Staro 12.05.2020., 23:21   #1021
DSA
Lokacija: Sarajevo
Postovi: 291
Jel pametno umisto antivirusa uzeti malwarebytes premium? jel ista zaštita on ko antivirus ili se ipak razlikuju?
Nije. Stavi neki klasicni antivirus, recimo Avast Free ili Kaspersky Security Cloud Free a kad je MBAM njega koristi za povremeno skeniranje sistema. MBAM ima i browser ekstenziju koja nije losa, ali prednost ipam dajem UBO ili ADG
DSA je offline   Reply With Quote
Staro 18.05.2020., 15:25   #1022
Postovi: 8,354
Windows 10 Defender's hidden features
Većina korisnika je sasvim sigurna s Windows Defenderom, jer su ga stvarno doveli na fini nivo, a i cijelo vrijeme implementiraju nove mogućnosti, samo jebiga - treba tu i tam koju opciju provjeriti i podesiti.
Windows 10's built-in Microsoft Defender antivirus solution has many advanced hidden features that allow you to customize how the security software works. Unfortunately, most people do not know these settings exist or even how to access them. Now that you know how many hidden advanced settings there are for Microsoft Defender let me introduce you to a utility called ConfigureDefender that allows you to manage them easily. ConfigureDefender was created as part of the Hard_Configurator project but was also released as a standalone project. Using this utility, Windows 10 users will get access to a graphical user interface that allows them to view all of Microsoft Defender's settings and easily set them.
Izvor: BleepingComputer
Staro 19.05.2020., 10:40   #1023
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,012
Jesi isprobao kako funkcionira utility?
Sent from my Redmi Note 8 Pro using Tapatalk
Staro 19.05.2020., 11:08   #1024
Postovi: 8,354
Jesam, jučer i nema nekih problema (bar kod mene).
Staro 04.09.2020., 10:18   #1025
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
Jel se može podesiti kako Bitdefender Antivirus Plus da ne cacka di nema potreba?
Piratsko nemam instalirano bas nista, ako ta informacija igra ulogu. Isto tako ne posjecujem sumnjive stranice.
Radi se o poslovnom kompu koji služi za obradu podataka (dosta HW zahtjevno), pa ocu imamti maximum hardware-a na raspolaganju.
Hvala
Staro 06.09.2020., 21:22   #1026
Mogy
Hala Madrid!
Mogy's Avatar
Postovi: 1,321
Uzeo sam si jučer preko ebaya bitdefender total security, 3 mjeseca za 9kn (a godinama prije toga koristio nod32 i malwarebytes). Čitao malo po komentarima i odlučio preći na bitdefender pošto ga svi hvalite i kažete da je najbolji. Koju još zaštitu bi preporučili za kućnog korisnika windowsa tj. što vi koristite? Koristim ublock origin ekstenziju za browser i još par stvarčica.
Zadnje izmijenjeno od: Mogy. 06.09.2020. u 22:05.
Mogy je offline   Reply With Quote
Staro 06.09.2020., 22:31   #1027
d0X
Kostolomac
d0X's Avatar
Postovi: 1,519
@The Exiled, hvala na ovome, skinuo sam Hard_Configurator. Super alat. Jedino sam Default Security Level stavio na Unrestricted jer mi je draži default allow pristup.
PSN Steam
d0X je online   Reply With Quote
Staro 08.04.2021., 17:45   #1028
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
treba mi antivirus pa me zanima ima li kakvog smisla oslanjati se na microsoftov defaultni defender ili to ne vrijedi ništa? ako taj ne vrijedi ničemu, onda ću staviti open source ClamAV, samo me zanimaju vaša mišljenja i iskustva?
ševa!
Staro 08.04.2021., 17:53   #1029
DSA
Lokacija: Sarajevo
Postovi: 291
Autor ALiEN17 Pregled postova
Defender je danas jako dobar antivirus. Mozes ga dodatno “utegnuti” sa configure defender i bice bombona. Mozda jos staviti simple windows hardening tool i run by smart screen. U browsere koji koristis stavi par ekstenzija kao npr. Bitdefender TrafficLight, zatim uBlockorigin i privacy badger. Ovo ovako sve podeseno imaces zastitu na nivou komercijalnih rjesenja.
Staro 08.04.2021., 17:56   #1030
zalman1
zalman1's Avatar
Datum registracije: Mar 2017
Postovi: 623
Defender je dovoljan, uz njega jos skini besplatan program za spyware:
https://www.superantispyware.com/
zalman1 je offline   Reply With Quote
Staro 12.05.2021., 23:51   #1031
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
upravo kupio preko gamers outleta key za Kaspersky Internet Security 2020 i kada pokušam trail verziju downloadanu sa njihove službene stranice aktivirati tim keyom, naravno da mi izbaci poruku da je invalid code jer je na web stranici naravno moguće skinuti samo najnoviju verziju 2021 - pretpostavljam samo: bacio sam tih 20-ak kn u vjetar? ako je tako, zašto se to onda prodaje uopće na gamers outletu? :think:
ševa!
Staro 13.05.2021., 07:50   #1032
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,829
Defender je dovoljno dobar. Starta se kao servis unutar Windowsa pa ga neće baš svaka šuša od virusa isključit, ne troši puno resursa kao neki antivirusni programi koji znaju usporiti računala do bola. Konfiguracija je jednostavna samo si korisnik treba dati truda pa pogledati koje sve opcije ima na raspolaganju.
Staro 13.05.2021., 07:57   #1033
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 497
Ja sam sa svakim keyom mogao aktivirat noviju verziju softwarea. Mozda ti je nevaljala...
Sent from my SM-G965F using Tapatalk
njOob je offline   Reply With Quote
Staro 13.05.2021., 16:47   #1034
dadoremix
dadoremix's Avatar
Postovi: 4,720
skini 2020 verziju i probaj
ili pa reklamiraj i uzmi 2021 verziju
Staro 13.05.2021., 17:01   #1035
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
nema nigdje vise verzije 2020 za download, poslao sam im ticket pa neka mi vrate lovu - ako je to moguce uopce?
p. s. a mozda je i key stvarno invalid
ševa!
Staro 13.05.2021., 17:10   #1036
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 497
Ja sam uvijek mogao aktivirat noviju verziju. Jedino ako nemas za Total Security ili nes drugo...
Staro 13.05.2021., 19:48   #1037
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
ne, imam za onaj internet security
ševa!
Staro 13.05.2021., 20:58   #1038
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 497
Jos mozes napravit account na kaspersky i tamo dodat activation code pa vidi sto kaze.
Staro 14.05.2021., 09:55   #1039
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,242
Autor njOob Pregled postova
hvala zapravo je tako i upalilo, morao sam se registrirat na njohovoj stranici, ubaciti kod i onda sam dobio link za download, kada sam downloadao opet me trazilo isti kod bas u programu, ubacio i dobio aktivaciju za sljedecih sest mjeseci, siper
ševa!
Staro 14.05.2021., 15:03   #1040
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
I nakon 6 mjeseci izbriši AV, postavi Defender i nemaš više problema sa aktivacijama
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 03.06.2021., 17:59   #1041
Postovi: 8,354
Norton 360 antivirus now lets you mine Ethereum cryptocurrency
NortonLifelock has added the ability to mine Ethereum cryptocurrency directly within its Norton 360 antivirus program as a way to "protect" users from malicious mining software. This new mining feature is called 'Norton Crypto' and will be rolling out tomorrow to Norton 360 users enrolled in Norton's early adopter program. When Norton Crypto is enabled, the software will use the device's graphics card (GPU) to mine for Ethereum, which will then be transferred into a Norton wallet hosted in the cloud. It is not clear if every device running Norton Crypto is mining independently or as part of a pool of users for a greater chance of earning rewards of Ethereum.
Jedna od žešćih gluposti za tzv. AV rješenje, ali očito da svi pošto-poto žele skočiti na kripto vlak.
Staro 03.06.2021., 18:23   #1042
masterCG
Datum registracije: Apr 2021
Postovi: 124
Zesca glupost je uopce imati third party AV
masterCG je offline   Reply With Quote
Staro 03.06.2021., 18:26   #1043
Postovi: 8,354
Je, ali većina prosječnih korisnika bude i na ovo nasjela, isto kak im treba zaseban AV ili dva-tri, mada je zapravo dosta onaj integriran u OS i pamet u glavu.
Staro 05.11.2021., 14:47   #1044
Roberto
Roberto's Avatar
Postovi: 2,648
Baš sam usred žešće rasprave s jednom iT firmom koja se bavi bazama podataka. Naime, u firmi u kojoj održavam računala oni će sad na novi server postaviti svoju app, i kao uvjet traže da se instalira neki third aprty antivirus, (štoviše, oni preporučuju eset).
A ja u toj firmi na dvadesetak računala zadnjih 10 godina nisam stavljao nikakav AV osim defendera, nikad nisu virus pobrali ili imali neko sranje.
Raspravljam se s njima već danima oko toga, nemam više volje ni živaca, i vjerojanto ću popustiot, uzet licencu za server i par računala, i kad istekne deinstalirat
Uistinu, nisam primjetio osobiti razlog za kupovinu licenciranog AV, barem iz mog primjera - defender sve ove godine radi i štiti ok, barem za većinu korisnika
Staro 05.11.2021., 14:58   #1045
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Meni je pomogao najviše (i jedino) samo oko detekcije i brisanja dolazećih malwarea u Outlooku korisnika.
Sve ostalo čemu bi trebao služiti - ESET se nije ni pokazao ni dokazao. Pogotovo u nekim realtime detekcijama.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 05.11.2021., 16:58   #1046
masterCG
Postovi: 124
Autor Roberto Pregled postova
jbg, to je zato jer ne uzimas proviziju po prodaji eset-a kao ta IT firma za baze.
Staro 06.01.2022., 19:49   #1047
Postovi: 8,354
Nakon probnog roka, Norton AV "rješenje" sad po defaultu dolazi s implementiranim kripto ludostima, tako da su krajnji korisnici sigurniji uz 15% provizije.
Norton 360 now comes with a cryptominer
Norton 360, one of the most popular antivirus products on the market today, has installed a cryptocurrency mining program on its customers’ computers. Norton’s parent firm says the cloud-based service that activates the program and allows customers to profit from the scheme — in which the company keeps 15 percent of any currencies mined — is “opt-in,” meaning users have to agree to enable it. NortonLifeLock began offering the mining service in July 2021, but the program gained broader attention on Jan. 4 when Boing Boing co-editor Cory Doctorow tweeted that NortonCrypto would run by default for Norton 360 users. Norton Crypto lets users withdraw their earnings to an account at cryptocurrency platform CoinBase, but as Norton Crypto’s FAQ rightly points out, there are coin mining fees as well as transaction costs to transfer Ethereum.
Izvor: Krebs on Security, BleepingComputer i gHacks
EDIT: Popularna antivirusna rješenja sada i službeno više ne služe apsolutno ničemu, ponajmanje zaštiti od malicioznih čuda tehnike.
500M Avira Antivirus users introduced to cryptomining
Avira antivirus — which has built a base of 500 million users worldwide largely by making the product free — was recently bought by the same company that owns Norton 360 and is introducing its customers to a service called Avira Crypto. Founded in 2006, Avira Operations GmbH & Co. KG is a German multinational software company best known for their Avira Free Security (a.k.a. Avira Free Antivirus). In January 2021, Avira was acquired by Tempe, Ariz.-based NortonLifeLock Inc., the same company that now owns Norton 360. Like Norton 360, Avira comes with a cryptominer already installed, but customers have to opt in to using the service that powers it. In August 2021, NortonLifeLock said it had reached an agreement to acquire Avast, another longtime free antivirus product that also claims to have around 500 million users. It remains to be seen whether Avast Crypto will be the next brilliant offering from NortonLifeLock.
Zadnje izmijenjeno od: The Exiled. 08.01.2022. u 19:48.
Staro 08.04.2022., 20:19   #1048
Roberto
Roberto's Avatar
Postovi: 2,648
Baš malo gledam, potpuno freaky čega sve danas nema što se malwarea tiče.
keyloggery, cryptomineri, clipboard hijackeri, uz već klasične trojance i viruse...
Kako se od toga uopće zaštititi? Da li tu rješenja poput Malwarebytes Antimalware pomažu ili ne? Ima li išta da može sranja poput tih novih malwarea ala clipboard hijackera spriječiti realtime?
Staro 08.04.2022., 20:27   #1049
Postovi: 8,354
Iskreno, ništa više nije sigurno, tj. nema te zaštite koja može korisnika zaštititi od vlastite ili tuđe gluposti.
Malwarebytes je OK, ali obzirom kakve sve virtualne gamadi ima, nije ni Malwarebytes imun u svakoj situaciji.
Jebiga, treba još dodatno paziti kud se diljem neta krećemo, kakve stvari se skidaju, instaliraju i koriste.
Privatnost na netu je ionak fatamorgana, a društvene mreže su samo dodatno pojačale taj efekt.
Staro 08.04.2022., 20:34   #1050
Roberto
Roberto's Avatar
Postovi: 2,648
Ma je, to se sve slažem. Oduvijek govorim da nema tog softwarea koji će nekog zaštiti od njegove vlastite gluposti..
Čisto razmišljam kako average joea zaštiti od njega samog
