Staro 18.03.2021., 09:32   #211
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
A da, ista stvar, reinstall je pomogao.
Ali baš to - 100 giga gluposti xD
Staro 13.07.2021., 10:06   #212
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,183
AI-assisted Call of Duty cheat for PC and console targeted by Activision
https://www.kitguru.net/gaming/matth...by-activision/
Call Of Duty Machine Learning Cheats May Already Have Activision's Attention
https://screenrant.com/call-duty-mac...ion-attention/
The cheat uses machine learning and sends input to your controller whenever it sees a valid target, this is aim assist but more amplified without you even needing to do anything all you have to do is aim in the general area and the machine will do the work for you.
Is this detectable? yes, but it will be a pain for the developers to detect this it will certainly not be an easy job to detect these types of cheats, this already exists on PC but now is available in consol.
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 13.07.2021. u 11:30.
Staro 13.07.2021., 13:42   #213
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
i sta reci....
slow is smooth, smooth is fast...
santos je offline   Reply With Quote
Staro 25.10.2021., 14:44   #214
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Da pitam ovdje, one koji igraju na PCu, naime prije nekog 2 tjedna počela mi je igra trzati.
CPU: AMD R5 3600
GPU: GTX 1080Ti
RAM: 2x16GB 3000MHz DDR4
Mislio sam da je do grafe, kupio novu RTX 3060 Ti, na kraju ista stvar, vratio grafu, jer mi je davala i 10% manje fpsa nego 1080 Ti.
Reinstalirao OS, promjeino RAMe, sve živo sam promjenio osim MBO i CPU.
Čitam po netu da se to i drugima događa, naime, igra kao da ima neki suttering ili trzuckanje od par milisekundi, što izludi čovjeka kad se dogodi usred akcije. Još neki frendovi su mi prijavili istu stvar, pa nekako daljnjim istraživanjem dolazim do zaključka da je možda da drivera ili su pak nešto ponovo syebali u igri. Da, znam da je bilo problema sa štekanjem menu-a, ali to su riješili, ovo je baš u igri. Izluđuje me.
Također, ono što me je jako razočaralo, Warzone sam počeo igrati na svom ASUS laptopu G751JY, i7-4710HQ, GTX980M 4GB, 32GB RAM, SSD. Probao ponovo igrat na laptopu, igra nije igriva više. Očito su toliko boostali igru i detalje i sve skupa zajedno, da sam stvarno razočaran. Još mi je uvijek igra bila najbolja prve 2-3 sezone, sad je svakakva, al yebga, nisam našao bolju.
MC
Staro 25.10.2021., 14:54   #215
picajzlaaa
picajzlaaa's Avatar
Datum registracije: Apr 2009
Lokacija: eu
Postovi: 789
Ista stvar, baš sam i ja o ovome nedavno htio tu napisati.. nova konfa (sve osim dobre stare 1080) ryzen 9, novi ram, m.2 itd.. i igra me počela rubber-bandati po mapi, trzati itd, samo nije u milisekundama, nego mi se zblesirana dobrih 2-3 sec. Doduše fps mi je veći ali jbg.. naporno do jaja, ponekad gotovo neigrivo.. mislim da do mog hardwera nije, u čemu je stvar, nemam pojma
picajzlaaa je offline   Reply With Quote
Staro 25.10.2021., 15:28   #216
The AC
The AC's Avatar
Postovi: 1,147
Meni se događa uvijek u prvom meču nakon pokretanja igre(mouse stuttering) . Nakon toga normalno radi. Isto tako je i frendu ali njega igra sama baca okolo, kontrole rade po svojoj volji a nakon prvog meča mu je sve ok. Također, i mi bi nes drugo igrali, ne toliko zbog bugova već zbog hrpetine cheatera ali nismo našli nes bolje još....
Staro 25.10.2021., 16:01   #217
picajzlaaa
picajzlaaa's Avatar
Lokacija: eu
Postovi: 789
Ovaj mouse stuttering je i buraz imao, kupio je još 8 gigi Rama pa mu je malo bolje.
Da zbog toga i cheatera, jedva čekamo bf42, WZ bacimo samo tu i tamo.
Ja sam se u međuvremenu malo vratio u Destiny 2 a kako je ta igra fluidna sa punim serverom, milion mobova, efektima, i k tome predivne mape i vizuali, milina u odnosu na WZ
Staro 25.10.2021., 18:37   #218
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Budam probao vidit za ovaj Mouse Suttering, to mi nije ni palo napamet...
MC
Staro 25.10.2021., 18:43   #219
The AC
The AC's Avatar
Postovi: 1,147
Pa probaj prvi meč odradit tak krnjavo i onda vidi u sljedećem dal ima problema. Eto, nama je stalno tako.
Staro 26.10.2021., 13:18   #220
santos
santos's Avatar
Postovi: 1,782
ja sam odavno skuzio da svakim sljedecim apdejtom usporavaju igru namjerno, samo gledas kako ti svakim sljedecim apdejtom igre padne po par fps-a....
tak da sam na kraju odustao.
presaltat cu se na novi battlefield i to je to.
Staro 26.10.2021., 13:52   #221
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 476
Autor Sa_Stilom Pregled postova
CPU: AMD R5 3600
GPU: GTX 1080Ti
Ja sam imao takve probleme prije nekih godinu dana, svasta zivo sam pokusavao i one neke postavke u configu, uglavnom nista nije pomoglo dok nisam promjenio neke postavke unutar same igre i odjednom je prestalo trzati. E sada koje su to postavke bile stvarno se ne sjecam probaj se igrati s tim postavkama pa vidi.
Silthrax je offline   Reply With Quote
Staro 26.10.2021., 14:09   #222
Postovi: 16,724
Meni je to ovisilo od update-a do update-a, zato sam i prestao igrati.
Staro 27.10.2021., 09:22   #223
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Svi igrate samo warzone? Nitko ne igra cold war? Ja samo tučem cold war i vrti se na konfi stvarno super. Veliki boost je bio novi proc, nisam ni znao koliko me Ryzen 5 2600 kočio...
Staro 27.10.2021., 09:23   #224
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Autor Silthrax Pregled postova
Ako se sjetiš, javi...
MC
Staro 27.10.2021., 12:27   #225
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,410
Ja samo Cold War
Staro 27.10.2021., 14:57   #226
picajzlaaa
picajzlaaa's Avatar
Lokacija: eu
Postovi: 789
Nope. Još da plaćam za poluproizvod...
Staro 15.11.2022., 23:34   #227
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,278
bumpam ovo, za 2.0 da se ovdje raspravlja
Staro 16.11.2022., 12:52   #228
Hrconja
Hrconja's Avatar
Postovi: 1,620
Navecer akcija krece. Budemo vidjeli jel valja
Hrconja je offline   Reply With Quote
Staro 16.11.2022., 13:14   #229
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Kak je moguće da igra u pre-loadu zauzima 19gb?
gin.tonic je offline   Reply With Quote
Staro 16.11.2022., 13:25   #230
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 476
Ima vec novi download od 24 gb.
Staro 17.11.2022., 03:39   #231
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,847
Hm, što bi sad ovo bilo?
Zasebna igra, ili dodatak za MW2..?
Pojma nemam, preskočio sam zadnjih preko nekoliko KaloDjutija
EDIT:
aha, sad vidim što je..
Ima li to uopće smisla igrati obzirom da je besplatno
(cheateri itd.)?
Staro 18.11.2022., 08:40   #232
axo
Datum registracije: Sep 2017
Postovi: 1,428
Autor fler Pregled postova
EDIT:
(cheateri itd.)?
Probaj pa prosudi sam
axo je online   Reply With Quote
Staro 18.11.2022., 09:35   #233
jucca
jucca's Avatar
Postovi: 1,689
Meni od sinoc ze vise ne zeli pokrenii igra uopce. Probao sam repair kroz Steam, ali nula bodova.
Sent from my SM-S908B using Tapatalk
Staro 18.11.2022., 09:56   #234
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,078
meni kroz battlenet radi ok
Staro 18.11.2022., 13:29   #235
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,847
Autor axo Pregled postova
Ah, pametovanje.. netko uvijek mora
Čemu služi ova tema i forum općenito,
ako ne razmjeni dojmova vezanih uz samu igru?
U jednom trenutku ću po svoj prilici i isprobati -
pitam čisto ima li smisla skidati desetke GB.
Staro 18.11.2022., 14:51   #236
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,278
pogledaj si na twitchu malo gameplay, ak te interesira, probas, ne kosta nista
Staro 18.02.2023., 16:21   #237
KixzoR
noob?
KixzoR's Avatar
Datum registracije: Jan 2011
Lokacija: Zaprešić
Postovi: 135
Imam pitanje zašto ova igra kod mene na i7 4790k,16gb ram,Gtx 1070 radi jedva na 40ak fps bilo sve na max ili na low?Ako netko zna odgovor?
KixzoR je offline   Reply With Quote
Staro 18.02.2023., 16:58   #238
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,048
Vjerojatno te koči proc
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 18.02.2023., 17:34   #239
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
nije pc ja igram na 4790 verziji ali nakon svakog updatea igra mi nekih pola sata neradi dobro
dok neucira i nepoinstalira valjda sve sto treba ali bas moras uci u igru u izbornik i ostaviti da drobi poslje toga ide normalno isto 16gb rama i gtx 3060 12gb
VoodooRain je offline   Reply With Quote
Staro 18.02.2023., 18:08   #240
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
Decki, di najpovoljnije uzeti ova zadnja dva Call of Djutija, samo bi odigrao single player kampanje, i da li se skidaju sa njihove official stranice ili moze preko Epica ili nekog drugog servisa!
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
