Staro 18.06.2021., 19:53   #31
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Ovo je baš tužno.
Sent from my SM-N950F using Tapatalk
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 18.06.2021., 20:01   #32
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ne znam, ne mogu se vec duze vrijeme oteti dojmu da je u repki nesto trulo, kao da nisu kompatibilni. Cijela igra ide suvise sporo, previse dodira sa loptom i uporno vracanje lopte unatrag.
Neki doslovno bjeze od lopte a oni koji bi trebali vuci igru prema naprijed i koji bi trebali biti mozak igre kao da nisu prisutni.
Boga mi, ni Dalic ne izgleda zainteresirano.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 18.06.2021., 20:02   #33
Exomaniac
Datum registracije: Mar 2016
Postovi: 773
Žalosno, da nisam vidio postavu, ja ne bi znao da Kramarić uopće igra. Rebić 1 na 1 s golmanom ni ne pogodi golmana barem. Pokoj im duši, al Zambata i Cico dan danas imaju veće šanse za zabit gol nego što ih ima Rebić.
Igra je troma, bezveze, igrači na terenu izgledaju kao usporeni film
Ajde, fala Bogu pa smo živnuli u drugom poluvremenu, čim Petko razigrava u napadu to odma liči dosta bolje nego prije
Zadnje izmijenjeno od: Exomaniac. 18.06.2021. u 20:20.
Exomaniac je online   Reply With Quote
Staro 18.06.2021., 21:24   #34
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,553
pitaju me na poslu dal se ovo prenosi negdje na njemački?
mislio sam da ide na zdf-u ali kažu mi da ne...
gdje to gledati a da je na njemački? mislim na prvenstvo općenito.
Staro 18.06.2021., 21:25   #35
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,837
nek ispadnu što prije.. ponestalo sreće od 2018. godine.. ipak mamićeva repka treba još puno pure pojest da bi to bilo to.. počevši od lukice srednjeg imena ne sjećam se i ostatka ekipice
Staro 18.06.2021., 21:31   #36
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor jp_rv Pregled postova
Ja gledam na Waipu, prijenos prvenstva je jedan dan na ARD (1/Das Erste HD) a drugi dan na ZDFHD-u. Danas su tekme na ZDFHD-u.
Staro 18.06.2021., 21:34   #37
jp_rv
Lokacija: istra
Postovi: 3,553
pretpostavljam da onda ide i na ne-HD verzijama tih kanala? jer imamo samo SD kanale na centrali, a vučemo ih sa astre.
tnx
Staro 18.06.2021., 21:35   #38
spawn
spawn's Avatar
Postovi: 8,483
Bit ce dobra repka kad se maknu oni koji.me doprinose. Trener treba vidjeti tko treba s klupe
Staro 18.06.2021., 21:38   #39
John Creasy
Lokacija: Beograd
Postovi: 2,837
tnx
ide na SD ZDF isto večeras u 21 utakmica
Staro 18.06.2021., 21:52   #40
nickross
Budget gamer
Datum registracije: Nov 2017
Postovi: 909
čim su se maknuli ti na poluvremenu bilo je puno bolje.
nickross je offline   Reply With Quote
Staro 18.06.2021., 22:49   #41
Exomaniac
Postovi: 773
Ono što mi nije jasno kako sudac svira kraj 20 sekundi prije isteka nadoknade, i to dok mi još imamo loptu na njihovoj polovici. Pa valjda si za nekog vraga produžio barem 3 minute
Staro 18.06.2021., 23:08   #42
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ako Škoti protiv nas budu igrali kako igraju protiv Engleza, uff...bit ce ovdje svega.
Staro 18.06.2021., 23:12   #43
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,346
I neka, ili nek pocnu igrat ili nek se vrate doma.
Meni se cini da ovo nije ekipa, nema te simbioze ko 2018.
Ne zanima me tko je kriv, al meni djeluje da to nije to.
Naravno da bi najvise volio da se medjusobno isamaraju i da pokazu da smo svi u krivu.
žmnpp
Staro 18.06.2021., 23:48   #44
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Tek sad vidjeh da je UEFA dala Modricu nagradu za najboljeg igraca na utakmici. WTF
Staro 19.06.2021., 15:00   #45
danijel_b
danijel_b's Avatar
Datum registracije: Jun 2004
Lokacija: Sj. Njemacka
Postovi: 503
tnx
Ja gledam preko neta, zdf live i ard live aplikacije na TV ili mobu
Gesendet von meinem SM-G781B mit Tapatalk
danijel_b je offline   Reply With Quote
Staro 19.06.2021., 16:20   #46
tizhu
Datum registracije: Sep 2014
Postovi: 775
Autor estugarda Pregled postova
To stvarno ne bi imalo smisla...
pros:
- uigraš mlade koji imaju motiv i brži su i izdržljiviji od ovih.
- stvoriš jako dobru bazu i ozračje između novih dečkiju i zbližiš ih
- usput imaš promjenu generacije na bezbolan način jer trenutna nema snage i znanja za velike stvari. naravno - izbornika mjenjati isto da se upoznaju i budu klapa.
- daš poticaja u narednoj sezoni svim budućim i trenutnim reprezentativcima da igraju u što boljim ligama i da budu u prvoj postavi svog kluba.
- svi ti novi i mlađi dečki će igrati moderniji nogomet od ovih koji su odavno prestali učiti već rade sve na rutinu i iskustvo.
- za tri godine imaš repku u peaku snage sa uigranim ili relativno uigranim nogometašima sa prosjekom od kojih 25 ili 27 godina nevažno i bit će spremni na dobar rezultat - ne kažem da će ga ostvariti, ali od nekud se mora krenuti
PS mandžo, boban i neki pojedinci su otišli iz repke i dali mjesta kao prava gospoda znajući da je ritam igranja u ligi visok i da još moraju igrati kvale u kojima nekad i nemaš motiv i rađe bi ostao dva tjedna doma sa family i slično.
EDIT:
englezi puste česima i idu dalje kao drugi u slučaju da mi pobjedimo škote - iako mislim da nemamo znanja ni snage.
isto tako ako bude x - eng i česi sa 5 bodova idu dalje bez obzira ko pobjedi između nas i škota i već vidim 0:0 ili 1:1 loool
Staro 19.06.2021., 18:25   #47
masterCG
Datum registracije: Apr 2021
Postovi: 124
Autor tizhu Pregled postova
pros:
Jedno je igrati football manager na PC-a pa eksperimentirati, a drugo je realnost koju ti ni najmanje ne razumijes kad je nogomet u pitanju.
Nogomet je prije svega biznis u kojem je cilj zaraditi, a ne napravit rezultat.
masterCG je offline   Reply With Quote
Staro 19.06.2021., 18:48   #48
spawn
spawn's Avatar
Postovi: 8,483
Autor masterCG Pregled postova
Totalno fulan komentar. Sve gore napisano je točno. Samim time što će mladi igrat i trčat, veće su šanse da se prodaju za dobre pare i naravno klubovi zaradit. Rebić i ekipa su dali ono što mogu dati, on jednostavno nema neku ulogu o kojoj ovise novi igrači. Ja bih zadržao Perišiča i Modrića i sve ostale na klupu da ulete a ne biti u prvoj postavi. Pošto je nerealno očekivati Modrića u repki nakon Eura, od novog trenera se očekuje remont i samim time rasprodaju igrača nakon Svjetskog. Sve je to biznis, i svi naši igrači su se više manje rasprodavali nakon Eura ili SPa.
Staro 19.06.2021., 18:54   #49
masterCG
Postovi: 124
Ni ti nista ne kuzis, nije trener taj kojem je dozvoljeno raditi ikakav remont niti on poziva igrace na svoju ruku.
To je biznis, trener je tu marioneta i radi prema uputama, igraci imaju menadzere, vrte se milijuni.
Kakvi remonti i reforme...
Neki stariji igraci moraju igrati jer su zvijezde i oni prodaju gledanost, a od mladjih ce igrati onaj koji ima dobrog menadzera.
Staro 19.06.2021., 18:56   #50
spawn
spawn's Avatar
Postovi: 8,483
Kakvi stari igraci kad su svi najbolji otisli a sad ode i Modrić? Pa valjda stvaraš nove zvijezde i na njima zarađuješ.
Staro 19.06.2021., 21:30   #51
King of 4
Datum registracije: Dec 2020
Lokacija: na zapadu
Postovi: 150
Autor Alph4Dawg Pregled postova
meni samo nije jasno zasto je Modric igrao obrambenog cijelu tekmu, pa jel nije on veznjak i treba goniti igru naprijed.
Nije lopta kod njeg bila 10 puta.
King of 4 je offline   Reply With Quote
Staro 19.06.2021., 21:35   #52
spawn
spawn's Avatar
Postovi: 8,483
Zato sto se nije dalo drugima trcat pa je on trcao. On je defenzivni veznjak po prirodi iako je cesto u napadu/gradnji igre. Zelim mu svu srecu i nadam se da ce se oprostiti od reprezentazije nekakvom pobjedom ili bar vrhunskom igrom
Staro 23.06.2021., 01:14   #53
spawn
spawn's Avatar
Postovi: 8,483
Čestitke na prolazu skupine, Modrić legenda. Meni osobno, osim što konačno igraju mladi, ugodno iznenađenje Kovačić. Konačno je po meni pokazao ono što on ima.u sebi, znanje, snagu i volju ,šteta što nije komstantan.
Staro 23.06.2021., 01:28   #54
King of 4
Lokacija: na zapadu
Postovi: 150
Modrić napokon na poziciji di treba biti. Veznjak i playmaker.
Napokon su svi trčali i igrali šire i radili presing. Ovu su zasluženo dobili. Idemo u finale
Staro 23.06.2021., 10:22   #55
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,216
Barišić je space shuttle za Gvardiola na beku. Nadam se da će iduću utakmicu Gvardiol biti stoper umjesto Lovrena kojeg nema zbog kartona.
Staro 23.06.2021., 10:23   #56
viper84
viper84's Avatar
Datum registracije: Dec 2012
Lokacija: Vž
Postovi: 277
Konačno da su odigrali kako spada i nadam se da je Dalić nešto naučio iz ovog (makar on teže uči). A Modrić? Jednom riječju, legenda. Bit ćemo u velikom problemu kad ga više ne bude zato uživajmo dok traje.
Trgovine: 1, 2, 3, 4
viper84 je offline   Reply With Quote
Staro 23.06.2021., 12:37   #57
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,138
To te ja pitam. Modrić, već sada legenda...
Sad i ostatak Eura i današnje utakmice u 18:00 i 21:00 imaju opet smisla, da vidim buduće protivnike.
Rasplamsao mi se onaj žar iz 2018-te
Staro 23.06.2021., 15:27   #58
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,516
Jedna dobra nakon 15 losih neznam koliko je dokaz da ce na sljedecoj biti bolje ali opet napokon to lici na nesto i ima glave i repa
Staro 23.06.2021., 15:35   #59
spawn
spawn's Avatar
Postovi: 8,483
Jedna dobra na 15 losih je dokaz da nesto ne stima u repki koja ima dobre igrace jer su to pokazali. Daleko je to od vrhunske momčadi ali nešto znači 3 gola zabiti ekipi koja je motivirana , kojoj isto prijeti ispadanje, ekipi koju nikad nismo dobili. Znači, kockice su tu, samo se trebaju složiti i u igri i u glavama. Nije to samo kod nas. I Englezi imaju taj problem već godinama.
Staro 23.06.2021., 22:53   #60
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,138
smiješan penal na Mbapeu za francusku protiv portugala
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
