aka Striko
Lokacija: Krapina - Zagreb
Postovi: 1,733
HP Omen 2018 + Ballistix 2666 Mhz = 2400 Mhz
Pozdrav, Kupih ovaj ram https://www.crucial.com/usa/en/nuc6i5syh/CT9643384 , za HP Omen 2018 (HP 15-dc0005nm ) . Kit je 2 x 16 GB ( I know why 32 GB) ; no bio je jeftiniji nego kod nas 16GB. Memorija radi, no na 2400 MHZ! Postoji koja fora da ju upogonim na nativnu brzinu? BIOS koliko sam vidio nema Advanced setup? Danke. |
Datum registracije: Nov 2016
Postovi: 142
Na linku di si kupio imas 9 reviewa, i odmah u prvom je netko napisao: "The issue with these particular modules is that the only profile which runs at the speed of 1333 MHz DDR (2666) is an XMP profile, not a JEDEC profile. If your BIOS does not support XMP(Extreme Memory Profiles) , then you will not be able to run this ram at 2666, only at 2400" |
aka Striko
Postovi: 1,733
Dođe to s godinama. ![]() |
