Staro 20.04.2020., 20:07   #2701
Brekulja
Datum registracije: Jul 2017
Lokacija: abc
Postovi: 26
2)to je normalno za wifi na 5ghz
Poslano sa mog SNE-LX1 koristeći Tapatalk
Brekulja je offline   Reply With Quote
Staro 29.04.2020., 18:37   #2702
t-krom
Datum registracije: Oct 2013
Postovi: 70
Oprostite, ima li ovaj uređaj admin username i pass? Ili bilo koji drugi username i pass?
Imam Speedport W 724V Type Ci 11ac i nemam pojma kako da dođem dalje od početnog sučelja na 192.168.1.1.
U kutiji nema nikakvih uputa.
Našao:
Autor nike.com Pregled postova
Našao sam u prijašnjim postovima, kopiram ovdje link ako nekome zatreba ;
Edit;
Treba se prvo ulogirati preko ovog linka http://speedport.ip/engineer/html/dsl.html tek tada će proraditi donji link.
Username : user
Pw: na poleđini
http://speedport.ip/html/engineer/ro_dsl.htm
Evo i objašnjenje za SNR i line Att ;
Have you ever heard about line attenuation? Leaving out some of the technical jargon, the line attenuation figure describes the distance between you and the exchange of the ADSL provider. It is expressed in dBs and you can check this number on your ADSL statistics of your home / corporate router (show dsl interface atm(something) for Cisco). In short, the lower this number is, the better:
20dB and below is outstanding
20dB – 30dB is excellent
30dB – 40dB is very good
40dB – 50db is OK
50dB and above is bad
Signal-to-noise ratio (SNR) is another figure you can check in the ADSL stats of your home / corporate router (show dsl interface atm(something) for Cisco). This number is also expressed in dBs and describes the relation between your speaking strength (signal) and the street’s noise strength (noise). The higher this number is, the better, as your speaking voice outperforms the noise.
10dB and below is bad
11db – 20dB is OK
20dB – 28dB is excellent
29dB and above is outstanding
Onaj prvi link meni ne radi. Baš sam gore pitao kako ući i sad gledam unazad postove, možeš opet to objasniti? Inače, ušao sam unutra s ovim što je pisalo, user i pass iza. A sad kako doći do skrivenog?
Zadnje izmijenjeno od: Nikky. 29.04.2020. u 21:00.
t-krom je offline   Reply With Quote
Staro 29.04.2020., 18:50   #2703
Postovi: 34,085
Meni su rekli da koristim slijedeće podatke: user: user, pass: serijski broj uređaja.
Staro 29.04.2020., 18:56   #2704
t-krom
Postovi: 70
Da, to sam sad našao u ovom starijem postu, ali tražim način kako doći do ovih skrivenih postavki, onaj link koji je čovjek stavio meni ništa ne otvara.
usput, gdje se preko user/pass vidi brzina na koju si spojen?
ne mogu to naći nigdje.
edit: našao sam i to.
još samo samo ostaje to oko admin moda ako netko može pomoći.
Zadnje izmijenjeno od: Nikky. 29.04.2020. u 21:02.
Staro 29.04.2020., 19:52   #2705
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Pa piše ti sve u citiranon postu. Prvo se ulogiraj sa User/Pass, onda u drugom tabu otvori; http://192.168.1.1/html/engineer/ro_dsl.htm
Ako nisi mijenjao IP trebao bi biti taj po defaultu, ako je neki drugi upiši njega.
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 29.04.2020., 20:27   #2706
t-krom
Postovi: 70
Hvala zupy, sad sam uspio, pa nisam bio promijenio ip adresu, lapsus. Ali nema ništa tamo, obični info tab.
Ne postoji uopće neki dodatni menu da se može nešto mijenjati?
Mah, nije ni bitno, odlučio sam uzeti neki ruter i staviti ovaj u bridge.
Zadnje izmijenjeno od: t-krom. 30.04.2020. u 11:41.
Staro 03.05.2020., 04:28   #2707
maxima
Datum registracije: Nov 2017
Postovi: 6
pozdrav svima od (su)patnice po Speedportu.
malo o mojoj situaciji: bakar 50/10, centrala na kraju neduge ulice, zadovoljna sam stabilnošću veze i brzinom s obzirom na to da o optici mogu samo sanjati. kvart s obiteljskim kućama u predgrađu zg, totalno nezanimljivo za provlačenje optike što si mi i sami potvrdili, ne baš doslovno ali između redaka.
HT-u sam se vratila nakon više godina kruženja po drugim dostupnim telekomima (iskon i amis dok su još bili iskon i amis) i sad mi teče treća godina kako sam kod njih. prve dvije godine savršenstvo, nisam ni znala gdje je reset tipka na modemu, o web sučelju da ne govorim.
dva - tri mjeseca unazad počeli su problemi, vjerojatno donekle povezani i s mojim mahnitim povećavanjem raznih wifi uređaja, a bome imam i nekoliko bridgeva za smart home uređaje koji su povezani utp-om što drito u modem što u gigabit switch koji sam nedavno nabavila jer mi je ponestalo mjesta u modemu. switch je D-LINK GO-SW-8G, Gigabit GOSwitch, 10/100/1000 Mbps, 8-port
pa eto, pokazalo se da se speed baš i ne može nositi s više od jednog mobitela i eventualno tableta: uređaji su počeli ispadati iz mreže, ne bi mogli uspostaviti wifi konekciju, a počeli su žmigati za internetom i oni na kablu. ručni restart modema rješavao je stvar, a bome sam počela i pratiti logove modema.
pa sam skužila svako malo pojavljivanje Providing DHCP information to a requesting station has failed (H003).
više mailova i zivkanja SZK napokon je rezultiralo time da su mi prije tjedan dana zamijenili modem. naravno za isti jer eto nemaju drugih. dečki su ga odmah digli na novi firmware 09091602.00.011 tako da sad imam i 5 GHz frekvenciju.
i nakon tog sretnog dana sve je ošlo još više kvragu.
mislim da mi sad dvije trećine wifi uređaja ne može izaći na internet: spoje se na wifi ali nema majci švrljanja po netu. "your wifi has no internet connection".
TV, iPhone, dvije alexe i broadlink rm4 mini unazad nekoliko dana žive u izolaciji zajedno sa mnom.
zanimljivo je da dok iphone uporno dobija nogu na wifiju, ipad i apple tv uredno rade. wd mycloud je uštekan kabelom, isto malo malo pa vidim da nema konekciju. PC je uvijek ima, i ikein bridge se dobro drži.
a ono što je najzanimljivije je da više nikakav reset modema ne pomaže. čačkalicom, kroz web sučelje, na tvorničke postavke... zadnjih nekoliko dana sam provela više resetirajući smeće nego čilajući na netflixu. nula bodova. čak više nema ni toliko DHTC failova. ti uređaji se jednostavno više i ne pojavljuju u popisu uređaja na mreži.
i kao rezultat svega sam malkice pukla ko kokica i temeljem iščitavanja preporuka routera naručila Archera.
maxtv nemam i ne želim, telefon nemam i ne želim (premda ga plaćam), VPN možda i uzmem jednog dana kad postane opasno torrentirati ili da napokon mogu gledati BBC. no otom potom.
ono što mi sad odmah treba je stabilna veza za smart home (Tado bridge za thermostat i AC, Ikein bridge i nekih petnaestak žarulja plus 2 smart pluga, yeelight smart strip na TVu, Nuki smart lock koji je u dugoročnom planu jer košta ko svetog petra kajgana) plus već nabrojane wifi uređaje.
plus još neke koje sam skoro zaboravila (npr. xiaomijeva kućna nadzorna kamera i radna lampa - prva je isključena jer sam već mjesec i pol na radu od doma, druga jer ju i ne koristim preko wifija premda ima tu mogućnost).
TL;DR hoće li TP-Link Archer C1200 AC1200 Dual Band Gbit router biti dostatan za izdržati veći broj smart home i veći broji wifi uređaja? ovo smeće koje imam ide u špajzu, archer bi bio jedini modem.
još nisam dobila predračun, stignem otkazati narudžbu i kupiti nešto jače ako za tim ima potrebe.
hvala svima koji ovo pročitaju na strpljenju, a po vremenu kad ovo pišem vidite koliko sam u banani.
Zadnje izmijenjeno od: maxima. 03.05.2020. u 04:39.
maxima je offline   Reply With Quote
Staro 03.05.2020., 09:22   #2708
Blagus
Datum registracije: Jun 2012
Postovi: 510
Ne znam ti reći hoće li zadovoljiti potrebe kućne mreže, no mogu ti reći da Sppedšrot ne može u špajzu jer taj TP-Link nema DSL modem. DSL modeme imaju neki Asusi i neki drugi modeli TP-Linka, ali nemam iskustva s tim pa ne mogu preporučiti niti jedan. Meni doma Fritzbox tjera DSL vezu i 10-ak WiFi uređaja i par na kabelu.
S ovim Archerom ti Speedšrot ostaje u bridge modu.
Staro 03.05.2020., 11:48   #2709
Postovi: 23,635
Vjerojatno je da će ti Archer C1200 dobro raditi, definitivno je sposoban pokriti uređaje koje imaš ...
Kako je kolega Blagus već rekao, ovo su ti koraci:
- Speedšrot ostaje u igri i spojen je na xDSL liniju (kako i je sada)
- kad ti stigne Archer, zovi SZK i traži da Speedšrot prebace u Bridge mode za Internet konekciju
- dok si još na tel. sa SZK provjeri / potvrdi / zapiši user i pass za PPPoE internet konekciju
- usput neka ugase WiFi na Speedšrotu (možeš i ti naknadno)
- spoji novu igračku (Archera), Speedšrot Lan1 > WAN Archer
- spoji komp Lan kabelom na Lan1 Archer
- prođeš wizzard, odabereš PPPoE konekciju, upišeš gore spominjane user / pass ... i eto te na Internetu
- WiFi postaviš po želji, isto ima 2.4 i 5 Ghz, za 2.4 bilo bi dobro da manualno postaviš radni kanal na kojem su susjedi najslabiji
- po potrebi imaš opciju za Guest WiFi, za goste i one koji ne trebaju pristup lokalnoj mreži
Ostale finese se lako kasnije promijene.
That's it
Staro 03.05.2020., 14:13   #2710
maxima
Postovi: 6
iz ovog niže quotanog sam zaključila da može bez speedporta
zato sam i išla na archera. kaj, da uzmem nešto drugo? i što bi to onda bilo otprilike u tom cjenovnom rangu do max 600 kn?
(malkice sam limitirana slobodnim prostorom na radnom stolu, bolje rečeno nemam ga. jedino da počnem kačiti uređaje čavlima po zidu).
btw hvala na step to step uputama Nikky, trebat će mi
Autor marke Pregled postova
Gledao sam ovako nešto:
1) D-Link DIR-842/MT AC1200
2) ASUS RT-AC57U
3) TP-Link Archer C1200 AC1200
4) Asus RT-AC1200
Dali išta od tih routera u tom jeftinijem rangu mogu to upogoniti? Naravno, bilo kakva druga preporuka je dobrodošla. Cilj je potpuno zamijeniti Speeedport, ako je moguće, bez previše muke, a ako ne, onda dodati nakon njega još router za wifi mrežu.
Hvala svima!
Autor Nikky Pregled postova
Prvi ako ćeš na njega prebaciti samo AP dio posla,
sa ostalima možeš da postanu gl. router.
Ako si čitao onda znaš da imaš dvije opcije:
a) Speedšrot ostaje, na njemu i dalje radi VoIp i/ili MaxTv, a Internet ide u Bridge mode
b) na novom složiš Internet i MaxTv, VoIp otpada
Zadnje izmijenjeno od: maxima. 03.05.2020. u 14:25.
Staro 03.05.2020., 15:09   #2711
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,844
Ako nećeš dva uređaja, onda moraš ići na router koji ima i DSL modem. Fritz! su hvalili, čak ga je HT davao uz nekih 20kn/mj naplate. Mislim da imaš i nekih Asus routera+modem, ali mislim da su svi oni preko 1000kn u slobodnoj prodaji. Ali svakako provjeri.
Staro 03.05.2020., 15:12   #2712
Blagus
Postovi: 510
Niti jedan od navedenih nema DSL modem. Najbolje rješenje za eliminirati Speedporta (pretpostavljam da ti je to cilj zbog prostora na stolu/zidu) je da uzmeš Fritzboxa na Njuškalu, treba ti 7360 koji se prodaje po 300-ak kuna, ja ga imam (model 7362 koji je praktički isti uređaj) i radi savršeno. Budući da ne trebaš telefon i MaxTV, konfiguracija je jako jednostavna, a možeš flashati OpenWrt pa su ti mogućnosti praktički neograničene (adblock i sl.). Jedino nema 5,8 GHz WiFi.
Staro 03.05.2020., 15:56   #2713
t-krom
Postovi: 70
Uspio sam S-port staviti u bridge i upogoniti PPPoE preko mog rutera, ok radi sve. Jel se može i telefon prebaciti nekom forom il da zaboravim to? Ruter je TP-Link AC2300.
Staro 03.05.2020., 17:41   #2714
Postovi: 23,635
@t-krom
Ostavi tel. (VoIp) na Speedšrotu, tako ti je jednostavnije a i namjerno je komplicirano upogoniti ga na nekom custom uređaju.
@maxima
Speedšrot bi mogao ispasti iz kombinacije da imaš optiku, na xDSL - u ga trebaš ili da nabavljaš uređaj koji ima xDSL modem u sebi,
međutim to otvara problem dostupnosti / cijene / podešavanja.
Nemoj se opterećivati sa Speedšrotom, ni ne treba da stoji na radnom stolu, slobodno ga "baci" negdje sa strane / u ćošak / po podu ...
U toj novoj ulozi (samo kao modem) će raditi uredno.
Nabavi ovog Archera C1200 (šta si ga već naručila) i sve će biti ok.
Na taj način si ready ako sutra budeš mijenjala operatera pa će opet odgovarati,
samo opet prođeš opisanu proceduru (router od ISP - a u Bridge mode + user / pass za PPPoE konekciju.
Staro 03.05.2020., 17:46   #2715
madwifi
Postovi: 61
> en.wikipedia.org/wiki/Wi-Fi_deauthentication_attack
Bilo je toga i davno prije po kvartu ali puno manje, jeftine kineske antene imaju injection danas tak da...
Ima lijeka, al jedino kabel cat5e/cat6 <-> AP i signal koji je toliko slab da se ne vidi s ceste. "Extender" je komedija, meta samo takva.
Neki kupe komplet novi hardver svaki put kad se promjeni rfc standard, ostali ugase wifi, promjene ssid/pass svakih par dana, itd.
To zadnje pali ako je neki putnik s ceste probio, ali ako je netko u krugu 20m taj nebu zaboravil tak brzo.
Problem ti je kad stari wifi driveri (u laptopima, ruterima, kamerama) imaju rupu koju nitko nikad ne pokrpa, nemaju tvornice profita u tome.
Preferiram lan kabel za po doma, jeftinije nego kupit opremu svako malo. Def sigurnije nego ovisit o tome jel bude ISP pokrpal svoju kantu ili ne.
madwifi je offline   Reply With Quote
Staro 03.05.2020., 23:43   #2716
t-krom
Postovi: 70
@Nikky
Hvala, ok, zanemario i zaboravio na telefon.
Samo jedna stvar ako netko može pomoći, ne znam što mi koči ovo; ne mogu nikako riješiti da se spojim u sučelje S-porta, koje sam ostavio na 192.168.1.1. Imam 4 kompa u kući, svi se sad spajaju na AC kao gateway, preko svog AP u clientu (osim "glavnog" kompa, koji je žično spojen na AC jer je blizu). Znači stavio sam da svaki komp ima svoj statički IP, i svaki njegov AP ima svoj statički IP, i svima je gateway AC. I ni s jednog se ne mogu spojiti na S-portovo sučelje 192.168.1.1. A sa svakog kompa mogu se unakrsno spojiti na sučelje svakog AP clienta.
Jedini način koji sam skužio je da kod glavnog kompa preštekam PC LAN kabel iz ACa u S-port, onda mogu ući u sučelje. Ali to mi je nepraktično svaki put preštekavati ako slučajno moram ući u S-port sučelje, pogotovo jer sam sad oba rutera zgurao tamo di ne smetaju. Možda da promijenim privremeno dok mi to treba na bilo kojem kompu (i njegovom AP clientu?) gateway u postavkama mreže na 192.168.1.1, bi li radilo sučelje? Ali i to mi je nekako nepraktično, no ako radi i nema drugog načina, ok.
EDIT: hm, možda se ne spaja jer je na Sportu isključen wifi i jednostavno ne možeš se onda na njega ovak spojit bez žice dok je u bridgeu?
Zadnje izmijenjeno od: t-krom. 04.05.2020. u 00:03.
Staro 04.05.2020., 12:24   #2717
Postovi: 23,635
Logično da sad ne možeš otvoriti web konfig Speedšrota jer je on sad na wan strani novog routera.
EDIT: Evo me, prvo da potvrdimo činjenice :
- WEB konfig Speedšrota je na defaultnih 192.168.1.1
- rekao si da si uzeo TP-Link AC2300, ne pronalazim emmulator za njega nego za Archer A2300 i Archer C2300 ?
- pretpostavljam da slikovnica od C2300 odgovara tvom slučaju > https://emulator.tp-link.com/Archer_...0712/index.htm
- po tome je njegov web konfig defaultno na 192.168.0.1
- za ovo niže bitno je da su "modem" i router na različitim ip adresama / u različitim mrežnim segmentima
Evo šta probati:
1. ako ima opciju pod Internet (WAN) - Secondary Connection
(igra za uređaje koji imaju tu opciju)
- Secondary Connection = Static IP
- IP=192.168.1.2
- Subnet=255.255.255.0
- na dnu Save
Sačekati malo pa viditi jeli imaš pristup kad u browseru staviš 192.168.1.1.
2. static route
- Advanced routing - static routing
- sa Add dodaj novu stavku
- Destination=192.168.1.1 (eventualno treba unijeti kao 192.168.1.0)
- Gateway=192.168.0.1 (IP adresa Archera)
- Interface=WAN
- Status=Enabled
- na dnu OK
Odmah ispod imaš Refresh, treba se pojaviti stavka koju si unio,
sačekati malo pa viditi jeli imaš pristup kad u browseru staviš 192.168.1.1.
3. vjerojatno ću se sjetiti još opcija
That's it
Zadnje izmijenjeno od: Nikky. 04.05.2020. u 14:06.
Staro 04.05.2020., 14:16   #2718
t-krom
Postovi: 70
Puno ti hvala, budem isprobao poslije posla.
Inače, ovo je ruter, da budem precizan
https://www.tp-link.com/en/home-netw.../archer-c2300/
Da, IP sam mu s 192.168.0.1 promijenio odmah u jedinstven i sukladan ostalim adresama na mreži, 192.168.1.nešto.
Zadnje izmijenjeno od: Nikky. 04.05.2020. u 14:41.
Staro 04.05.2020., 14:43   #2719
Postovi: 23,635
E sad vrati mu ip na defaultnih 192.168.0.1 jer mora biti različit od Speedšrota, piše gore ...
ili ako ti je lakše promijeni Speedšrot na 192.168.0.1 (samo tada moraš prilagoditi gore navedene brojeve).
Ako je C2300 onda odgovara ovaj gore emmulator / trebao bi imati 1. opciju.
Staro 05.05.2020., 00:42   #2720
t-krom
Postovi: 70
Još jednom ti puno hvala, odmah je upalila prva metoda. Moram ti reć da sam ja to jednom znao da moraju biti u različitoj domeni, sad mi se sve vratilo pomalo. Al to je bilo pradavno, još dok sam stavljao D-link, onaj mali metalni ko kutijica, sivi, da bude u bridgeu prema nečemu. Zaboravio sve. A i još bolje ovako. Nisam imao više pojma koje su mi adrese slobodne, pa sam na svaki novi uređaj stavljao neke okrugle brojke, 192.168.1.45, 192.168.1.55 itd, i opet nisam znao di je kaj. Sad me ovo prisililo da krenem od početka od 192.168.0.1 od uređaja do uređaja i sve ću lijepo zapisati na papir. Još jednom, hvala ti.
Staro 05.05.2020., 01:03   #2721
Postovi: 23,635
No frx, forum je tu da se razmjenju je info / znanje.
Još jedna napomena, za one koji će naknadno čitati,
gore navedena prva metoda vrijedi samo za određene (novije) routere koji imaju opciju paralelnu Secondary WAN Connection.
Staro 06.05.2020., 14:23   #2722
t-krom
Postovi: 70
Da probam jos nesto ovako pitati. Jel postoji npr na njuski ili negdje neki modem od hta ili koji radi na ht vezi, kvalitetniji od ovog, da ga iskoristim umjesto ovog?
Zadnje izmijenjeno od: t-krom. 06.05.2020. u 14:41.
Staro 06.05.2020., 21:26   #2723
Blagus
Postovi: 510
Spomenuo sam ih gore, imaš Fritzbox na kojem možeš, i na original FW-u i na OpenWrt-u, ciljati up/down margine i s tim si podesiti stabilnost i performanse konekcije.
Staro 07.05.2020., 00:23   #2724
t-krom
Postovi: 70
Autor Blagus Pregled postova
Ciljati up/down margine. To mi treba ko kruh. 7362l je taj? Ili 3390? lli 7330?
Evo uostalom da nabrojim koji se sve mogu kupiti trenutno: 7362l, 7330, SL, 3390, 7320, 7360, 3050.
Zadnje izmijenjeno od: t-krom. 07.05.2020. u 00:59.
Staro 07.05.2020., 01:52   #2725
Blagus
Postovi: 510
Autor t-krom Pregled postova
Ja bih uzeo 7360 ili 7362. Ostali su ili ADSL ili ne podržavaju OpenWrt.
Na 7360 imaš engleski FritzOS (na 7362 sam nešto na pola uspio sklepati). Oba su podržana u OpenWrt-u. 7360 ima 16 MB flasha, 7362 ima 128 MB.
Ako ti ne treba telefonija, stavi gore OpenWrt pa možeš u decimalu štimati neovisno upload i download marginu.
Staro 07.05.2020., 11:06   #2726
t-krom
Postovi: 70
Nažalost moram imati telefon. Znači ako nije original firm ne radi telefon? I ako je original, onda se ne može štimati, ili može ali ne tako precizno kao s Open WRT?
Staro 07.05.2020., 12:10   #2727
Postovi: 34,085
Imaš o fritzu posebnu temu pa baci oko na nju
http://forum.pcekspert.com/showthread.php?t=301851
Staro 07.05.2020., 12:42   #2728
t-krom
Postovi: 70
Evo jesam.. samo čekam ovu potvrdu za štimanje (i tamo za OpenVPN) pa da znam da kupim 7362 il ne.
Staro 07.05.2020., 12:43   #2729
Blagus
Postovi: 510
Na original FW-u imaš namještanje u 5 koraka, između max performance i max stability.
Ja vrtim OpenWrt a telefon sam si riješio sa ATA adapterom kojeg kinezi prodaju po 20-ak dolara ako se sa Speedšrota mogu izvući SIP podaci.
Alternativa bi bila da Speedport staviš iza Fritza i propustiš mu VoIP VLAN. Teoretski ništa to ne sprječava, u praksi je pitanje koliko se Speedport može konfigurirati.
Autor coconut Pregled postova
Slažem se da ovo nije tema za nastavak diskusije o Fritzu, ali ta tema je specijalizirana za jedan model Fritzboxa vezanog uz HT (koji je uz sve to pauzirao pilot projekt). Idealno bi bilo da imamo neku generičku Fritzbox temu nevezanu uz model i ISP-a.
Staro 07.05.2020., 18:40   #2730
frezer
frezer's Avatar
Datum registracije: Jan 2018
Postovi: 519
Radit će i telefon. Trebaš iz speedporta izvući podatke i sve unijeti ručno u Fritza. Pazi još na jednu stvar, 7330 ne podržava vdsl.
frezer je online   Reply With Quote
