#4021 |
Postovi: 480
može preporuka za monitor, ništa specijalno ali da je oke po pitanju boja, kvalitete. konfa: athlon x4 860k, 8gb, rx 570 4gb edit: kupio monitor Zadnje izmijenjeno od: Pegasus8. 30.09.2020. u 01:03. |
#4022 |
Postovi: 1,620
#4024 |
Postovi: 1,620
#4026 |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,183
@ Hrconja & gin.tonic PS5 ima svoju temu/topic Playstation tehnikalije u kojoj sam napisao odogovor pa nastavimo diskusiju tamo. back on topic Došao je novi model koji je kvaliteto slike lošiji od starog: Upravo ono cega sam se "bojao" da bi moglo biti ... Novi AOC 24 VA 165 Hz curved je ipak lošiji, https://youtu.be/cIUtOUz1_mY?t=583 ...bolji je stari model 24G2U 144 IPS kojeg preporucujemo preko godinu dana (od 10/2019 -te) AOC C24G2U zakrivljen ekran (curved), 1080p , VA matrica, 165 Hz , FreeSync Premium , Low Input Lag mode 1550 kn u instaru https://www.instar-informatika.hr/mo...24g2u/product/ Detaljnih testova trenutno još nema ... tako da trenutno nemogu dati preporuku za njega dok ne vidim rezultate. Novi AOC -i https://hexus.net/tech/news/monitors...ming-displays/ C24G2AE and C24G2U, and the 27-inch C27G2AE and C27G2U. Decoding those less obvious 'AE' and 'U' suffixes for you before we go further, the AE models are affordable versions with tiltable stands, while the U models feature both height-adjustable stands and a USB 3.2 hub with four USB ports. Aggressive 1500R curvature screen with slim bezels VA display panel with 178/178° viewing angles FHD 1920 x 1080 pixels High contrast (3000:1 native contrast for 24-inch models and 4000:1 for 27-inch models) Typical brightness: 250 nits Colour gamut: 120 per cent sRGB 48-165Hz refresh rate AMD FreeSync Premium support MBR (Motion Blur Reduction) option Low Input Lag mode 1 ms MPRT (Moving Picture Response Time) G-Menu OSD with six gaming modes, game colour, crosshair config Flicker-Free and offers a Low Blue Mode Built-in speakers (2x 2W) ![]()
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 30.11.2020. u 13:49. |
#4027 |
Datum registracije: Aug 2003
Postovi: 412
Sorry... da ne otvaram novu temu... 24" monitor....
Da li bi mogao kupiti novi 24" monitor i na njega preko HDMI-a spojiti ovaj novi reciever DVB T-2 za TV? Pitam zbog frekvencije monitora u odnosu na frekvencije TV-a.... Hoće li se slika normalno prikazati ili će biti nekoh "filozofija"? Nisam po tom pitanju baš nešto.... Na taj način bih spojio ugodno s korisnim...
ZnaM Da niŠta Ne ZnaM |
#4028 |
Postovi: 2,183
DVB-T2 resiver možeš HDMI kablom spojit na HDMI ulaz od monitora i to ce najnormalnije raditi. Jedina negativna strana toga su zvucnici monitora koji su opcenito dosta tihi (u usporedbi sa normalnim TV zvucnicima) i fali im "topline tj boje" zvuka ali bit ce dovoljno glasni ako nemaš drugih izvor zvuka (buke) oko sebe.... Bolja je ta konbinacija Monitor + DVB-T2 za koju pitaš nego da uzneš bilo koji TV monitor konbo. Ovako dobiješ pošten monitor sa odlicnom matricom i sam si biraš resiver koji ti paše, a onako dobiješ srednju žalost monitor i pitaj boga kakvi DVB-T2 resiver. A da ne pricam o stalku, podesivosti po visini, nagibu, rotiranju te VESA rupama sa kojima možeš monitor imati na nosaču - monitor arm.
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 28.10.2020. u 02:33. |
#4029 |
Postovi: 412
OK hvala na detaljnom odgovoru...
#4030 |
Postovi: 54
AOC I2481FXH
Pozdrav! Imate li molim vas mišljenje ili iskustvo korištenja monitora AOC I2481FXH? Koristio bi se na konfiguraciji u potpisu za uredski rad, gledanje filmova te WoT i simulaciju Assetto Corsa. Samo kvaliteta prikaza me zanima (u odnosu na druge monitore slične cijene ili eventualno do 1200 kn), ergonomija mi nije bitna i razumijem da ima samo podešavanje nagiba. Cijena mu je 1000 kn a ovdje preporučeni AOC 24G2U ne mogu iskoristiti u punom potencijalu s navedenim hardverom. |
#4031 |
Datum registracije: Nov 2014
Postovi: 73
Molim preporuku za solidan monitor 24'', nije za igrice. Isključivo office, programiranje... |
#4032 | |
Lokacija: Zg/Zd
Postovi: 712
Nisi naveo budget ili detaljnije što radiš, ali za posao nije loše razmisliti i o 27" (2560x1440) ili 2x24" (npr. rabljeni U2412M se može naći po 750-900 Kn), ukratko, što više radne površine - isplati se. |
#4033 |
Postovi: 2,183
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv |
#4034 |
Postovi: 73
Hvala decki. A sto od 27" onda preporucate?(znam da nije tema). Budzet do 2000 ako stane. Iskljucivo programiranje, excel. Ne zelim samo da me oci bole jer radim 10+sati dnevno na tome Sent from my MRD-LX1 using Tapatalk |
#4035 |
Postovi: 2,183
DELL P2720D 2280kn https://www.protis.hr/products/detai...just-3y/150946 2560x1440 @ 27" bi ti trebala biti dovoljno oštra da da te ne bodu pixseli i slova u oci pri radu. Uzni preko internet bankarstva, za slucaj da bude mrtvih piksela, IPS glow -a, backlight bleed -a ; lako ga vratiš i dobiš povrat love. Ako uplatiš platiš oneline do 10 - 12h vjerojatno ti stigne i pokupiš ga isti dan u poslovnici.
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 04.11.2020. u 01:01. |
#4036 |
Postovi: 93
Za nešto ispod 2000 kn je odnedavno dostupan Dell S2721DS koji je specifikacijama vrlo sličan P2720D. |
#4037 |
Postovi: 1,315
Evo imaš ovo https://www.mall.hr/lcd-monitori/aoc...m_medium=click A imaš još par modela na BlackFriday popustu pa si pogledaj, ima dobrih cijena |
#4038 |
Postovi: 447
Pozdrav ekipa, do 2500Kn (+/- 200 kn) dajem za 24" monitor koji ima USB-C (power delivery). Ukratko, monitor je za rad na racunalu, tablice, dokumenti, nesto modeliranja, nije primarno za gejming ali odvrtit ce se koja partija. Ovaj ili ima nesto drugo? ![]() |
#4039 |
Postovi: 16,747
1440p za 24" je prevelika rezolucija. Ili gledaj 27" ili uzmi FHD. |
#4042 | ||
Postovi: 16,747
![]() Citiraj:
Ovo što ti imaš je standardna rezolucija za ultrabookove i laptope u nekom normalnom budžetu. |
#4043 |
Postovi: 1,806
Nisam probao ali recimo jedan inč više u2515h 1440p sasvim u redu i rekao bi taman. Kad sam imao kratko dell u2719dc nisam se moga oteti dojmu da rezolucije fali, ali čudno na aoc q27t1 nisam imao taj osjecaj da je rezolucija premala. Očito je postojala razlika u oštrini jer u sustini oba su bila ips 27" i 1440p,ali je aoc bio daleko bolji monitor |
#4044 |
Postovi: 447
#4045 |
Postovi: 2,183
![]() /connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv Zadnje izmijenjeno od: Blue Spirit. 11.11.2020. u 02:14. |
#4046 | |
Postovi: 2,434
#4047 |
Postovi: 16,747
Ne kužim zašto su išli na VA ponovo a s IPS-om slomili svu konkurenciju u tom budžetu. Iskreno 165hz nakon 144 je nikakav upgrade ali preći s IPS na VA je baš korak unazad. |
#4048 |
Yare Yare Daze
Datum registracije: Jan 2014
Postovi: 202
Frend bih uzimao ovaj monitor:ASUS VG258QR Pa bih molio ako moze par komentara? Trazi neki 24" Monitor Freesync/gsync,144hz+. Ja sam sebi bio uzeo AOC 24G2U 24" FHD 144hz 1ms IPS prije 6-7 Mjeseci jer je bio best buy,pa me zanima dali je dalje best buy for the price ili ima neceg boljeg? Hvala Unaprijed. |
#4049 | |
Postovi: 2,434
