Staro 08.10.2020., 18:39   #8401
Postovi: 8,351
Ode...
Generation-on-generation, this would be a 17.8% performance increase. Over Intel’s highest performing desktop Core i9, that would be a lead of 17.3%. Over Intel’s latest generation microarchitecture, Tiger Lake, this is a 6% performance increase at the same frequency. Whichever way you slice it, whether you consider the lead a 17% lead from desktop-to-desktop, or a 6% lead from best-to-best, one thing is clear that if this result is correct, AMD will have the single threaded performance crown.
Staro 08.10.2020., 18:39   #8402
axo
Datum registracije: Sep 2017
Postovi: 1,429
Za mene sa 1600 r5 ovo je milina, jos baba rekla da ce podrzavat sve platforme i da asus pukne bios bit ce
Ili u svakom slucaj back to R9 zen 2.
axo je online   Reply With Quote
Staro 08.10.2020., 18:43   #8403
Women: "Men wants only one thing and it is disgusting".
Men wants: "BIOS for Zen3 support on X370 čipset boards"
Staro 08.10.2020., 18:44   #8404
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 08.10.2020., 18:45   #8405
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Odjeb je lansiran!
Kako mi je sad drago kaj sam se prebacio na AMD platformu, pa to nisu istine... A i ova najava nove radeonke ukazuje da bi trebala biti 15ak posto jaca od 2080Ti (ovisno od igre negdje manje negdje vise) no svakako meni dovoljno da se odlucim na kupnju pogotovo jer nevidija nema na vidiku...
Nista, sad se ceka preorder button. BIOS 1.1.0.0 je vec gore.
Staro 08.10.2020., 18:47   #8406
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,312
Tek u siječnju!
Ovo su sad već intel/nvidia fore.
Ko oće dmaho, neka kupi ploču.
Ko neće, nek se ukiseli čekajući.
Slobodno me dodajte na PSN
Staro 08.10.2020., 18:51   #8407
Postovi: 8,351
To su MBO ekipa igre, jer oni bi najrađe ko za Intel opet nove ploče, mada realno nema potrebe. Ovak svi dobe podršku, ali novije ploče idu na vrh liste i bez čekanja.
Staro 08.10.2020., 18:54   #8408
sharyn
sharyn's Avatar
Datum registracije: Jun 2010
Lokacija: grubišno polje
Postovi: 565
a s stajališta average korisnika to je i bolje, taman se prva 2,3 batcha procesora riješe i uklone svi mogući problemi.
OT: el ovo pokazatelj da AMD grabi jače s cijenama? ako intel ne odgovori u prvoj polovici 2021 mozda refrex ovih procesora bude još veća cijena.
OFF: navodno je amd jasno odlučio da x370 neće dobit podrsku za nove procesore; nadamo se da će pametni ljudi napravit sami ko za x470
sharyn je offline   Reply With Quote
Staro 08.10.2020., 18:56   #8409
Postovi: 8,351
Bude u proljeće 2021. Rocket Lake u još jednom 14nm izdanju i nove ploče s 500 serijom čipseta. Mada sudeći po ovome, Zen 3 nema brige.
Staro 08.10.2020., 18:59   #8410
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
..kako kaze moj dobar prijatelj "nabijem ih na japanca"
i sad bi ja kao trebao cekati 3 mjeseca ..al ce me izmust ovog puta
MojSkuter
Staro 08.10.2020., 18:59   #8411
Ploča je najmanji problem. Kome hitno treba, B550 Tomahawk se nađe za 1150-tak kn, a ploča je bomba. Malo je škrta sa USB portovima iza ali ako zadovoljava nekoga samo 5 USBa, ta ploča će na Day 1 moći ugostiti i ove masne R9 mrcine. Ali kombinacija solidne B550 ploče i najjeftinijeg Zen3 procesora iz ove palete bude cca 3500 kn. Fino.
A to znači da i Zen2 procesori tipa R5 3600 neće baš bit po ispod-800 kuna po oglasima kak su se neki nadali i priželjkivali niti 3700X bude po 1400 kn u dućanima kao onomad Zen i Zen+ X modeli oktaša možda i bude, tko zna.
Staro 08.10.2020., 19:00   #8412
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Zen 3 vs Zen 2 : IPC +19%
Staro 08.10.2020., 19:02   #8413
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Pozdrav, evo upravo odgledao ovo sve... impresivno. ))
Može li netko od vas zagriženih igrača komentirati ove podatke FPS-u u igrama u 4K za Big Navi, mislim koliko je to u odnosu na RTX 2080 i RTX 3080? Hvala...
Staro 08.10.2020., 19:02   #8414
Postovi: 8,351
Autor Eladio Pregled postova
Ja si to ovak gledam, R7 4750G i 3700X su trenutno na kakvih 2.300 kn, pa koji prvi padne na 2.000 kn ili kojim slučajem ispod - to je to kaj se mene tiče i ide zamjena za sada već više od tri godine stari R5 1600.
Čist račun, duga ljubav.
Autor BusMaster Pregled postova
U rangu s RTX 3080, možda malo slabija.
Staro 08.10.2020., 19:03   #8415
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
..a tako nekako i ja gledam.. ocito ce moja ploca i proc uskoro na bubanj, ..sumnjam da cu moci cekati
..ako nista drugo necu prodati u bescjenje, jos uvjek ce ta kombinacija imati neku svoju vrijednost
MojSkuter
Staro 08.10.2020., 19:07   #8416
guerra
Datum registracije: May 2019
Postovi: 522
U gamingu 5-6% brzi u prosjeku kako sam i pretpostavljao. A nis, ceka se iduci gen od od jednih i drugih za neki posteni upgrade
guerra je offline   Reply With Quote
Staro 08.10.2020., 19:16   #8417
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,312
Ovo se i meni čini.
Zen/Zen+ i Zen2 su bili za penetriranje Intela i tržišta.
E sada nema više labavo, vraćamo se u eru Athlona 64 FX (premda mislim da je Pentium Extreme ipak bio skuplji).
A jbg, bilo je lijepo dok je trajalo, najgore je što plavi doslovno ne trzaju cijenama ni najmanje. Boli njih briga, prodaje se.
Staro 08.10.2020., 19:16   #8418
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Kolko vidim vecina ploca je postala skrta sa usb portovima, a pogotovo MSI ploce. Cak i moja Godlike ima samo 5 usb portova iza sto je smijesno obzirom na cijenu... Uvalise mi wifi antene i mega headphone jack umjesto da su strpali jos npr 4 usb porta...
Staro 08.10.2020., 19:25   #8419
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Pogledao kosatog Stevicu (novinari su dobili više informacija):
I/O die identičan sa zen2
Memorijski kontroler također identičan zen2
Overclocking naravno ovisi o čipu, no kaže vjerojatno slično ponašanje
Autor Disco Pregled postova
Tek u siječnju!
To be fair, kad su "popustili" za 400 ploče rečeno je da će biti beta biosi, te da neće možda biti odmah...
Staro 08.10.2020., 19:29   #8420
Postovi: 8,351
Sve ovo je snimljeno i pripremljeno prije, tako da odmah sad na dan službenog predstavljanja svi pisani i JubiTo tehnički mediji imaju finog materijala.
Zadnje izmijenjeno od: The Exiled. 08.10.2020. u 19:34.
Staro 08.10.2020., 19:47   #8421
BusMaster
BusMaster's Avatar
Postovi: 343
Za I/O die nemaju potrebe ništa mijenjati, za Mem. kontroler nevjerujem jer nema više onog sweet spota ... around 1800MHz, (pa iznad toga skalira frekv. tj. ratio na dole), sada bi to navodno trebalo biti ispravljeno.
Treba stvarno pričekati prve ozbiljnije testove, glede OC potencijala i ostaloga, mada mislim da im je taj misteriozni 7nm+ "Warhol" nekako u rezervi ako Rocket Lake bude imalo ugrozio Vermeer. Očito je da imaju potencijala i spustit cijenu i nategnut još malo clock za ovu seriju... s obzirom da od Intela nema baš ništa novo do proljeća.
BTW, ovaj potez da ne izdaju novi čipset ima itekako smisla, ono gdje su stvarno sjebali motku je to da R7 i R9 modeli dolaze bez stock kulera. S obzirom na ovaj TDP i više cijene, cicije samo takve... (
___________________________________________________________
Staro 08.10.2020., 19:53   #8422
Postovi: 8,351
Ne daju cooler s tim modelima, jer ljudi ionako kupe pošteni za 12 i 16-core modele, pa (po njima) nema potrebe stvaljati hladnjak koji nitko neće, a podiže cijenu. Kaj se Intela tiče, Rocket Lake bude imal verziju Willow Cove jezgri kakve sad ima Tiger Lake, ali umjesto 10nm, opet ide sve na 14nm. Zen 3 već sad ima bolje performanse od najboljeg kaj Intel nudi, a to je 10nm Tiger Lake, pa ako i izvedu neko čudo u proljeće 2021. tek budu dostigli ovo kaj je AMD danas preCtavil. Dok se Intel snađe krajem 2021. sa svojim Alder Lakeom, AMD već dolazi s 5nm Zen 4 modelima.
Staro 08.10.2020., 19:59   #8423
Manuel Calavera
Postovi: 14,584
Kakav stock cooler za cpu cijenovnog ranga R7 i R9. Taj cicija ako nema za sftermarket cooler nek se rani
Pa ja sam uvijek preporučivao Freezer 33/34 za R5 3600, nije ni 200kn
Staro 08.10.2020., 20:03   #8424
Exomaniac
Datum registracije: Mar 2016
Postovi: 767
Prije prezentacije sam se nećkao bi li upgradeao svoj i7 4790, no s obzirom na podizanje cijena, sad me malo cijela ova priča ohladila. Zasad je za 1080p60 sasvim dovoljan, ima vremena za pričekati pad cijena kroz godinu, a možda i dolazak Zen 4. Da ima po cijeni R5 3600 ne bih se nećkao duže od nekoliko minuta
Staro 08.10.2020., 20:03   #8425
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
Mislim da nema smisla za 58xx i 59xx seriju davati stock coolere uz to. Ionako tko god uzima tako šta vjerujem da mu nije problem uložiti još 150$ pa uzeti nekakav AIO ili Noctua (ako stane na ploču).
Što se tiče biosa za 570 i 550 chipsete može nastati problem ako netko kupi ploču koja je stajala na polici dulje vrijeme, a nema nikakav proc s kojim može updateat bios. U svakom slučaju napredak u odnosu na ranije, ali još nije takav da upgredam sa svoje 3000 serije.
-potpis-
h3lld je offline   Reply With Quote
Staro 08.10.2020., 20:19   #8426
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor Exomaniac Pregled postova
Za tebe je i R6 3600 velik upgrade, a obzirom da 5600X kosta osjetno manje nego je 4790 kostao kad je izaso, ne znam sta si ti ocekivao da ce dijelit djabe?
Staro 08.10.2020., 20:23   #8427
Exomaniac
Postovi: 767
Autor zwer54 Pregled postova
Sori, ali 20% bolje performanse za 17% veću cijenu osobno ne smatram baš i nekim velikim skokom za potrošaće.
Staro 08.10.2020., 20:24   #8428
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Što se tiče memorije sve je ostalo isto, tako i granica od 3733 MHz za 1:1 odnos IF:RAM. Naravno i IF je moguće overklokirati pa dobiti 3800 MHz ili više ali to opet ovisi o samom procesoru. Samo su se chipleti mijenjali a memorijski kontroler je na IO jezgri.
Staro 08.10.2020., 20:27   #8429
Postovi: 8,351
20% u odnosu na Zen 2, dok je razlika u odnosu na Core i7-4790K ipak malo konkretnija. Ovaj put AMD ne mari za osjećaje potrošača, niti bi trebali, cilj je zaraditi nofce, pogotovo sad kad su u ovakvoj situaciji.
4C/8T Core i7 modeli su zaključno s 7700K sad već zaboravljene 2017. uredno išli za 300$+, pa ovo kak god bilo povećanje cijena, ipak nije loše.
Staro 08.10.2020., 20:29   #8430
Flegma
Flegma's Avatar
Datum registracije: Jul 2004
Lokacija: Zagreb/Šibenik
Postovi: 832
Nisam gledao predstavljanje, samo sam pogledao key stvari.
Znaci tih 26% ili koliko vec vise FPSa u CS:GOu (DX9) na FullHD rezi je nesto sta bi me trebalo natjerat da kupim CPU koji vise nije puno jeftiniji od nekog Intelovog?
Bila je toliko lijepa da sam poželio da nikad ne otvori usta. A onda mi je nekako objasnila da je nijema. Oženio sam ju Las Vegasu, tjedan dana kasnije. I sad napokon živim sa ženom koju razumijem.
Moj PC - https://www.twitch.tv/flegmoar
Flegma je offline   Reply With Quote
