Staro 17.05.2020., 22:35   #7741
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Koliko ćemo morati čekati na prve 3 nm procesore od AMD i za koju to generaciju planiraju?
Sada su na 7 nm, 5 nm je u najavi.
Intela za sada križam, a možda se u međuvremenu pojavi i koji novi igrač?
sakomako je offline   Reply With Quote
Staro 17.05.2020., 22:39   #7742
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ovisi o TSMC-u, a oni najavljuju 3 nm za drugu polovicu 2022. Znaci tamo negdje sredinom-krajem 2023. mozda i AMD izbaci neki 3 nm procesor.
Staro 18.05.2020., 01:23   #7743
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Autor MadBoY Pregled postova
AMD Ryzen 7 4700G 8-core APU pictured
Navodne specifikacije Ryzen 7 4700G 8c/16t - Base 3.6 GHz, Boost 4.4 GHz, GPU 8 CU, 2.1 GHz, 65 W TDP.
Znači isti APU kao i Ryzen 9 4900H, samo 300 MHz visi base clock CPU-a i 350 MHz visi clock GPU-a.
Ma to je to. 100% legit
To samo što nije izašlo. Jedino još fale hexe APU i novi quad APU
Staro 18.05.2020., 02:04   #7744
Postovi: 8,331
Staro 18.05.2020., 06:34   #7745
Manuel Calavera
Postovi: 14,584
Tim Sweeney Explains Exactly Why the PS5’s SSD and I/O Architecture Is Way More Efficient Than PC’s
Systems integration and whole-system performance. Bringing in data from high-bandwidth storage into video memory in its native format with hardware decompression is very efficient. The software and hardware stack go to great lengths to minimize latency and maximize the bandwidth that's actually accessible by games.
Those PC numbers are theoretical and are from drive into kernel memory. From there, it's a slow and circuitous journey through software decompression to GPU driver swizzling into video memory where you can eventually use it. The PS5 path for this is several times more efficient. And then there's latency.
On PC, there's a lot of layering and overhead. Then you have the issue of getting compressed textures into video memory requires reading into RAM, software decompressing, then calling into a GPU driver to transfer and swizzle them, with numerous kernel transitions throughout.
Intel's work on non-volatile NVDIMMs is very exciting and may get PC data transfer on a better track over the coming years.
Staro 18.05.2020., 10:02   #7746
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Ja sam pogledao AMD slajdove di se lijepo vidi podrska do 2020
Prema tome ispada da su ispostovali obecano.
Mozda je malo kurvanjski ne dopustit ekipi sa pretpotopnim plocama da stave najnoviji super duper Ryzen,ali forma obecanja je zadovoljena.
Amd_Shill je online   Reply With Quote
Staro 18.05.2020., 10:25   #7747
Rogue92
Rogue92's Avatar
Datum registracije: Oct 2017
Lokacija: Našice
Postovi: 276
Autor Amd_Shill Pregled postova
Internet pamti, prije su ovo navodili ; "With the launch of the AM4 platform in 2016, we at AMD made a commitment to maintain and support socket AM4 through 2020."
Znači prije su navodili "THROUGH 2020", a odnedavno navode "UNTIL 2020".
Rogue92 je offline   Reply With Quote
Staro 18.05.2020., 10:27   #7748
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Neki ocito ne prate sto je vec receno, ponavljamo se...
Staro 18.05.2020., 10:31   #7749
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,191
AMD Loses Either Way: B450 & Zen 3 Compatibility Deep-Dive, 32MB ROM Issues, & More
00:00 - Recapping the Problems
01:50 - AMD Chipset Outrage
04:37 - AMD's Current Plan & DDR5 Concerns
08:21 - Most AMD CPUs Can't Even Address 32MB ROMs
17:17 - Shrinking BIOS & AGESA Loader Module
22:09 - Blank Spaces in BIOS & What They Mean
23:54 - What Motherboard Makers Think
26:52 - Enthusiast Marketshare and 32MB Saturation
28:43 - Business Motivations & Partner Trust
32:34 - "AMD Still Misled Customers & is Responsible"
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 18.05.2020. u 10:36.
Staro 18.05.2020., 10:56   #7750
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,797
Malo preskakao po dijelovima koji su mi bili interesantni. Ako sam dobro razumio, MSI je ZA podršku Ryzen 4 na B450 dok je ASUS PROTIV. Ostali su svi li la za sada. Ima nade.
Nije da planiram uskoro nadograđivati 6 mjeseci staro računalo, ali bilo bi dobro za jedno 2 godine uzeti Ryzen 4700X ili slično pa dok traje neka traje.
Staro 18.05.2020., 12:04   #7751
Dottore
Dottore's Avatar
Postovi: 7,660
Ako MSI obećava i to će biti na svim MAX modelima. 16Mb je upitan.
Отправлено через SM-N960F
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 18.05.2020., 12:22   #7752
lobo64
lobo64's Avatar
Postovi: 1,346
Ovo sa 16 i 32 MB biosima je čisto sra... samo zato da bi oni mogli potrpat svoje ROG, AORUS, ZMAJČEKE i ostale šikimiki neukusne malograđanske grafičke simbole i sličice...
Na kraju budu uvjetovali 256 MB zato da bi još i ARGB diode radile u biosu...
Staro 18.05.2020., 12:33   #7753
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 477
Pa je, kao sto je receno nek stave odvojene BIOSe za stare i nove CPU ako zelis staviti novi CPU stavis BIOS koji podrzava samo nove i gotovo.
Silthrax je offline   Reply With Quote
Staro 18.05.2020., 12:44   #7754
Postovi: 8,331
ASRock to već ima složeno otkad su stigli Zen 2 modeli i lijepo piše, "BIOS donosi, ali ukida podršku za...", tak da, ako žele mogu svi.
*ASRock do NOT recommend updating this BIOS if Pinnacle, Raven or Summit Ridge CPU is being used on your system.
*Before updating this BIOS, please also read the description in previous BIOS version.
MSI je ionak unaprijed najavil podršku, pa je tak jasno njima najviše u interesu, a ASUS se po običaju cigani žešće nego AMD u ovom slučaju.
Staro 18.05.2020., 12:46   #7755
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Autor Silthrax Pregled postova
Lako je reci... Ko sto je Steve u videu spomenuo - entuzijasti i DIY su samo jedan mali % ukupnih korisnika kojima flashanje biosa ne predstavlja neki problem.
Svima ostalima (velikoj vecini) ce sigurno biti problematicno, AMD to zna i vjerojatno ovim potezom zele izbjeci potencijalno veliki broj zbrikanih ploca...
Iako IMO to bi bio korektan i ispravan potez - makar time i dobili "nekoliko" ljutitih korisnika na redditu i sl.
Staro 18.05.2020., 12:51   #7756
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,309
Ako drugi budu dali podršku za 3xx i 4xx a Asus ne bude, ova ploča koju imam je zadnji komad HW-a koji sam kupio od njih.
Do sada se već pokazalo i da su debelo najsporiji što se tiče novih BIOS-a, ali to je navodno zbog stabilnosti, dok drugi kao samo šibaju van. Ne znam, nisam vidio da je to netko negdje dokazao.
Usrali su muški i sa Navijem pa su za to okrivili AMD. Baš i nisu kul.
Slobodno me dodajte na PSN
Staro 18.05.2020., 12:52   #7757
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,797
Autor Dottore Pregled postova
Naravno. Oko 24min pogledajte, spominje se MAX i da su isključivo naveli Ryzen 3 i svi ostali noviji na tom socketu. Vjerojatno imaju i veliku zalihu tih ploča i čipova, pa im je isplativo nastaviti podršku kako bi se i dalje prodavale, dok ostali proizvođači nisu u takvoj situaciji.
Tako da, oni će vjerojatno nastaviti podržavati nove procesore na MAX pločama, jedino ako ih AMD blokira u istome, dok drugi vrlo vjerojatno neće.
Staro 18.05.2020., 12:56   #7758
Franf
Franf's Avatar
Datum registracije: Oct 2010
Lokacija: EU
Postovi: 181
Autor Sn4k3 Pregled postova
Nekako mi ne zvuči vjerovatno da će osobi koja se upustitila u nabavku novije generacije cpu-a te ugradnju, predstavljati problem flashanje biosa...
Ili znaš i dobro istražiš što i kako, ili uopće ni ne razmišljaš o DIY zamjeni procesora IMHO
Franf je offline   Reply With Quote
Staro 18.05.2020., 12:57   #7759
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 477
Ako Asrock bude podrzavao Zen 3, definitivno uzimam novi 4600. Sada je samo pitanje da li ce podrzavati i ako hoce kada ce doci BIOS. Za ZEN+ je bilo brzo a za ZEN 2 se dosta cekalo novi BIOS na Taichi x370.
Staro 18.05.2020., 13:04   #7760
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,749
Autor Franf Pregled postova
Definitivno se slazem, no na ogroman broj korisnika imas i ogroman broj varijabli a time i potencijalnih problema... Just sayin
Staro 18.05.2020., 13:09   #7761
Postovi: 8,331
Prema ovome kaj Steve priča, njih (AMD) najviše muči kakve budu reakcije korisnika, ako slože novi BIOS na X470/B450 ploče, a ovi na taj način izgube podršku za starije CPU modele.
I onda se opet vraćamo na ASRock rješenje, složi(te) BIOS i nek bude na raspolaganju, ne mora biti odmah flashan na starije ploče, dosta da postoji opcija.
Mislim, složili su automatsko flashanje GPU BIOS-a za RX 5600 XT, a ako bude trebalo za one koji ne znaju, a žele podršku za novije stvari, ne vidim prepreku da se isto složi za AM4 ploče.
Autor Disco Pregled postova
Sjećaš se onog nVidia GeForce Partner Program pederluka? ASUS je bila prva firma koja je odmah pristala i krenula s novim karticama za AMD.
Tak da, jesu cigani samo takvi. Nažalost.
Staro 18.05.2020., 13:37   #7762
Dottore
Dottore's Avatar
Postovi: 7,660
Ako znaju/znaš čitati koju verziju i oznake ploče i ne bi trebao predstavljati problem. Već godinu i pol flashano preko sedam biosa i nije bilo problema. Samo treba izvojiti min 10 minuta da flashanje dođe do kraja.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 18.05.2020., 14:21   #7763
Mislim da je najteže sada naći razlog zašto odfakat support za Zen3.
Ajmo MBO klošari, muški recite "ne želimo trošiti R&D resurse na support EOL proizvoda i nećemo se time zamarati" ili "želimo prodavati nove ploče".
Ovo loptanje će sad postati i upiranje prstom vrlo uskoro: MBO klošari će reći da je do AMDa, a AMD će reći da je do MBO klošara to je neminovno.
I baš mi je drago što je Stevo rekao kako su se MBO klošari ponijeli kod proizvodnje prvih AM4 ploča, podcjenjivački, jer su mislili da će Ryzen bit flop ko i Buldožer. To im svako malo treba nabit na nos.
Vrlo jednostavno - reći da Zen3 SLUŽBENO nije podržan. Ali... da postoji neslužbena podrška koja je na dušu korisnika tj DIY entuzuijasta.
Tak jasno da averidge joea tak ne zanima što je Zen2 ili Zen3. Njemu je bitno da mu diže vindovse i pokreće igre. Mi, drugu ruku smo takvi da bi radije imali tu i tamo koji bug i imali Zen3 nego obrnuto
Danas je 18.05. Priča je krenula 07.05, pred 11 dana. Shitstorm raste i povećava. To je tek početak a još smo mjesecima do launcha.
A možda je i to dobro za AMD. Piše se o njima neprestano
Na kraju, i dalje vjerujem da će na ovaj ili onaj način, Zen3 raditi na SKORO svim non-5x0 pločama
Staro 18.05.2020., 14:33   #7764
Postovi: 8,331
Nakratko se dotaknul i DDR5 priče, tj. da imaju dokumentaciju za IMC, ali AMD još uvijek ne zna da li će ti procesori podržavati i DDR4. Znači i to se (kak smo pričali) može, ako se hoće.
Staro 18.05.2020., 14:36   #7765
Ruku u vatru dajem da je Ryzen priča debelo nadmašila očekivanja doktorice Su i kompletnog AMD rukovodstva.
Ono, mislili su da će biti dobar proizvod, ali kladim se da se nisu nadali da će biti ovako "awesome" proizvod. Iznenadilo je i njih.
Bit će zanimljivo čitati sve ovo kad Zen3 ekšuali izađe. Toliko se toga napisalo, a još nemamo ni datum (osim Late 2020)
Staro 18.05.2020., 14:39   #7766
Postovi: 8,331
Da, to sigurno, pa ja sam prvi 2016. čitajući prve naznake nadolazećeg Ryzena, mislil evo još jedan Bulldozer i jebenih "8 jezgri".
Nije loše biti totalno u krivu u takvim slučajevima, a i oni su mislili da budu imali 40% IPC-a, a dobili su 52% u odnosu na građevinske strojeve prijašnje generacije.
Staro 18.05.2020., 14:48   #7767
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,484
Santa Barbara
Staro 18.05.2020., 17:42   #7768
Manuel Calavera
Postovi: 14,584
+1
Kao što sam i ranije pisao - da se moram kladit tko će prvi - MSI (radi MAX refresha sa 32mb i obećanja daljenjeg supporta) ili as rock (koji već ima selektivne odnosno parcijalne biose) + isti dvojac nije slušao intel kad su omogućili OC na intelovim non-K cpu
Staro 18.05.2020., 17:47   #7769
Postovi: 8,331
Lijepo ćemo se svi zajedno vratiti na Intel, a Baba nek se slika sa svojim BIOS-ima.
Staro 18.05.2020., 19:25   #7770
Mladenxy
Mladenxy's Avatar
Postovi: 4,370
Intel je zbilja nepotrebno dao šlagvort za sprdnju sa tim modelom. 4/6/8 jezgreni su zbilja vrhunski, na platformi bez nekih većih bugova. Taman se smirila negativna kampanja sa sigurnosnim propustma koja je po meni bila obični clickbait, da bi sad dao opravdani povod za komentare na tragikomičnu sutucaiju sa 350W potrošnje, upravo je napravio najnoviji neslavni rekord sa najvećim drlogom u povijesti procesora.
Uz takvu konkurenciju tko može zamjeriti AMD-u...čak i GPU dijelu.
