Staro 05.11.2020., 16:25   #3541
Keyser Söze
Rent-a-maniac
Keyser Söze's Avatar
Postovi: 757
zte 286r kako podesiti QoS?
Staro 05.11.2020., 16:47   #3542
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,913
Oce netflix oce oce, a nije ni yt puno drugaciji
  • Low - 0.3 GB per hour per device
  • Medium - SD: 0.7 GB per hour per device
  • High - Best video quality, up to 3 GB per hour per device for HD, and 7 GB per hour per device for Ultra HD
  • Auto - Adjusts automatically to deliver the highest possible quality, based on your current internet connection speed
https://help.netflix.com/en/node/87
OuttaControl je online   Reply With Quote
Staro 05.11.2020., 20:52   #3543
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Autor window09 Pregled postova
Hoces mi reci da sam možda i 1gb više napravio dok sam ovo gledao? Haha, strašno, pa po tome ne možeš ni gledat stream nogometa ili košarke. Inače gledam lige i što ću ja, na 10 utakmica potrošit 100gb?
Stavi 240k rezoluciju
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 06.11.2020., 00:33   #3544
exzzy
exzzy's Avatar
Datum registracije: Aug 2014
Postovi: 844
Autor Keyser Söze Pregled postova
A1 firmwire?
Staro 06.11.2020., 09:22   #3545
Keyser Söze
Rent-a-maniac
Postovi: 757
da a1
Staro 06.11.2020., 09:47   #3546
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,290
Jel postoji neki drugi/bolji firmware za taj 286r?
Staro 07.11.2020., 01:56   #3547
exzzy
exzzy's Avatar
Postovi: 844
da a1
Bojim se da nikako, imo sam ga sam 2 dana al kolko se sjecam to vidio nisam. A1 je jako puno stvari zakljuco s tim firmwierom.
@Cuky nemozes na a1 flashat nista izgleda, kad probas đubre se zbricka.
Staro 08.11.2020., 22:46   #3548
user_Ime
Datum registracije: Oct 2020
Lokacija: Lokacija
Postovi: 44
1. Gdje točno mogu provjerit trenutno potrošeno stanje pokucnog tele2 interneta?
Na 192xxxx ne mogu, tamo imaju razne postavke, ali ne i potrošnja.
trenutna potrošnja se može provjeriti putem moj.tele2.hr. Portal je ok i za različita podešavanje (npr. primanje računa isključivo putem email-a)
user_Ime je offline   Reply With Quote
Staro 09.11.2020., 13:35   #3549
skalar
skalar's Avatar
Datum registracije: Apr 2015
Postovi: 1,703
moraš prvo registrirati tel, broj pokučnog piše ti na ugovoru, i onda ti se pojavi potrošnja po mjesecima
Staro 09.11.2020., 16:17   #3550
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,438
Nisam nigdje nasao gdje pise to ogranicenje od 200gb mjesecno.
Moze neki link il nesto?
komer je offline   Reply With Quote
Staro 09.11.2020., 16:29   #3551
beli14
beli14's Avatar
Datum registracije: Mar 2011
Lokacija: Gotham City
Postovi: 519
https://www.tele2.hr/privatni-korisn...-uz-pretplatu/
EDIT: također došla obavijest uz račun za 9/2020
beli14 je offline   Reply With Quote
Staro 09.11.2020., 16:31   #3552
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,438
To je za nove.ja nisam dobio nikakvu obavjest da se spušta na 200gb.pod ugovorom sam jos godinu dana otprilike.
Staro 09.11.2020., 16:51   #3553
johnsmith
Lokacija: vž
Postovi: 1,337
Autor komer Pregled postova
Za sve vrijedi, pocinje se primjenjivati s 1.11.2020. Morao si dobiti na zadnjoj strani papirnatog ili eračuna, bilo je dernjave oko toga zadnja tri tjedna, masovne bežanije na A1 Flatbox, raskidanja ugovora bez penala na tele2. Ćeš vidit ak ti brzina odleti na 2mbit tokom mjeseca
Staro 09.11.2020., 18:21   #3554
franzD
Postovi: 1,552
Pregledaj cijeli PDF računa koji si dobio u 10. mjesecu, tamo negdje na petoj stranici nakon pet stranica "ispisa poziva" su sakrili obavijest metodom APP.
Staro 09.11.2020., 18:51   #3555
quazar912
quazar912's Avatar
Lokacija: north-northwest
Postovi: 1,991
Upravo dobio mail da mi raskidaju ugovor iako mi je izašlo 24 mjeseca na koliko sam i potpisao.
Inače bi uredno stizali računi .
Ponesao ga na more i kad je bilo najviše potrebo brzina bila 1mbs
.uploada nema.
Po njima "velik broj korisnika je online"
Reko čim izađe ugovor kupim prnje i idem...
...and fly...
Thule nosač
Staro 09.11.2020., 19:29   #3556
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,438
Nasao sam.
Hvala na info..kao socijalan korisnik(nezahtjevan) 250gb mjesecno trosimo.
Izlazim van,jedino neznam kak je s plejkom,to sam na rate uzeo...
Staro 09.11.2020., 20:46   #3557
exzzy
exzzy's Avatar
Postovi: 844
To ces platit jednokratno.
Staro 11.11.2020., 19:03   #3558
beli14
beli14's Avatar
Postovi: 519
Ima kome da su smanjili brzinu nakon 200GB?
Evo ja prije 20min prebacio 200GB ako je za vjerovati onome što piše u postavkama rutera. Sad je 215GB.
Brzina i dalje OK. Od 50 do 150mbps (najcesce oko 100mbps).
Staro 11.11.2020., 20:20   #3559
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,489
Kako uspijete u 11 dana slupati 200Gb?
Staro 11.11.2020., 20:32   #3560
exzzy
exzzy's Avatar
Postovi: 844
Pa ode 10+gb dnevno sam na surfanje, malo yt, malo spotify, online predavanja. Mislim ovih 200gb je zalosno, cak i kad pazim nema sanse da izdrzi duze od 2tjedna. Nedaj boga nes slucajno i skinut, drugog u mjesecu bi vec ispucal.
Staro 11.11.2020., 20:40   #3561
beli14
beli14's Avatar
Postovi: 519
Imao sam 130GB do danas, a budući da ne mislim ni jedan dan biti na 2mbps, skidao sam nekih 70GB danas pa da vidim šta bude. Kod mene Tele2 radi bolje i od A1 i od HT-a.
Još uvijek sve normalno
Staro 11.11.2020., 20:41   #3562
glazZ
glazZ's Avatar
Datum registracije: Jul 2010
Lokacija: Pakrac
Postovi: 359
Autor Ag008 Pregled postova
Ja sam u 10 dana izolacije sa netflixom potrosio 540gb prometa. Samo tv i mobitel, nista skidao nisam.
Poslano sa mog BLA-L29 koristeći Tapatalk
glazZ je offline   Reply With Quote
Staro 11.11.2020., 21:16   #3563
goran1985
Ili jesi ili nisi
Datum registracije: May 2011
Lokacija: vrgorac
Postovi: 737
Autor beli14 Pregled postova
Slično i ja razmišljam. Ja sam počeo pratiti potrošnju prije tjedan dana, od tada sam na 170GB potrošenih.
Kad ograniče na 2mbps odmah idem u Tele2 centar reć pa-pa.
goran1985 je offline   Reply With Quote
Staro 12.11.2020., 00:51   #3564
Inovator
Inovator's Avatar
Lokacija: Bjelovar
Postovi: 482
Cini mi se da svi jednako razmisljamo. Mogli su biti korektni pa (ako vec moraju) staviti limit na upola dosadasnjeg, a brzinu korigirati na visu. Ovako se to vise ne moze zvati neogranicenim pristupom.
Staro 13.11.2020., 09:00   #3565
goran1985
Ili jesi ili nisi
Lokacija: vrgorac
Postovi: 737
Nešto se ipak čeka sa ograničavanjem brzine, samo što?
Ovo 266gb mi je potrošnja za ovaj mjesec.
Staro 13.11.2020., 09:56   #3566
johnsmith
Lokacija: vž
Postovi: 1,337
Zaboravio netko stisnuti kvačicu Ili bude stvarno komedija ako se odnosilo samo na nove korisnike...
Staro 13.11.2020., 19:57   #3567
cickova
Datum registracije: Jan 2013
Postovi: 15
bez problema, zivimo u 2020. godini, gledamo netflix u 4K, gledamo youtube u 4K. kaj, trebali bi gledati 144p?
7 dana studenog - 190 GB. Raskinu ugovor, al slab mi ej A1. Kontaktirao HT da vidim kad planiraju osposobit optiku
cickova je offline   Reply With Quote
Staro 13.11.2020., 22:02   #3568
Exomaniac
Datum registracije: Mar 2016
Postovi: 772
Autor cickova Pregled postova
Dobro, svi živimo u 2020., ali kvalitetu koju možeš gledati uvjetuje infrastruktura na kojoj si, a ne godina u kojoj živiš. Ima ljudi i u razvijenijim državama europe od nas koji se na internet spajaju sa 2, 3 megabita i oni sigurno ne gledaju u 4K nego ono što im brzina dopušta.
Ali ako si na ograničenom prometu onda staviš postavke na 720p ili 1080p koji troše 700MB na sat ili do 3GB maksimalno, a ne 7GB+ na 4K HDR i sve điđe-miđe. Da se sad vidi tako ogromna razlika da je 1080p u odnosu na 4K negledljiv, pa baš i nije.
Staro 13.11.2020., 22:08   #3569
Inovator
Inovator's Avatar
Lokacija: Bjelovar
Postovi: 482
Ma jok, citaju ove komentare pa su se uplasili.
Staro 13.11.2020., 22:31   #3570
smirnoff
smirnoff's Avatar
Datum registracije: Dec 2009
Lokacija: nisam u ZG!!!!!!!!
Postovi: 1,204
Autor Exomaniac Pregled postova
eh al vidiš da on oće to imat top topova a da ne plati niš...ne iđe to kod IT firmi tako. prvo plati pa pitaj...
i nemaju svi optiku ili 50 mbs vezu.
i da, jako se malo vidi razlika 1080p i 4K na telki koja je 4K.
