Staro 31.12.2019., 16:16   #4171
Autor Flood Pregled postova
Kod mene u opcijama power&sleep ne postoji taj slider...zašto?
Nemaš 1909 windozere.
Staro 31.12.2019., 16:51   #4172
Venomgamer
Venomgamer's Avatar
Datum registracije: Sep 2010
Lokacija: Peljesac
Postovi: 293
OS Version 10.0.18363.535 (Win10 19H2 [1909] October 2019 Update)
nemam taj slider uopce
Windows 10 pro
Zadnje izmijenjeno od: Venomgamer. 31.12.2019. u 17:01.
Venomgamer je offline   Reply With Quote
Staro 31.12.2019., 17:49   #4173
Čipset driver koji je?
Staro 31.12.2019., 17:52   #4174
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 779
1
2
3
Ovo je situacija na kompu...
AMD drivers-1.11.22.454
Staro 31.12.2019., 17:56   #4175
bono.tadic1
Datum registracije: Feb 2012
Lokacija: zemlja
Postovi: 23
Misljenja o asus tuf b450 plus gaming? Upogonit cu je s ryzen 5 3600, rtx 2060 super i vengeance 16gb ram
bono.tadic1 je offline   Reply With Quote
Staro 31.12.2019., 18:27   #4176
1
2
3
Ne kužim zakaj to nemate... čudno.
Staro 31.12.2019., 18:28   #4177
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Premršava na VRMu i njegovom hlađenju. PRO Gaming model je nešto bolji.
#1: https://www.futura-it.hr/msi-main-bo...m_medium=click
https://www.telebit.hr/mb-asus-tuf-b...a0-m0eay0.html
Staro 31.12.2019., 18:39   #4178
Postovi: 8,570
Autor Venomgamer Pregled postova
The Windows power slider is available for AMD and Intel platforms running Windows 10, build 1709 and newer builds of Windows. It is not available on devices with ARM64 processors. The slider will appear on a device only when the Balanced power plan, or any plan that is derived from Balanced, is selected. There is not an option for either users or OEMs to remove the slider UX. Devices that have the High Performance, Power Saver, or any “OEM Recommended” power plans will not be disturbed during the Windows upgrade process. If a user upgrades from a version of Windows that does not support the slider, to a version that does, there will be no change to their High Performance, Power Saver, or "OEM Recommended" power plan. These users will not see the slider UX, and they can still configure their power plans in the same way they could before upgrading. Users will see the power slider appear only when they apply the Balanced power plan from the Settings app, under System > Power & Sleep > Additional power settings.
Kak god bilo, morali budete u nekom trenutku složiti Balanced da bi uopće dobili Power Slider mogućnost. Nakon toga, lako kasnije opet prebacite na Performance.
Staro 31.12.2019., 18:40   #4179
Venomgamer
Venomgamer's Avatar
Lokacija: Peljesac
Postovi: 293
Zadnji driveri,s amd stranice,zadnji update,mozda ti imas neku drugu verzijubwinsa,mi imamo pro
Meni je power plan na high performance,mozda je to
Staro 31.12.2019., 18:44   #4180
bono.tadic1
Lokacija: zemlja
Postovi: 23
Autor Smartic Pregled postova
Ma rekao sam im da zelim Asrock B450M Steel legend, ali odgovorili su mi da posto sam uzeo NZXT H700, da mi nema smisla uzet matx plocu, pa su mi ubacili tuf b450 plus i rekli da je kvalitetnija. Al i ja sam napravio gresku sto nisam malo istrazio
Zadnje izmijenjeno od: bono.tadic1. 31.12.2019. u 20:13.
Staro 31.12.2019., 18:45   #4181
Flood
Flood's Avatar
Postovi: 779
Ok
Stavio na Balanced i pojavio se slider,bio na sredini...
Staro 31.12.2019., 18:51   #4182
Doktore...
Staro 31.12.2019., 19:01   #4183
Venomgamer
Venomgamer's Avatar
Lokacija: Peljesac
Postovi: 293
Pojavio se slider,a kad vratis na high performance nestane,boost je u oba slučaja isti.....
Da se mi razumijemo da nema brke i njegovog ludog proca bio bi prezadovoljan,ovako uvijek nesto cackam pokusavam,a sto god poduzmem boost sve manji.
Staro 31.12.2019., 19:02   #4184
tetak dudo
tetak dudo's Avatar
Lokacija: 45.594-16.217
Postovi: 239
1
2
3
stavi na balanced i onda ti se pojavi crta za podešavanje- AMD RYZEN balanced-
PS. sad vidim da si riješio
i sa novim biosom mi se više ne pali pa ugasi pa opet upali konp kad je bio bez struje
u biosu sam uključio PBO 75MHz , ram nisam ništa dirao, probao i vrationa default i toje to
https://i.postimg.cc/Kz2jhp2w/Snimka-zaslona-32.png
Dell OptiPlex Micro
ThinkPad T470
Zadnje izmijenjeno od: tetak dudo. 31.12.2019. u 19:19.
tetak dudo je offline   Reply With Quote
Staro 31.12.2019., 19:14   #4185
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Mah, Brko ima nekuo čudo tj po svemu krivo brandirani 3600X i mi mu ne možemo ni prismrdit, tako da okanite se ćorava posla i koristite komp za što god ga već koristite.
Slobodno me dodajte na PSN
Staro 31.12.2019., 19:55   #4186
Joza_Seraf
Joza_Seraf's Avatar
Datum registracije: Jun 2015
Lokacija: Klc
Postovi: 568
Brko potajno radi za AMD. Vidit cemo kad moj dođe 3600 jel možda X verzija :-) samo ce mi netko objasniti najbolje postavke za OC... i ploca je valjda oke :-)
Samo čekam dan kada će mi netko pokucati na vrata i zatražiti me bubreg jer sam negdje odscrollao dolje i stavio kvačicu na "Slažem sa svime"!!
Joza_Seraf je offline   Reply With Quote
Staro 31.12.2019., 20:49   #4187
Pa prestani čačkat i ja sam neki dan čačkao isto neke besne gliste izvodio sa OCN foruma iako sam rekao da neću više.
Na kraju sam 2x BSOD dobio i jednom hang. Rekoh tak mi i treba a reko sam da neću više drkarit. Tako da sam nakon toga flešao zadnji BIOS 7704 i postavio opet samo par postavki i sejvao taj .cmo na USB stick. Više ne drkarim.
Autor Disco Pregled postova
Nakon svih failova od procesora i PTSPova pretpljenih, mislim da je u redu da je i mene posralo jednom
Kaj je najbolje, imao sam 2 komada i jedan sam proslijedio frendu bez da sam isprobavao prvo i ostavio si "bolji".
A i taj boost se nije odmah pojavio. Prvi boostovi (nakon što sam odbacio fix OC) su bili 4250-4290 sa istim postavkama kao i danas. Tek od onog famoznog 0075 Beta BIOSa i nekih čipset drivera se diglo na 4400 MHz
Autor Joza_Seraf Pregled postova
Da bar radim za AMD
Ne znam je li se sjećate, bilo je i R5 1600 koji su bili 8c/16t čak ih je tu na forumu bilo 2 ili 3 komada ako se sjećam. Po meni je to bolji pogodak neko ovih 100-150MHz boosta više.
R5 3600 su po svemu trebali biti smeće. Otpad od ovih boljih 8, 12 i 16 jezgrenjaka. Loše jezgre i ne veliki boost. Očito da se koji omaknuo
Postavke za OC najbolje na automatiku. O kojoj se ploči uopće radi?
Staro 01.01.2020., 01:09   #4188
Dottore
Dottore's Avatar
Postovi: 7,712
Doktore...
Molim?
Отправлено через iPhone
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 01.01.2020., 14:41   #4189
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
B 350-F sutra valjda stize procesor :-)
Staro 01.01.2020., 17:41   #4190
Autor Dottore Pregled postova
Molim?
The Exiled je dobio titulu doktora
Aha, sretno u šerafanju. Nemoj zaboravit BIOS flešat ako već nisi zadnji tutno gore
Staro 07.01.2020., 11:30   #4191
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Jel jos uvijek ima ploca koje imaju rupe za AM3+ hladnjake?
Amd_Shill je offline   Reply With Quote
Staro 07.01.2020., 11:58   #4192
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Autor Amd_Shill Pregled postova
Ima c6h.
Staro 07.01.2020., 13:49   #4193
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Ima c6h.
To je x370 i tesko ih se vise moze nac
Staro 07.01.2020., 19:24   #4194
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,414
Kolko ja znam niti jedna druga.
Staro 07.01.2020., 20:55   #4195
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Ima ova
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 07.01.2020., 21:25   #4196
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
a ni cijena nije loša
Staro 08.01.2020., 16:03   #4197
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 728
Po izgledu malo vuče na CH6, ali nisam našao da li isto ima rupe i za AM3 hladnjake.
Za CH6 se premišljam između Sythe Ninje 5, Fume 2 i "stare" Noctue D14 (non AM4), upravo zbog tih AM3 rupa. Netko možda probao taj combo ? (D14 na CH6)
Staro 08.01.2020., 16:13   #4198
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,493
javi se noctua-i i bus dobil free potrebno, ako imas papire.
a mozes i posebno kupit potrebno za bilo koji socket.
geronimo_2 je online   Reply With Quote
Staro 08.01.2020., 16:19   #4199
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 728
Prošlo bi i da sada kupim D14 ? Vidim da i kod nas imaju AM4 kit za 60-tak čn ali za CH6 bi mogao i bez toga.
Jasno da bi jednostavnije bilo uzeti D15 ali ne vidim baš neku razliku pa svašta kombiniram dok čekam proc .
Staro 08.01.2020., 16:23   #4200
geronimo_2
geronimo_2's Avatar
Postovi: 4,493
pa sta se prodaje novi d14 jos uvjek ?
ako ides na novo, osobno nebi bacao pare na noctua-u vec uzeo provjereno dobru fumu za puno manje dinero.
ja nisam ni gledao dali am3 set ide na moju primku. narucio set za am4 i vozi. ulaganje u buducnost.
