Staro 23.07.2021., 09:26   #121
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,340
Sub-400$ gotovo niti ne postoji u ovoj generaciji, tako da je ovo samo potvrda postojećeg stanja.
Staro 24.07.2021., 08:41   #122
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Slobodno me dodajte na PSN
Staro 24.07.2021., 18:12   #123
Dr. Strange
Datum registracije: Aug 2020
Postovi: 899
Jednom kad se pomaknu granice neće se nikad vratiti na staru razinu, plus još što je sve skuplje i kompleksnije prelaziti na niži node i izvlačiti performanse, treba prihvatiti to i gotovo.
Staro 24.07.2021., 23:18   #124
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
Staro 04.08.2021., 18:31   #125
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,516
Staro 18.08.2021., 16:35   #126
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Staro 18.08.2021., 16:41   #127
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Odlično, trebat će mala elektrana sa frižiderom betnonskom armiranom konstrukcijom.
Staro 20.09.2021., 15:14   #128
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
The Hopper GPU, which is primarily aimed at the Datacenter & AI segment, is allegedly taping out soon and will feature an MCM architecture. NVIDIA won't be using an MCM design on its Ada Lovelace GPUs so they will keep the traditional monolithic design.
AMD on the other hand is going on board with offering both MCM and Monolithic chips in its RDNA 3 and CDNA 2 families. The CDNA 2 GPUs will be MCM only while RDNA 3 will feature a mix of MCM and monolithic design as detailed here. It isn't confirmed which process node each company will be relying on but based on speculation, AMD's RDNA 3 & CDNA 2 family is going to be a mix of 6nm & 5nm nodes featuring new and refreshed GPUs while NVIDIA is expected to utilize TSMC's 5nm process node for its Ada Lovelace GPUs though it is not confirmed if those will be fabricated on the N5 or N5P node. Intel, on the other hand, may also rely on TSMC's 6nm process node for its own ARC Alchemist lineup of GPUs which enter mass production later this year and launch in Q1 2022.
Staro 20.09.2021., 18:14   #129
Dr. Strange
Postovi: 899
Dostupnost će biti ekstra koma, sve 3 kompanije na 5/6nm procesu.
Staro 20.09.2021., 19:06   #130
Antony
Lokacija: Poreč
Postovi: 69
Autor Dr. Strange Pregled postova
TSMC već odavno nije bottleneck, već supstrati. AMD/Intel/nvidia svaki imaju svoj supply chain što se toga tiče. To je jedan od razloga zašto bi npr. štancanje DG2 GPU-ova na N6 nodeu trebalo poboljšati dostupnost grafa pošto Intel ima jako dobar supply chain (MLID je to već objašnjavao u par svojih videa).
Također -> https://semiwiki.com/semiconductor-m...-versus-apple/
To be clear, wafer agreements are signed 2-3 years before the chip makes it into HVM and TSMC can build fabs faster than that so there will be no N3 shortages for anyone who signed a wafer agreement (apple, AMD, NVIDIA, QCOM, etc…). If they need more chips than what they signed up for, which happens, there may be shortages. This is how TSMC and the foundry business works. It’s all about the wafer agreements.
Antony je offline   Reply With Quote
Staro 21.09.2021., 15:56   #131
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
To govorimo nas par vec 5 godina ali uporno se pojavljuju "kad padne cijena/pričekati ću..." odgovori
Nema više nazad. Može samo gore uz sve sto se atm dogadja u svijetu.
Bez potpisa.
Staro 22.09.2021., 19:46   #132
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
https://videocardz.com/newz/nvidia-g...specifications
samo rumorsi ali najvjeroatnije će bit tako da koštat će te isto ko 3060 ti možda i više 3060 super sa više cuda coresa i 12 gb rama.
Staro 03.12.2021., 09:50   #133
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Izgleda da gosn jakna ipak nije baš toliko moćan protiv mobilne ekipice (Apple, Samsung, Qualcom...):
I dobro da je deal propao, bio bi to opak monopol.
Staro 03.12.2021., 17:45   #134
Dr. Strange
Postovi: 899
Autor Disco Pregled postova
Šta je on stvarno bio toliko optimističan i mislio da će deal proći? Pa svaki laik je znao da će to propasti. ARM mora ostati neutralan, a znamo koliko je Nvidia draga prema konkurenciji, i kakvim se sve metodama služe.
Staro 03.12.2021., 19:44   #135
Postovi: 8,535
Š.T.E.T.A., jer riječ je o preduzeće koje voli da im cvate cveće i sad su ih zakinuli za inovacije kakve svijet još nije biJo vidiJo, a sad ni neće.
Kaj se Toma tiče, lagano postaje karikatura samog sebe, kad izdaje ovakve video uratke u kojima opet i po ko zna koji put mora naglasiti da je sve ovo već prije prvi saznal.
Jebeno, nema kaj, i onda od jučer kad je cijeli net pun vijesti o tome da FTC blokira nVidia + ARM selpo, dajte da vam Tom veli ekskluzivu kroz izvore iz UK vlade i vojnih satelita.
Staro 06.12.2021., 08:41   #136
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
A izgleda da i Jim-a i njega hebe ego.
Tj Jim se više volio obračunavat sa trolovima.
Ali dobro, meni su uvijek fora za poslušati.
Staro 06.12.2021., 10:21   #137
Postovi: 8,535
IMHO Toma najviše muči to da uvijek (ne) može reći da je prvi imal te informacije i to stvarno s vremenom postaje sve veći fokus, nego informacije s kojima raspolaže.
Staro 06.12.2021., 11:03   #138
Odinarius
All-rounder
Postovi: 1,340
Meni je malo dosadan s onim "one of my best sources...", sve za različite teme i područja. Nemaju neke vrijednosti ti leakovi jer 50% budu točni, 50% ne, zabavno za poslušati makar nekakvu linije spekulacije i to je to. No tu i tamo ubode sa podcastom (Broken Silicon). I tu je fifty fifty što se tiče gostiju, no ponekad budu zbilja dobri, bude jasno u prvih 5min da li ću potrošiti 2h na to.
One koji su samo on i brat sam prestao slušati.
Staro 06.12.2021., 11:47   #139
Postovi: 8,535
Da, brat mu je davež koji je tu samo zato, jer može, a kaj se gostiju tiče, stvarno su super u dosta slučajeva. Jedino kaj Tom neovisno o gostu uporno gura gaming tematiku.
Staro 06.12.2021., 13:14   #140
Mladenxy
Mladenxy's Avatar
Postovi: 4,465
Gora ono što smatra da će osigurati klikove.
Staro 06.12.2021., 14:23   #141
delavi
Datum registracije: Apr 2020
Postovi: 978
Problem je kaj ovi "ispod 35e" gotovo slijepo vjeruju svakoj budali na youtubeu. To je baš problem generacije. Mi smo rasli bez tih svih sranja pa smo se sami morali naučiti misliti haha
Staro 09.12.2021., 21:13   #142
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,369
Staro 04.01.2022., 08:08   #143
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,203
Nevidija bome duboko posegnula u kasu da bi osigurala buducnost i konurentnost sa TSMC -ovim 5nm protiv nadolazecih kartica iz AMD-a koje ce također biti na TSMC -ovoj 5nm litografiji.
NVIDIA is reportedly coughing up big money to TSMC (Taiwan Semiconductor Manufacturing Company) to ensure that it secures plenty of next-gen 5nm wafers for its upcoming Ada Lovelace GPUs that will power the next-gen GeForce RTX 40 series graphics cards.
But in new rumors from MyDrivers, NVIDIA is paying much more than usual to get 5nm wafer from TSMC with the company reportedly paying TSMC a large $1.64 billion in Q3 2021... but that increases to $1.79 billion in Q1 2022 as they ramp up to the Ada Lovelace GPU being made and printed onto next-gen GeForce RTX 40 series GPUs.
A larger long-term deal has also reportedly been struck, which would see NVIDIA coughing up $6.9 billion to TSMC in order to secure next-gen 5nm wafers for Ada Lovelace. We've heard before that NVIDIA's next-gen GeForce RTX 40 series GPUs would be made by TSMC -- and not Samsung -- and its upcoming 5nm node.
MyDrivers reports: "According to industry sources, TSMC's requirements for Apple, MediaTek, AMD and other three major customers are relatively low. They do not need to pay too much deposit in advance to stabilize production capacity. Customers like NVIDIA need to pay huge advance payments in advance if they want to obtain 5nm production orders".
Samsung has been making Ampere GPUs for NVIDIA and its GeForce RTX 30 series, but we all know they aren't the most power-efficient GPUs when you get to the high-end. AMD has hit its stride with its RDNA 2 GPU architecture, with TSMC baking their Radeon RX 6000 series chips on the 7nm node -- the same node used to make the semi-custom chips inside of the PlayStation 5 and Xbox Series X consoles -- and they're fantastic with power.
NVIDIA is making a move that it needs to in order to... well, frankly survive. The company makes its bread and butter from GPUs and if it can't sell enough -- especially of the very best, which TSMC will be capable of providing with its new N5 node -- then well, that's not going to be good at all. NVIDIA can't have another misfire as things will be radically different for Team Green in 2022, 2023, and beyond.
AMD will have its next-gen RDNA 3 architecture here with an MCM-based design -- MCM being a multi-chip module, so multiple GPU chiplets on the same card, similar to how the Zen CPU chiplets are on the Ryzen CPUs -- and will offer some truly monster performance on the next-gen Navi 31-based Radeon RX 7900 XT.
Not only that, but the GPU market is going to be completely different this time next year with CPU giant Intel joining the GPU market with its Xe-based Arc Alchemist. Later in the year we'll see how Intel has gone, and what comes next with Intel's Arc GPUs, and then in 2023 we've been hearing that is when things will really ramp for Xe and Arc... and NVIDIA knows that.
It gets worse, as the ongoing pandemic has been wreaking havoc on every single industry -- and the tech industry hasn't been shy from being slammed into the ground. The entire supply chain is f***ed right now, and Taiwan is in the middle of a shit-flinging fight with China + Japan, with the threat of nuclear strikes from China on Taiwan if Japan intervenes in any form.
NVIDIA's next-gen Ada Lovelace GPU and the flagship GeForce RTX 4090 or GeForce RTX 4090 Ti should be capable of 4K 120FPS gaming without a problem, but I think next-gen 8K 60FPS and better yet, 8K 120FPS gaming to be in the sights of NVIDIA. Maybe not raw, but with a next-gen DLSS 3.0 up its sleeve... it's entirely possible, and that is very, very exciting.
AMD's next-gen Navi 31 GPU has recently taped out, the very first MCM-based GPU that should form into a new flagship Radeon RX 7000 series graphics card in the second half of 2022. NVIDIA will be fighting back with the GeForce RTX 40 series and new flagship GeForce RTX 4090, which should offer 2x the performance and power consumption of the GeForce RTX 3090.
Read more: https://www.tweaktown.com/news/83634...022/index.html
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 04.01.2022., 12:30   #144
Postovi: 8,535
Da, to je nastavno na ovu priču, a sad kad su svi fino ovisni o TSMC-ovim kapacitetima, nVidiji i Intelu ostaje koliko su voljni platiti za usluge koje se nude.
Zadnje izmijenjeno od: The Exiled. 04.01.2022. u 14:55.
Staro 24.01.2022., 20:19   #145
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
https://videocardz.com/newz/gpu-pric...ing-to-decline
https://www.guru3d.com/news-story/nv...in-europe.html
jel rastu ili padaju??
mislio sam reć guru3d objavljuje da cjene rastu dok videocardz objavljuje da cjene padaju što ćemo naravno vidjet kroz 2-3 mjeseca ili/i prije.
Zadnje izmijenjeno od: demetrius. 24.01.2022. u 20:33.
Staro 24.01.2022., 20:29   #146
Postovi: 8,535
Za koji dan stiže RTX 3050 za kakvih 5.000 kn, dok istovremeno nudi GTX 1660 rang performanse i to će samo dodatno potvrditi da budžet segment stvarno nudi najbolji omjer uloženog i dobivenog.
Kaj se samih cijena tiče, tj. pitanja da li cijene grafičkih kartica rastu ili padaju, odgovor je tak jasno - da.
EDIT:
Ma zajebancija s moje strane kaj se cijena tiče, ali nažalost izgleda da nema kraja ovom ludilu u neko skorije vrijeme.
Zadnje izmijenjeno od: The Exiled. 24.01.2022. u 20:42.
Staro 24.01.2022., 20:47   #147
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
stara cjena za rtx 3060 ti 419 eura nova cjena 443 eura di to ima rtx 3060 ti za 443 eura??
Staro 24.01.2022., 21:13   #148
Postovi: 8,535
Nema, to je već dulje vrijeme kartica od 1.000€, a MSRP je tu reda-radi.
Staro 25.01.2022., 13:04   #149
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,662
Autor demetrius Pregled postova
Oboje
Nvidija diže MSRP, a cijene padaju jer pada i potražnja za grafičkim.
Ali s obzirom da su cijene jako prenapuhane, u dućanima cijene padaju bez obzira štoi nvidija pokušava naplatiti koliko može
RimtuTiTuki je online   Reply With Quote
Staro 25.01.2022., 19:12   #150
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Ove visoke cijene će samo većinu korisnika natjerati da kupuju CPU koji u sebi ima uključenu i grafiku. Koliko smisla imati za jednu grafulju dati od 7K kuna naviše da bi se na njoj igralo?
Druga stvar je kada se kupuje nešto za posao i kada ti je to sredstvo za rad.
I nije samo u pitanju visoka cijena već i period kroz koji će to što si kupio zastarjeti. A mnoge od najavljenih mogućnosti i potencijala same grafičke kartice možda se nikada neće niti iskoristiti u budućim igrama jer će u međuvremenu doći nešto bolje i ove mogućnosti će postati zastarjele.
sakomako je offline   Reply With Quote
