Staro 23.07.2020., 11:29   #2731
Nybelung
Možda nije do hardvera? Imam isti proc, jednako rama, i radi mi sve perfektno.
Staro 23.07.2020., 12:08   #2732
nino
nino's Avatar
Postovi: 12,613
1 x Intel Core i9-9900K
1 x ASRock Z390 PRO4
1 x Zalman CNPS11X Performa+
1 x Corsair Vengeance LED 32GB (4x8GB) DDR4 3000 MHz
1 x Gainward GF GTX1050Ti, 4GB GDDR5
1 x SSD ADATA 512GB SX8200 Pro PCIe M.2 2280
1 x WD Blue 1TB SATA
1 x Lian Li PC-O11 Dynamic Midi kućište Crno
1 x Riotoro ENIGMA G2 PSU, 650W, 80 GOLD
Ukupno: 10 781,40 kn
Staro 23.07.2020., 12:08   #2733
NePitajPuno
Datum registracije: Sep 2018
Postovi: 8
Autor Nybelung Pregled postova
mislim moguće, ali nemam ja problema dok mi nije masa tabova upaljena
https://imgur.com/a/as6fNLC
evo refresh 1-2 taba i cpu odmah leti na 90+, memorija je cijelo vrijeme tamo dok se ne počnu rušit tabovi
@nino gdje si slagao ovo?
NePitajPuno je offline   Reply With Quote
Staro 23.07.2020., 12:14   #2734
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,629
NePitajPuno
1 * INTEL Core i7-10700 2.9GHZ LGA1200 16M Cache Boxed BX8070110700 S RH6Y
Šifra: INT-0718 - 3.222,00 Kn
1 * Enermax ETS-T50A-FSS AXE hladnjak za procesore, S.775-2066/FMx-AM2-AM4, PMW 140mm ventilator, Twister Bearing Technology
Šifra: 43901 - 421,00 Kn
1 * ASRock Main Board Desktop Z490 PHANTOM GAMING 4
Šifra: ASR-0029 - 1.386,00 Kn
1 * Crucial Ballistix 2x16GB (32GB Kit) DDR4 3200MT/s CL16 Unbuffered DIMM 288pin Black EAN: 649528824141
Šifra: BL2K16G32C16U4B - 1.528,00 Kn
1 * XFX Radeon RX 570 8GB, XXX Ed 1286M D5 3xDP HDMI
Šifra: RX-570P8DFD6 - 1.421,11 Kn
1 * SSD 512GB Adata SX6000PNP PCIe M.2 2280
Šifra: 0141091 - 721,00 Kn
1 * WESTERN DIGITAL WD10EZEX 1TB Blue
Šifra: WD10EZEX - 400,00 Kn
1 * Riotoro ENIGMA G2 PSU, 650W, 80 GOLD
Šifra: RIO-PR-GP0650-FMG2EU - 921,11 Kn
1 * Kućište BIT FORCE Mid Tower Tiho Gaming PC SHADOW SE-2
Šifra: 2911102 - 443,33 Kn
2 * BIT FORCE PC ventilator CHILL 120 crni
Šifra: 3010101 - 55,56 Kn
Sveukupno na rate: 10.519,11 Kn (-2%=10.308kn)
Sveukupno s popustom za keš: 9.467,20 Kn (-2%=9.277kn)
Besplatno slaganje i dostava
ibme74 je online   Reply With Quote
Staro 23.07.2020., 12:36   #2735
Postovi: 34,057
Ja bi prvo pokušao sa ubacivanjem još rama. Isto tako mi je vrlo čudno da je proc zakucan na 95% samo zbog browsera.
Baš sam bacio oko kod sebe. FF sa 6 tabova i još nekoliko programa u pozadini, troše cpu sa mizernih 1-2% s time da radim na office konfi koja je starija (i5 3330, 16Gb DDR3). Pritom guta oko 30% rama.
Staro 23.07.2020., 12:54   #2736
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,492
Moguće ako ima otvorene stranice koje imaju animacije ili reklame, ili nešto drljaju u pozadini. Nije nigdje naveo da li taj komp ima SSD disk uopće
Staro 23.07.2020., 13:04   #2737
NePitajPuno
Postovi: 8
Autor Alister Pregled postova
ima ssd da
Autor coconut Pregled postova
to je bio prvi plan ali sam onda vidio da je i procesor često na max opterećenju pa sam zaključio da možda red da ubrzam i uzmem neš ranije od planiranog sve novo
stranice su većinom razne burze i sl gdje se cijelo vrijeme osvježavaju cijene i sl tak da se definitivno dešava nešto u pozadini konstatno, pretsptoavljam da je to razlog opterećenja
Staro 23.07.2020., 14:34   #2738
Postovi: 34,057
Ja bi ipak išao u smjeru nabavke još 8Gb rama i pokušaja reinstalacije winsa.
Ili, stavi neki live Linux i probaj otvoriti isti broj tabova u njemu. Ako ne zakuca proc na tih 90+%, onda je do winsa, a nikako do hardvera.
Staro 23.07.2020., 14:53   #2739
NePitajPuno
Postovi: 8
a probat ću onda zasada tako pa ću vidjet šta će biti, nova kanta ide sigurno u bližoj budućnosti a linux tesko da ide gore ali za nove windowse bi bilo vrijeme
Staro 23.07.2020., 14:53   #2740
RimtuTiTuki
RimtuTiTuki's Avatar
Postovi: 1,661
Linux za test pokreni sa USB stick-a
Reinstaliraš windowse, ispušeš kompresorom od prašine i eventualno zamijeniš pastu na procesoru. Ili odnesi u jedan od servisa da ti to naprave.
Taj komp bi trebao letiti za to što tebi treba, stvarno nema smisla kupova ništa novo ako je komp samo za surfanje i office.
Ja i dalje imam i7-920 sa 6GB memorije i GF 570 kao backup komp za puno ozbiljnije programe, i radi bez greške.
RimtuTiTuki je online   Reply With Quote
Staro 23.07.2020., 15:13   #2741
guerra
Datum registracije: May 2019
Postovi: 522
Autor ibme74 Pregled postova
NePitajPuno
Zasto to smece od ploce sa najgorom izvedbom vrm-a koji skoro throttlaju na stocku pored puno bolje, a u istom ducanu samo 14kn skuplje MSI Z490-A PRO?
edit: Sad tek vidim da si cijene za kartice stavljao. U tom slucaju je msi 170kn skuplja, ali na ovu cifru i ovakvu konfiguraciju svejedno nema mjesta za onu asrock plocu... Za tu razliku bolje da uzme nesto jeftinije kuciste.
Zadnje izmijenjeno od: guerra. 23.07.2020. u 15:38.
guerra je offline   Reply With Quote
Staro 23.07.2020., 15:43   #2742
Postovi: 34,057
@nepitajpuno
Ne čitaš s razumijevanjem - live Linux znači da se Linux pokreće direktno sa dvd/usb sticka i da se ne instalira na hard disk. Koristi se baš za takve stvari tj. da se vidi je li problem softverske ili hardverske prirode.
Znači, ako ti u Linuxu FF/Chrome sa otvorenih 20-30 tabova ne zakucaju procesor na 90%, definitivno imaš softverski problem (čitaj: winse treba reinstalirati) i nemaš potrebe za novom konfom (čitaj: uštedio si sebi +10k kn).
Staro 23.07.2020., 19:22   #2743
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
@Nepitajpuno
Neštu tu smrdi, nebi ti trebao browser toliko napuniti cpu i memoriju. Taj pc je čak i overkill za to što si naveo.
Možda si pokupio minermalware. Rađe si napravi clean install windowsa
EDIT
Ah nisam vidio drugu stranicu
Staro 24.07.2020., 11:04   #2744
NePitajPuno
Postovi: 8
@nepitajpuno
da nisam nikad to radio, budem proguglao kak ak reinstall ne pomogne
Staro 24.07.2020., 13:04   #2745
Postovi: 34,057
Napravi to prije reinstala winsa da budeš siguran da nije hardverski problem.
Staro 25.07.2020., 04:36   #2746
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor nino Pregled postova
ne kupuje se vise 9900k od kad je 10 vani. 10700k kosta oko 100 eura manje, iste specke ima.
Staro 11.08.2020., 23:30   #2747
ppm3
Datum registracije: Nov 2014
Postovi: 109
Pozdrav znalci,
Zadnji komp sam složio prema vašim preporukama pa nastavljam u tom duhu i dalje
Ta zadnja konfa je bila Intelova i radila je perfektno (5 godina ni brige ni pameti), a sada vidim da su AMDovi preuzeli primarnu ulogu što se tiče CPU-a :O
Trebam komp ISKLJUČIVO za gejming (kanta + monitor).
100% ga NEĆU OCat pa pliz uzmite i to u obzir.
Jedino što NE TREBAM su miš i tipkovnica, to ostavljam.
Budžet je max 12k kuna za keš.
Vidim da ovdje ekipa spominje 2% popusta za članove foruma i dodatnih 2% za kupovanje na keš, ali ne vidim uopće o kojem se dućanu radi niti mogu li to uopće iskoristiti (možda vrijedi samo za istaknute članove?!)? Pa eto, ako mogu dobiti samo ovaj popust za keš pliz uzmite i to u obzir.
Volio bih sve uzeti u ADM-u i da mi oni to slože, ali ako se nešto promijenilo od zadnjeg puta naravno da ću uzeti gdje god preporučite.
Neke posebne želje i pozdrave nemam, ali pod obavezno bih 1 TB SSD + neki best buy monitor (144hz) za oko 1500 - 2000 kn (minimum 24 inca, idealno 27*), kao i 32 GB RAM-a jer ne mislim kupovat ništa idućih 5 godina, a vjerujem da će mi trebati kasnije.
Hvala unaprijed..
ppm3 je offline   Reply With Quote
Staro 12.08.2020., 09:24   #2748
ibme74
ibme74's Avatar
Postovi: 1,629
1 * Monitor 27" AOC Q27G2U, VA, 144Hz, 1ms, 250cd/m2, 3000:1, pivot, crni
Šifra: 100.300.501 - 2.693,00 Kn
1 * Procesor AMD Ryzen 7 3700X
Šifra: 0400500 - 2.776,67 Kn
1 * Hladnjak LC-Power LC-CC-120, Intel/AMD + AM4
Šifra: lcp-hlad-lc-cc-120 - 200,00 Kn
1 * ASRock Main Board Desktop B450 GAMING K4
Šifra: ASR-0004 - 861,00 Kn
1 * Corsair 2X16GB DDR4 3000 C15
Šifra: COR-CMK32GX4M2B30C15 - 1.368,00 Kn
1 * Sapphire RX 5700XT Pulse, 8GB GDDR6
Šifra: sap-rx5700xt-pul-8 - 3.778,00 Kn
1 * SSD Western Digital Green™ 1TB WDS100T2G0A
Šifra: 0130860 - 893,00 Kn
1 * Napajanje Seasonic SS-650GB, 650W, 80+ Bronze
Šifra: 0151690 - 600,00 Kn
1 * Zalman S4 PLUS Mid Tower Case
Šifra: ZAL-S4 PLUS - 433,33 Kn
Sveukupno na rate: 13.603,00 Kn (-2%=13.330kn)
Sveukupno s popustom za keš: 12.242,70 Kn (-2%=11.997kn)
Staro 12.08.2020., 09:57   #2749
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
3700x mu ne treba za igre, tu je 3600 bb i onda utrpati rtx 2070 super. A i ram pogotovo nema potrebe 32GB. I bolje Bit Force Galaxy kućište jer ima bolje i tiše ventove od tog Zalmana.
1 * Procesor AMD Ryzen 5 3600, 6C/12T, 3.6GHz/4.2GHz, 32MB, AM4
Šifra: 0400496 - 1.644,44 Kn
1 * Hladnjak ID-Cooling SE-224-XT ARGB, 120mm, Intel/AMD
Šifra: SE-224-XTARGB - 354,44 Kn
1 * GIGABYTE Main Board Desktop B550 GAMING X
Šifra: B550_GAMING_X - 1.234,00 Kn
1 * Patriot Viper Steel, 3200Mhz, 16GB (2x8GB), CL16
Šifra: pat-vs416g320k-16g - 654,44 Kn
1 * Palit GF RTX2070 Super GamingPro, 8GB GDDR6
Šifra: pal-2070s-gp-8gb - 4.278,00 Kn
1 * SSD 1TB AD SX8200 PRO PCIe M.2 2280 NVMe
Šifra: 0141105 - 1.332,22 Kn
1 * Kućište BIT FORCE Mid Tower ARGB Gaming PC GALAXY ARGB-4
Šifra: 2911104 - 598,89 Kn
Sveukupno: 13.389,43 Kn
Sveukupno s popustom: 12050,49 Kn
-2 % za članove foruma, 11.810,00 Kn
Ako je baš potrebno 32GB RAM-a, uzme se slabija B450 ploča.
Zadnje izmijenjeno od: FRipper. 12.08.2020. u 10:16.
Staro 12.08.2020., 10:28   #2750
ibme74
ibme74's Avatar
Postovi: 1,629
rekao je da ne planira ništa kupovati u narednih 5 godina, vjerujem da će mu dodatne 2 jezgre i 4 threada dobro doći u tom periodu...
ali kako goduzeo, ako se želi igrati na 1440p 144hz ne gine mu u tih 5 godina promjeniti grafu, uzeo sada rtx2070s ili rx5700xt
Što se RAM-a tiče izrazio je želju za 32Gb, dali će mu u idućih 5 god trebat 32GB ili ne teško je reći.
Staro 12.08.2020., 10:28   #2751
nino
nino's Avatar
Postovi: 12,613
1 x GIGABYTE Main Board Desktop B550 GAMING X
1 x AMD Ryzen 5 3600
1 x G.Skill Ripjaws V (2x16) 32GB DDR4 3200MHz
1 x KFA2 GeForce RTX 2070 Super EX Gamer Black Edition
1 x KINGSTON 1000GB A2000 M.2 2280 NVMe
1 x GIGABYTE B700H Power Supply 700W
1 x Aerocool AERO-500G RGB White Midi
1 x AOC LCD 27" Q Wide , 1ms, 16:9, DP
Ukupno: 12.000 kn
Staro 12.08.2020., 11:01   #2752
ppm3
Postovi: 109
Svaka cast na brzini i savjetima!
Danas cu uzet malo vremena pa proucit sto je sve napisano, javim se se pitanjima jer vec vidim da imam dosta upitnika nad glavom
Edit: vec sam prakticki narucio jednu od gore predlozenih konfi i uletio mi je neplanirani trosak. A sada citam da vec 1.9. nvidia izbacuje 3xxx seriju pa pretpostavljam da je pametno pricekati jos mjesec dva sa nabavkom racunala, pogotovo jer je i intel poceo smanjivati cijene procesora, a i amd bi trebao izbaciti neke novine..Tako da hvala jos jednom i malo cu se strpit jer realno trenutna konfa i dalje vrti skoro sve, a moguce da za tih mjesec dva puno bolje prodem za istu lovu..
Zadnje izmijenjeno od: ppm3. 18.08.2020. u 10:06.
Staro 27.08.2020., 18:15   #2753
NePitajPuno
Postovi: 8
NePitajPuno
Ipak ću uzet nešto, ali ću uzet u protisu pa ak može mala prepravka jer nema svega ovog tamo. Znači trebao bi drugu grafu (ima slična ali neznam jel to ok?), kućište, napajanje i ventilator/e
Zamjenio sam za onu dolje preporuku matičnu isto pretpostavljam da je upgrade za sitno $$
Hvala
Staro 08.09.2020., 15:17   #2754
fooK
Powaaa user
fooK's Avatar
Lokacija: Hrvatska, Zagreb
Postovi: 160
Pozdrav svima,
Trebam savjet, kolega kupuje računalo za nekih cca 9.500-10.000 kn sa monitorom unutra i Windowsima, ostalo od periferije ne treba.
Glavna namjena računala je gaming, nekih preferencija nema, eventualno da za koju godinu može ustekati jaci proc ili grafičku ako će trebati.
Kupovati će u Zagrebu i platiti gotovinom, tako da to uračunate u cijenu.
Ako treba još informacija za složiti konfiguraciju pišite!
Hvala unaprijed na pomoći 👋🏻
Poslano sa mog SM-G986B koristeći Tapatalk
Fun starts @ 2000 rpm with 465nM
Pošteni trgovac: 1
fooK je offline   Reply With Quote
Staro 08.09.2020., 15:27   #2755
RimtuTiTuki
Postovi: 1,661
Ako kupuje za gaming, neka čeka da stignu nvidia rtx30xx grafičke u dućane... prije toga nema smisla....
komp će mu vrijediti 3-4 tisuće manje kad dođu ove grafičke kroz koji tjedan
Staro 08.09.2020., 16:51   #2756
Postovi: 34,057
Windowse mu nema potrebe kupovati kod nas kad ih na ebayu dobije za kikiriki. Isto važi za Office i brdo drugog softvera.
Staro 08.09.2020., 19:49   #2757
Manuel Calavera
Postovi: 14,589
Defintivno čekaj mjesec - dva, nove gpu i zen3
Staro 09.09.2020., 00:06   #2758
fooK
Powaaa user
fooK's Avatar
Postovi: 160
Tnx na odgovorima!
Ima smisla onda slagati ostatak konfiguracije uopće ili jednostavno sačekati ovo sve?
Pošteni trgovac: 1
Staro 09.09.2020., 00:30   #2759
Nybelung
Ne kupuj ništa, strpi se još tjedan dana.
Staro 15.09.2020., 21:45   #2760
Anghx
Datum registracije: Feb 2011
Postovi: 72
Evo prošlo tjedan dana, što se promijenilo?
Ako je ovo vezano za nove Ryzen-e, vidim da bi trebali ići 8.10. u prodaju (možda).
Anghx je offline   Reply With Quote
