Staro 30.09.2020., 17:06   #4051
Dottore
Dottore's Avatar
Postovi: 7,712
uz napomenu da ja svaku iteraciju iOS-a radim frišku instalaciju bez povlačenja bekapa
Niti čuvaš moje poruke
Отправлено через SM-G975F
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 30.09.2020., 17:39   #4052
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
ništa, sve ode
osjećam se odlično nakon fresha
Staro 30.09.2020., 17:49   #4053
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
clean install valjda nisam napravio od ios7
thuNdeR je offline   Reply With Quote
Staro 30.09.2020., 18:07   #4054
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,714
A ja valjda od prvog iPhonea 2010.
Ali ozbiljno, ne vidim potrebe za kompliciranjem, doslovno ni jednom nisam imao problema sa updateom direkt s moba uz očuvanje svih podataka.
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 30.09.2020., 18:34   #4055
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,153
Nikakvih problema, također.
Jedini problem koji se vuče već godinama je "A Device Attached to The System is Not Functioning" kad čovjek spoji kabel na USB 3.0 port i pokuša izvući video i fotke s iPhonea na Windows 10. Izvuče desetak komada i baci poruku.
Pomaže jedino spajanje na USB 2.0 port što em traje čitavu vječnost kad imaš 256 GB memorije, em nije moguće kad imaš komp koji nema nijedan USB 2.0.
Potrošio pola dana na to. Probao 4 različita kabela, sve USB portove, restartao oba uređaja desetak puta. No go...
I onda nađem rješenje, probaj na USB 2.0 portu. Naravno, takav komp nemam kod sebe, pa ajmo naći prvi koji ima i onda je tek uspjelo.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 30.09.2020., 23:39   #4056
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
A imas ljudi koji su poremeceni kao i ja, pa mislim mozda ce bolje raditi kada sve to načisto odradim
kvaju je offline   Reply With Quote
Staro 02.10.2020., 11:13   #4057
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Staro 20.10.2020., 20:13   #4058
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
iOS 14.1 includes improvements and bug fixes for your *iPhone*.
- Adds support for 10-bit HDR video playback and edit in *Photos* for *iPhone* 8 and later
- Addresses an issue where some *widgets*, folders, and icons were showing up in reduced size on the Home Screen
- Addresses an issue where dragging *widgets* on the *Home Screen* could remove apps from folders
- Fixes an issue where some emails in Mail were sent from an incorrect alias
- Fixes an issue that could prevent incoming calls from displaying region information
- Fixes an issue on some devices where selecting zoomed display mode and an alphanumeric passcode could result in the Lock Screen emergency call button overlapping with the text input box
- Addresses an issue where some users were occasionally unable to download or add songs to their library while viewing an album or playlist
- Fixes an issue that could prevent zeroes from appearing in Calculator
- Resolves an issue where streaming video resolution could temporarily be reduced at the start of playback
- Fixes an issue that prevented setting up a family member’s Apple Watch for some users
- Resolves an issue where the Apple Watch case material was displayed incorrectly in the Apple Watch app
- Addresses an issue in the Files app that could cause some MDM-managed cloud service providers to incorrectly display content as unavailable
- Improves compatibility with Ubiquiti wireless access points
- Some features may not be available for all regions or on all Apple devices. For information on the security content of Apple software updates, please visit this website:
https://support.apple.com/kb/HT201222
Staro 20.10.2020., 20:33   #4059
Dottore
Dottore's Avatar
Postovi: 7,712
Upravo instaliram.
Отправлено через iPhone
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 23.10.2020., 17:22   #4060
Igorr
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,714
Ne znam što su točno napravili ali iPhone X mi je prodisao ponovo punim plućima na iOS 14.1.
iOS 14 i 14.0.1 su mi malo usporili mob bili.
Tako da preporuka za update!
5.1.4 setup:
Staro 01.11.2020., 18:13   #4061
AntiEkspert
Lokacija: U konobi
Postovi: 57
iPhone cookie
Pozzz kako rješiti da ne iskaču upozorenja stranica o kolačićima
Bez da dozvolim da ih spremaju
iOS 14.1
IP Xs je u pitanju
Relativno nov
AntiEkspert je offline   Reply With Quote
Staro 01.11.2020., 18:24   #4062
Postovi: 17,143
Nikako. To nije do mobitela.
Staro 01.11.2020., 19:08   #4063
Wizzard
Wizzard's Avatar
Postovi: 497
Može se riješiti ali sa tim da ne koristi safari..instaliraj google chrome i dodaj u proširenja tj extensions mali program zvani.. i dont care about cokies..i neće biti više pitanja za kolačiće..
i naravno postavi da ti je default browser chrome ako koristiš ios 14..
CPU: Amd Ryzen 5 9600x cooled by Ac Freezer 36 Co
MBO: Gigabyte x870 Gaming X Wifi 7
RAM: 2x16gb ddr5 Kingston Fury Beast Rgb Expo 6000mt
VGA: ASRock Intel Arc B580 Challenger OC 12Gb
HDD:Kingston FURY Renegade G5 2Tb+Nvme Kingston KC 3000 1TB+Cruical SSD BX500 1TB
PSU: Corsair RM 850x (Gold+)Atx 3.1 Fully Modular
Case: Endorfy ARX 700 ARGB
Mause: Logitech G403 Hero
Monitor: Asus Tuf Gaming VG249 24"
OS: Win 10 X64 Pro
Wizzard je offline   Reply With Quote
Staro 01.11.2020., 19:24   #4064
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,144
Autor Wizzard Pregled postova
Odkad Chrome za iOS podržava instalaciju extenzija?
Staro 01.11.2020., 21:47   #4065
AntiEkspert
Lokacija: U konobi
Postovi: 57
Ne nego do je gugla
Jeli jailbrejk može rješiti stvar
Staro 01.11.2020., 21:52   #4066
prileee
laser
prileee's Avatar
Postovi: 2,356
Staro 01.11.2020., 22:00   #4067
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
kaj oćeš, jel piše lokalna birtija? )))))
Staro 05.11.2020., 23:04   #4068
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
Staro 05.11.2020., 23:27   #4069
salvarez
salvarez's Avatar
Postovi: 273
Mene zeza baterija na xs max otkad sam napravio update na ios14. Ako 14.2 ne popravi stvar, moram ga resetirati i set up as new.
salvarez je offline   Reply With Quote
Staro 06.11.2020., 14:57   #4070
domis
Lokacija: Hrvatistan
Postovi: 4,165
Staro 08.11.2020., 19:25   #4071
Postovi: 8,245
Dal mi moze netko preporucit neke korisne aplikacije, il aplikacije koristite svaki dan? Prvi put sam na ajfonu i nemam pojma nista Nemojte mi pisat fejs, instagram i to, to znam. Al za mail aplikaciju sam otvoren
Tnx
Staro 08.11.2020., 19:39   #4072
Hrconja
Hrconja's Avatar
Postovi: 1,626
Autor Pupo Pregled postova
Tnx
Spark probaj
Sent from my iPad using Tapatalk Pro
Hrconja je offline   Reply With Quote
Staro 08.11.2020., 19:40   #4073
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,542
meni je đi mejl skroz simple i ok
Staro 08.11.2020., 19:53   #4074
prileee
laser
prileee's Avatar
Postovi: 2,356
Doslovno koristim iste aplikacije ka sta sam koristia i na androidu.
Staro 08.11.2020., 19:56   #4075
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,153
Isto...
Bluemail mi je bio ok, iako Gmail i njegova ugrađena aplikacija rade sasvim dobro
LCD: BENQ PD3200Q
Staro 08.11.2020., 21:04   #4076
DSA
Lokacija: Sarajevo
Postovi: 295
Meni je Outlook favorit mail aplikacija
DSA je offline   Reply With Quote
Staro 08.11.2020., 21:25   #4077
kvaju
kvaju's Avatar
Lokacija: Cirkus
Postovi: 642
Probao sve navedene iznad, al ovaj Spark mi se pravo svidio, preporuka.
Staro 08.11.2020., 22:15   #4078
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
Autor 1v@n Pregled postova
Malo kasnim s odgovorom, ali bolje ikad nego nikad
Kod mene iPhone 7. Javljao mi je tu grešku kada sam imao uključeno u opcijama kamere da fotka u HEIF/HEVC formatu i Automatic u opcijama fotki kod Transfera na MAC ili PC:
Settings -> Camera -> Formats -> High Efficiency
Settings -> Photos -> Transfer To Mac or PC -> Automatic
U toj kombinaciji opcija (koje su naravno defaultne ), on kod skidanja fotki u realnom vremenu prekodirava HEIF/HEVC u JPG/MP4 i tu nastane problem. To očito ne radi dobro, a još gubiš na kvaliteti fotki i videa.
Sebi sam promijenio Format na Most Compatible i nemam problema, a transferi idu daleko brže.
Staro 09.11.2020., 12:55   #4079
Spikeman
Lokacija: bi volio znat?
Postovi: 1,221
pitanje, uređaj je iPhone 11, iOS 14.2 ova crta preko texta koja se smanjuje i povecava prilikom zooma web stranice, to je neko pomagalo il koji vrag? kako to maknut?
poisključivao sam sve opcije unutar pristupačnosti i zoom opcije ali i dalje je tu.
pliz help
Staro 09.11.2020., 18:01   #4080
tomycrosound
Datum registracije: Jan 2010
Lokacija: Vinkovci
Postovi: 307
Apple iOS - info, pitanja, jailbreak, downgrade, unlock, FAQ
Prvi put vidim. Djeluje kao neki glitch..
“Ubij” sve aplikacije, napravi hard reset il makar isključ/uključ foru..
Jel to na svim stranicama ili samo sada?
Ta crta postoji kod mene, skroooz uz donji rub ekrana.. sad obratio paznju pa spazio. Smanjuje se i povecava kako zoomiram site.
Zadnje izmijenjeno od: tomycrosound. 09.11.2020. u 19:28.
tomycrosound je offline   Reply With Quote
