Staro 25.09.2020., 20:54   #2431
robert7
robert7's Avatar
Postovi: 1,711
Ekipa, pozdrav, trebam brzi savjet.
Manje od 15incha,sto laksi i sto bolje autonomije, a da opet vrti uredski posao i svakodnevni rad kako spada.
Cash placanje
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 25.09.2020., 21:55   #2432
Postovi: 16,957
Zenbook.
Staro 25.09.2020., 22:02   #2433
Pentel33
Datum registracije: Feb 2020
Postovi: 327
Autor robert7 Pregled postova
Cash placanje
Acer Swift 3 sa i5 i IPS ekranom, ovaj model:
https://www.nabava.net/search.php?q=NX.HPMEX.002
Pentel33 je offline   Reply With Quote
Staro 25.09.2020., 22:07   #2434
robert7
robert7's Avatar
Postovi: 1,711
Da li je taj proc bolji od Ryzen5 3500u?
http://www.prosat.hr/default.aspx?pi...m_medium=click
Ovo mi je nekako prvo upalo u oci?
Staro 25.09.2020., 22:54   #2435
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
Nadmašite ovo
Lenovo IdeaPad Flex 5 14ARE05 81X2009ASC 4929 Kn
Frendica kupila prije 2 dana na moju preporuku i oduševljena je.
https://www.ekupi.hr/hr/Ra%C4%8Dunal.../p/EK000326709
Intel i3/i5/i7 može se samo pokrit preko glave , AMD Ryzen 5 4500U Review, Mid-Range Zen 2 Beats Intel's Best https://www.youtube.com/watch?v=lfkvZc-8ZU8
14" FHD IPS , touchscreen + Lenovo Digital Pen (stylus olovka)
Ryzen 5 4500U
512GB SSD PCIe NVMe
8GB RAM
Tipkovnica s pozadinskim osvjetljenjem
Windows 10 Home
1,5 Kg
Up to 12 hours*
Up to 13 hours 1080p video playback
Rapid Charge Boost: 15 minutes for 2 hours chage (65WHr, FHD only)
*All battery life claims are approximate and based on test results using the MobileMark® 2014 ver 1.5 battery life benchmark test. Actual results will vary, and depend on numerous factors including product configuration and usage, software, operating conditions, wireless functionality, power management settings, screen brightness and other factors. The maximum capacity of the battery will naturally decrease with time and usage.
†All battery life claims are approximate and based on internal test results using continuous 1080p local video playback, 150 nits brightness, default volume level, with the latest update of Microsoft Windows. Actual results will vary, and depend on numerous factors including product configuration, software, operating conditions, screen brightness and other factors. The maximum capacity of the battery will naturally decrease with time and usage.
Rapid Charge Boost: 15 mins of charging gives you up to 2 hours of battery life, based on the MobileMark2014 ver. 1.5 battery life benchmark test.
https://www.lenovo.com/hr/hr/laptops.../p/88IPF501453
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 26.09.2020. u 00:30.
Staro 26.09.2020., 00:01   #2436
Roso
Roso's Avatar
Postovi: 698
Da je bar 15.6" bilo bi idealno.
Roso je offline   Reply With Quote
Staro 13.10.2020., 23:34   #2437
rokoko
In Rainbows
rokoko's Avatar
Postovi: 715
Nadmašite ovo
uzeo sam navedeni laptop, sve super, ali ekran kao i za ocekivat ocajan, svi ti budget ultrabookovi imaju zbilja komican ekran, backlight bleed je uzasan. cak sam uzeo lap jer sam mislio da je WVA panel sto i dalje stoji na ekupi stranici, kad ono najgora vrsta ips-a moguca. mislio sam ga cak vratit unutar 14 dana ali sam smatrao da nema smisla jer ce vjerojatno doc isto g**** od panela, a lap je po ostalim specifikacijama ok samo naprosto ne mogu vjerovat da su TN paneli prije 5g imali bolje rezultate nego danasnji budget IPSovi
"Success can only be achieved with a kind of pioneer spirit and repeated use of three tools: failure, introspection and courage." - Soichiro Honda
rokoko je offline   Reply With Quote
Staro 18.10.2020., 12:26   #2438
Blue Spirit
Postovi: 2,195
Autor rokoko Pregled postova
... backlight bleed je uzasan.
Okvir laptopa previse pritisce IPS panel, zato i imas preizrazeni bleed.
Trebao si ga vratit i narucit drugi.
Dati 5 somica i preci preko toga nije mala stvar s obzirom da ces gledat u njega i imat taj problem konstantno.
Tek sa narucenim 3-cim monitorom bio sam zadovoljan sa backlight bleed -om.
To je nazalost panel lutrija.
Zadnje izmijenjeno od: Blue Spirit. 18.10.2020. u 12:32.
Staro 19.10.2020., 23:30   #2439
rokoko
In Rainbows
rokoko's Avatar
Postovi: 715
na ovom modelu ili opcenito na ips monitorima/panelima?najvise je izrazen u lijevom dijelu ispod kamere
Staro 27.10.2020., 09:53   #2440
Postovi: 16,957
Upravo me pitala susjeda da li joj mogu naći kakav laptop za klinca (8. razred) da ima za srednju školu ali da može igrati Fortnite. Do nekih 4300-4400kn top.
Gledam malo, ništa bez integrirane za tu lovu?
Gledam po Linksu, jer im je sila.
Vidim da s Ryzen 5 i 500GB SSD-om ima dosta izbora, no je li taj APU dovoljan za igranje?
Uglavnom, vidim da najjeftinije nešto s vanjskom grafom je oko 5000kn. Jesam li u pravu?
Zadnje izmijenjeno od: Mommistake. 27.10.2020. u 10:02.
Staro 14.11.2020., 18:45   #2441
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,087
Trebala bi mi preporuka 17" laptopa do 4.500kn cca, bolje na manje. Nije za igranje, za uredske poslove primarno. Volio bi bar 240gb+ ssd, 8+gb rama. Nadao sam se ubost nesto na ovim crnim tjednima ali nis bas vrijedno paznje nisam nasao
Staro 20.11.2020., 20:23   #2442
spitfire83
spava mi se
spitfire83's Avatar
Datum registracije: Nov 2013
Postovi: 329
Ima li što zanimljivo za black friday?
Gledam, ne nalazim neke posebno dobre ponude, a tražim IPS, Ryzen5 i min 8GB rama.
Vecinom TN paneli svugdje.
spitfire83 je offline   Reply With Quote
Staro 24.11.2020., 11:17   #2443
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
@Work HP Zbook15
@Home Acer 5020
Deathwish je offline   Reply With Quote
Staro 26.11.2020., 18:55   #2444
Alfa_R
Alfa_R's Avatar
Postovi: 2,907
Forumasi molim preporuke za laptopove od 17" do 4.500 kn.
Namjena : office, filmovi, Windows... Bez igrica.
Sa Ssd-om, poželjan IPS.
Ako nešto i probija budget, a puno više se dobije slobodno do 5k.
Zahvaljujem.
Edit - ipak 17"
Zadnje izmijenjeno od: Alfa_R. 26.11.2020. u 20:03.
Staro 27.11.2020., 21:49   #2445
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 715
Autocad, bentley, rhino, qgiss...
Što bolji ekran, 16gb rama, SSD, ryzen 4500u...
Može li ta integruša poslužit za lagodan rad u 3d autocad i nabrojanim programima ?
Molio bih 1-2 opcije koje bi bile best buy 4500-5500kn.
Fala unaprijed.
Revolver3844 je offline   Reply With Quote
Staro 02.12.2020., 12:21   #2446
turista
turista's Avatar
Lokacija: čakovec
Postovi: 205
Naišao sam na ovu ponudu, piše gaming laptop:
Intel i5 - 9300H 2,4 GHz (do 4.1)
15,6 " Ips full HD
8 GB RAM
512 SSD
Nvidia GeForce GTX 1650, 4GB
Cijena 5000 kn
Konfiguracija i cijena su OK za neki srednji gaming?
Poslano sa mog Mi 9T koristeći Tapatalk
Zadnje izmijenjeno od: turista. 02.12.2020. u 12:33.
turista je offline   Reply With Quote
Staro 04.12.2020., 11:09   #2447
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
Autor turista Pregled postova
15,6 " Ips full HD
8 GB RAM
512 SSD
Cijena 5000 kn
Trebao bi biti, ja curi uzeo isto samo s manjim diskom za 5200kn
@Work HP Zbook15
@Home Acer 5020
Staro 06.12.2020., 11:36   #2448
kiki86
Tehničar
Postovi: 1,087
Autor Alfa_R Pregled postova
Zahvaljujem.
Edit - ipak 17"
Jesi kolega uspio naći nešto ovakvo? Trebalo bi mi za prijateljicu ista specifikacija, a ne nalazim nista za normalne pare, samo neki gejming laptopi za 6-7-8k kn
Staro 08.12.2020., 10:36   #2449
freerock0
Datum registracije: Apr 2014
Lokacija: tu i tamo
Postovi: 210
15,6 " Ips full HD
8 GB RAM
512 SSD
Cijena 5000 kn
Pozdrav !
Može link jer i meni treba nešto slično.....
Hvala !
freerock0 je offline   Reply With Quote
Staro 09.12.2020., 09:24   #2450
freerock0
Lokacija: tu i tamo
Postovi: 210
Kolega turista , može link od ponude ....
Staro 09.12.2020., 09:25   #2451
freerock0
Lokacija: tu i tamo
Postovi: 210
Autor Deathwish Pregled postova
Može link jer bi i ja trebao nešto slično ?
Staro 09.12.2020., 10:27   #2452
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
Autor freerock0 Pregled postova
https://www.ekupi.hr/hr/Ra%C4%8Dunal.../p/EK000316273
S time da smo imali 10% popusta na maestro ili nesto, tu pise da ima 10% popusta na neku ekupi spajalicu pa pogledaj to.
@Work HP Zbook15
@Home Acer 5020
Staro 09.12.2020., 14:08   #2453
freerock0
Lokacija: tu i tamo
Postovi: 210
Hvala na linku !
To mi treba za klinca koji namjerava sljedeće godine na fax a usput i za pokoju igricu. Za njegove potrebe bi bio OK - pokoja igrica,surfanje...ništa zahtjevno ?
Fortnite bi vrtelo na tom lapu ? Ne kužim se u tu tehniku pa da ne bacam novce...
Staro 09.12.2020., 14:53   #2454
freerock0
Lokacija: tu i tamo
Postovi: 210
Tek sam sad skužil da mu je operativni sustav Linux. To bi se dalo "prebaciti" na windowse ?
Staro 09.12.2020., 23:10   #2455
Blue Spirit
Postovi: 2,195
Samo da javim da morao sam apdjetat BIOS na Lenovo laptopu: (Ryzen 5 4500U laptop star 3 mjeseca) da bi WiFi proradio nakon današnjeg apdejta.
Nije pomoglo brisanje apdejta, brisanje WiFi drajvera, rucno instaliranje službenih Lenovo WiFi drajvera, niti brojni restarti.
WiFi bi ocitao sve mreže ali nije se mogao spojiti ni na jednu.
Staro 10.12.2020., 09:54   #2456
freerock0
Lokacija: tu i tamo
Postovi: 210
Hvala na linku !
Staro 10.12.2020., 11:01   #2457
Postovi: 34,003
Vodite računa da Aceri poznati po lošijoj kvaliteti hardvera i materijala izrade. Zato i koštaju toliko koliko koštaju.
Zadnje izmijenjeno od: coconut. 10.12.2020. u 11:20.
Staro 10.12.2020., 12:22   #2458
freerock0
Lokacija: tu i tamo
Postovi: 210
Autor coconut Pregled postova
Kako se ne kužim u tematiku, isplati li se uzimati taj laptop , prema navedenim potrebama- fax,surfanje, povremeno igranje...? Znači ,nije isključivo za igranje...
Nekako mi se čini premalo prostora za hard,može se to nekako "proširiti" ?
Staro 10.12.2020., 13:34   #2459
andy91
Datum registracije: Oct 2014
Postovi: 78
5.023,00kn za ovo:
https://www.ekupi.hr/hr/Ra%C4%8Dunal.../p/EK000354694
Što mislite?
Po meni za taj novac ne mogu naći ništa bolje. Uvjet je do 14'', oko 5.000kn, 8GB RAM, SSD 512.
Ili još malo protegnuti i uzeti ovo za 5500,00kn
https://www.ekupi.hr/hr/Ra%C4%8Dunal.../p/EK000334448
andy91 je offline   Reply With Quote
Staro 10.12.2020., 14:23   #2460
Postovi: 34,003
@freerock
Većina novih laptopa ima NVMe disk koji se može zamijeniti većim, a kod dobrog dijela njih se može ugraditi dodatni SSD.
Za konkretni laptop treba potražiti točne podatke.
