Staro 21.09.2020., 18:24   #991
gmax
Tuco “the Rat” Ramirez
gmax's Avatar
Postovi: 474
Da, kompletni ZeniMax za 7,5 milijardi bucksa
Staro 24.09.2020., 00:31   #992
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,286
Mike Morhaime, cofounder of Blizzard who left the company in 2018, has recently started up a new company called Dreamhaven, and it has established two new game studios, Moonshot and Secret Door.
- These studios are made up of a lot of former Blizzard employees and are entirely self-funded.
- Morhaime says, "We’re almost trying to create a haven for creators who want an environment that is development friendly, values product, and player experience over short-term financial pressures.”
- više o tome https://venturebeat.com/2020/09/23/b...or-dreamhaven/
https://www.dreamhaven.com/
Staro 30.09.2020., 19:15   #993
Alfredo nr.3
Alfredo nr.3's Avatar
Lokacija: Požega
Postovi: 1,244
Ako kupim ključ na G2playu preko VPN iz recimo Brazila i aktiviram ga na Stemu, mogu li imati kakvih problema kada se ponovo spojim na račun bez VPN-a?
Alfredo nr.3 je offline   Reply With Quote
Staro 30.09.2020., 19:16   #994
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,409
Ne vjerujem da steam ima regijska ograničenja ili se varam?
Hala Madrid!
Staro 30.09.2020., 19:57   #995
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Ako prođe prođe, piše da će poslati kroz 72 sata
Overwatch giveaway (Battle.net) od nekog Overwatch tima, piše samo da je za US ali u kometarima jedan kaže da je dobio iako je iz EU
https://www.reddit.com/r/GameDeals/c...h_for_pc_free/
treba samo upisati američki zip code npr.
Just insert a random zip code lmao that's what I did. Try 93247
Redeemed 2 keys without a problem. (I'm in EU)
Got it from Brazil. Just use any zipcode. Didn't need a VPN.
UPDATE: Isteklo
""This form has been deactivated and is closed to any further submissions.""
Zadnje izmijenjeno od: Old.machine. 30.09.2020. u 21:00.
Old.machine je offline   Reply With Quote
Staro 01.10.2020., 08:13   #996
Dalthor
Dalthor's Avatar
Datum registracije: Aug 2019
Postovi: 113
Autor Alfredo nr.3 Pregled postova
99% ti neće proći, odnosno ovisi jeli igra sama po sebi ima regionalna izdanja, a većina AAA naslova ima, eventualno ako je neki indie naslov bi moglo proći.
prije cca 3 godine su uveli ograničenja, prije toga su se mogli keyevi i steam giftovi mogli iz brazila, rusije i od svagdje aktivirati.
ako se ne varam, provjeriti ima li igra regionalne verzije se može provjeriti na steamDB, ako ima više registriranih unosa onda ima regionalna izdanja.
Dalthor je offline   Reply With Quote
Staro 01.10.2020., 14:47   #997
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
Kupio sam ključ sa ove stranice https://www.hrkgame.com/en/
Aktivirao sam ga na Steamu i zasada je sve ok. Je li sigurno kupovati s te stranice? Kupio sam Global key. Čuo sam da su neki korisnici imali iskustva sa suspendiranje računa. Ja sam aktivirao igru na glavnom računu gdje su mi sve ostale igre, ne bi volio da mi suspendiraju račun. U kojim uvjetima se suspendira račun i može li se vratiti nazad nakon nekog vremena? Zašto samo ne obrišu igru koja je sporna?
Staro 01.10.2020., 14:55   #998
Postovi: 16,767
Nikada problema s njima nisam imao.
Sve što kupuješ od 3rd party resellera nije 100% sigruno (najbolje uzeti od official).
Ali kupio sam u životu brdo keyeva, nikada, ali nikada problema.
Staro 01.10.2020., 15:22   #999
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
Imaš poseban račun na koji ih aktiviraš ili ih aktiviraš na glavnom računu?
Staro 01.10.2020., 15:45   #1000
Postovi: 16,767
Ma glavni račun sve.
Staro 03.10.2020., 19:49   #1001
Old.machine
Lokacija: ______
Postovi: 1,455
Za onaj gore Overwatch giveaway očekivano: "Pursuant to the Promotion Rules, your entry did not meet the requirements to receive a code from this Overwatch League initiative."
Ugasili su bili giveaway nakon sat vremena a na stranici im je pisalo: "Entrants must be 13 years of age or older and U.S. residents. Entries must be submitted by 1/15/2021
and codes must be redeemed by 1/31/2021. Limit 1 code per Battle.net account."
Na Indigali cijeli Theatre of war serijal besplatan
https://freebies.indiegala.com/theatre-of-war/
https://freebies.indiegala.com/theat...2-africa-1943/
https://freebies.indiegala.com/theat...ar-2-centauro/
https://freebies.indiegala.com/theat...-2-kursk-1943/
https://freebies.indiegala.com/theat...ttle-for-caen/
https://freebies.indiegala.com/theatre-of-war-3-korea/
Usporeba sa Steamom.
Staro 15.10.2020., 21:34   #1002
svetac.svetac
Datum registracije: Dec 2014
Lokacija: novi zagreb
Postovi: 324
Autor IGoR_2803 Pregled postova
Alien: Isolation definitivno. Nema igre u kojoj si manje bespomoćan pred gadnom beštijom...
upravo prešo više od pola, moram priznat da sam oduševljen, malo me ambijent ako ne i puno podsjeća na dead space, sad me zanima dal ima nešto u tom stilu igro onaj prastari avp sad ne znam dal se isplati odigrat novije nastavke ?
svetac.svetac je offline   Reply With Quote
Staro 16.10.2020., 06:34   #1003
Alfredo nr.3
Lokacija: Požega
Postovi: 1,244
Ja igram Aliens : Colonial Marines Overhaul Version 6 i meni je odlična. Mod igru pretvara u ono što je trebala biti kad je izašla.
Od AVP serijala, kažu da je dvojka daleko najbolja, a i ima dosta modova za istu.
Ovdje ti je retrospektiva AVP serijala https://www.youtube.com/watch?v=Jz1iMnLiGf4
Staro 20.10.2020., 19:08   #1004
Old.machine
Lokacija: ______
Postovi: 1,455
Staro 21.10.2020., 22:30   #1005
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 28.11.2020., 22:01   #1006
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Jel hoće tko ovo
With your order, you can now get a 30% discount on Game Pass for PC. To get Xbox Game Pass for PC 3 months for only €17.99
Staro 11.12.2020., 03:48   #1007
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,286
GOTY 2020. TLOU 2
Staro 11.12.2020., 12:01   #1008
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,409
S obzirom da nisu ni imali pravu konkurenciju, nije čudno.
Hala Madrid!
Staro 14.12.2020., 16:46   #1009
Staro 14.12.2020., 18:01   #1010
Necto
Necto's Avatar
Postovi: 747
Lako za F1, formula ima odlicnih ako ne i boljih sim alternativa
Sranje je sta ce unistit Dirt Rally, jednu i jedinu pravu rally simulaciju =(
Necto je offline   Reply With Quote
Staro 14.12.2020., 18:54   #1011
Koje su to F1 alternative?
Staro 14.12.2020., 19:08   #1012
Old.machine
Lokacija: ______
Postovi: 1,455
Sad EA pod kontrolom ima ove trkaće serijale:
F1, WRC, Dirt, Grid, Project Cars, Burnout, Real Racing, NFS
Jel imaju sad monopol na tom polju? Od ovih što nemaju i valjaju jedino mi na pamet pada Forza horizon...
Staro 14.12.2020., 19:09   #1013
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,286
Autor Necto Pregled postova
Probaj wrc 8/9, uzivam
Staro 14.12.2020., 20:00   #1014
Necto
Necto's Avatar
Postovi: 747
Automobilista
rFactor 2
Asseto Corsa RSS mod
Iracing
Sve nabrojano su prave formula simulacije, dok je F1 serijal vise simcade
Ali ako se igra samo SP i to uglavnom radi kampanje onda je F1 tu najbolji
@mamute
Dobar je WRC, cujen da su 9ku popravili dosta
Meni je malo zaostajala za DR2.0 ali nema podrsku za VR
A sad nakon sta san vozia u virtualnoj realnosti simulacije na ekranu su mi puno losije
Staro 15.12.2020., 08:14   #1015
Postovi: 16,767
GOTY 2020. TLOU 2
Tek sad vidim ovo.
Zbog nikakvog tržišta ove godine, ajde, ne vidim bolju igru.
Ali koliko je to daleko od nekakvog ranga "GOTY", to je nevjerojatno.
Staro 17.12.2020., 20:46   #1016
Morpheous
Morpheous's Avatar
Postovi: 1,137
Ako koga zanima imate Theatre of War 2: Kursk 1943 na IndieGala.
Morpheous je offline   Reply With Quote
Staro 23.12.2020., 22:48   #1017
Postovi: 10,039
Imate neku preporuku couch local co-op igri tipa Overcooked? Poželjno da ima full controller support (barem 2 playera).
Vidim ima Moving out, maltene ista šema. Guglajući nisam uspio naći nešto drugo, a slično. Bez nasilja, bez nekih komplikacija, bildanja charactera, kompliciranog gameplaya, pay to unlock fora i sl...
Staro 23.12.2020., 22:59   #1018
buljaka
Datum registracije: Aug 2014
Postovi: 2,929
Tools up
Sent from my Mi 9 Lite using Tapatalk
buljaka je online   Reply With Quote
Staro 24.12.2020., 07:50   #1019
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Automobilista
rFactor 2
Iracing
FIA Formula 1 nema službenu ni pravu alternativu.
Uz RSS modove za Assetto ima i drugih. Naravno svi se plaćaju.
https://www.assettocorsamods.org/pro...prix-2020-mod/
Ali nikada to ne bude iskustvo koje pruža F1 sluzbena igra
Staro 24.12.2020., 09:34   #1020
nub
PREMIUM
nub's Avatar
Postovi: 2,146
Naravno da F1 nema pravu alternativu. Kome je do storya i želi sve licencirane timove i vozače oko sebe da se uživi i pritom vidjeti kako staze otprilike izgledaju iz perspektive vozača nema druge. Također se da pikat s joypadom.
S druge strane, iskustvo vožnje je arkadno, tj nema puno veze sa stvarnim svijetom. Pošteni volan + simulacija su skroz drugačije iskustvo. Naravno, u takvim igrama nikad neće biti toliko službenog recentnog contenta nit će službena F1 igra ikad ići u smjeru simulacije jer to većini ljudi nije interesantno. Ovisno što se traži od igre.
