Staro 25.06.2021., 10:54   #31
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,186
Odeš na search i upišeš TPM
Klikneš OK i izbaci ti ovo
i Enejblaš ga
Onda mi se pojavilo ovo upozorenje
Klikneš F10 ili sejv i exit changes
nakon restarta i ponovnog ulaska u UEFI dobijem ovo
Gore ti pišu system requirements:
Đabe sve ako MBO / Laptop nema TPM ili nema mogucnost dodavanja TPM modula
Svaki MBO maker ima drukciji TPM modul jer nije standardiziran te razlikuju se po broju PIN -ova:
Asus, MSI, Gigabyte, Asrock they TPM are not compatible with each other.
As far as I can tell as of 2020 there is no standard TPM header so you must buy TPM from the same vendor as motherboard and even in that case check how many pins you have.
https://superuser.com/questions/9250...he-same-vendor
Navedimo mamutarku kao primjer koji ima ASUS PRIME Z370-A MBO koja ima UEFI i ima DX12 GPU ali jedino mu fali taj TPM
Njegova ploca podržava da se na nju ugradi TPM modul.
TPM modul za Ausu ploce https://www.asus.com/Motherboards-Co...es/TPM-M-R2-0/
How To Enable BitLocker With Intel PTT https://www.legitreviews.com/how-to-...ecurity_211713
Naveo sam kako se trenutno na Win 11 verziji koje je procurila i bez TPM-a može usnimiti Windows 11 , a dal ce se TPM u buducnosti moc zaobic i dal ce Win 11 moc radi bez njega to cemo tek vidjeti.
Windows 11 Leak and TPM 2.0 FIX https://www.youtube.com/watch?v=H3D9o8Dpt-8
How to INSTALL Windows 11 Error FREE on ANY PC! (fast and easy) https://www.youtube.com/watch?v=iL_X_Sxt0vQ
How to bypass TPM 2.0 and Secure Boot on windows 11 installation? Step by Step guide https://www.youtube.com/watch?v=b-2-nIcfh1c
Find Windows 11 specs, features, and computer requirements
Processor: 1 gigahertz (GHz) or faster with 2 or more cores on a compatible 64-bit processor or System on a Chip (SoC)
RAM: 4 gigabyte (GB)
Storage: 64 GB or larger storage device
Note: See below under “More information on storage space to keep Windows 11 up-to-date” for more details.
System firmware: UEFI, Secure Boot capable
TPM: Trusted Platform Module (TPM) version 2.0
Graphics card: Compatible with DirectX 12 or later with WDDM 2.0 driver
Display: High definition (720p) display that is greater than 9” diagonally, 8 bits per color channel
Internet connection and Microsoft accounts: Windows 11 Home edition requires internet connectivity and a Microsoft account to complete device setup on first use.
Switching a device out of Windows 11 Home in S mode also requires internet connectivity. Learn more about S mode here.
For all Windows 11 editions, internet access is required to perform updates and to download and take advantage of some features. A Microsoft account is required for some features.
https://www.microsoft.com/en-us/wind...specifications
Disco moraš enejblat TPM u BIOS -u / UEFI -u pa ce ti Microsoft PC Health Check pokazat "This PC can run Windows 11"
klikni na spoiler za detaljniji prikaz kako to izgleda u UEFI-u od Asus B450 ploce
i Enejblaš ga
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 25.06.2021. u 11:29.
Staro 25.06.2021., 11:00   #32
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,325
enejblao sam ja TPM sinoć na kraju, procesor valjda podržava, ko ima asus ploču i intel cpu:
UEFI - PCH-FW Configuration - PTT
i tamo sam stavio TPP Firmware
taman sam našao da ADM prodaje modul za 90kn, al na kraju ću izgleda moći bez toga
Staro 25.06.2021., 11:39   #33
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,325
jedno pitanje, ako ja imam win 10 retail https://i.ibb.co/zxrgdmW/unnamed.jpg
i idem instalirat win 11 ISO, dal kod instalacije vrijedi win 10 key? pošto je free upgrade kao, zanima me kak aktivirat ako ne radim upgrade iz windowsa 10, nego friški install win 11
Staro 25.06.2021., 11:46   #34
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
Nisam niti ukucaovao key prilikom instalacije, standard shema kao da nemas key sam odabrao i povuko je sam w10 key.
Staro 25.06.2021., 11:53   #35
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,325
aha, još se HOME useri poput mene moraju sa msoft accom logirat pri instalaciji, tak da se nadam da bude onda povukao
Staro 25.06.2021., 19:48   #36
Postovi: 8,250
Windows 11 Feature deprecations and removals
  • Taskbar functionality is changed including: Alignment to the bottom of the screen is the only location allowed.
  • Desktop wallpaper cannot be roamed to or from device when signed in with a Microsoft account.
Jebeno, nema kaj, ovi ko da se stvarno trude da ljude prebace na neki drugi OS. Sva sreća pa popularne Linux distribucije fino napreduju, tak da izbora ne nedostaje.
Staro 25.06.2021., 20:33   #37
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,325
dobro je dok može start lijevo, već sam se prepo
Staro 25.06.2021., 20:44   #38
Postovi: 8,250
Ma općenito uvode kojekakve "novosti" koje su pak same sebi svrha, dok istovremeno ograničavaju sasvim normalno korištenje OS-a pod izlikom sigurnosti i napretka.
Staro 25.06.2021., 20:49   #39
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,325
pitaj boga što će još sve ''dodat'' do releasa, smjer kojim ide mi se baš i ne dopada
Staro 25.06.2021., 22:12   #40
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,843
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / FreeBSD 14.3
Staro 25.06.2021., 22:56   #41
hardflat
hardflat's Avatar
Lokacija: Sisak
Postovi: 250
TPM nije bauk jedan dll. iz windowsa 10 to može bezbolno riješiti!
Najbolje čekati do kraja godine kada izađu zakrpe i dok "dobri ljudi" isključe sve od MS-a što vas prati i guta disk i memoriju!
Sam OS izgleda ok, i radi fluidno, ali ima tonu stvari koje se same updejtaju iako ste isključili updejtanje!
Pričekajmo pa vidimo što će dalje biti!
hardflat je offline   Reply With Quote
Staro 26.06.2021., 01:51   #42
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,325
evo i ja stavio 11, sve je ok za sada
pri startapu me traži PIN svaki puta, nema opcija da disejblam to, sivo je, ima neki način drugi?
Staro 26.06.2021., 06:46   #43
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
Slobodno me dodajte na PSN
Staro 26.06.2021., 06:54   #44
tomek@vz
tomek@vz's Avatar
Postovi: 4,843
Zohari danasnjice. Netko tome treba stati na kraj ili regulativama ili jednostavno ko u stare dane cizma u paksu...
Staro 26.06.2021., 07:06   #45
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,265
A piše odmah u tekstu da se valjda da uključiti fTPM koji je ako sam skužio softverski.
Staro 26.06.2021., 08:48   #46
tomek@vz
tomek@vz's Avatar
Postovi: 4,843
Autor Disco Pregled postova
Komentar je bio sa skalpere MS samo pokusava opet gurat ono sto je dobro za MS na silu i stetu korisnika (iako ce 90% ekipe s vremenom samo klikat next). Stara praksa.
Kaj se teme tice ...ne bas. Moj Lenovo Y520 ima fizicki TPM 2.0 cip ali 11-ici firmware ne pase + unutra je Intel 7th gen. Da mogu se zezat sa pripasavanjem fajlova na instalaciji al cemu? I vecina klasicnih korisnika to nece radit. Posto je lap malo stariji > nema firmware upgrejda (bar zasad ne). Uglavnom ne zamaram se jer mi Widnows nije primarni OS ali je sranje za ekipu koja nije tehnicki potkovana i samo zeli instalirat OS. Komp je samo alat i ne vjerujem da cu ikad biti bas primoran gore vrtjeti Windows 11 - po trenutacnim MS uvjetima. Kemijanje me ne zanima, dok god postoje rijesenja s kojima mogu raditi svoje privatne i poslovne stvari bez kemijanja.
Staro 26.06.2021., 17:27   #47
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,424
A inače ljudi ne vole linux jer je previše kemijanja da se upogoni
Welcome to Windows 11.
Staro 26.06.2021., 18:20   #48
tomek@vz
tomek@vz's Avatar
Postovi: 4,843
Autor mkey Pregled postova
(LOL)
Inace sam mislio na instalaciju Windows 10 vs Windows 11 ali - Touché Razlika je da ne trebas editirat instalaciju Linuxa da instaliras Linux osim ak nemas pojma a zelis instalirat na primjer - Arch :P
P.S. drzimo se teme Win 10 vs Win 11 , necemo spamat
Zadnje izmijenjeno od: tomek@vz. 26.06.2021. u 18:25.
Staro 26.06.2021., 19:19   #49
Mladenxy
Mladenxy's Avatar
Postovi: 4,343
upalio TPM Koja glupost.
Prelazim jer je besplatno, makar nemam potrebe, desetka je super.
Staro 26.06.2021., 21:32   #50
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,083
Windows 11 - info, how-to, pitanja, novosti, savjeti...
Ni moj procesor (i7 8809G) nije kompatibilan
Ima TPM 2.0, ali procesor nije na listi kompatibilnih
I bolje, manje znatiželje i izgubljenog vremena na reinstalacije i podešavanja
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Zadnje izmijenjeno od: 1v@n. 26.06.2021. u 23:30.
Staro 26.06.2021., 21:48   #51
tomek@vz
tomek@vz's Avatar
Postovi: 4,843
Ok...ovo je sad bilo interesantno. Instalirao 11-icu u KVM virtualku - do prvog boota. Konvertirao u RAW image > lupio na disk. Boot. Sve radi. Secure Boot onemogucen. Sve - radi najnormalnije. Kad zelim direkno instalirati - banana. Dakle...svaka rijec je suvisna
Staro 26.06.2021., 22:57   #52
Postovi: 8,250
WhyNotWin11 is a better replacement for Windows 11's PC Health Check
Instead of just giving vague responses like the PC Health Check tool, WhyNotWin11 will list each requirement and show where your computer's hardware is lacking.
Izvor: BleepingComputer
Staro 26.06.2021., 23:15   #53
Mladenxy
Mladenxy's Avatar
Postovi: 4,343
Kaj ne bi trebalo biti ovak
Staro 26.06.2021., 23:21   #54
Postovi: 8,250
Je, ali ne pada mi na pamet to sve uključiti samo zato, jer si je Microsoft nekaj zamislil.
Windows 10 je službeno podržan do 2025., a do onda se lako mogu opet prebaciti na Linux.
Fedora je ionak uvijek spremna, samo prebacim defaultni boot disk i to je to.
Staro 27.06.2021., 12:31   #55
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 946
Znaci i5 7500 nije dovoljan za win11 i sada bi ja ako zelim nove win trebao kupiti novi cpu i mbo? Hm, sta reci....
Prvo te prc4 Intel sa soketima a sada i win
Vidjet cemo sto se Apple na jesen predstaviti. Mozda je vrijeme da se ode u drugi tabor.
robee je offline   Reply With Quote
Staro 27.06.2021., 12:55   #56
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,359
Autor robee Pregled postova
ne razumijem tu foru s nekompaktibilnosti s 6. i 7. gen. procesora, recimo i7 7700K, sto... preslab je za win11... u čemu je fora s tim, stariji cpu nemaju TPM 2.0 ?
btw. robee... kojiu je to softver, app ?
Zadnje izmijenjeno od: nick praskaton. 27.06.2021. u 13:09.
Staro 27.06.2021., 13:09   #57
Postovi: 23,528
U pozadini je ista priča kao sa supportom / instalacijom W7 samo obrnuto,
želi se raju maknuti od "starog" hw kako bi umjetno jedina opcija bila W10 / W11 iz win svijeta.
Obavezni TPM modul tu isto igra + pročitajte čemu je taj modul namijenjen,
sad na to nadodajte priču oko win licence, detekcije pojedinog kompa i sl.
Po onom šta je ekipa otkrila / napisala W11 Home varijanta ide samo preko online accounta + TPM ... pogodi dalje ...
Staro 27.06.2021., 13:10   #58
Postovi: 8,250
Prodaja novih računala, tj. prisiljavanje običnog korisnika koji u panici gleda kako ne može koristiti novi Windows 11 OS, a "treba i mora" pa kreće u kupnju novog hardvera.
Nek se fino do kraja izjasne, pa onda, ako stvarno nekome trebaju novosti i prednosti koje donosi novi OS - može si lakše isplanirati prelazak i potencijalnu nadogradnju.
Ko bi ih znal kaj točno izvode s ovom verzijom, ali ne treba odmah skakati na prvi vlak za Windows 11.
Staro 27.06.2021., 13:51   #59
masterCG
Datum registracije: Apr 2021
Postovi: 124
Ja sam tek nedavno prešao na Win 10 nakon ne znam koliko godina koristenja Windowsa 7 jer sam nabavio novu konfu na koju ide samo 10 i jednostavno sam bio prisiljen.
U ovih par mjeseci koliko sam na Win 10 mogu reci da je to jedno veliko sranje, razno razne bugove i nepravilnosti u radu OS-a imam konstantno dok na Win 7 nisam imao apsolutno ni jedan problem svih tih godina.
Ne vidim apsolutno ni jednu prednost windowsa 10 i sta sam to dobio, a da nisam imao na Win 7.
Sad se vec gura Win 11 jer se zeli imati potpuna kontrola nad nasim pc-evima sa raznim novim cakama, a ujedno se potice potrosnja i prodaja novog hardvera.
Problem je sto alternative nema, na Linuxu ne radi dosta toga i treba puno vremena da bi se upogonili neki programi koji po defaultu ne rade, ali ako to bude jedina opcija onda ce biti linux i gotovo...
Ne znam kakav je macOS sa svojim softverom i guraju li oni spijunazu kao ovi smradovi i kakvi su sto se tice updejtova i podrzanog starijeg hardvera.
Ali uglavnom, treba polako prelazit na nesto drugo jer ovo ne ide dobrim smjerom.
masterCG je offline   Reply With Quote
Staro 27.06.2021., 13:59   #60
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Autor masterCG Pregled postova
Kao npr?
žmnpp
