Staro 17.01.2006., 19:56   #1
Mars4445
Mars4445's Avatar
Lokacija: Koprivnica
Postovi: 9
Windows xp, need help
Imam problem, stavil sam u biosima da first boot divec bude cd rom i nece mi bootati ,i mam 2 cd roma i probal sam u oba dva uopce nemre nejati. Probaj sam u windowsima dal radi cd i nece mi ga otprti pise "Windows cannot read from the disk. The disk might be corrupted, or it could be using a format that is not compatible whit the window" to mi pise bez obzira koji cd stavil ili DVD... kak da formatiram komp ako mi cdromi jedeju govna..
Mars4445 je offline   Reply With Quote
Staro 17.01.2006., 20:06   #2
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,753
Da li se to događa sa svim cd/dvd medijima ili samo na nekom specifičnom?
GIGABYTE B450 AORUS PRO
Fractal Design Define XL R2
Chieftec A-80, CTG-750C, 750W
AMD Ryzen 5 3600
Be Quiet Dark Rock Pro 4
Asus Nvidia GTX 1060 OC Edition, 3GB
Avermedia Live Gamer HD Lite
GEIL Evo Spear AMD GASB416GB3200C16ADC, DDR4 3200MHz, kit 2x8GB
Kingston NVMe M.2, 1TB
LG BH16NS55 Bluray writer
LG GGW-H20L Bluray writer
27" Philips
Brother HL-2240
Das Keyboard 4 Professional, MX brown
Logitech mouse G402
Scanner HP Photosmart G3010
Cambridge Audio DacMagic 100
Scythe SDAR-2100 + Scythe Kro Craft Speaker SCBKS-1000
Windows 10 PRO x64
Staro 17.01.2006., 20:07   #3
Mars4445
Mars4445's Avatar
Postovi: 9
ma da bez obzira kaj denem u cd rom, morem deti i jabuku i isto bu rekel..
Staro 17.01.2006., 20:18   #4
Mars4445
Mars4445's Avatar
Postovi: 9
Kuzis neznam kak da instaliram windowse, morem si ih skopirati na komp kad ima 2 kompa, prek LAN si prebacim kad meni se cini da radi na 2 kompu cek da provjerim.
Staro 17.01.2006., 20:43   #5
Mars4445
Mars4445's Avatar
Postovi: 9
Radi mi cd ali dok stavim u biosu da cita s cdrom pise da ubaci sistem disk ali unutra je i nece ga citati ovo mi bi trebal biti 3 formtiranje komp.... neznam zakaj ali u biosu dok stavim da cita neradi..
Staro 17.01.2006., 20:46   #6
nicko
Postovi: 4,190
a jesi siguran da su cd-romovi ispravni?
nicko je offline   Reply With Quote
Staro 17.01.2006., 20:48   #7
Mars4445
Mars4445's Avatar
Postovi: 9
da ali bum probal u windowsima instalirati XP i onda dok se instalira bum otisel u dos i moza bu radilo jel tak sam napravil dok sam 1 put formatiral...imam ASUS i samsung asus je novi i obba dva rade
Staro 17.01.2006., 21:07   #8
Mars4445
Mars4445's Avatar
Postovi: 9
nemogu pa kak da ja te jebene windowse instaliram.....
Staro 17.01.2006., 21:14   #9
domy_os
domy_os's Avatar
Postovi: 18,921
Probaj zamjenit IDE kabal. Stavi neki 80-žilni.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 17.01.2006., 21:16   #10
Mars4445
Mars4445's Avatar
Postovi: 9
bah bum probal ali sad na pameti imam jednu drugu ideju
Staro 18.01.2006., 15:10   #11
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,873
ja isto imam 2 optikalije,ali mi normalno buta s onoga u kojima su win xp,ne znam odspoji 1,ili još bolja opcija kupi pržilicu,cd-rom ne čita dvd.
Staro 20.01.2006., 21:26   #12
Mars4445
Mars4445's Avatar
Postovi: 9
Ma uspel sam sloziti, posudil sam drugi win xp i sad oce butati. Sad rade odjedamput oba dva cdeja.
