Staro 06.07.2021., 09:35   #3751
Postovi: 10,107
Radije za te sitne pare kupi dirt rally 1 ako zelis malo prosiriti horizonte. Pcars 1 je bzvz kad vec igras gore nabrojane naslove.
Staro 06.07.2021., 13:19   #3752
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
Battlefield V Definitive Edition 14,99€ još sutra
https://store.steampowered.com/app/1...Battlefield_V/
Edit: 10€ je na https://www.allkeyshop.com/blog/buy-...ompare-prices/
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 15.07.2021., 20:10   #3753
Postovi: 8,324
Steam Deck is Valve’s Switch-like portable PC, starting at $399 this December
The hefty-looking console, which is 11.7 inches long (compared to 9.4 inches for the default Switch with Joy-Cons), will launch at three price points, differentiated by built-in storage capacity, higher SSD speed ratings (jumping from default eMMC storage to a pricier NVMe protocol), and differently tempered glass on its screen. Those upgraded versions will cost $529 (256GB) and $649 (512GB, "anti-glare etched glass"). Both pricier bundles include a carrying case. All models will have the same AMD-powered combination of a four-core Zen 2 CPU with eight threads and eight compute units’ worth of RDNA 2 GPU, which Valve describes as a "custom" APU. Each model also includes 16GB of LPDDR5 RAM, a 40 Whr battery (guaranteeing "2-8 hours of gameplay" on a single charge), a microSD card slot for expandable storage, and a 7-inch, 1280x800, 60 Hz touchscreen LCD.
Izvor: ArsTechnica
Staro 16.07.2021., 00:00   #3754
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,850
Cijene su za EU "malo" više,
419, 549 i 679 E.
Pa, ako pare nisu problem, ovo izgleda vrlo zanimljivo (barem na papiru).
Switch mi je drag, ali me iritiraju cijene igara (Nintendove su rijetko snižene
drže cijenu jače od Golfa, a ostale budu ali drastično manje nego na PCu),
tako da mi je ideja mobilne Steam kolekcije jako privlačna.
Glavno mi je pitanje hoće li ergonomija biti prihvatljiva -
uz sve prednosti, Switch je nevjerojatno nezgodan za držanje,
i meni osobno neupotrebljiv bez nekakvog grip-dodatka, što je onda dodatan trošak.
Ozbiljno, to treba isprobati da se vidi koliko je grozno,
pogotovo za ljude s malo većim šapama.
Staro 16.07.2021., 11:44   #3755
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,308
Sve ručne konzole su jako neudobne bez gripa.
Ja sam ga morao kupit i za Vitu,PSP, DS i 3DSXL...od svih mi se javi grč u ruci nakon 20ak min, sa gripom se da izdržat i duplo duže.
Jedino nemam grip za onaj prvi GBA.
Slobodno me dodajte na PSN
Staro 16.07.2021., 11:59   #3756
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,648
Ova od Stema izgleda kao da ima fini komad gripa
Staro 16.07.2021., 12:28   #3757
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,850
Izgleda da ima za što uhvatiti, da,
samo treba pričekati recenzije.
@ Disco
Ha, kako koja.
Originalni Gameboy mi nije bio problem,
Sega GameGear je također bila vrlo ugodna za držanje.
Vitu, PSP, DS nisam isprobao, pa ne znam.
Uglavnom, ako koga zanima, rezervacije kreću danas u 10am PDT
(19 kod nas, mislim? Tako nekako).
Staro 16.07.2021., 13:33   #3758
Postovi: 8,324
Staro 16.07.2021., 15:32   #3759
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
FSR FTW na ovom čudu. Sviđa mi se
Staro 16.07.2021., 16:55   #3760
tuna3
Datum registracije: Mar 2009
Postovi: 472
Meni ovo izgleda sasvim solidno.
Ako uzmemo u obzir cijenu grafičkih danas, best buy.
Da ne govorim da većina u startu ima popriličan library igara
tuna3 je offline   Reply With Quote
Staro 16.07.2021., 21:58   #3761
veve
woot!!!
veve's Avatar
Postovi: 2,496
Samo da ne ispadne kao STEAM BOX/LINK/Controller... Veliki hajp oko toga, a na kraju sranje.
veve je offline   Reply With Quote
Staro 16.07.2021., 22:13   #3762
tuna3
Postovi: 472
Autor veve Pregled postova
BOX nije nikad ni zaživio.
Kontroler meni osobno Xbox je bolji i iako nije idealan daleko od toga da je sranje, pogotovo mi je bio dobar za igre poput This war of mine itd.
Da ne govorim o steam linku koji dan danas koristim, pogotovo od kad postoji i aplikacija na smart TV-ima. Bez greške
Staro 16.07.2021., 22:21   #3763
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Napravio rezervaciju, ko mu jebe mater
Fleshnem gore neki drugi OS i na dockingu imam više nego dostatnu mašinu za sve kaj mi treba, ko Nintendo Switch za muške
Pisalo je da će moj order biti ispunjen tek u Q1 2022, tak da imam vremena ili skupit lovu ili odustati kad se glava ohladi.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 16.07.2021., 22:25   #3764
Mladenxy
Mladenxy's Avatar
Postovi: 4,369
Ne znam gdje bi ovo koristio, na WC-u
Za po doma je bezveze, igrat se na klupici u parku Na odmoru u viksi/hotelu? Laptop je bolja solucija. IMO.
Staro 16.07.2021., 22:41   #3765
tuna3
Postovi: 472
Meni je bas mobilno igranje primamljivo. Sumnjam da ma laptopu baterija traje kao na decku, da ne spominjem da je deck uzmi i igraj za razliku od laptopa.
Sent from my M2101K7AG using Tapatalk
Staro 16.07.2021., 22:47   #3766
Postovi: 8,324
U slučaju da se pokaže OK, mislim da ne bude problema s pronalaženjem razloga kupnje i korištenja, posebice obzirom na hardver u tom malom pakiranju.
Staro 16.07.2021., 23:05   #3767
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Ma ovo je mrak hardver unutra, čak se ne bi čudil da bude i main divajs ekipi, pogotovo sa dockuljom koju bu D(r)eck podržaval.
Desktop replacement koji moreš hitit u ruksak bez da osetiš. Istina, laptop je versatilniji i naravno da je i dalje opcija, al ovo je baš bomba u malom volumenu. Bar na papiru, jel.
AMD je napravil brutalan posel, pogotovo jer ovo je APU temeljen na RDNA 2 GPU jezgrama, a ne na Vegi.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 16.07.2021., 23:10   #3768
tuna3
Postovi: 472
Baš to, specifikacije su odlične a sve košta tek nešto više od moje grafička kad je bila nova.
DA ne spominjem integraciju sa Steamom, cloud saveovima itd.
Staro 16.07.2021., 23:46   #3769
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,826
I gledam ja review i mislim si kako bi bilo super daje touchscreen gore, a kad tamo - touchscreen.
Strojčić izgleda odlično, mislim da bi to mogao biti hit, bolji od bilo koje konzole.
Staro 17.07.2021., 08:17   #3770
Mladenxy
Mladenxy's Avatar
Postovi: 4,369
https://www.pcgamer.com/uk/steam-dec...-expectations/
The Steam Deck isn't quite the "powerhouse" Valve claims it to be, but if you're happy to run your games on low to medium settings at 720p to hit 30-60 fps, then it should get you happily playing PC games away from your desk—at least while the 40Whr battery lasts.
Staro 17.07.2021., 09:50   #3771
Zaggy111
Zaggy111's Avatar
Postovi: 438
Znači s dual bootanjem i deckom ovo meni može biti zamjena za laptop. Laptop mi ionako stoji 99% vremena zatvoren i priključen na monitor.
Zaggy111 je offline   Reply With Quote
Staro 17.07.2021., 11:08   #3772
tuna3
Postovi: 472
Pa to su i rekli u Q&A nista vise.
A i onaj tko je malo upoznst sa performansama tih Ryzena zna otprilike koje su mogucnosti.
No ta razina detalja i reza na tom ekranu je i vise negodovoljna
Staro 17.07.2021., 16:07   #3773
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,850
Ma da, pa to bi bilo taman - više od 720 ni ne treba,
samo da radi kako spada i bude ugodno za držanje.
S tim da igre koje bih igrao u prijenosnoj varijanti
generalno i nisu zahtjevne (platformeri, možda koji RPG, itd.);
za ostalo, tu je PC.
Napravio i ja rezervaciju (srednji model), pa ćemo vidjeti ..
ima dosta vremena, lako otkažem ako se predomislim.
Staro 28.07.2021., 08:31   #3774
Strider
Nuclear Experiment
Strider's Avatar
Datum registracije: Aug 2009
Postovi: 647
free RunnerDot
Free to keep when you get it before 1 Aug @ 8:00am.
For everything you gain,
You lose something else
Strider je offline   Reply With Quote
Staro 28.07.2021., 09:58   #3775
spawn
spawn's Avatar
Postovi: 8,426
Ajme poklona. Poslat cu im sladoled za zahvalu
Staro 28.07.2021., 11:58   #3776
Morpheous
Morpheous's Avatar
Postovi: 1,140
Haha, baš
Morpheous je offline   Reply With Quote
Staro 29.07.2021., 21:38   #3777
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Play Marvel's Avengers - Play for free! Ends in 3 days
Play Golf With Your Friends - Play for free! Ends in 3 days
Alienware arena - Bloodrayne 1&2 giveawayi
https://eu.alienwarearena.com/ucf/sh...-cut-1-2-lvl-2
https://www.reddit.com/r/FreeGamesOn..._terminal_cut/
Danas je bila jedinica prije oko tri sata, sutra se očekuje isto a 31.7 i 1.8 biti će dvojka
Treba biti level 2 za sudjelovanje u giveawayu.
Old.machine je offline   Reply With Quote
Staro 31.07.2021., 19:06   #3778
Old.machine
Lokacija: ______
Postovi: 1,455
Autor Old.machine Pregled postova
u tijeku je giveaway za dvojku
Staro 06.08.2021., 19:23   #3779
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
Staro 07.08.2021., 15:38   #3780
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,066
Evo još jedan first hand, za one ko ja koji nemreju zmisliti Linusa, pa čak i na razini debilnog thumbnaila
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
