Staro 11.07.2021., 22:51   #841
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,188
Developer who goes by fholge on Reddit has created a mod that enables FSR in most Steam VR games.
https://www.reddit.com/r/virtualreal...elityfx_super/
https://github.com/fholger/openvr_fsr
FSR upsampling in Fallout 4 VR (click on pictures below to see before and after RESULT / picture side by side ):
https://imgsli.com/NjAxNTE & https://imgsli.com/NTk1OTI/2/1
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 12.07.2021. u 10:09.
Blue Spirit je online   Reply With Quote
Staro 14.07.2021., 16:20   #842
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Ovo je drop: RX6700XT za 5165kn! Još malo pa smo na MSRP (po mojoj računici to je cca sitno preko 4000kn)
https://www.hardsoft.hr/vga-asr-rx67...m_medium=click
Staro 15.07.2021., 22:39   #843
Postovi: 8,300
AMD FidelityFX FSR Source Code released & updates posted
To begin with, the company released the source code of the technology to the public under its GPUOpen initiative, under the MIT license. This makes it tremendously easy (and affordable) for game developers to implement the tech. Inspecting the source, we find that FSR relies heavily on a multi-pass Lanczos algorithm for image upscaling. Next up, we learn that close to two dozen games are already in the process of receiving FSR support. Lastly, it's announced that Unity and Unreal Engine support FSR. With the source code now fully available, nothing stops developers from adding FSR into their games. Unlike nVidia's DLSS solution, FSR requires almost no engine tweaks, you just add the shader pass into your rendering pipeline. In a separate PDF document AMD went into more detail on how to integrate FSR, what inputs are required, and how to present the new rendering options to the end-user.
We took a closer look at the source code AMD is providing, and it's really the full source. There are no external dependencies or DLLs. You are free to modify and adapt as you see fit. This makes FSR an interesting tech for modders, who should be able to more easily integrate the tech into existing games, through hooks. Also there's nothing that would prevent this from running Linux. AMD's sample code includes Windows samples only at this time, but integrating FSR with other operating systems, even cell phones is trivial at this point. AMD has also released a demo for FSR, which lets you dig into all the settings options and compare them in a way that's better suited to investigation, than a hectic game.
Izvor: TechPowerUp
Staro 19.07.2021., 16:08   #844
Blue Spirit
Postovi: 2,188
Staro 19.07.2021., 16:13   #845
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,331
Sad apsolutno nema prepreka da ovo postane novi standard za svaku igru koja postoji. I stvarno je doba stvar, kad se gleda koliko se vizualno izgubi za dobitak u fps, ovo je spas za sve nas sa starijim grafičkima, a većim monitorima.
Staro 19.07.2021., 18:03   #846
Postovi: 8,300
Dresdenska šrot firma ne tako davno pred bankrotom s kojom Intel i nVidija danas muku muče, a za 2020. im je od strane svih mogućih i priznatih analitičara - predviđena momentalna smrt
Staro 19.07.2021., 21:23   #847
Mladenxy
Mladenxy's Avatar
Postovi: 4,362
Očekujem ovo u svakoj igri, bez iznimke
Staro 19.07.2021., 21:33   #848
Postovi: 8,300
Trebalo bi biti, pogotovo sad kad je open-source, jedino, ako nVidia pojača ciganluk na 11 i počne plaćati enormne nofce developerima samo da ne implementiraju FSR.
Staro 20.07.2021., 01:39   #849
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 843
Kakva dresdenska firma? AMD je američka firma ko i ove druge dvije, to kaj si ti videl na kojem procesoru diffused in dresden je nes drugo.
Staro 20.07.2021., 08:41   #850
Postovi: 8,300
Zajebancija je to, koja na ovom forumu traje već više od 15 godina, barem koliko sam tu aktivan i potječe iz vremena kad su imali FAB u Dresdenu, pa je kasnije sve prešlo u GloFo ruke.
Staro 20.07.2021., 14:15   #851
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,471
a ne nece ngreedija je to pa najveci uzor im je apple
Staro 02.08.2021., 13:10   #852
Postovi: 8,300
Ima sve kaj trebaš.
Zadnje izmijenjeno od: The Exiled. 02.08.2021. u 14:56.
Staro 02.08.2021., 19:04   #853
Postovi: 8,300
Možeš i to, Radeon Software automatski poskenira sve igre koje imaš ili ih ručno dodaš, ako koju propusti i onda pod Gaming kategorijom imaš mogućnost za svaku igru pojedinčano podesiti ove postavke s mojih screenshota.
Staro 09.08.2021., 22:38   #854
Postovi: 8,300
IMHO ne isplati se, rađe pogledaj RTX 3070 (Ti) ili 3080 za te nofce, ako je ray-tracing bitan.
Staro 09.08.2021., 22:40   #855
robimarko-bug
Datum registracije: Jul 2013
Lokacija: Tenja(Osijek)
Postovi: 1,127
Isto kao i RX3090, ne isplati se.
Ray tracing ti je must have ili?
Meni osobno je to još gimmick
Nego, jel netko uspio kupit 6800 XT preko AMD shopa i Mailboxa?
Nema mi smisla davati 700+ EUR-a za 6700 XT nikako a moram nešto u dogledno vrijeme uzeti
Staro 10.08.2021., 00:19   #856
exzzy
exzzy's Avatar
Postovi: 843
Nemoze prek mailboxa vec sam napiso par puta, al ne čitate. Jedino ak se oces kockat i upisat sam adresu mailboxa i svoje ime i tam narucit ko da stanujes tam. Al je pitanje di ce ti paket zavrsit, a oni ak ga i uspiju primit jel bu se tam onda zagubil negdje.
Staro 10.08.2021., 00:32   #857
robimarko-bug
Postovi: 1,127
Vidio sam, ali ne kuzim sto nebi moglo.
Svasta sam preko mailboxa shippao, ono doslovno PC-eve s Mindfactorya, mobove s ebaya, nema sta ne svakakve cijene i nikad me nisu zeznili.
Jedino gdje su mi stornirali zbog mailboxa je Notebooksbilliger.
Cak sam PS5 kada ne na kapaljku isao uspio preko deset puta goreg forwardera u Austriji uzet.
Ono, na Paypalu imam adresu od mailboxa, ne kuzim sta je problem, stavim ime i prezime te ID od mailboxa.
Ako bas neide mogu uskoro na frenda u DE narucit.
Sent from my POCO F2 Pro using Tapatalk
Staro 10.08.2021., 01:15   #858
exzzy
exzzy's Avatar
Postovi: 843
Zato kaj neće slat prek forwarding servisa.
Staro 10.08.2021., 09:54   #859
Le0n
Groarrr
Le0n's Avatar
Postovi: 438
Autor robimarko-bug Pregled postova
Kako si uspio na PP staviti mailbox adresu? Meni javlja da ne može biti adresa u drugačijoj državi od kartice kada sam zadnji puta probao prije par mjeseci.
Ja sam probao i s VPN i odbili me na mailbox da ne može na forward servis. AMD site ti ima klauzulu za to u općim uvjetima.
Staro 10.08.2021., 10:05   #860
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,698
Neće vam prolaziti Mailbox sa AMD web-a.
Svaka narudžba se kod njih ručno još provjerava.
Sent from my Pixel 4a (5G) using Tapatalk
Staro 10.08.2021., 10:54   #861
robimarko-bug
Postovi: 1,127
Autor Le0n Pregled postova
Imam DE PayPal account baš zbog toga što se inače nemože dodati adresa van države koja je odabrana prilikom kreiranja accounta.
A šteta, onda ću morat gnjavit frenda da na njegovu adresu šalju ako slučajno uspijem uzeti.
Staro 10.08.2021., 15:46   #862
Postovi: 8,300
Staro 10.08.2021., 17:03   #863
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Odlične performanse u odnosu na 5xxx seriju, ali čak i MSRP je previsoka, i odnosu na nvidiu i u odnosu na predhodnu generaciju.
Jbmu, pričamo o 128bitnim karticama koje imaju razinu performansi od last-gen onoga što je trebao biti mainstream
X
Staro 10.08.2021., 17:06   #864
robimarko-bug
Postovi: 1,127
MSRP je visok i ocigledno iskoristavaju situaciju, iako MSRP trenutno ne znaci nista.
Jedino ce ovih moci puno vise nastancat, ocekujem ih sutra vec po 500-550 EUR-a.
Cijela situacija je zalosna, doslovno nema mainstream kartica uopce.
Staro 10.08.2021., 19:33   #865
SlavoS
Datum registracije: May 2003
Postovi: 1,116
Ako budu 3500kn (+/- 10%) prodavat će se ko vruće kifle...
SS
SlavoS je offline   Reply With Quote
Staro 10.08.2021., 19:39   #866
robimarko-bug
Postovi: 1,127
To je sigurno, nazalost ce se prodat sve sto se proizvede.
Staro 10.08.2021., 20:19   #867
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,300
Nemojte zaboravit i da je samo X8 i na PCIe 3.0 što joj dosta smanjuje performanse.
Jako jako loše za tu cijenu...koju ionako vj niko neće ni vidjet...
Slobodno me dodajte na PSN
Staro 10.08.2021., 21:39   #868
SlavoS
Postovi: 1,116
Ne da je jako jako loše, već je katastrofalno....
Imamo situaciju gdje XX60 kartica, dakle ulazni model 150-200$, ima MSRP x2 i prodavat će de ko da nema sutra, van pameti...
SS
Staro 10.08.2021., 21:41   #869
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,788
Nisam točno shvatio što je loše na toj kartici (osim cijene) ako prebacuje 5700xt i 3060?
Staro 10.08.2021., 21:44   #870
robimarko-bug
Postovi: 1,127
Samo 8 laneova, 128bitni bus i najvise cijena.
Da je 200 USD bilo bi taman, ovako je daleko previse.
