Staro 11.08.2021., 23:21   #3931
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 715
Autor Old.machine Pregled postova
Veća brzina će se najviše osjetiti kod obrade multimedije. Imaš ovdje detaljnu recenziju (pročitaj i komentare), kod nekih grafova ima i A2000:
https://www.techpowerup.com/review/c...-m-2-nvme-ssd/
Uglavnom bolji disk od a2000 ?
Revolver3844 je offline   Reply With Quote
Staro 12.08.2021., 00:12   #3932
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Autor Revolver3844 Pregled postova
Je, brži je Crucial, u recenzijama se spominje da zna biti vruć, pa ako ga misliš staviti u laptop onda možda bolje neki drugi. Ako ide u komp po komentarima sa TPU recenzije ne bi trebao biti problem:
Heat was never really a concern. Heat is only a problem if you transfer hundreds of GB of data at once, which you rarely do at home.
ovaj je stavia heatsink
I don't even break 40 celsius on this drive.
I can confirm anyone wanting to buy this drive, don't bother with momentum cache, its basically junk. I did a 7-zip unzipping test of same files, momentum cache off and on, and when the cahce was on it was slower by about 7-10 seconds each time.
Leaving it off everything feels a bit snappier too. I already uninstalled the software, best to just use the p5 1tb drive plug n play.
I added a heatsink and some copper to mine, I don't break like 45 celsius now for 90% of things.
A i stekao sam dojam da ljudi baši ne vole Kingstona, npr jedan od komentara. Spominjao si da imaš u Austriji besplatnu dostavu, na akciji ti je i P2 1TB model (70€) ako bi nešto jeftinije, ali i sporije.
Old.machine je offline   Reply With Quote
Staro 12.08.2021., 09:26   #3933
markosan
Why so serious?
markosan's Avatar
Postovi: 60
Bok, vidim da je ta ponuda Crucial P2 1TB za 70€ s UK amazona, pa me zanima ima li nekih problema/ dodatnih troškova / procedura s njima nakon brexita, ili sve ide glatko i platim samo item+dostavu kao i prije?
markosan je offline   Reply With Quote
Staro 12.08.2021., 09:31   #3934
Old.machine
Lokacija: ______
Postovi: 1,455
Autor markosan Pregled postova
Ponuda za P2 je bila sa njemačkog Amazona, danas je skočila cijena na 79€. Na britanskom je sad 70€, ne znam kakva su sad pravila za dostavu od tamo...
Staro 12.08.2021., 10:17   #3935
Old.machine
Lokacija: ______
Postovi: 1,455
Cijena za P2 je upravo pala ponovno na 70€ na .de
UPDATE: Ubuduće ne uzimati ovo, QLC verzija sa slabim perfomansama.
https://www.tomshardware.com/feature...swap-downgrade
Zadnje izmijenjeno od: Old.machine. 16.08.2021. u 20:55.
Staro 12.08.2021., 11:50   #3936
sti
Lokacija: Lawl
Postovi: 1,375
Ovo je SATA disk, samo u M.2 pakiranju.
sti je online   Reply With Quote
Staro 12.08.2021., 11:55   #3937
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,697
Vidi vraga
Hvala kolega, budem napisao napomenu.
Staro 13.08.2021., 13:05   #3938
Postovi: 16,783
Ajmo se teme držati, molim vas. Dobio sam brdo reportova na raspravu koja nije vezana uz temu, tako da, ajmo ostati konzistentni i držati se "rasprave", bez priče o pošti i PDV-u.
Staro 14.08.2021., 09:32   #3939
tomo19
Postovi: 317
Autor Mihael Pregled postova
U Mall.hr je još povoljniji (+poklon), ali, koliko vidim, 2.god garancije:
https://www.mall.hr/tv-prijemnici/lg...utm_medium=cse
Kakav je taj A1 model spram C1?
tomo19 je offline   Reply With Quote
Staro 14.08.2021., 09:35   #3940
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Tnx. Dodacu link
Staro 14.08.2021., 10:37   #3941
Ninja_Zg
Ninja_Zg's Avatar
Datum registracije: Aug 2013
Postovi: 266
Acer XB323UGP (na eng verziji u naslovu je krivi model) - 499€, sa dostavom 534€. Na nabavi od 5798kn. Ušteda 1739kn. ZAVRŠILO
Old.machine, hvala na obavijesti i opcenito ogromnom, korisnom, nesebicnom doprinosu forumu.
Ubo monitor, naletio kao narucen, skicam ga otkad su uopce najavljeni monitori s tim panelom, ludilo je.
Ninja_Zg je offline   Reply With Quote
Staro 14.08.2021., 15:27   #3942
Old.machine
Lokacija: ______
Postovi: 1,455
@Ninja_Zg
Hvala ti
Uživaj
Staro 14.08.2021., 15:59   #3943
fora
fora's Avatar
Postovi: 455
Završilo.
Zadnje izmijenjeno od: fora. 16.08.2021. u 14:58.
fora je offline   Reply With Quote
Staro 16.08.2021., 14:55   #3944
markosan
Why so serious?
markosan's Avatar
Postovi: 60
Opet se vraćam na ovu ponudu, ovaj put on-topic uz upozorenje kolegama forumašima.
Dakle naručio sa .de, stiglo (vrlo brzo, kroz par dana) i onda vidim da se radi o QLC verziji sa strahovito lošim performansama, a istim part numberom kao i kod TLC verzije:
Mam ide natrag. Crucialu debeli minus bodovi.
Staro 16.08.2021., 15:03   #3945
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Kako je krenulo još će stavit QLC i na top P5 model
Staro 16.08.2021., 20:49   #3946
Old.machine
Lokacija: ______
Postovi: 1,455
jebiga, da sam znao ne bi ga stavio u temu Staviti ću napomenu u taj post i ubuduće ga više neću stavljati
Staro 16.08.2021., 21:37   #3947
Old.machine
Lokacija: ______
Postovi: 1,455
@markosan imaš PM
Ukratko: Kontaktirao sam Amazon support preko chata, objasnio im situaciju i poslao taj gore Tom hardware link. Rekao sam da je kolega sa foruma uzeo SSD i da ga misli vratiti nazad pa postoji li šansa da dobije nekakav povrat shippinga jer su perfomanse SSD-a stvarno loše, a u opisu nije bilo naznačeno da se radi o QLC verziji. Rekli su mi da im se kolega javi sa Order ID pa će vidjeti što mogu napraviti. Ako je još netko uzeo neka kontaktira njihov support pa nešto proba iskombinirati. Još jednom isprike zbog Crucial sranja
UPDATE: kaže mi kolega Markosan da čim je išao kroz normalnu proceduru povrata da mu je pisalo da mu automatikom refundiraju do cca 9 eur poštarine
Nisam znao za to, mislio sam da vraćaju poštarinu samo u slučaju reklamacije. 9€ bi valjda trebalo biti dovoljno da pokrije slanje HP (nemaju osiguranje paketa), tko misli vraćati Crucial SSD nečim drugim kao Eurosender (skuplje slanje, ali imaju osiguranje paketa) neka se javi Amazon chatu za veći shipping refund
Zadnje izmijenjeno od: Old.machine. 16.08.2021. u 22:02.
Staro 22.08.2021., 13:01   #3948
Postovi: 16,783
Ima netko nekakav popust za ekupi? Hvala
Staro 22.08.2021., 14:02   #3949
buljaka
Datum registracije: Aug 2014
Postovi: 2,929
Stavio sam ja neki dan u eKupi temu.
Staro 23.08.2021., 09:57   #3950
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,914
Philips Fidelio X2HR/00 - 78€, sa dostavom 91€. Na nabavi nema, ali ako potražite prijašnje postove sjećam se da su ove išle obično preko 1500kn+.
https://www.amazon.fr/dp/B01N5VHLUG?...ogi&th=1&psc=1
Kakve su za gaming, ako se uzmu sa mikrofonom ?
Matta je offline   Reply With Quote
Staro 23.08.2021., 10:34   #3951
thunder11
thunder11's Avatar
Postovi: 1,697
Autor Matta Pregled postova
https://www.rtings.com/headphones/re...s/fidelio-x2hr
Staro 23.08.2021., 10:58   #3952
Old.machine
Lokacija: ______
Postovi: 1,455
Uf šta ne volim takav ukupni prikaz ocjena kod rtings, tako izgleda kao da su teški škart Kad se stavi miša na upitnik kod ocjene dobije se detaljniji prikaz ocjena. Evo za wired gaming:
Zadnje izmijenjeno od: Old.machine. 23.08.2021. u 11:03.
Staro 23.08.2021., 11:07   #3953
thunder11
thunder11's Avatar
Postovi: 1,697
Pa tak je . Treba procitat ne samo žutilo pogledati
Staro 23.08.2021., 13:24   #3954
Old.machine
Lokacija: ______
Postovi: 1,455
Da da
Kakav je onaj LG monitor koji sam stavio u glavnu temu? Čini mi se da nisam mogao bolje za svoj tisućiti post na forumu
https://www.lg.com/uk/monitors/lg-27gn88a-b#none
Staro 23.08.2021., 13:31   #3955
thunder11
thunder11's Avatar
Postovi: 1,697
Znaci svaka čast na ovome
Staro 23.08.2021., 13:49   #3956
Old.machine
Lokacija: ______
Postovi: 1,455
cestitam i hvala na trudu
hvala
po specifikacijama ova izgleda slabije ali eto neka se spomene, 32inch (4k, 60Hz) verzija je na akciji - 389€, pad sa 650€. Na nabavi nema. ZAVRŠILO!!
https://www.hagglezon.com/en/s/B088BMZ41V
https://www.nabava.net/search.php?q=32UN88A&cod=&cdo=
https://www.lg.com/uk/monitors/lg-32un88a-w
Zadnje izmijenjeno od: Old.machine. 23.08.2021. u 14:44.
Staro 23.08.2021., 13:50   #3957
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
hvala
Staro 23.08.2021., 15:09   #3958
Hrconja
Hrconja's Avatar
Postovi: 1,620
Da da
Hvala za link, brzo je i nestalo bome
Hrconja je offline   Reply With Quote
Staro 23.08.2021., 16:08   #3959
Revolver3844
Lokacija: SB
Postovi: 715
Kad prevedes stranicu pise da su rabljene slušalice ne nove.
Staro 23.08.2021., 16:21   #3960
Old.machine
Lokacija: ______
Postovi: 1,455
Više nisu na akciji pa sad pokazuje stvari sa Amazon warehouse. Kad sam stavio link bile su nove, hagglezone link je upućivao na njih. I na keepi kad su nestale više ne piše da ima new nego samo used. Sve je bilo regularano, new and dispatched and sold by Amazon.
https://keepa.com/#!product/4-B01N5VHLUG
Zadnje izmijenjeno od: Old.machine. 23.08.2021. u 16:27.
