Staro 06.06.2020., 13:37   #1
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,568
Nvidia GeForce RTX 30X0 series (Ampere)
Tema za nadolazecu 30X0 seriju i sve vezano za nju
NVIDIA GeForce RTX 3080 Pictured?
Staro 09.06.2020., 21:24   #2
Postovi: 8,375
nVidia's Next-Gen reference cooler Costs $150 by itself, to feature in three SKUs
Pictures of alleged next-generation GeForce "Ampere" graphics cards emerged over the weekend, which many of our readers found hard to believe. It features a dual-fan cooling solution, in which one of the two fans is on the reverse side of the card, blowing air outward from the cooling solution, while the PCB extends two-thirds the length of the card. Since then, there have been several fan-made 3D renders of the card. nVidia is not happy with the leak, and started an investigation into two of its contractors responsible for manufacturing Founders Edition (reference design) GeForce graphics cards, Foxconn and BYD (Build Your Dreams), according to a report by Igor's Lab.
According to the report, the cooling solution, which looks a lot more overengineered than the company's RTX 20-series Founders Edition cooler, costs a hefty USD $150, or roughly the price of a 280 mm AIO CLC. The cooler consists of several interconnected heatsink elements with the PCB in the middle. Igor's Lab reports that the card is estimated to be 21.9 cm in length. Given its cost, nVidia is reserving this cooler for only the top three SKUs in the lineup, the TITAN RTX successor, the RTX 2080 Ti successor, and the RTX 2080/SUPER successor. All three will use the same cooling solution, and a common PCB design codenamed PG132. Further, all three cards will be based on a common ASIC, codenamed "GA102," with varying hardware specs. When launched, "Ampere" could be the first implementation of the new GDDR6X memory standard, which could come with data-rates above even the 16 Gbps of today's GDDR6, likely in the 18-20 Gbps range, if not more. Lesser SKUs could use current-gen GDDR6 memory at data-rates of up to 16 Gbps.
  • The "SKU10" could ditch the TITAN brand to carry the model name "GeForce RTX 3090," max out the 384-bit wide memory bus of the GA102 ASIC, and feature a whopping 24 GB of GDDR6X memory, with 350 W typical board power.
  • The next SKU, the SK20 will likely feature the RTX 3080 Ti brandingr, will be cut down from SKU10. It will feature 11 GB of GDDR6X memory across a 352-bit wide memory interface, and have a 320 W typical board power rating.
  • Lastly, there's the SKU30, which is further cut-down, features 10 GB of GDDR6X memory across a 320-bit wide memory interface, and it bears the RTX 3080 model number, succeeding the RTX 2080 / RTX 2080 Super.
Izvor: TechPowerUp
Staro 09.06.2020., 23:48   #3
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,568
150 bucksa ne kosta taman da su mu pozlaceni finovi. Klasicni maocetung koznati marketing. Pa 25$ ne kosta vodeno u izradi a ne ova skalamerija. Ali kao sto je netko napisao u komentarima, joj belaja proizvodacima vodenih blokova za ovaj PCB Koja je uopce poanta zasebnog PCB za power delivery ?
Staro 10.06.2020., 03:10   #4
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,493
Referentno gofno
Staro 10.06.2020., 07:37   #5
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
U početku mi je djelovalo fake, no glasina se uhvatila kao činjenica + još nova glasina iz igors lab...
Staro 10.06.2020., 08:45   #6
DuHc
DuHc's Avatar
Lokacija: Dubrovnik
Postovi: 204
GTX1650 MSRP $150
RTX3080 MSRP $150 (Cooler only. Graphics card not included)
DuHc je offline   Reply With Quote
Staro 10.06.2020., 08:58   #7
Postovi: 16,968
Šta neće treća serija biti jeftinija od druge?
Kao što rekoh onda i kažem sada "In your dreams".
Staro 10.06.2020., 10:36   #8
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
Autor xulos Pregled postova
https://www.techpowerup.com/268278/n...-in-three-skus
Nvida Ampere rađena je na 7nm litografiji od TSMC -a u istoj tvornici koja radi Ryzene 3000 i nove Ryzene 4000 serije.
Ako ce Ampere biti na istom proizvodnom procesu kao i Ryzeni 3000;
mislim da postoji šansa da ce imati isti "problem" sa zagrijavanjem kao i Ryzeni 3000.
This large difference in heat-density is the reason why newer Ryzen 3000 processors become much warmer at similar heatloads than their predecessors.
https://noctua.at/en/why-is-my-ryzen...with-my-cooler
We’re getting to the point where performance gains on new nodes are actually slowing down because the transistors are getting packed closer and closer together while consuming the same amount of power and thus producing the same amount of heat. Less surface area is going to mean less area to spread heat from, and consequentially that hurts thermal performance.
https://adoredtv.com/ryzen-3000-ther...-best-and-why/
više o tome smo pisali tu
http://forum.pcekspert.com/showpost....postcount=2658
Pretpostavljam da zbog 7nm litografije bit ce teže odvest toplinu sa cipa kao i na Ryzenima 3000 te ima smisla toplinski odvojit sam cip od naponskog djela grafe i tako omoguciti niže radne temperature samog cipa.
Ako se ne varam VRM ovi mogu raditi max do nekih 100 - 110 stupnjeva.
Autor scarzz Pregled postova
Kako onda misle hladit efikasno 5nm,3nm,2nm?
Autor Gigi1 Pregled postova
TEC hladnjenje kod stackinga...stavljao sam linkove i slike međuostalim i na TEC patente od AMD-a (upravo zbog ove problematike disipacije topline sa prelaskom na manje proiz.procese) u temi nadolazeci procesori, međutim nije nikad bilo pinnano.
S obzirom da je interes bio skoro pa nikakav odustao sam od daljneg postanja patenata, a dobar dio ce ih se na ovaj ili onaj nacin implementirati u buduće proizvode kako bi riješili neke od postojecih limitacija.
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 10.06.2020. u 17:28.
Staro 10.06.2020., 10:44   #9
guerra
Datum registracije: May 2019
Postovi: 522
Iskreno se nadam da ce AMD stisnuti u segmentu kartica kao sto je to napravio sa procesorima tako da mozemo jeftinije kupiti Nvidiju
guerra je offline   Reply With Quote
Staro 10.06.2020., 10:59   #10
Postovi: 8,375
Moglo bi i tak ispasti, jer nVidia ovaj put odmah ide s najjačim čipovima, da što više ublaži potencijalni udarac.
Staro 10.06.2020., 11:21   #11
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
Konacno ce ovi rudari koji se nisu rjesili onih 1000W plus bjesnih napajanja moci prodat to, samo tko ce kupit polovno napajanje kad ce za GPU skipat tolike pare.
Staro 10.06.2020., 15:42   #12
rokonja
rokonja's Avatar
Lokacija: tamo tamo daleko
Postovi: 163
Autor dada-as Pregled postova
A neće valjda i AMD ić u tom visko buđetnom smjeru.
rokonja je offline   Reply With Quote
Staro 10.06.2020., 15:59   #13
Manuel Calavera
Postovi: 14,584
Pa i ovu 2000 generaciju su odmah izbacili najjače, dok AMD nije bio nigdje sa high endom...
Radeon VII i 5700XT još nisu skinuli ni 1080Ti koja ima 4 god.
Tako da sam skeptičan da će AMD moći u utrku sa najjačom nvidijom, no ako ništa konzole su me barem uvjerile da mogu prebaciti 2080Ti. Prije toga sam mislio (ekstrapolacijom RDNA 1) da im je plafon skinuti 2080S sa gpu do 300w
Staro 10.06.2020., 16:15   #14
Postovi: 8,375
Ma je, ali mogli su komotno dodatno razvodniti taj GA102 čip i opet bi kartice bile jake. Ovak odmah u startu ide najjača konfiguracija čipa s tri modela bazirana oko istog, pa kud puklo da puklo, ako AMD slučajno ima kakvu konkurenciju.
Staro 10.06.2020., 16:23   #15
Manuel Calavera
Postovi: 14,584
Bome izgleda da su ovi cooleri legit, curi sa svih strana
https://wccftech.com/nvidia-geforce-...ink-leaks-out/
Na kraju možda nvidia izbaci prije AMD-a next gen, pa da nemaju najjaču gpu niti koji tjedan, kao u vrijeme R9 290X
Staro 10.06.2020., 16:27   #16
Mladenxy
Mladenxy's Avatar
Postovi: 4,383
Odrat će nas ko seljak poticaje. PS5 zadnja nada za gamera sirtotanovića.
Staro 10.06.2020., 16:42   #17
Postovi: 16,968
Očekujem cijene:
3060 - nešto ala 2070 po performansama - cijena oko 4000kn i više
3070 - nešto kao 2080S - cijena 5500kn i više
3080 - nešto kao 2080Ti - cijena 8000kn
3080Ti - najjača i cijena s preko 10 000kn
Staro 10.06.2020., 17:17   #18
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,568
3060 nema sanse da bude 4000 kn , mislim da si ipak malo pretjerao. Ne branim koznatog ali 3060 nece biti 400$ nikako.
Staro 10.06.2020., 17:18   #19
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,307
Ne vjerujem da ce uspjet održat takve cijene.
Možda kratko u startu
Chuby je offline   Reply With Quote
Staro 10.06.2020., 17:28   #20
Manuel Calavera
Postovi: 14,584
3070 će 99% sigurno biti jača od 2080Ti, a imat će (nagađam) MSRP kao 2070 Super, možda malo više
Maximalnu snagu flagship modela je teško reći, no priča se minimalno 50% više od 2080Ti. Cijena - nebo je granica, no ne vjerujem da će se usuditi puno više od MSRP 2080Ti (za 3080Ti, potencijalnu 3090 gledam kao titanku)
Staro 10.06.2020., 17:38   #21
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
10k za 3080ti ce biti sigurno, jer po toj lovi su dosdad isle prilicno dobro u startu.
A mene zanima kako ce onda 2080 reagirat a jos bolje sto ce se desiti sa 1080. Uglavnom polovna racunala bi mogla postat jaca i vec je vrijeme da nestanu one smijesne graficke s 1GB rama.
Cak si sad mislim da ce mozda cijene biti i vece od ovih sto je Mommistake napisao. Bas me zanima...
Staro 10.06.2020., 17:50   #22
Chuby
Chuby's Avatar
Postovi: 1,307
Pitanje je koliko je COVID-19 napravio financijskog cirkusa worldwide i hoce li se to odraziti na prodaju skupih grafickih kartica. Tj jesu li ljudi spremni dati toliko love
Staro 10.06.2020., 17:50   #23
Blue Spirit
Postovi: 2,195
Chuby , to si dobro rekao... navodno je amazon imao neku akciju 30% i da su americani koji su dobili kao korona poticaje sta vec jer su ostali bez posla kupovali hardver ko blesavi
...vec je vrijeme da nestanu one smijesne graficke s 1GB rama.
AMD Hints at More Than 4 GB Graphics Memory As Standard on Next-Gen Radeon RX Graphics Card
In a recent blog post, AMD might have hinted at the end of the 4 GB entry-level graphics cards era as we get closer to the launch of the first RDNA 2 powered Radeon RX graphics cards.
The blog post that is cleverly titled 'Game Beyond 4GB' compares AMD's most entry-level Navi based Radeon RX graphics card, the 5500 XT,
in both 4 GB and 8 GB flavors and shows how the increased VRAM size not only delivers better performance but has become crucial from a support point of view in next-generation AAA titles.
https://wccftech.com/amd-radeon-rx-r...b-memory-hint/
Staro 10.06.2020., 17:50   #24
Manuel Calavera
Postovi: 14,584
Ma nema od tog ništa. Neće ljudi krenuti za đabe prodavati RTX 2080 zato što će nove biti isplativije. Prerano je to za prodaju, te ih ionako nema puno ljudi
Staro 10.06.2020., 17:59   #25
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
Da, slazem se s tobom, jer ce ove nove biti skupe i nedostupne svima. Tako je bilo sa 1080 tako je bilo sa 2080, no moguce je da bi 3060 mogla biti ispod 4k, mozda tu ostave za mase. Barem je dosad ta verzija bila prilicno dostupna.
Da, znam da je 4GB ili ajde ako se i uzme ona famozna 1060 3gb OK, ali covjece u nas se prodaju one ja ihn zovem spamerske graficke po 200, 300 kuna, a neznam sto ljudi rade s njima. Odes na njuskalo i odes pod graficke kartice i tamo ima 90% trasa koji nevrijedi ni jednu kunu. E pa sam si pomislio da kad ce konacno istisnut taj tresh sa oglasa pa da onda imamo GPU na trzincama koji barem nekako mogu pokrenut novije igre.
Staro 10.06.2020., 18:12   #26
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Očekujem cijene:
Ako ce nabit takve cijene, siguran sam da ce AMD imat popunjen donji segment sa grafama koje su bolje od 5700/5700XT. Mislim da bi si s takvim cijenama nVidia "pucala u nogu".
Ako budu malo razumniji od tebe, 3060 serija bi trebala biti u rangu cca 2000-2500kn.
JC Denton je online   Reply With Quote
Staro 10.06.2020., 18:39   #27
rokonja
rokonja's Avatar
Postovi: 163
To bi bile super cijene kad nebi tebao ništa drugo osim ove grafe. Mislim da je moj sljedeći hradver ps5. Pa za 3080ti izađe ps5 i hebački TV, to bi bilo za gaminđž sasvim ok.
edit: ma još i ostane za ekipu cuge i čevapi
Staro 10.06.2020., 18:55   #28
Postovi: 8,375
IMHO ovaj put im AMD sprema malo konkretniju konkurenciju, pa bi vrlo lako sve osim Titan/3090 modela moglo biti odmah zahvaćeno (boljom) cijenom, performansama i potrošnjom Radeon modela.
Staro 10.06.2020., 19:36   #29
Manuel Calavera
Postovi: 14,584
Autor JC Denton Pregled postova
Tom iz Moore Law is Dead (trenutno najjači nvidia leaker) tvrdi da bi 3060 mogla biti barem 15% od 2080Ti, te koštati 350$. Cijene naravno nisu leak, formiraju se pred kraj, nego neki gestimate
Inače 15% slabija 3060 od 2080Ti se uklapa sa 3070 koja je jača ili egal 2080Ti. Nekome ovo možda zvuči preoptimistično, no uzmite u obzir da pričamo o full node shrinku + novoj arhitekturi. To smo zadnji puta imali sa pascalom, sjetite se koliko je koštala 980Ti (6000kn pred kraj?), a onda je došla gtx 1070 za 3700kn...
Možda nvidia neće biti toliko darežljiva ovaj put, no ne smiju ni pretjerivati, prodaja Turinga nije bila bajna, imaju loš imidž zbog cijena + konkurencija bi trebala biti ozbiljnija
Nisam siguran da će uhvatit 3080ti, no mogli bi možda 3080. No nema šansona da će radeonke biti efikasnije, niti bitno jeftinije. Jbga u gpu segmentu jednostavno nisu "disruptive" nego samo prate Nvidiju
Staro 10.06.2020., 19:56   #30
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,302
Ovi double sided cooleri ce zakomplicirat airflow i GPU stacking (jedino za sta su FE bile bolje), jedan vamo jedan tamo cooler, hmm , nadmaase da 3rd party modeli budu imali sve ventove sa iste strane .
Lewis je online   Reply With Quote
