Staro 23.11.2020., 22:22   #5131
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Uvijek
Prije par godina sam na T420, skidajući tipkovnicu, rasparao flat kabel od iste. Naravno, kad mi je laptop najviše trebao
Pa sam nakon toga nekako sjebao komunikaciju s BT modulom (isto flat kabel), jer novi modul nije riješio problem.
kod mene su pali 1x wlan modul i 2x tipke na jednoj tipkovnici (strgao) pa sve mijenjao cim prije
Skidanje tipkovnice na xx40+ mi je najgori dio svega..
Staro 24.11.2020., 03:35   #5132
domy_os
domy_os's Avatar
Postovi: 18,884
Ima li ovdje razloga za brigu? U pitanju T480 iz potpisa.
Code:
stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 8682)
stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 8682)
stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 16453)
stu 24 02:21:19 Domy-NB kernel: mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 16454)
stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Core temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU0: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Core temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU4: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU6: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU2: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU1: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU5: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU3: Package temperature/speed normal
stu 24 02:21:19 Domy-NB kernel: mce: CPU7: Package temperature/speed normal
Laptop je stalno u idle, a te poruke se javljaju svakih 10-15 min. Mislim da su mi iste greške bile i na Windowsima, samo zaboravio pitati. Kontam da je nešto do BIOS-a, ali updatea nema.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 24.11.2020., 07:40   #5133
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
A temp. su ok (valjda da, jer idle)?
Staro 24.11.2020., 16:26   #5134
Night
Lokacija: Dbk
Postovi: 1,307
Možda nekome bude zanimljivo ... Pošto mi klasična metoda uklanjanja IME iz BIOSa nije upalila, tj. nije se više moglo ući u BIOS iako se lap podizao u OS, tražio sam drugo rješenje i našao nešto dosta zanimljivo.
https://medium.com/@n4ru/1vyrain-an-...k-fd4bb0bdb654
To je nekakav poboljšani firmware za xx30 seriju, konkretno ja sam zasad probao na T430s i radi super, idući mi je T530 na redu. Dobije se dosta opcija za fino tuniranje hardvera, overclock, i može se u BIOSu ugasiti Intel Management Engine. Navodno se i miče whitelista WiFi adaptera pa se može koristiti bilo koji, a ne samo onih par što Lenovo prodaje po zlato.
Cijela procedura se odradi bez potrebe za otvaranjem laptopa i spajanjem programatora, sve je softverski.
Edit, instalirano i na T530 bez problema.
Naravno kao i kod svakog petljanja sa BIOSom dobro je imati programator pri ruci ako nešto pođe po zlu, meni onaj ch341a od 40kn radi odlično na nekoliko Lenova i jedanom Dellu, zapravo na svemu na čemu sam probao.
Zadnje izmijenjeno od: Night. 25.11.2020. u 14:03.
Staro 24.11.2020., 16:37   #5135
domy_os
domy_os's Avatar
Postovi: 18,884
Autor pci_e3x Pregled postova
Da, da, tako oko 40°C non-stop.
Staro 25.11.2020., 00:07   #5136
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Autor domy_os Pregled postova
Ovo s tresholdom mi zvuci kao nesto podeseno negdi. Jer u idleu nemoguce da ode do limita.
No nije mi jasno sto i kako. Skroz zbunjujuce :s
BTW, jel se moze "prčkat" po TDP-u kod TP-a. Povecat max me konkretno zanima. A da nije BIOS mod.
Staro 25.11.2020., 19:40   #5137
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,062
Sve 5, ali predlažem ti da probaš da ipak ne bi bio u pitanju osigurač, kao u slučaju @Mario92.
Ak je fakat ekran, onda pogledaj tekst niže.
Ipak je (samo) ekran
Probao sam BOE staviti u T420 i tamo isto samo crnilo. Pozitivno je to kaj mi je za zamjenu ekrana trebalo manje od pet minuta (očekivao sam više), negativno kaj sad moram naći novi ekran pa mi je pala suluda ideja za ipak ubodem onaj Innolux GR2/GQ2 i da ga probam ubaciti u T420,... to bi zaista bio overkill za tako stari laptop
Usput, dok razmišljam što nabaviti, ako netko ima neki ok FHD IPS za T4x0 seriju nek se javi pa da ne naručujem i čekam proljeće da doputuje
EDIT:
Sad kad gledam boje na monitoru sa S-PVA matricom i ovaj AUO IPS, nekako bi najrađe ekran za ThinkPada sa S-PVA matricom, ali to vjerojatno ne postoji
Staro 25.11.2020., 20:51   #5138
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Kupio sam za htpc veći SSD, dosadašnjih 120GB se eto napunilo.
Kloniranje na veći je odrađeno bez problema, SSD fercera.
Manji SSD sam odlučio staviti u svoj x60s i ostaviti HDD kao backup, jer na njemu imam nekih posebnih programa koje je problematično pribaviti i instalirati.
Klonirao sam HDD na SSD na svom normalnom piceku ali mi se lapić neće bootat sa SSDom, nakon POST-a ostane na blinkajućem kursoru. HDD naravno fercera.
winxp boot stick koji sam koristio imam i funkcionira, međutim čim ga bootam ne pokaže opciju "press R to enter Recovery" te ne mogu odraditi klasične fixboot fixmbr bootsect /nt60 c: /force /mbr
Ne sjećam se otkud ili otkad mi taj stick, znam samo da sam ga nekoliko puta koristio bez da sam primijetio da mi fali recovery. Mislim da sam napravio iso od jednog origigi winxp CD-a kojeg sam imao. Naravno, bootanjem s CD-a je recovery bio prisutan.
Mogu li kako dodati recovery na postojeći usb stick?
Trenutno se pokušavam dokopati još jednog 32bit winxp imagea jer su mi originalni CD-i ko zna gdje - valjda u podrumu u ZG-u. Ima neki (polu)pouzdani izvor?
Spoiler alert!
Staro 25.11.2020., 21:07   #5139
medo
#erase startup-config
medo's Avatar
Postovi: 3,728
Zar je ovako loš izbor NVMe 2242 SSD-ova? Nije za sistem nego dodatni storage. Od brand name SSD-ova koji idu u T480/T580 sam našao samo WD SanDisk SN520 i Samsung PM991. Što vi imate?
SK Hynix BC501.
Ima ih u 2280 i 2242 varijantama. Sve verzije su DRAM-less pa bi ti to mogao biti dealbreaker, ali rade jako dobro i ne zastajkuju. Meni su bili skroz fine. Prošle godine je puno HP laptopa dolazilo s tim SSD-ovima.
medo je online   Reply With Quote
Staro 25.11.2020., 21:09   #5140
Postovi: 23,547
Nekad iako si radio "clone" ne napravi 100% isto i posljedično nema boot u winse.
Druga moguća greška je boot loader ima "info" i put prema winsima na hdd - u a sad bi trebao "pucati" na ssd.
Trebalo bi nekako dodati još jednu "stavku" u boot loaderu i prepraviti je da puca na winse sa ssd - a.
Staro 25.11.2020., 23:07   #5141
domy_os
domy_os's Avatar
Postovi: 18,884
Autor medo Pregled postova
SK Hynix BC501.
Nije dealbreaker kad ni SN520 nema DRAM. Ma nema veze, uzeo sam što je bilo kad je izbor nikakav. Hvala.
Staro 25.11.2020., 23:56   #5142
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor Nikky Pregled postova
Nisam nikad potpuno ručno to radio - fixmbr i fixboot su mi dosad rješavali probleme. Jel ide to ručno, da otvorim boot.ini tipktipk -> voila?
Sad gledam da sam napisao bootsect /nt60, čime se winxp može samo još više zeznuti, treba ići /nt52 (source).
Nakon što postojeći usb nije imao recovery na sebi, skinuo sam neki treći xp image, stavio na stick.
fixboot fixmbr nisu niš napravili, dapače, primijetio sam nakon fixboota da nemrem više bootat usb stick.
*lampica*
map naredba - samo USB stick mapiran, tak da sam naredbama zapravo "popravljao" stick.
Pretpostavljam da je problem je što ovaj iso nema slipstreamane drivere za SATA, to se primijeti i prilikom podizanja tog plavog sučelja, vrlo malo stvari loada.
Spoiler alert!
Staro 26.11.2020., 01:37   #5143
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,074
Omiljeni mi je bio AUO B140HAN01.3 koji je sad kod bertonea u T420, a onda sam uzeo low power Innolux N140HCG-GR2 koji me oduševio potrošnjom, masom i svjetlinom od 400 nitsa (i "ghostingom", kojeg zapravo nema ili nije izražen kao na drugim low power panelima), uz standardnu 100% sRGB pokrivenost (isto kao navedeni AUO).
Ako si na budžetu, onda AUO (nađe se za 50-60 dolara), a ako se želiš obezobrazit, onda ovaj Innolux (GR2 ili GQ2 i pazi da su mat) za ~ $90, obavezno s bracketima jer nema kopče na sebi. Sve to iz Kine, dakle može te potrefit PDV (mene dosad za 3 ekrana nije, ali...).
Meni je kao IPS stigao Innolux N140HCA-EAB. Kolko gledam, IPS je ali po speckama je daleko od tvojeg N140HCG-GR2:
https://www.panelook.com/modelcompar...ds=30063,42985
Bolji color coverage, veći brightness, kontrast, broj boja (ne kuzim kak ovaj pokazuje samo 262k boja, mozda to nije točna informacija?), al pod total power consumption razlika nije velika (3.36W naspravm 3.05W), dok je ta neka BLU power consumption čak na strani jeftinijeg panela.
Interesantno, trebalo bi usporediti panele jednog kraj drugog... ili možda bolje ne, onda će me to previše kopkati
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 26.11.2020., 02:51   #5144
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Autor Mario92 Pregled postova
262k boja ti je 64 nijanse po svakom od RGB piksela (64x64x64). 8 bit (256^3) je 16,7M.
Na tom panelooku zna bit dosta krivih informacija pa i kontradiktornih. Za GR2 kaže sRGB color coverage 88%, a NTSC 82%, što ni matematički ne može biti.točno Naravno, kolorimetrom sam izmjerio 99% sRGB-a (što je oko 72% NTSC-a, uz standardnih 75% Adobe RGB-a i DCI-P3).
A što se potrošnje tiče, zaboravljaš da se radi o ~ potrošnji 250 vs 400 nitsa
Eh, N140HCA-EAB...
Baš taj Innolux (N140HCA-EAB). Nisam ga kalibrirao, ali je precrvenkast out of the box, a boja koja bi trebala biti kričavo crvena na njemu izgleda ko isprana narančasta. Te stvari kalibrator ne može sredit jer je color gamut jednostavno očajan
Autor bertone Pregled postova
EDIT:
Dobro je!
Ne znam kak u Linuxu upravljat color profilima, ali predlažem da si skineš color profil za taj ekran: link
I provjeri hoće li ti PCB za retrofit raditi s bilo kojim drugim ekranom.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Zadnje izmijenjeno od: ThePornstar. 26.11.2020. u 03:00.
Staro 26.11.2020., 10:46   #5145
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,074
Pas masters, probal budem zaboraviti tvoj post i ne se fokusirati na crvenu nijansu
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 26.11.2020., 12:28   #5146
ThePornstar
Postovi: 4,403
Ma dobro, crvenkasta slika se da riješiti color profilima, ali gamut ostaje kakav je. Neki kažu da su im ti ekrani ok, mogu živjeti s njima. Zapravo su isti kao i ostali FHD IPS od T460 do T470, tako da nisi fulao po pitanju tvorničkih vrijednosti
T440 i pogotovo T450 su tvornički dolazili s boljim FHD IPS ekranima od tih serija, a gore navedeni AUO je jedan od njih.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 26.11.2020., 13:01   #5147
bertone
bertone's Avatar
Postovi: 2,062
Ja iz trenutnog iskustva sa BOE ekranom mogu potvrditi da je bolje i da je malo crvenkast nego da uopće ne radi
Staro 26.11.2020., 13:08   #5148
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Cek, znaci li to da si uspio fixat issue koji si imao ili se samo mentalno spremas da ce te zivcirati?
GoGzS je online   Reply With Quote
Staro 26.11.2020., 13:24   #5149
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,074
Niš još nisam fiksao, mentalno se - pokušavam - spremiti
Prvo moram odfurati laptop na zamjenu backlight fuse-a pa onda ide instalacija ekrana.
Nego, kaj se tiče zamjenske backlit tipkovnice koju sam naručio preko AliExpressa - Ne znam zapravo jel je to original ili fake, ali iza na naljepnici piše:
Product number: SN20K93235
Model: SN5324
FRU No.: 01AX080
Na drugoj naljepnici ispod nje stoji:
SG-84500-XUA
PK1311N3A00 SN5325
9026 LITEON
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 26.11.2020., 13:42   #5150
ThePornstar
Postovi: 4,403
Nešto je tu sfejkano. 01AX080 je FRU za Lite-On, ali non-backlit tipkovnicu:
Slika 1
Slika 2
A jesi baksuz
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 26.11.2020., 13:55   #5151
Postovi: 23,547
@De5tr0yer
Pa poznati je zaheb da (sve) treba imati integriran sata drajver kako bi vidio ssd / hdd.
Sad sam se sjetio da je razlika XP (NT52) u odnosu na W7 i novije,
prvi koristi boot.ini i radi ručno kukičanje po njemu, treba znati / pogoditi kako "vidi" ssd u odnosu na hdd (ono br. diska, br. particije).
W7 i noviji rade preko boot loadera, M$ je predvidio koristiti dosadno komplicirani BCD cmd tool pa je bitno lakše preko alt. alata kao EasyBCD.
E sad, kako da riješiš problem:
- boot u Live Win sa integriranim sata drajverom, čak nije nužno da je XP based, može i W10, bitno je da "vidi" ssd i hdd
- kroz Notepad urediš boot.ini da:
a) stavi timeout=10 (da čeka tvoj izbor, to kasnije lako makneš)
b) kopiraš stavku pod "operating systems"
c) tu drugu stavku treba preurediti da "puca" na ssd
Ne zaboravi da prije edita boot ini treba makniti (a kasnije vratiti) S, H, R atribute fajla.
Za žuntu:
https://www.howtoforge.com/custom_boot_menu_windows_xp
https://neosmart.net/wiki/invalid-boot-ini-file/
https://neosmart.net/wiki/windows-wont-start/
Da si olakšaš možeš i ovako:
- privremeno makni ssd
- neka je hdd gdje i treba biti i da winsi rade sa njega kako treba
- odradiš ove manipulacije sa boot.ini da imaš menu i dvije boot opcije
- spremi negdje taj boot.ini na sick
- zamijeni hdd sa ssd - om, nemoj stavljati hdd
- boot u Live Win
- kopirati boot.ini, editirati da pogodiš kako treba ...
Nadam se da sam te usmjerio u dobrom pravcu.
Staro 26.11.2020., 14:01   #5152
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 1,990
Code:
Instaliraj intel XTU i odradi Stress Test na default postavkama... Ako ti tamo stalno throttla CPU, nosi na servis ako je laptop jos pod jamstvom...
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 26.11.2020., 15:22   #5153
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,074
Slika 1
Slika 2
A jesi baksuz
Mora netko biti, da ostali ne budu
Niš, gledam sad po jebajevima neke slightly abused backlit sa velikim enterom
Fala lepa na pomoći, Pornstar
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 26.11.2020., 15:30   #5154
ThePornstar
Postovi: 4,403
Nije baš pomoć, više party-pooping
Prije nego naručiš, scimaj lika s Njuškala od kojeg smo (forumaši) već uzimali. Trenutno ne vidim da ima za T460/50/40 (od T460s ili p ne paše), ali je blizu i ima skroz korektne cijene pa ga ne bih preskakao. I probaj da je Lite-On backlit - i @bertone ti može potvrditi da je bolja od Chicony backlit tipkovnica.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 26.11.2020., 18:01   #5155
domy_os
domy_os's Avatar
Postovi: 18,884
Autor calypso Pregled postova
Ne vidim da ga ima za Linux?
Testirao sam u Primeu i ThrottleStopu više U procesora uključujući i ovaj kad sam ga tek kupio i svaki mi je throttlao u turboboostu, to je za njih normalno. Kada nisu u turboboostu, onda nema ni throttlinga, a uz undervolt mi je sweetspot bio negdje na pola puta između nominalne i max turboboost frekvencije.
Staro 26.11.2020., 18:06   #5156
Dottore
Dottore's Avatar
Postovi: 7,671
Model: SN5324
FRU No.: 01AX080
SG-84500-XUA
PK1311N3A00 SN5325
9026 LITEON
Obavezno popij pivu pa onda šarafiš. Tako fa ne budeš opet ponavljao grešku.
Отправлено через SM-N986B
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 26.11.2020., 23:52   #5157
domy_os
domy_os's Avatar
Postovi: 18,884
Ja baš nemam sreće s ekranima. Od dva ThinkPada, kod oba problematičan ekran.
Pokušao sam uslikati da bude koliko toliko blizu onome što ja vidim, ali je jako teško, pogotovo što ne mogu dobiti focus na pravom mjestu, a da slika liči na nešto, i još mobitel previše kompresira slike pa dobijem ove kao artefakte.
Problem je taj kao neki svjetli okvir uz sam rub, kao da neka tepsija stoji preko ekrana. Ali pošto je brightness bio na 100% dok sam pokušao uslikati, skužio sam da pomalo nestaje i nakon 10 min se skoro ništa nije vidjelo.
Nije mi vrag dao mira, stavio sam bijelu boju da stoji neko vrijeme na max osvjetljenju jer sam to našao na Lenovo forumu i poslije toga je nestalo da bi se nedugo nakon što smanjim osvjetljenje počelo opet lagano pojavljivati. To sam napravio i na T580 i otklonilo je image retention problem, ali i to se vrati natrag. Sudeći po forumima, očito su im te novije serije ekrana malo u banani.
Pošto radim u mračnijoj prostoriji, rijetko kad mi je brightness na preko 10% pa ga možda i to zeza, a na 20% i više već dosta blješti pa ga tako koristim kad sam vani.
Ima li netko od vas takvih problema?
Staro 28.11.2020., 13:45   #5158
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Nakon što sam zagnjavio Nikkya još dodatno preko PM-a, moje kloniranje je uspjelo tek kad sam uzeo eksternu usb ladicu i klonirao disk na nativnoj platformi, tj. acronis true imageom iz winxp.
Isproban je i Macrium Reflect, ali nema vajde na drugom računalu.
Nakon ubacivanja ssda je vremešni x60s odmah bootao, malo se pobunio i nije imao driver za wlan i integrušu, ali je brzo dodano i ne vidim daljnje probleme.
Maknuo pagefile, ugasio prefetch. Za povremenu upotrebu bi to trebalo funkcionirati kako treba
Hvala na pomoći
Spoiler alert!
Staro 28.11.2020., 14:13   #5159
Postovi: 23,547
Nisi ništa "zagnjavio", bitno da je beba ili starčić oživilo i ubrzan.
I da, bude tih situacija gdje je bitno da se odrađuje na nativnoj platformi.
Staro 28.11.2020., 17:05   #5160
Garro
Postovi: 2,392
Tako je, plava i narančasta. Ovak bi trebalo izgledat:
Ako nemaš te žice, znači da nema ni instalacije (antena). Ak imaš žice i želiš ugraditi WWAN modul, treba ti Fibocom L830-EB modul, obavezno s Lenovo FRU oznakom jer ti u protivnom neće raditi WWAN ili će ti javljati pri svakom POST-u da modul nije original.
FRU za Fibocom L830-EB je 01AX761, a vidim da na eBayu idu za 50-ak dolara.
Softverski ne trebaš ništa, osim provjeriti u BIOS-u pod Security da je WWAN na enabled, a Windows će onda automatski povući driver ili ćeš ga ručno instalirati.
Samo da javim da sam otvorio lap i da žica nema. Ima čak i plastika za kanaliziranje žica, ali njih nigdje.
Ah well, imate li preporuku za USB 4G modem i A1 tarifu?
