18.01.2006., 22:14 | #1 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,483
Doom 3 i Quake 4 Brilliant highlights
DOOM 3/RoE This is a modified shader for Doom 3 and RoE that gives high quality dynamic highlights and enhances the 3D look of the surfaces. Any hardware capable of the ARB 2.0 path can run this mod. Regarding performance, it favours math power over memory bandwidth as this is the current trend. ------------- Features: ------------- :: Dynamic highlights :: Using the original specular mapping from the game, my shader adjusts the highlight falloff separately per pixel. :: Highlight masking :: Like in the built-in shader, the specular map is also used to mask the highlights from less shiny surfaces. ----------------- What's new: ----------------- - Redesigned lighting to process the specular highlights separately from the diffuse lighting. This allows the highlight to position differently from the diffuse which can lead to more realism. - Added a new splash screen. http://doom3.filefront.com/file/Bril...ghlights;55113 471.32 KB Quake 4 A modified shader for Quake 4 (and D3/RoE as a separate mod) that gives high quality dynamic highlights and enhaces the 3D look of surfaces. - Dynamic highlights. Using the original specular mapping from the game, my shader adjusts the highlight falloff separately per pixel. - Highlight masking. Like in the built-in shader, the specular map is also used to mask the highlights from less shiny surfaces. - Compatibility. Any hardware capable of the ARB 2.0 path can run this mod. - Performance. BH mod favours math power over memory bandwidth as this is the current trend. http://quake4.filefront.com/file/;55174 510.74 KB |
