Lokacija: Kutina
Postovi: 1,208
SuperTalent novosti
novosti iz kod nas popularnog SuperTalenta: San Jose, California - January 25, 2006 -- Super Talent Technology today announced two new ultra high performance DDR memory kits. Both kits consist of a pair of 1GB DDR memory modules. X40PB2GC3 is a kit of two 1GB PC4000 CAS-3 modules. This kit supports ultra fast 500MHz clock speeds at standard latencies. X32PB2GC2 is a kit of two 1GB PC3200 CAS-2 modules. This kit is ideal for users demanding reduced latencies at standard clock speeds. These products were developed specifically for gamers and enthusiasts who need top notch performance with no compromises in reliability. Both kits have been tested extensively in Super Talent's engineering labs on multiple enthusiast motherboards to ensure compatibility and reliability. Every module built is subjected to a full battery of production testing at its rated specifications before it gets the Super Talent label. Both these new memory kits are clad in thermally bonded aluminum heat spreaders to deliver optimum thermal performance. Keeping critical components cool not only enhances performance, it also extends the life of the components. Super Talent backs all their DRAM modules with a lifetime warranty. According to Super Talent Marketing Manager, David Crume, "Super Talent has established a solid reputation for building quality desktop memory. With these products, we've leveraged our engineering and manufacturing strengths to make a competitive entry into the performance memory market." Both products are available today from resellers worldwide. http://supertalent.com/Home/2GB_DDR_KITS.php Zadnje izmijenjeno od: Vedran. 27.01.2006. u 19:35. |
Lokacija: n/a
Postovi: 6,128
Uf taman da ubacim jos jedan stick od 1GB i da sve ostane na CL2. Sigurno ce ih bit uzet i posebno. |
Lokacija: Kutina
Postovi: 1,208
pojedinačni 1GB PC3200 CL2 stickovi postoje već neko vrijeme... ima ih u Ve-milu, ali nisu na lageru već neko vrijeme. |
#4 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
![]() Sudeći po njihovom promptnom naručivanju još ih neće ni biti jedno vrijeme... |
#6 | |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,771
#7 | |
Super Moderators
Postovi: 17,485
Lokacija: Kutina
Postovi: 1,208
jesu... ali jutros nisu bili raspoloživi. izgleda da imamo SuperTalent fan club ovdje. ![]() |
#10 | |
M.U.P.
Datum registracije: Sep 2004
Postovi: 2,277
Lokacija: Ispred kompa
Postovi: 2,004
kvragu i sve nekak mi je malo puno dat 2 k krznasa, neznam di da potamanim toliko krznatih vec sam sve izlovil. hm treba kupit x19000 pa sad jos 2 gb meme pa di da ih toliko nadjem :-(. neznam nadam se da cijene padnu bar malo :-(
#12 | |
Lokacija: Kutina
Postovi: 1,208
![]() :burn: EDIT: previdio rendulu... ajde vas dva u shopping. ![]() |
Lokacija: Kutina
Postovi: 1,208
ovako... prijatelji SuperTalenta. ![]() malo sam se poigrao sam svojim stickovima (koje inače 24/7 držim 2.5-3-2@228MHz) i evo rezultata: http://img93.imageshack.us/img93/3918/st2503324ss.jpg sutra idemo dalje, nadam se. ![]() Zadnje izmijenjeno od: Vedran. 27.01.2006. u 01:05. |
#14 | |||||||||||
Postovi: 3,263
Krenio si masnjakovim stopama... ![]()
#15 | |
Datum registracije: Jun 2004
Postovi: 3,996
#16 | |
Lokacija: Kutina
Postovi: 1,208
Zadnje izmijenjeno od: Vedran. 27.01.2006. u 01:33. |
#17 | |
Postovi: 3,996
Ne pratim ti ja te nove AMD-ove pa nemam pojma a i nije me briga,sorry što sam pitao ![]() Zadnje izmijenjeno od: Srky. 27.01.2006. u 12:36. |
#18 |
Lokacija: Kutina
Postovi: 1,208
ako zbog 'rolleyes-smileya' misliš da se ljutim evo... mičem ga. ![]() |
#19 |
Super Moderators
Postovi: 17,485
I, ima li ikakvih informacija po netu o tim 1GB CL2 modulima? Ja nisam bogme ništa uspio naći ![]() |
#20 |
Lokacija: Kutina
Postovi: 1,208
ne, nema još ništa. ali ne brini, budući da je ovo prvi put da iz SuperTalenta u istu rečenicu stavljaju svoje proizvode i pojmove entuzijasti i gameri uopće ne sumnjam da će se kroz određeno vrijeme pojavit recenzije gorespomenutih. |
#21 | |
Super Moderators
Postovi: 17,485
#22 |
Lokacija: Kutina
Postovi: 1,208
nećeš na XSu naći ništa od 1GB SuperTalentima. mali update, cijelonoćna prime tortura na 250MHz odrađena bez problema: http://img70.imageshack.us/img70/1238/st2503329xb.jpg no izgleda da je tu negdje kraj... 255MHz stabilno nisam izvukao niti sa dizanjem napona, stavljanjem na 2T ni opuštanjem latencija... što samo potvrđuje moju teoriju da sa Infineonima (novije proizvodnje barem) treba samo podešavati CL. Trcd=3 & Trp=2 i to se ne dira, kada zapneš samo opustiš Tcl, eventualno se doda malo Vdimma i to je to. ![]() |
#23 | |||||||||||
Postovi: 3,263
Vekija nek neko krivo pogleda on odma burno reagira, a kolko smo pricali o S754 i Single Channelu mogo je i zapamtit ![]() @Vedran Fino taj talentirani ram ide ako izostavimo Jelcov ![]() ![]()
#24 |
Super Moderators
Postovi: 17,485
Meni je dosta 24/7 stabilno i ovo ![]() Proc na 2500, mema na 208... |
#25 |
Super Moderators
Postovi: 17,485
Ni Everest nije loš. Pitanje je kakve bi reze davale na 250 CL3??? Meni je dosta i CL2 ![]() |
#26 |
Lokacija: Kutina
Postovi: 1,208
ma ide i Jelcov... samo ne na DFI ploči. masni je isto imao muke s raznim SuperTalentima na DFI NF4, npr. budeov mu ne ide ni blizu kao na Epoxici. evo vam (n)Everest: http://img82.imageshack.us/img82/10/st250332read3fz.jpg da je DC bio bi fin score. ![]() inače, moj se ponaša ovako nekako: 2-3-2 - 210MHz 2.5-3-2 - 230MHz 3-3-2 - 250MHz sve to sa 2.6-2.7V. |
#27 |
Super Moderators
Postovi: 17,485
Ovaj moj se da navući sa 2-3-3 na 215 max. Ovo mi je najstabilnije za najbolje perfomanse. Taljent ok. radi na DFI ali ne voli dividere i bilo koji CL osim 2 ![]() Zato mi je Redline bio ok. ![]() Proc mi je max. 2650, na toliko je radila i mema 2-2-2-5 i bog te veseli... Uf, da mi se dočepat neke 2x1GB meme CL2 koja bi radila na 220...to bi bilo taman. |
#28 |
Postovi: 4,190
@VedranP: jel stavljas kakve ventove da pusu po memi, dok je drzis na 228 ili su pasivci dosta? |
#29 |
Lokacija: Kutina
Postovi: 1,208
nikakvo dodatno hlađenje za RAMe. istina, vent od Freezera je praktički iznad njih pa dobivaju malo povjetarca. ![]() EDIT: evo baš provjeravam, mlaki su na 250MHz 2.7V. |
#30 | |
Lokacija: n/a
Postovi: 6,128
