., 15:47   #5316
Hombre
Datum registracije: Jan 2011
Lokacija: Ploče
Postovi: 283
Najmanje 99,9% korisnika računala na svijetu koristi ih na poslu i to najčešće za pisanje.
Kod kuće neki nešto napišu, stave porodične i ine fotografije, odu na neku društvenu mrežu, kupe nešto preko Neta, pogledaju film za odrasle, rezultate klađenja, youtube, email, plate račene net bankingom i... nadopiši po želji.
Baba roge oko virusa, ransomwarea i ostalo ne brinu previše prosječnog građanina svijeta niti čita kojekakva upozorenja oko ovog ili onog. Hrvatskog prosječnog usera ne brine ni mogućnost da ga netko orobi preko kartice jer je u kronično dubokom miusu i onaj tko bi ga htio opljačkati prvo bi trebao pokriti minus. Bugovi u OS su važni samo ako nešto ne radi i onda se zove prvi koji se razumije u to, po mogućnosti besplatno. To ti je ko veliki mobitel i sve više ih koristi mobitel u te svrhe. Kupio prijatelj Nikona s dva dobra objektiva za 1000EU, kažu u trgovini da se foto aparati sve manje prodaju, zamijenili ih mobiteli, kad se nekome svane drugome se smrkne.
Kada šetaš parkom ne misliš hoće li ti otrovnica pasti na glavu, oko tebe se oviti udav, iza nekog grma izači medvjed i pretvoriti te u puzzle, hoće li u snježnom parku za tobom juriti čopor gladnih vukova...
Ipak ima onih koje sve to pa i gore i te kako muči, svaka druga slika u ruralnim dijelovima Afrike (i oni imaju mobitele) tip nosi Kalašnikov, žena na polju pri ruci Kalašnjikov, momak grli djevojku, a u drugoj ruci Kalašnjikov.
Važno je što radiš i gdje se krećeš. Ja kliknem na ikonu fotografije da se otvori pa gledam dvije sekunde kako se otvara ta stranica, pa dvije neka druga, pa dvije neka treća i na kraju se otvori četvrta ali one dvije koje su pregazile prvu uredno otvorene. Jednom sam u Firefoxu zatvarao preko 900 stranica s tim da sam ja otvorio nešto preko 200 dok se ostalo ukrcalo samo i još dodatno moraš kliknuti na Yes da je želiš zatvoriti.. Otvori ti se stranica koju hoćeš i još preko oka vidiš kako se gore u task naselila još jedna, sve crnjaci i lažnjaci. Nabavim Blocker pa kopiram ime stranice i stavim je na blacklist. Nakon dva minuta evo je ponovo jer ima sto adresa i ako ne ide s jednom hoće s dugom, trećom... dosadi čovjeku stavljati u blocker. Poslije svakog takvog surfanja iz predostrožnosti isključim računalo iz struje i Interneta, sačekam pola sata da se isprazni RAM i SSD pa onda puknem backup, a opet sam Backup imam na pet mjesta i držim sve u zatvorenom ormaru da kakva napaste ne preskoči na disk ako je blizu računala :-)
Imam jedan mikrić SSD od 240GB na koji sam klonirao boot disk.
Jedan u ruci nosi bocu Cole, drugi Kalašnjikov. Takav je svijet. Takav je život.
Hombre je offline   Reply With Quote
Staro 24.11.2021., 15:51   #5317
Postovi: 8,217
Mislim ono, bu hu, kad ti treba instalacijski medij i 2 komande da napraviš rewrite passworda od bilo kojeg usera na kompu, pa tako i admina.
Autor kopija Pregled postova
Staro 24.11.2021., 19:39   #5318
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,625
Enkriptiran mi disk.
Staro 25.11.2021., 03:23   #5319
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
ekipa,
ima kakav free backup software za W10. Službeni laptop m ide na reklamaciju pa zlu ne trebalo. Znači backup windowsa, instaliranih program a, pluginova (sve je licencirano) i svih user stavki (postavke programa, downloads, documents, ...)
Mozda se i dobije novi laptop na reklamaciji pa ne znam koliko to utjece na opcije.
Moze cak i biti placen ako bas mora. Ali da licencu imam sad ujutro
Hvala
Zadnje izmijenjeno od: Problem. 25.11.2021. u 03:55.
Staro 25.11.2021., 05:50   #5320
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,625
https://www.windowscentral.com/how-m...kup-windows-10
Naravno, na eksterni drive, za slučaj da dobiješ novi laptop.
Staro 25.11.2021., 08:02   #5321
tiki66
tiki
tiki66's Avatar
Postovi: 2,746
Moja preporuka je macrium reflect i napravi image cijelog diska, pa nakon toga možeš i još ovaj backup u Windowsima napraviti.
Staro 25.11.2021., 08:23   #5322
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,300
Acronis True Image (nije free ali radi mi vec godinama bez beda za cjeli Image diska)
Staro 25.11.2021., 19:39   #5323
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
za sada sam koristio inbuilt w10 alat, valda ce posluziti. Za ubuduce cu investirati u neki alat nek radi tipa tjedni backup. Moram priznati da do sada nisam previse razmisljao o toj problematici, a nije na odmet imati
Staro 26.11.2021., 03:59   #5324
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,625
To je to.
Za dnevni/tjedni backup Macrium Free FTW!
Staro 26.11.2021., 13:47   #5325
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,625
Acronis True Image koristim godinama, odličan softver.
virty je offline   Reply With Quote
Staro 27.11.2021., 09:10   #5326
Hombre
Lokacija: Ploče
Postovi: 283
Godinama sam koristio Macrium Reflect Free i radio je kako i treba raditi.
Kupio sam ga jer je bio jedan dan u godini jako povoljno.
Radim često backup jer mi je to navika s posla kada sam učio ljude korisnosti istog.
Kupiš neki SSD od 240 GB za sitan novac, napraviš clone i miran si.
Ako baš nisi megaloman sve što imaš stane na tih 240GB uključujući i ono što si pisao, crtao, snimao... u slučaju da imaš više uzmeš prijenosni HDD (ja koristim ladicu jer ih imam više) i ono što si radio ili snimao jednostavno presnimiš bez backup programa, staviš u sigurnu i suhu ladicu pa po potrebi uzimaš ili stavljaš.
Staro 28.11.2021., 11:14   #5327
Charlie Harper
YouTube Master
Charlie Harper's Avatar
Datum registracije: Oct 2020
Postovi: 59
Autor Problem Pregled postova
...free backup software za W10... backup windowsa, instaliranih programa , pluginova...
Backup fileova to kužim, no što je to backup instaliranih programa?
Ja sam do sad mislio da kod novih Windowsa moram krenuti opet sa instalacijom svih programa ispočetka...
Dakle, trebam imati instalacijsku verziju programa?
Recite slobodno; Charlie, to je zastarjela tehnika, sad se radi tzv. full backup, nije potrebna nova instalacija programa, nemaš pojma.
Bi'će mi drago to čut'.
Charlie Harper je offline   Reply With Quote
Staro 28.11.2021., 13:27   #5328
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,625
Charlie, to je zastarjela tehnika, sad se radi tzv. "Refresh", nije potrebna nova instalacija programa, nemaš pojma.
Staro 28.11.2021., 14:13   #5329
Warrior
Warrior's Avatar
Postovi: 1,015
Na toj stranici unutar Refresh poglavlja piše da briše sve aplikacije, a niže u tablici usporedbi piše da ne briše.
Ma sve je to zbunjujuće.
Full backup cijelog C: diska svako malo i amen.
Poslano sa mog Samsung S9+ koristeći Tapatalk
Everything is sooooo slow... Why? Oh, why?
Warrior je offline   Reply With Quote
Staro 29.11.2021., 12:24   #5330
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,809
EaseUS TodoBackup, besplatan i radi.
Staro 05.12.2021., 09:13   #5331
Hombre
Lokacija: Ploče
Postovi: 283
Ma svi rade.
Imam informatičko iskustvo od 1990. kada sam zbavio prvi 286.
Cijeli OS na jednoj 5,25 disketi. Kasnije su došle trake za backup, metalne kao mini video kasete spore do očaja. Sada par minuta i full backup gotov.
Backup se obavezno radi na drugom mediju koji je pohranjen van računala. Za one malo ozbiljnije dva medija pohranjena na različitim mjestima.
Što je najgore malo tko uči ljude sigurnosti, nauči te raditi, koristiti program, a ostalo plati njemu ili nekome da ti održava.
Staro 05.12.2021., 10:11   #5332
quazar912
quazar912's Avatar
Lokacija: north-northwest
Postovi: 1,979
situacija,
instalirao novi W10 na novi NVME disk no sad su mi ostali HDDi promijenili slovo iako njima nisam mijenjao SATA na matičnoj i sad Firestik više ne vidi te diskove (odnosno sadržaj).
S obzirom koliko je komplicirano natjerat Fire da očita SMB i sherane diskove mogu li zamjeniti mjesta SATAe diskovima kako bi dobio isti driveletter kak je bilo na starom W10?
...and fly...
Thule nosač
Staro 05.12.2021., 10:17   #5333
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,241
zar nemos promjenit drive letter u OS-u?
edit: nemam pojma sta je firestick pa mozda pisem gluposti.
Staro 05.12.2021., 10:23   #5334
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,012
Promjeni preko disk managmenta slova particija kako ti odgovara.
Sent from my GM1917 using Tapatalk
Staro 05.12.2021., 10:29   #5335
quazar912
quazar912's Avatar
Postovi: 1,979
ajd probam pa javim
@đeronimo - firestick onaj famozno hvaljeni IPTV i streamer za kućnu mrežu filmova/serija/muzike
...and fly...
Thule nosač
Staro 05.12.2021., 10:59   #5336
geronimo_2
geronimo_2's Avatar
Postovi: 4,241
skuzio.
odi samo ovo sto kaze kasno i problem solved.
control panel/computer management/disk management
Staro 06.12.2021., 10:44   #5337
chief_wolfinjo
kako u potpunosti isključiti update na win 10 ?
naime sada tu i tam se pojavljajuje onaj plavi prozorčić da trebam odraditi update...
a meni se neda to raditi, pa bih molio savjet.
tnx
Staro 06.12.2021., 11:19   #5338
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
https://wpd.app/
Iskljuciš ga pod Privacy i Blockers.
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 06.12.2021., 11:43   #5339
Charlie Harper
YouTube Master
Postovi: 59
A zašto bi ga isključivao, Chief?
To je jedan klik gratis, ide brzo i nemaš što podešavati, a osobno imam pozitivno iskustvo, Win 10 mi, čini mi se, bolje radi nego prije par mjeseci, nisu ni ti updatei bez veze.
Staro 06.12.2021., 11:51   #5340
chief_wolfinjo
zato što imam jedan slabiji komp kod kojeg bi taj update trajao satima...
dali se može bez programa ugasiti update ili ne ?
