Staro 22.09.2020., 23:42   #1
Ivan14
Datum registracije: Jul 2020
Postovi: 20
problemi s fps
dakle kupio sam ryzen 3 3200g i imam problem dakle na 1080p low u csgo dobiam 6o fps dok drugi 100+ ram je 2x8 3200 a grafička je vega 8
Ivan14 je offline   Reply With Quote
Staro 23.09.2020., 00:14   #2
d0X
Kostolomac
d0X's Avatar
Postovi: 1,533
Da ti nije uključen vsync u igri ili u drajverima?
PSN Steam
Staro 23.09.2020., 10:18   #3
Ivan14
Postovi: 20
Autor d0X Pregled postova
nije uključen
Staro 23.09.2020., 10:52   #4
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
lock na 60 FPS mirise na taj vsync da je ukljucen negdje pa provjeri da nije ili u driverima ili unutar same igre. Ako stvarno nije onda je negdje neki drugi razlog, mozda reinstal drivere...
Staro 23.09.2020., 11:38   #5
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,459
Probaj upisati u consolu
fps_max 0
- This command would remove the FPS cap, meaning your frames-per-second would go as high as possible.
https://totalcsgo.com/command/fpsmax
google je prekrcan s tim problemom, neka od rješenja:
Windows C:/D: > Program Files > Steam > steamapps > common > Counter-Strike Global Offensive.
In this directory right click on csgo icon, go to properties, open compability tab, and then make sure "Disable fullscreen optimizations" is ticked. This one fixed the issue for me.
Changing the settings to run the game in fullscreen windowed mode worked for me. I got from 60 to 400 FPS
If windows 10, ensure XBox game dvr is disabled (it caps you at 60 fps)
Disable v-sync, check your graphics card driver menu to make sure you don't have any setting enabled that could force v-sync even if it's disabled in game.
found a CS:GO profile under afterburner configured for 60fps cap.
Jesus christ I certainly didn't make it who did
Old.machine je online   Reply With Quote
Staro 23.09.2020., 12:13   #6
Ivan14
Postovi: 20
Autor dada-as Pregled postova
Nije baš zaključano fps je od 60-70 nekad i 80...zo ovo da ponovno reinstalaliram drivere jedan jedan na youtubu. Je imao isti fps kao i ja onda je testirao na svježem Windowsu 10 i driverima instaliranim i dobio je 100+fps
Staro 23.09.2020., 12:14   #7
Ivan14
Postovi: 20
Autor Old.machine Pregled postova
fps_max 0
Probati ću i to za svaki slučaj
Staro 23.09.2020., 12:39   #8
Old.machine
Lokacija: ______
Postovi: 1,459
Autor Ivan14 Pregled postova
Onda si krivo objasnio problem, nije ti 60fps lock. Da li ti je memorija namještena na 3200mhz? To možeš provjeriti tako da skineš CPU-Z program, pogledaš u njemu pod tabon memory i pročitaš vrijednost pod DRAM frequency.
Staro 23.09.2020., 12:47   #9
Ivan14
Postovi: 20
je u biosima tako pokazuje 3200 u cpu z pokazuje 1596.8
Zadnje izmijenjeno od: Ivan14. 23.09.2020. u 13:15.
Staro 23.09.2020., 15:50   #10
Old.machine
Lokacija: ______
Postovi: 1,459
To je u redu.
Rami su ti u dual channelu? Pratio si u manualu u koje slotove pločice idu?
Upaljen ti je multicore rendering u postavkama igre?
Staro 24.09.2020., 12:34   #11
Ivan14
Postovi: 20
To je u redu.
moja matična ima samo dva slota za ram i ram je u dual channelu nije upaljen multicore rendering
Zadnje izmijenjeno od: Ivan14. 24.09.2020. u 12:43.
Staro 24.09.2020., 12:59   #12
Old.machine
Lokacija: ______
Postovi: 1,459
Uključi ga i testiraj ponovno, trebao bi s tom opcijom imati veći fps
Staro 03.10.2020., 18:11   #13
Ivan14
Postovi: 20
Dakle odlučio sam reinstalirati windows i drivere jer sam primjetio da ni druge igrice nisu na levelu performansa na kojem bi trebale biti...ne znam dali će pomoći..vidjeo sam da jedan lik na youtubeu imao isti fps pa je probao na tek instaliranom windowsu10 i driverima i bolje je radilo
EDIT:nisamo još probao reinstalirati drivere pa ću to
Zadnje izmijenjeno od: Ivan14. 03.10.2020. u 19:23.
Staro 04.10.2020., 12:45   #14
Ivan14
Postovi: 20
Evo ljudi csgo radi normalno dobijam 130-140fps na otvorenom u zatvorenom prostoru dobijam i do 180fps!Hvala svima na pomoći
Staro 06.10.2020., 16:59   #15
Postovi: 17,089
A što si napravio? Reinstal drivera?
