Staro 23.11.2020., 20:32   #121
Postovi: 8,139
Vulkan officially delivers Ray Tracing
Today, the Khronos Group has officially added Ray Tracing extensions to their Vulkan API, moving the API's support for Ray Tracing from Provisional to Official status. On GitHub, the change has already been noted, though the Khronos Group is yet to announce the change officially. As of version 1.2.162, Vulkan officially supports ray tracing, further embedding ray tracing into the modern gaming feature set. Vulkan now contains the following extensions, all of which are due to be supported soon by RTX series nVidia graphics cards and RDNA 2-powered AMD GPUs.
Before now, ray tracing was only available on Vulkan through nVidia made extensions, which were optimised for nVidia's RTX hardware. Now, Vulkan supports Ray Tracing extensions which can be used by all vendors and are not optimised for a specific brand of graphics hardware. Developers who are currently using DXR should find Vulkan's Ray Tracing support to be easy to implement, and the API's support for HLSL shaders should allow DXR ray tracing calls to be translated to Vulkan calls with future versions of VKD3D or Proton. Playing ray-traced Windows games on Linux should be possible in time, which is great news for Linux lovers. This Vulkan update also gives developers the ability to develop ray traced games on PC without Microsoft's DirectX 12 API.
This adds some much-needed developer choice to creators and makes the transition to ray-tracing easier for developers who are already familiar with the Vulkan API.
Izvor: OC3D
Staro 24.11.2020., 07:39   #122
BoobZ
BoobZ's Avatar
Datum registracije: Feb 2012
Lokacija: Usa
Postovi: 160
BoobZ je offline   Reply With Quote
Staro 24.11.2020., 07:58   #123
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,350
Nvidia se ljepše smije .
Staro 24.11.2020., 08:51   #124
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Possible Radeon RX 6700 XT Specs Surface, 12GB the New Mid-Range Memory Size?
Ovo ce biti prava stvar, 5700 XT sa 12 gb i 15 - 20% visim taktom. po prihvatljivoj cijeni naravno
Staro 24.11.2020., 09:28   #125
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Autor stef Pregled postova
Budimo iskreni, najveća je šteta što ne možeš imati obje istovremeno. U kompu, naravno
Staro 24.11.2020., 10:19   #126
Yoman
Yoman's Avatar
Postovi: 707
Autor HCS Pregled postova
Ovo bi mogla biti moja sljedeća kartica
Planiram čekati prvi, drugi mjesec 2021 da se malo stabilizira tržište.
Planiram ubost ryzena 5600 non X ako cijena bude ispod 2000 i neku grafu tipa ovoga ovisno o benchmarcima i performance/price chartovima u datom trenutku.
Yoman je offline   Reply With Quote
Staro 24.11.2020., 19:09   #127
Postovi: 8,139
Staro 24.11.2020., 19:21   #128
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,746
To ova high quality slika s ebaya?
Staro 24.11.2020., 19:27   #129
Postovi: 8,139
Ovo je orginal, jer su na drugoj strani svijeta već spremni za sutra, pa raspakiravaju i testiraju prije, nego mi ostali uopće stignemo provjeriti službene recenzije.
U svakom slučaju, izgleda da budu Sapphire Nitro+ modeli i ovaj put u samom vrhu AiB ponude.
Staro 25.11.2020., 08:47   #130
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Kad ovi aib modeli krecu u prodaju? Opet u isto vrijeme ili?
Staro 25.11.2020., 08:50   #131
Postovi: 8,139
Da, ako nisu ništa mijenjali u međuvremenu - onda danas u 15:00h po našem vremenu, ali tokom dana svakak. Složi si za svaki slučaj sve stranice na kojima inače pratiš i kupuješ, pa da si spreman.
Staro 25.11.2020., 08:52   #132
14:59:03 - 57 seconds to go
15:00:00:001 - out of stock
Staro 25.11.2020., 09:16   #133
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,239
Otprilike, vidim an nabavi još ništa...nije da bi kupio, samo stalkam cijene.
Slobodno me dodajte na PSN
Staro 25.11.2020., 09:43   #134
obsidian
Postovi: 35
Zar očekujete da će ih i u RH isto biti danas?Gdje?
ja više gledam po EU sajtovima....
obsidian je offline   Reply With Quote
Staro 25.11.2020., 14:23   #135
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD Radeon RX 6800 XT & RX 6800 Custom Model Roundup Ft. ASUS, MSI, Gigabyte, PowerColor, Sapphire, XFX, ASRock & More
Link: https://wccftech.com/amd-radeon-rx-6...re-xfx-asrock/
Staro 25.11.2020., 14:28   #136
imik
imik's Avatar
Postovi: 626
Baš čitam na Overclockers.co.uk
Gibbo said: ↑
Hi there
We shall be launching cards around 2pm to browse, but we won't be taking any orders online or via the phones sorry.
Reasoning is simply due to lack of stock and were unwilling to allow a crazy backorder situation to build up on a product that we see very little stock incoming on this year.
Any stock that does come in, we shall give a heads up on the forum before making available to order, but that is very unlikely to happen this week, more like next week.
So in short today all you can do is window shop.
Sorry guys but we get so much flak when you guys are waiting on your orders and when I have gone and ordered 50,000 units and might struggle to see a few hundred cards this side of Christmas, it is ourselves who get the blame and the negative reviews, but as we do not manufacturer the product it is out of our control and considering that we can literally take 1000+ orders per minute on these new GPU launches which then causes havoc we have to take measures to stop this happening.
As such the product won't be available to order from OcUK today, when we feel we have adequate stock to make product available to order we shall do so and announce that date/time only on our forum.
NO STOCK TO BE SOLD TODAY OR LIKELY THIS WEEK
imik je offline   Reply With Quote
Staro 25.11.2020., 15:07   #137
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Usrali su se sa cijenama jos jace nego nvidia...
https://www.caseking.de/pc-komponent...Page=1&sSort=4
Staro 25.11.2020., 15:08   #138
Sapphire Nitro+ 6800XT - 770 USD MSRP
PowerColor RedDevio 6800XT - 800 USD MSRP
hahahaha, toooooo. Dakle ispod 1000 eura je ne bude ni u kojem obliku
Goodbye GPU upgrade. Biće GTX 1080 dobra dok joj gara ne ode tamo negdje u srpnju 2022.
Staro 25.11.2020., 15:10   #139
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Strix 6800XT LC na caseking 1086 eura...
Staro 25.11.2020., 15:14   #140
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Jos jedan paper launch, toliko o najavama da AMD ima lager, ima k...
Nema nista od novih kartica do proljeca izgleda, sucut ekipi koja je prodavala top tier grafe da izbjegnu pad vrijednosti
Staro 25.11.2020., 15:22   #141
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,578
Očekivano jbga
Ne vjerujem da će biti normalna situacija prije Q2 2021
Staro 25.11.2020., 15:23   #142
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
gle na sta smo dosli, da se ceka datum kad ce kartice doc u webshop ali ne i mogucnost kupnje...
Uzeo sam 3080 i mislio sad uzet 6800xt pa vidit koja mi bolje odgovara za sta ja koristim, a drugu prodat dalje no izgleda ostat ce ta nvidija neko dulje vrijeme kod mene...
Staro 25.11.2020., 15:30   #143
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,697
Nakon svega ovoga želim preći na konzole, kad ono nemogu nit to...
Tako da, kao što većina govori, grafu koju imam će morati do daljnjega. Na početku je bilo malo frustrirajuće, ali sada je već smiješno i šta? Ako ovo bude trajalo i do Q2 2020...govorimo o novom normalnom?
thunder11 je online   Reply With Quote
Staro 25.11.2020., 15:44   #144
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Evo cijene sa cclonline
Staro 25.11.2020., 18:30   #145
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,312
Naravno, kad bi išta bilo dostupno za MSRP, ovo bi bio jako loš deal za 6800XT Nitro+.
https://www.techpowerup.com/review/s...o-plus/39.html
"We've measured gaming temperatures of 75°C, 2°C lower than the AMD reference. Noise levels are pretty much identical, too".
"Sapphire's MSRP for the RX 6800 XT Nitro+ is $770, which is a $120 increase over the AMD reference design. That's a really large increase for a card that's just a bit better than the AMD card. Sure, noise levels and temperatures are improved, but only by a small amount. In a side-by-side test most people might not even notice a difference."
Staro 25.11.2020., 18:56   #146
Manuel Calavera
Postovi: 14,578
BTW ne znam zašto više ne mjere vrm i ddr6 temperature...
Uglavnom izgleda da je AMD napravio jeben refrerentni cooler, kad ga ova krmača od powercolora jedva malo skine
Staro 25.11.2020., 19:01   #147
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,499
Polako, polako, bude se to normaliziralo do proljeća. Nisu grafe životno važna roba da se treba živcirati. Da sam AMD/Nvidia, prodavao bi čipove proizvođačima kartica za jedno 2000 EUR i ljudi bi opet kupovali grafe za 3000. Ovih 770 za Sapphire je ništa, opet će nestat u roku odmah.
Staro 25.11.2020., 19:48   #148
Tak jasno.
Botebog, čekao sam Metro Exodus godinu dana da se vrati na Steam, a to je nešto što sam čekao mukotrpno.
Bez pardona mogu godinu dana čekat i GPU upgrade za koji i nisam tako zagoren ko što sam bio za Metro
Staro 25.11.2020., 23:05   #149
Joza_Seraf
Joza_Seraf's Avatar
Datum registracije: Jun 2015
Lokacija: Klc
Postovi: 568
Ja i dalje čekam Recenziju Nitro+ 6800 da uplatim lovu u švabiju i da se čeka da dođe u stock
Samo čekam dan kada će mi netko pokucati na vrata i zatražiti me bubreg jer sam negdje odscrollao dolje i stavio kvačicu na "Slažem sa svime"!!
Zadnje izmijenjeno od: Joza_Seraf. 25.11.2020. u 23:23.
Joza_Seraf je offline   Reply With Quote
Staro 26.11.2020., 09:15   #150
Proudcroat
Proudcroat's Avatar
Datum registracije: Feb 2017
Postovi: 243
Autor zwer54 Pregled postova
Nisu nromalni...
Proudcroat je offline   Reply With Quote
