Staro 29.04.2020., 20:27   #421
Postovi: 8,346
Autor microsoft66 Pregled postova
Nije mi do novaca jer mi disk treba,zato i gledam preporuke i one kvalitetnije.bas mi se da zezat sa ovim
Još na prijašnoj stranici teme sam napisal da se 4TB WD Red može naći u Protisu za kakvih 950 kn, a bome tolko sam i svoj zadnji 4TB platil u prvom mjesecu ove godine.
Također, spomenul sam ti i IronWolf modele kao alternativu. Di si na kraju našel ove sfušane crvene za 1.100 kn?
Staro 29.04.2020., 20:32   #422
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,264
Staro 29.04.2020., 20:33   #423
Postovi: 8,346
Je, to je taj.
Staro 29.04.2020., 20:34   #424
microsoft66
Lokacija: VK
Postovi: 1,264
hvala svima LP
Staro 04.05.2020., 17:37   #425
microsoft66
Lokacija: VK
Postovi: 1,264
znaci stigao ironwolf...sve radi savrseno zasad.tih,pc boota u win za 15 sekundi,nasao ga u disk menagmentu i vec ga se puni naveliko
jednostavno WD mi nije sudjen nakon sto su mi 3 krepala dosad (ukljucujuci i 2 blacka) a sa segate nikad problema.pa nek tako i ostane.
Staro 30.05.2020., 19:55   #426
Postovi: 8,346
Western Digital gets sued for sneaking SMR disks into its NAS channel
All three of the surviving conventional hard drive vendors—Toshiba, Western Digital, and Seagate—have gotten caught sneaking disks featuring Shingled Magnetic Recording technology into unexpected places recently. But Western Digital has been the most brazen of the three, and it's been singled out for a class action lawsuit in response. Although all three major manufacturers quietly added SMR disks to their desktop hard drive line-up, Western Digital is the only one so far to slip them into its NAS (Network Attached Storage) stack. NAS drives are expected to perform well in RAID and other multiple disk arrays, whether ZFS pools or consumer devices like Synology or Netgear NAS appliances.
WD Red SMR vs CMR tested: Avoid Red SMR
The WD40EFAX performed so poorly that we repeated the test on a second disk to rule out user error; the second disk exhibited the same extremely slow resilver speeds. We also tested the SMR drives before and after the CMR drives to ensure that it was not a case of something happening due to the order of testing. The WD40EFAX is demonstrably a worse drive than the CMR based WD40EFRX, and assuming that you have a choice in your purchase the CMR drive is the superior product.
Staro 12.08.2020., 09:55   #427
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
Sad bih pobjegao od seagatea, WD je uvijek radio dobro kod mene, koji je ekvivalent? neki blue? purple? ne pratim diskove baš, možda i 5400 nebi bilo loše za storage
Zadnje izmijenjeno od: domy_os. 12.08.2020. u 19:09. Razlog: obrisan višak
Staro 12.08.2020., 11:07   #428
Postovi: 23,542
Koji format ?
Ako je 1 TB dovoljno (pa da ih i uzmeš više) onda 1 TB Blue jer je to ustvari Black sa drugom naljepnicom, 7200, EZEX,
... pisali smo o tome ...
Staro 12.08.2020., 11:09   #429
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
ma ne, minimalno 3 ko što je ovaj bio, a možda i više
ok budem prelistao
Staro 12.08.2020., 11:12   #430
Postovi: 23,542
Onda ništa, ti veći su 5400, druga priča.
Staro 12.08.2020., 11:14   #431
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
za bekap je ok pretpostavljam, vjerojatno i tiši
Staro 12.08.2020., 11:27   #432
Nick7
Lokacija: Velika Gorica
Postovi: 1,525
Paa.. ovak', ja koristim 3x 3TB WD Green u svom NAS-u 24/7. Jedina izmjena je da je promijenjen (sa wdidle) parking time glave sa 8sec na 5min.
Trenutno su sva 3 diska u super stanju, nema gresaka, a broj radnih sati im je: 46068, 49060, 45018 (tj. sva 3 diska rade non-stop preko 5 godina).
Staro 12.08.2020., 12:13   #433
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
fala na info
informativno sad gledam
https://www.uzishop.hr/35-hdd/12464-...037840161.html
https://www.uzishop.hr/35-hdd/53534-...-wd40purz.html
cijenom tu negdje, koja je bitna razlika blue vs purple?
Zadnje izmijenjeno od: mamutarka. 12.08.2020. u 12:25.
Staro 12.08.2020., 12:33   #434
Postovi: 23,542
Staro 12.08.2020., 12:40   #435
bilicvitak
bilicvitak's Avatar
Datum registracije: Nov 2014
Lokacija: ¯\_(ツ)_/¯
Postovi: 539
Purple su tiši i hladniji diskovi, jedino su red još bolji po tom pitanju od njih.
Kupujem
bilicvitak je offline   Reply With Quote
Staro 12.08.2020., 12:43   #436
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
fala momci fala, proučim, pa s vremenom ovaj seagate zamjenim čisto da nebi bilo zajebancije poslije
Staro 12.08.2020., 12:45   #437
Postovi: 23,542
Da ali po komentarima (sad gledao / čitao), nije najsretnije rješenje koristiti Purple u desktopu za data / skladište, radije se "isprsit" za Red (Red Pro).
Čak mislim da Purple ima ugašen sleep zbog dizajnirane namjene.
Staro 12.08.2020., 12:47   #438
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
ali ovo moje je ''backup'' skladišta, znači nije main skladište, tak da kak me sad briga za ovaj seagate koji krepava, tak će me i za taj idući, jel
ako su cijenom tu negdje uzmem u obzir svakako
EDIT: evo na šta ja naletim i opet me zagolica seagate https://www.adm.hr/product.asp?produ...98%2E400%2E167
6tb po ok cijeni, a vjerojatno je bad sector čim ga umetneš u komp
Zadnje izmijenjeno od: domy_os. 12.08.2020. u 19:10. Razlog: spojeni postovi
Staro 12.08.2020., 13:08   #439
Postovi: 23,542
A zašto nebi uzeo dva 3 TB plavca za sitno više nofčića ?
Uzmi u obzir i račun vjerojatnosti na 2 odvojena diska
Staro 12.08.2020., 13:10   #440
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
ma i ovak mi vibriraju i krčkaju, čuju se da ga jebeš, želim što više mjesta sa što manje diskova, ako me bereš
Staro 12.08.2020., 13:13   #441
Postovi: 23,542
Pa složi pristojno kućište i laštik od gača pa neće krčkat i svirat cijela soba
Staro 12.08.2020., 13:15   #442
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
uzi je slago, nesam školovala, ne otvaram ništa, nedamise
Staro 22.08.2020., 11:54   #443
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
pomoć
što od ova dva je pametnije uzet, storage/backup disk, aktivnost slaba
https://www.links.hr/hr/tvrdi-disk-4...ktop-051500098
ili https://www.links.hr/hr/tvrdi-disk-4...-3-5-051500193
red je nešto skuplji, jel bitno bolji?
vučem ka plavom
Staro 22.08.2020., 12:21   #444
Postovi: 23,542
Hm, cijena je slična,
Blue - 2 god. gare, treba naći jeli konkretni model stari dobri CMR ili je novi šroteks SMR,
Red - 3 god. gare, piše da je WD40EFAX model, novi SMR
info > https://www.servethehome.com/wd-red-...avoid-red-smr/
Na žalost SMR su potiho uvalili u sve modele veće od 1 TB.
Staro 22.08.2020., 12:33   #445
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
blue mogu dobiti u dućanu za 750kn, što se čini ok cijena za 4TB, 5400rpm bi trebalo dat malo duži vijek trajanja, vjerojatno ću uzet blue baš da testiram pošto se radi o backupu, nije mi nešto bitan
Staro 22.08.2020., 12:33   #446
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,455
Ako ti je za storage i kažeš da ti nije toliko bitan zar ti nije onda bolje uzeti neki najjeftiniji ili baš mora biti u linksa?
Old.machine je offline   Reply With Quote
Staro 22.08.2020., 12:37   #447
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,408
ovdje sam mislio https://www.protis.hr/products/detai...d40ezrz/104513 , links je poslužio samo za linkanje ovdje jer ima oba
Staro 15.01.2021., 15:29   #448
Moshus
Moshus's Avatar
Datum registracije: Nov 2010
Postovi: 174
imam sličnu situaciju kao i mamutarka... tražim neki HDD od 4TB za storage s tim da se ne radi o backupu nego baš storage u PC-u. znači od tamo bi vrtio filmove, muziku, stavljao fileove koje koristim u poslu itd. znači HDD bi bio u pogonu, ne kao backup.
što bi bio best buy? jel bi ovaj iz prethodnog posta bio ok za tu namjenu?
Moshus je offline   Reply With Quote
Staro 01.09.2021., 07:01   #449
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,608
Ovaj Red je way-to-go ovih dana?
kopija je online   Reply With Quote
Staro 01.09.2021., 09:22   #450
Razer
Razer's Avatar
Postovi: 11,642
