Staro 23.10.2020., 14:36   #421
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Ma ne. Za profi aparat nemam ni mjesta, a nemam ni vremena za servisiranja. Ali znam da je ekipa prije nekog vremena kao budget rješenje kupovala neki jeftinjak delonghi za cca 100€, koji su onda nadogradili aftermarket košaricom bez pritiska i uz korištenje dobrog mlinca i kave dobili super rezultat. To sam negdje pročitao, možda i ovdje!?
Znam da se za EC685 to može, samo sam se pitao jel ima kakve prednosti pred drugim jeftinim uređajima iste klase, a koji mogu biti i duplo jefitniji. Npr. ova Gaggia.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 23.10.2020. u 15:00.
estugarda je offline   Reply With Quote
Staro 23.10.2020., 18:15   #422
Velikus
Velikus's Avatar
Datum registracije: Apr 2004
Postovi: 433
nisam neki barista, ali mislim da je 15 bara previše
ja tražim budget aparat na kojemu se može regulirati tlak, pa može preporuke
ili ako netko zna - kako se full automatic aparatu može postaviti drugačiji default
(...a volio bih modificirati i default temperaturu vode)
"Ups, sam neš uprsk'o?"
Zadnje izmijenjeno od: Velikus. 23.10.2020. u 18:21.
Velikus je offline   Reply With Quote
Staro 23.10.2020., 18:58   #423
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Na ovim Philips modelima imaš "aroma strength" koji ti je u biti jačina ekstrakcije iz kave (pritisak), ima i temperatura kave.
Nego, da se vratim na ovaj svoj Philips EP5930.
Imam problem s mlijekom, jednostavno mi presporo teče i ističe vrlo malo mliječne pjene. Mislio sam da nije do onog LatteGo vrča za mlijeko i prodajni agent iz Philipsa mi je čak donio novi tako da svaka pohvala (iako je aparat van garancije), ali nije pomoglo i jednako sporo ističe.
Sad mi nije jasno do čega je, pretpostavljam da tlak pare koja gura mlijeko nije dovoljno jak i zbog toga mlijeko teče sporo. Koje je rješenje ovoga? Možda je negdje brtva popustila ili je cijevčica kroz koju ide para napukla negdje? Iako kad sam skinuo LatteGo, čini se da para ide dosta dobro ali nemam s čime usporediti. Druga mogućnost je da mlaznica na koju se natakne LatteGo vrč ne brtvi dobro.
- Barney Stinson
Staro 24.10.2020., 00:45   #424
Velikus
Velikus's Avatar
Postovi: 433
Ključne stvari za pripremu savršenog espressa su:
Temperatura 90-95 °C
Pritisak pumpe 9 bara
7 –7,5 grama kave
Staro 24.10.2020., 15:41   #425
Doktor O
I encompass, and I eclips
Doktor O's Avatar
Datum registracije: Jul 2010
Lokacija: Plazikur
Postovi: 1,123
imam dolce gusto krups onaj mali
otkud najjeftinije nabavljat one kapsule? skupe su ko zlato...hvala
Doktor O je offline   Reply With Quote
Staro 24.10.2020., 16:05   #426
Postovi: 8,232
Imaš zamjenske. Originalne smo znali uzimati u edigitalu dosta jeftino.
Imaš i "posudice" u obliku kapsula za kupiti, onda ih puniš s mixom kave kakav ti odgovara. Ali to nismo isprobali/kupili.
Staro 25.10.2020., 17:21   #427
definho
definho's Avatar
Datum registracije: Nov 2010
Lokacija: /
Postovi: 171
ima li netko iskustva s DeLonghi EC 221? cak vidim da ima pozitivnih komentara i da je dosta ljudi zadovoljno, ima li tko na forumu info iz prve ruke, info nakon godinu dvije ili postoji nesto za 700 KN bolje?
ove dodatne stvari za pjenu, s parom i slicno me ne zanimaju, treba mi nesto iskljucivo za kavu, sve dodatne opcije su mi beskorisne
https://www.sancta-domenica.hr/apara...m_medium=click
Respect the Raise...!
definho je offline   Reply With Quote
Staro 29.10.2020., 10:54   #428
Postovi: 10,261
Staro 29.10.2020., 14:15   #429
c-shadow
c-shadow's Avatar
Postovi: 3,515
Slabo ti kavu kuhaš, ta moka izgleda jako malo rabljena
Staro 29.10.2020., 14:35   #430
Postovi: 10,261
Ima jedno 4-5 godina, nije baš ni tako stara... Imam dvije koje paralelno koristim, malu i veću, pa je zato wear and tear slab. Ali brtve idu
Staro 29.10.2020., 15:02   #431
c-shadow
c-shadow's Avatar
Postovi: 3,515
Pa kako?
Naša za 2 kave koja je svaki dan u uporabi izvana izgleda kao da je u ratu bila, a brtve još dobre, ne znam ni koliko je stara
Uspio sam za vrijeme zadnje rupe u koroni zaletiti se do Italije i kupiti lavazze, sad imam zalihu ko američki prepperi
Staro 29.10.2020., 15:29   #432
Postovi: 10,261
Kuhas na plin? Plamen prelazi okolo? Moja ima malo tragova na dnu od plina i u posudi za vodu od kamenca i patine od kave. Iznutra je cista, funnel je maaalo pozutio, a nemam je obicaj prati carlijem nego rukama i vodom, pa papirnatim ubrusom osusim i postruzem zaostale tragove kave na funnelu i gornjoj posudi.
Mislim da sam (tek) na drugoj brtvi, ali ubij me ne znam
Daj fotku, bas me zanima!
Staro 29.10.2020., 16:16   #433
c-shadow
c-shadow's Avatar
Postovi: 3,515
Sram me dati fotku, izvana stvarno ružno izgleda
Da, na plin, moka je za dvije kave i mala je, plin ako se stavi mrvicu jače onako lizne plamen okolo pa još kad zaboravimo i iskipi malo kave preko ruba odmah se zapeče i požutio je aluminij.
Nismo je izvana nikad čistili posebno, a iznutra slično kao i ti, samo voda i spužvica (mekana strana). Kad se skupi kamenca na dnu ostavim octa malo da se otopi, isto za lijevak i gornje sito. Brtva je neka silikonska, isto je posmeđila od starosti. Inače dugo traju te brtve, pitam se kako tebi odlaze tako brzo?
Staro 29.10.2020., 18:26   #434
Postovi: 10,261
Isao sam pogledati u paket brtvi koliko ih fali - meni je ovo ipak druga brtva. U ~5 godina koliko pijem kafe mislim da je to ok. Pocetkom ove godine sam je mijenjao, jos je bijela i tvrda (original bialeti). Tognana moke koje sam kupovao za posao su imale neke poluprozirne silikonske meke brtve.
Ma, nema veze sto je smedja ili crna sve dok brtvi. Ako oslabi, okreni brtvu i probaj tako. Zna se deformirati s vremenom, ali nije za baciti.
Inace kuham na najmanjem plamenu i stavljam prethodno kipucu vodu pa mi je moka puno krace na plinu. Dok kuham drzim je na "pola plamena" jer mi inace prebrzo iscuri (pogotovo mala moka za 1 salicu). Rijetko je zaboravim na plinu, u pravilu prekinem kuhanje i ide "pod vodu" netom prije sikne onaj zadnji jaki mlaz. Taj vruci mlaz na kraju hoce zgorit kavu pa bude gorka/kiselija
Bitnije je sto je cistis iznutra nego kakva je izvana. Tvoja barem ima neke karakterne crte
Staro 29.10.2020., 21:03   #435
c-shadow
c-shadow's Avatar
Postovi: 3,515
Evo spomenute moke, trenutno nije u baš reprezentativnom stanju jer je vrijeme za čišćenje
Kuha svaki dan barem dvaput, ako dođe netko u goste onda i više puta. Imamo i jednu x1 i jedne veću negdje x4 ili x5, te su klasičnog oblika kao ova tvoja gore, ali stoje i slabo se koriste. Znaš kako je s mokom, kava je najbolja ako se stalno kuha. Ova nam je najdraža jer je taman mjera da žena i ja popijemo kavu ujutro. Malo je ženica pala na dizajn s prozirnom plastikom gore koja ničemu ne koristi. Jedina mana je da se malo više podlijeva kod točenja nego recimo ona najveća, valjda ima nešto oko dizajna izljeva. Ako mi se žuri natočiti, kompenziram otvaranjem poklopca pa ide super. Gumica je prozirna silikonska, posmeđila od kave s vremenom, ali još drži. Dobili s njom i neke zamjenske, ali nemam pojma di su
Žena ju je čak jednom izribala izvana s grubom stranom kuhinjske spužvice što je ostavilo traga. Sad se skupilo gareži na dnu, valjda od plina. To imam u planu ispolirati kad stignem.
Nikad ne stavljam toplu vodu. Ujutro dok jedva dogegam u kuhinju i gledajući samo na jedno oko? Znalo mi se dogoditi da zaboravim kavu staviti
S vremenom sam naučio plin točno koliko moram smanjiti da mi se kava napravi za 4 minute, stavim timer na mikrovalnoj pa dođem kad pišti i taman zadnje kapi nacure. Kava ide u šalice odmah, ne hladim moku nikad, osim ako moram nabrzinu još jednu kuhati, a to je rijetko.
Nezgodno je što ponekad odem do kupaonice i dok se umijem da dođem k sebi, prođe više od 4 min, a kava veselo vrije u moki
Na poslu imamo espresso aparat i isto koristimo lavazzu, navikao na tu kavu. Trenutno radim od kuće pa je i moka dobra
Bilo u IT 5€ za paket 2x250g lavazze, kod nas u trgovinama je jedan paket 40+kn. Razlika u cijeni se osjeti.
Znam par ljudi koji idu povremeno do Trsta i tamo uzmu par kg mješavine od lokalnih pržioničara, dobiju dobru cijenu pa onda imaju neko vrijeme.
Ali otkako je korona teško je.
Kakva je ova kava i di si kupio?
E, da, da ne odlaze tebi gumice od hlađenja pod vodom?
Ono nagla promjena temp., aluminij je dobar vodič, naglo stezanje materijala, možda to ošteti gumicu.
Staro 29.10.2020., 23:24   #436
Postovi: 10,261
Aha nije bialeti, zato je drukcija brtva... A znas da nijedna moka koju sam probao na poslu i okolo nema dobar sistem tocenja, svaka kaplje i trazi da dignes poklopac. Ali bialeti ne (ove kockaste kao moja, ne znam kako rade venus, brikka itd). Ne kuzim, kako svi sjebu taj dio
Sumnjam da joj voda smeta. Ona bude vruca i dalje. Stavim je samo na hladan sudoper i pustim vodu sa strane, to zaustavi vrenje i za par sekundi je maknem. Kod brisanja krpom prije stavljanja na stol sam se stoput opekao tako da...
Mi inace, kad nemamo nista drugo, uzimamo 2x250g mljevene oro za 50kn u lokalnom ducanu. Sve ostalo u nasim trgovinama je preskupo.
Uzimam vec godinu i nesto od gringonordic-a iz svedske. Nisu bas najjeftinije, ali naviknuli smo se i fine su nam. Alternativa je taj mljeveni oro, a ostalo smo prestali kupovati. A sta ja znam, te dvije kave na dan ne zelim neke kompromise i drzim se poznatih okusa.
Staro 30.10.2020., 01:23   #437
Velikus
Velikus's Avatar
Postovi: 433
hoće li netko original ZanZibaR (made in Italy) iz 1972. ? (pm)
dobio je patine... trebalo bi uložiti malo ljubavi...
Staro 30.10.2020., 07:31   #438
Ziiky
Ziiky's Avatar
Postovi: 2,881
Dal bi ga mogao uslikati? Ne treba mi, al me interesira kako izgleda?
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 30.10.2020., 07:45   #439
c-shadow
c-shadow's Avatar
Postovi: 3,515
Autor xlr Pregled postova
G.A.T Valentina je ova naša:
http://gatspa.it/shop/caffettiere/valentina/
Što se hlađenja vodom tiče, mislio sam na puno zalijevanje, npr. moja punica kad joj se žuri skine moku s vatre i stavi je pod mlaz vode. Moka se ohladi za nekoliko sekundi pa se može rukom odšarafiti bez da se opečeš. To nikako nije zdravo za materijal, ali ona to radi često i bez nekih posljedica, osim pokoja brtva, mislim da je njezina isto bialeti.
Staro 30.10.2020., 07:58   #440
Matijac
Matijac's Avatar
Postovi: 851
Ja isto iz mokke odmah natočim u šalice, makar ne popijem sve odma, ali sam čitao da dobije metalan okus ako stoji duže i ostaje fleka od kave. Ja natočim sve i odma isperem mokku.
Imam ih 3 doma, original bialetti za indukciju i 2 no name i istina je da bialetti uopće ne podlijeva i vidi se da je robusnija, da je bolje napravljena, ali i ove su ok.
Zna vam biti u konzumu akcija, 2x250g lavazza mljevena + mokka za 3 osobe za 100kn što je ok.
Staro 30.10.2020., 08:03   #441
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Ja je zalijem vodom da prekinem vrenje kave, da ne gori kava, inače je gorka, a pijem bez šećera.
Nisam primjetio neke posljedice po brtve.
Brtva mi je najebala kad sam zaboravio vodu jednom stavit i čudio se kako ne ide kava van. Dok nije guma zasmrdila
Bialetti rainbow crvena za 1 espresso.
Staro 30.10.2020., 10:18   #442
Velikus
Velikus's Avatar
Postovi: 433
Staro 30.10.2020., 12:48   #443
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor estugarda Pregled postova
... za EC685 to može, samo sam se pitao jel ima kakve prednosti pred drugim jeftinim uređajima iste klase, a koji mogu biti i duplo jefitniji. Npr. ova Gaggia.
Stigao EC685 i upravo sam isprobao. Zaključak je da nema aposlutno nikakve prednosti u kvaliteti espressa u usporedbi sa 3x jeftinijim "Telefunken" jeftinjakom.
Izrada je super za tu cijenu. Djeluje kvalitetno. Držač portafiltera je iznenađujuće masivan. Ali sam filter je sranje i iz toga se ne može dobiti dobar espresso ni sa najboljim aparatom/zrnom/mlincem;
Osim što je "pressurized", ima idiotsku gumicu kojom se filter izvlači iz čašice, i koja strši u zrak, i naravno da se oko nje stvori kanal...
To može samo idiot smisliti. Vjeorjatno bi bilo bolje da je odrežem, ali neću se uopće zamarati.
Računao sam s tim, pa sam unaprijed naručio ovo:
https://www.aliexpress.com/item/4000...58944c4dUVKtMQ
Jedva čekam da stigne, pa da vidimo je li ova ec685 kupovina totalni fail ili ne. Filter na Telefunkenu je bio 10x bolji. Šteta da ne paše.
Vjerojatno sam mogao komotno uzeti najjeftiniji DeLonghi na koji paše ovaj kineski otvoreni portafilter. Mislim da ih je nekad bilo i za 600-700kn. EC35 se zvao. Sad ga nema izgleda.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 30.10.2020. u 14:20.
Staro 30.10.2020., 13:09   #444
Postovi: 23,607
Baš su blesavo napravili taj detalj, premalo rupica i presitne ...
Šta kažeš, isti đava si mogao dobiti za cca 700 - 800 Kn, samo primjeri:
https://www.sancta-domenica.hr/apara...ux-eea111.html
https://www.sancta-domenica.hr/mali-...va-crveni.html (vode ga pod krivom oznakom, tvornički je drugačiji)
Staro 30.10.2020., 13:35   #445
c-shadow
c-shadow's Avatar
Postovi: 3,515
Kako mogu rupice biti premale, proizvođač ne zna to napraviti?
Za svaki espresso aparat bi trebalo dobro uskladiti granulaciju mljevenja kave, aparat i sito itd. Dosta da samelješ puno kave odjednom i da se malo navlaži po zraku i eto drugačije kave. Ovi mali kućni aparati znaju imati slabe pumpe za vodu, točno čuješ kako se muči. U bivšoj firmi imali neku malu baby gaggiu, to je bilo zlo samo takvo. Skuhala bi ona, ali bi cvilila od muke. U sadašnjoj firmi imamo neki oveći bolji aparat, zaboravih marku, ali talijan je, voda ide van po 6-7 bara tlaka, možda i više, ima 2 manometra.Serviser nam obično namjesti to sve i onda aparat jedno vrijeme radi ko urica - dok se netko od kolega ne sjeti namještati mlinac ili firma promijeni kavu, a onda opet sve ispočetka dok se ne uštima
Staro 30.10.2020., 13:42   #446
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Nikky Pregled postova
A baš sam to pitao ovdje prije kupovine, ali mi nitko nije odgovorio, pa sam išao na sigurno jer sam htio aftermarket portafilter. Nije sad to neka cifra da ću propasti, ali eto da se zna da je, osim dostupnosti aftermarket opreme i podrške, više-manje svejedno što se kupi do 200€.
EC685 se definitivno ne muči. Sad sam namjerno samljeo na presitno i dobro nabio. Isto zvuči i dobro ide. Nema oscilacija. Ali kava očekivano blago pregori tako. Nije stvar ni u pritisku. Pritisak je, rekao bih, dobar, jednostavno je taj filter smeće. Svaki put oko te gumice nastane kanal bez obzira kako je tampano ili mljeveno. Nema tu pomoći. Ne može kroz taj filter ravnomjerno proći i gotovo. Filter ne valja.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 30.10.2020. u 14:06.
Staro 30.10.2020., 13:45   #447
Postovi: 23,607
Možda nisu presitne ali ih sigurno ima premalo, čak i ako ima pumpu od 15 bara.
Slažem se da treba uskladiti tlak - granulaciju - sito, za svaki drugi tip kave.
Staro 30.10.2020., 13:57   #448
Velikus
Velikus's Avatar
Postovi: 433
imate li preporuku za budget aparat na kojem se mogu podešavati tlak i temperatura vode?
poželjno bi bilo i da ima ugrađeni mlinac...
i koliko je realno da bi takav aparat pripadao nekoj budget (300-400€) kategoriji ?
Staro 30.10.2020., 14:33   #449
c-shadow
c-shadow's Avatar
Postovi: 3,515
Upravo se skuhala jedna kavica nakon ručka
Bila kriza neko vrijeme tijekom korone pa se nabavljalo svašta. Dovršili smo neku Segafredo i otvorili ovu kupljenu na akciji u IT za siću... ništa posebno nažalost. Ovu nisam dosad još probao, ali ne bi mogao preporučiti, nekako mi kiselkasta po okusu...
Staro 30.10.2020., 14:52   #450
Postovi: 23,607
Njihova crna mi je dobra, samo je fino skupa pa je uzmem samo ponekad.
https://www.lavazza.hr/hr/mje%C5%A1a...vena-kava.html
