Staro 07.06.2020., 11:43   #91
stifmeister
Datum registracije: Dec 2009
Lokacija: *
Postovi: 118
Može netko s T-com adsla pingat 1.1.1.1? To mi je bio najbrži dns, a sad kad ga pingam izbacuje 125ms dok su T-com i Google uredno oko 20ms. E sad znam da pinganje dns-a nije cjeloukupni pokazatelj brzine, ali nešto ipak znači ne?
Zadnje izmijenjeno od: stifmeister. 07.06.2020. u 11:49.
stifmeister je offline   Reply With Quote
Staro 08.06.2020., 07:55   #92
Postovi: 16,780
PING 1.1.1.1 (1.1.1.1): 56 data bytes
64 bytes from 1.1.1.1: icmp_seq=0 ttl=57 time=14.179 ms
64 bytes from 1.1.1.1: icmp_seq=1 ttl=57 time=16.858 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=57 time=23.183 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=57 time=14.262 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=57 time=17.903 ms
64 bytes from 1.1.1.1: icmp_seq=5 ttl=57 time=14.120 ms
Staro 08.06.2020., 10:34   #93
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,727
Autor stifmeister Pregled postova
Naravno da znači, svaki korak do stranice će ti trajati više od 125 ms.
meni je ping do 1.1.1.1 stabilnih 8 ms.
Staro 08.06.2020., 18:52   #94
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,223
Ping s iskona:
Pinging 1.1.1.1 with 32 bytes of data:
Reply from 1.1.1.1: bytes=32 time=7ms TTL=58
Staro 08.06.2020., 19:53   #95
Blagus
Datum registracije: Jun 2012
Postovi: 508
Stvarno nekaj ne valja... HT, Zagreb:
Code:
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=50 time=115 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=50 time=115 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=50 time=115 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=50 time=115 ms
64 bytes from 1.1.1.1: icmp_seq=5 ttl=50 time=115 ms
64 bytes from 1.1.1.1: icmp_seq=6 ttl=50 time=116 ms
 64 bytes from 1.1.1.1: icmp_seq=7 ttl=50 time=115 ms
Bilo je 10-ak. Opet se HT igra i pravi pametan s ne-peeranjem u CIX-u i Altusu, vjerojatno...
Edit: traceroute. Ping skoči između HT-a i Cloudflarea u CIX-u.
Code:
 1  Fritz7362.lan (192.168.1.1)  0.630 ms  5.506 ms  5.485 ms
 2  172.29.252.116 (172.29.252.116)  12.160 ms  12.268 ms  12.499 ms
 3  172.29.82.21 (172.29.82.21)  13.217 ms 172.29.16.129 (172.29.16.129)  13.895 ms 172.29.82.17 (172.29.82.17)  13.995 ms
 4  gtr11-htr11.ip.t-com.hr (195.29.110.146)  17.721 ms  17.832 ms  17.905 ms
 5  cloudflare.cix.hr (185.1.87.115)  110.628 ms  111.021 ms  111.137 ms
 6  one.one.one.one (1.1.1.1)  118.966 ms  116.066 ms  116.172 ms
Zadnje izmijenjeno od: Blagus. 08.06.2020. u 21:37.
Staro 14.12.2020., 22:02   #96
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,569
Autor Blagus Pregled postova
Stvarno nekaj ne valja... HT, Zagreb:Opet se HT igra i pravi pametan s ne-peeranjem u CIX-u i Altusu, vjerojatno...
Evo i meni u postu ista stvar http://forum.pcekspert.com/showthread.php?t=306088
Nešto se događa pri dobivanju IP adrese od DSLama?
Ako dobijem IP parove od 9x.xx.xx.xx. ili 8x.xx.xx.xx. sve radi ko po špagi a ako dobijem 78.xx.xx.xx. par nastaju isti problemi s 1.1.1.1 kao da su parovi posve odvojeni.
Pošten trgovac:
1,2,3,
Staro 26.02.2021., 13:45   #97
Karlo666
Karlo666's Avatar
Postovi: 1,569
Ajd da oživim malo temu.
A1 DNSovi
Primary DNS address 83.139.103.3
Secondary DNS address 83.139.121.8
EDIT #1
DNSove gore nemože se pingat/testirati ili koristiti ako nije router spojen na mrežu od ISPa.
DNSovi su izvučeni preko DSL-AC51 ako trebam dajem SS za proof.
Nikad dovoljno pizdekanja/muljaže sa našim ISPovima.
Pošten trgovac:
1,2,3,
Zadnje izmijenjeno od: Karlo666. 27.02.2021. u 15:35.
Staro 25.09.2021., 18:15   #98
Prezime
Datum registracije: Aug 2013
Postovi: 4,329
Jel mogu ovdje navedeni DNS serveri (popularne alternative za filtriranje reklama) naci svoje mjesto na ovom popisu?
Staro 25.09.2021., 18:28   #99
domy_os
domy_os's Avatar
Postovi: 18,849
Autor Prezime Pregled postova
Osobno nisam bio zadovoljan njihovim serverima, blokirali su i ono što ne bi smjeli pa onda traži što je, browser, add-on ili DNS. Jedan problem sam objavio na njihovom forumu, međutim, poslije je bilo još toga pa mi se nije dalo dalje zezati.
Sad imam Wireguard VPN koji također ima više block lista, ali u slučaju problema si mogu sam pomoći. Pod svojim accountom na webu imam debugger i odmah vidim što je blokirano pa stavim na white listu. Zasad odlično radi, samo to je VPN...
Od nedavno imaju ControlD uslugu pa možeš testirati. Nisam se igrao jer kažem imam njihov VPN.
https://controld.com/
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 26.09.2021., 18:09   #100
Postovi: 23,522
Svaki prijedlog je ok ako se dokaže kao koristan.
AdGuard DNS > https://adguard.com/en/adguard-dns/overview.html
Malo je čudno da navode više servera / čvorišta a u opisu niže samo po par ip adresa,
druga je sad stvar jeli Default ili Family protection ili Non-filtering.
Staro 26.09.2021., 18:26   #101
Prezime
Postovi: 4,329
Neznam tocno kako je s PC-ima, (tek sam ih nekidan upisao) ali koristim ih oko godinu dana na svim Android uredjajima gdje su mi se pokazali potpuno uredni i bez nekih nus-pojava i naravno bez bar 95% reklamnog $ranja.
Staro 27.09.2021., 16:44   #102
domy_os
domy_os's Avatar
Postovi: 18,849
Autor Nikky Pregled postova
Nije čudno, imaš jednu IP adresu za cijeli svijet pa se onda prema tvojoj lokaciji redirecta na najbliži server. Tako radi Cloudflare, Google i većina drugih providera, a i CDN serveri također.
Staro 27.09.2021., 19:06   #103
Marko :)
Datum registracije: Feb 2016
Lokacija: Unknown
Postovi: 718
Autor domy_os Pregled postova
Tako je, to se zove anycast. Iliti samo jedan od razloga zašto su javni DNS poslužitelji puno bolji od onih koje nam dostavljaju ISP-ovi.
Ako se dogodi neki problem u jednom data centru, kompanija čiji DNS koristiš te automatski preusmjeri na drugi najbliži koji radi i ti tu promjenu ni ne osjetiš.
S druge strane, kada padnu DNS poslužitelji od A1, Iskona, HT-a itd., oni nemaju zamjenski data centar na koji te mogu spojiti, pa ostaješ bez usluge dok to ne poprave.
Opekao sam se već dva puta (Vip) i od tada koristim isključivo javne DNS poslužitelje (prije Google Public DNS, a sada Cloudflare). I dok su se ljudi žalili i mediji pisali kako Vip ima problema i nitko nema interneta, ja sam surfao kao da se ništa nije dogodilo.
Cloudflare koristim jer je privatan i najbrži; 1 ms prema istima budući da su im poslužitelji u Zagrebu.
Marko :) je offline   Reply With Quote
Staro 27.09.2021., 19:19   #104
Postovi: 23,522
OcKe ekipa
Staro 15.01.2024., 11:25   #105
zwizard1
Lokacija: R Hrvatska
Postovi: 154
Čudna situacija. Izbacio sam Innbox ruter od A1 i vratio Fritza u pogon . Nisam ništa dirao po njemu već je ostala stara konfiguracija koja je do sad radila.
Problem se desio da su dns serveri u fritzu bili oni od :
CloudFlare Public DNS
IPv4:
Primary = 1.1.1.1
Secondary = 1.0.0.1
i niti jedan Iphone u kući se nežali spojiti preko wifija ustvari kaže da je: Nedostupna internet veza .
U lokalu iako pokazuje da nema interneta i da je spojen na wifi... mogu pristupiti svim uređajima u lokalu , serveru ....
Nakon stavljanja googlovih DNS-ova sve radi .
Što bi moglo biti uzrok ??
zwizard1 je offline   Reply With Quote
Staro 15.01.2024., 15:46   #106
Postovi: 23,522
Bit će da se iDrekec preko CloudFlare nemože "javit" doma a preko Googla može,
malo karikiram ali kužiš šta hoću reći.
Staro 15.01.2024., 21:50   #107
zwizard1
Postovi: 154
Da kužim.
Ali izgleda da me zaj...AdGuard, točninije na mom serveru se nešto poremetilo.
Izbacio ga iz DNS-a od rutera i sad ide i preko Cloudovih ...
Hmmmm
Staro 13.04.2025., 00:22   #108
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,570
Autor zwizard1 Pregled postova
IPv4:
Primary = 1.1.1.1
Secondary = 1.0.0.1
Interesantno, danas sam išao raditi recovery macbook air-a putem interneta i nije mi radio, spojim mac na mobilni internet i proradi. Promijenio samo dns-ove čisto da vidim jel do toga i bilo je. Na 8.8.8.8 i na 8.8.4.4 radi normalno na 1.1.1.1 i 1.0.0.1 koje sam stavio kao defaultne mi ne radi, ne kužim zašto su blokirali jabučine stvarčice
Zadnje izmijenjeno od: Thermaltake. 14.04.2025. u 07:16.
