Zaključane teme
Staro 01.09.2021., 20:01   #1201
Postovi: 8,245
Autor Lewis Pregled postova
Suska se da Kimi ide u penziju, Bottas u Alfu, George u Merc a Devries ili cak Akbon u Williams za 2022
Ode Kimi da. Zadnja sezona.
Pupo je offline
Staro 01.09.2021., 20:47   #1202
Exomaniac
Datum registracije: Mar 2016
Postovi: 775
Sad Red Bull uzvraća Mercedesu i čini mi se da traži neko dodatno pojašnjenje oko senzora za temperaturu zraka koji prolazi kroz hladnjak. Red Bull, i Ferrari valjda, sumnjaju da je Mercedes našao način kako da hladi zrak koji izlazi iz turbine ispod dopuštenih 10 stupanjeva iznad ambijentalne pri nižim opterećenjima motora, tj. kad trebaju velika ubrzanja. Red Bull i Ferrari sumnjaju da Mercedes tako dobiva možda i više od 20 konja u inicijalnim fazama ubrzanja.
Link
Translation:
Red Bull seeks Mercedes secret: Is the trick in the intercooler?
Since the British GP, Red Bull and Ferrari have suspected that Mercedes has found performance. Now their opponents think they know what it is. Red Bull has sent a request to the FIA.
It is a search for a needle in a haystack. Since the British GP, Red Bull has felt that Mercedes has gained significant power in the acceleration phases. Since that race, the balance of power between Mercedes and Red Bull-Honda has reversed again on the straights.
Whereas in the previous races Red Bull gained significant time on their world championship rivals in all full-throttle passages, since Silverstone it has been the other way round. Mercedes recently explained this with different wing settings and claims that their engine has been delivering the same power since the beginning of the season and that nothing has been changed on the drive unit.
But this does not necessarily contradict Red Bull's latest theory. According to this theory, Mercedes has the same maximum power, but distributes it differently. Ferrari is also said to be on the case. Both teams believe they know how the world champion gained an advantage at the start of the straights.
Cold air brings more power
The suspicion was fuelled because, according to GPS data, the Silver Arrows gain massive time when accelerating out of slow corners. In fact, at Silverstone and in Budapest, one could get the impression that the Mercedes pick up speed like a torpedo in direct comparison with the competition, but are not necessarily faster at the end of the straight. Unless they have smaller wings on the car.
The secret, according to the competition, is in the intercooler. The compressed air is normally cooled down from 100 degrees to ambient temperature there. However, according to a technical directive, the rules give a little more leeway. The lower limit is 10 degrees below the outside temperature.
In the partial load range, the temperatures of the air through all instances are naturally lower than at full load. Since cold air is denser than warm air, proportionally more fuel can be burnt. And that means more power. If you manage to reserve the share of cool air for the first part of the full-load range, you have an advantage in the acceleration process. And this is where you gain the most lap time.
Sensor under suspicion
And this is how the whole thing is supposed to work. According to the theory of Red Bull and Ferrari, Mercedes manages to separate cool air from warm air for a while by cleverly routing the air between the intercooler and the plenum, thus gaining up to 20 hp in the initial phase of acceleration. Later, the compressor only pushes in warmer air and the advantage fizzles out.
For the time being, this would all still be within the permissible range. The question is how far the air that is fed into the plenum can be cooled and whether the sensor is mounted at a point where relevant values are determined.
Red Bull has its doubts. They believe that the sensor measures at a point where it is ensured that the temperature in the air collector is above the required limit in any case. Red Bull has now submitted an official request to the FIA. Some also speak of a protest.
Exomaniac je offline
Staro 01.09.2021., 21:39   #1203
Morpheous
Morpheous's Avatar
Postovi: 1,144
Autor Pupo Pregled postova
https://www.formula1.com/en/latest/a...Ya89iZmOm.html
Evo i službeno.
Morpheous je offline
Staro 02.09.2021., 17:56   #1204
Matoje
Matoje's Avatar
Datum registracije: Apr 2011
Lokacija: Velika Gorica
Postovi: 183
Pričali su vozači kak je Zandvoort uska staza i kak neće biti niš od pretjecanja, ali sad kad sam vidio snimku vožnje SCa po stazi sam skužio kako je to Monaco 2.0.
https://www.youtube.com/watch?v=_KmFRx4r_-M
Matoje je offline
Staro 02.09.2021., 19:32   #1205
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
ovo ti je bolje
mamutarka je online
Staro 02.09.2021., 21:52   #1206
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,165
Meni je kul ova nova, proširena verzija s nagibima. Zadnji zavoj kao na Ovalu
Super je što ima tonu gravel trapova
nub je offline
Staro 02.09.2021., 21:59   #1207
Exomaniac
Postovi: 775
Neće tu bit nešto preticanja meni se čini. Evenutalno bi mogli gledat ponovno neku dobru defenezivnu vožnju ako netko od bržih bolida završi iza drugih pa se ponovi Alonso-Hamilton
Staro 03.09.2021., 13:01   #1208
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
vettelu se zapalio bolid (motor) u P1, dugo su gasili, vidit ćemo štetu https://i.redd.it/3z5dd60hf9l71.jpg
mamutarka je online
Staro 03.09.2021., 16:12   #1209
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
krepao i hamiltonu motor
mamutarka je online
Staro 03.09.2021., 17:15   #1210
Exomaniac
Postovi: 775
Danas su više bili pod red flagovima nego što su se vozili po stazi valjda
Staro 04.09.2021., 11:06   #1211
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Kimi neće voziti ovaj vikend. Pozitivan je na Covid.
Sent from my POCO F2 Pro using Tapatalk
Di sam stao?
aski je offline
Staro 04.09.2021., 11:28   #1212
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,152
Vozi Kubica umjesto njega ))))
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
1v@n je offline
Staro 04.09.2021., 13:30   #1213
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
sainz uspio izletit pred kvale, valjda će ga sfixat https://streamwo.com/LEOPBsU
mamutarka je online
Staro 04.09.2021., 16:15   #1214
AndroiOs
AndroiOs's Avatar
Datum registracije: Jan 2018
Lokacija: KA
Postovi: 611
Autor 1v@n Pregled postova
Smetat će po stazi
AndroiOs je offline
Staro 04.09.2021., 21:21   #1215
NightWalker
NightWalker's Avatar
Datum registracije: Feb 2010
Lokacija: PGŽ
Postovi: 236
Nisam gledao Q1, ulovio tek Q2 al sta se desilo sa perezom? jbt max najbrzi a ovaj ne moze ni do Q2 doc
NightWalker je offline
Staro 04.09.2021., 21:44   #1216
the-rider
ha?
the-rider's Avatar
Lokacija: Poreč
Postovi: 549
sjebala ga kolona na izlazu iz boksa, nije uspio brzi krug odvoziti
the-rider je offline
Staro 04.09.2021., 22:17   #1217
Exomaniac
Postovi: 775
Svejedno je trebalo i to vrijeme koje je radio biti bolje, on mi je drag i dobar vozač, ali ne može se dogoditi da bolid koji bez problema bude P1 ili P2 i brži od Mercedesa završi u Q1 iza Williamsa, Alfe, Astona i Alpinea koji sva 4 nemaju bodova zbrojeno kao Red Bull.
To stvarno ne volim nikako kad se jedno vrijeme odveze za goli k, onda se čeka i čeka neki kao savršeni trenutak pa na kraju jedna crvena zastava ili kolona sjebu stvar i onda su oni krivi. A pogotovo kad su cijeli vikend izlijetali ljudi i to automatski vuče crvene zastave. Sve pet, htjeli bi taj savršeni trenutak da se odveze maksimalno dobro, ali nekad se to jednostavno ne isplati čekati.
Staro 05.09.2021., 15:36   #1218
Exomaniac
Postovi: 775
Red Bull je napravio prilično pametnu stvar i kod Pereza je zamijenio sve dijelove pogonske jedinice tako da će Perez startati iz pita jer neki dijelovi imaju novije specifikacije. Perez tako sad ima već 4. pogonsku jedinicu i kaznu će odraditi sad kad se ionako loše plasirao na stazi na kojoj će se teško preticati.
Latifi će isto startati iz pita jer su osim mjenjača odlučili mijenjati dijelove prednjeg krila za drugačije pa tako i on mora iz pita.
Staro 05.09.2021., 16:58   #1219
tizhu
Datum registracije: Sep 2014
Postovi: 775
zakaj su maxu stavili hard gume?
jel to znači da više ne ide u box?
mislio sam da će kopirati lewisa.
tizhu je offline
Staro 05.09.2021., 17:08   #1220
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Autor tizhu Pregled postova
Nije imao vise novih mediuma, potrosio sve.
GoGzS je offline
Staro 05.09.2021., 17:20   #1221
tizhu
Postovi: 775
utrka je jebena.
ajmo max - zaslužio je.
ali i lewis isto tako - izvlače obojica maksimum iz tih bolida.
vjerojatno obojica moraju još jednom u box lol
tizhu je offline
Staro 05.09.2021., 17:30   #1222
AndroiOs
AndroiOs's Avatar
Lokacija: KA
Postovi: 611
Kakav box?
Kraj je
Dosadna utrka
AndroiOs je offline
Staro 05.09.2021., 17:31   #1223
tizhu
Postovi: 775
botara uzeo extra bod hahahaha
tizhu je offline
Staro 05.09.2021., 17:32   #1224
GoGzS
GoGzS's Avatar
Postovi: 979
Bottas fastest lap hahaha po tome kako slusa team orderse, rekao bi da Russel confirmed u Mercu sljedece godine hahaha.
GoGzS je offline
Staro 05.09.2021., 17:33   #1225
tizhu
Postovi: 775
sad ovaj mora ponovo u box lol
tizhu je offline
Staro 05.09.2021., 17:34   #1226
tizhu
Postovi: 775
toooo alonso i perez uzeli max kaj su mogli plus max doma --- ludilo
tizhu je offline
Staro 05.09.2021., 17:34   #1227
AndroiOs
AndroiOs's Avatar
Lokacija: KA
Postovi: 611
Ti si u nekom gadnom delayu haha
AndroiOs je offline
Staro 05.09.2021., 17:45   #1228
Postovi: 23,636
A kako je cvilidreta zavijala gume, gume, zašto nisam prva ??
Nikky je offline
Staro 05.09.2021., 17:59   #1229
Exomaniac
Postovi: 775
Al' sam guštao dok je ovaj cvilio oko guma i kolone koje su eto, samo njega zadržavale
Staro 05.09.2021., 20:19   #1230
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
https://mobile.twitter.com/f1esbian/...32051151081472 😁
Race ništa posebno. Ali drago mi je da je to Max uzeo. Iako mislim da po pitanju zanimljivosti ni Monza neće biti ništa bolja.
Di sam stao?
aski je offline
Zaključane teme
