Staro 08.01.2006., 19:41   #1
celduce
celduce's Avatar
Lokacija: Dimension 8
Postovi: 785
Nokia 3310 Security Code
Zaista nisam znao gdje da ovo postam pa evo ovdje cu.Susjed ima nokiu 3310 i otisla mu stara sim kartica,kupio je novu i mob zahtjeva security code.Covjek je star i netreba mu bolji mob pa da ne kupuje bezveze,ako netko zna kako to otkljucati preko IMEi koda neka javi.Glupo mi je dat 50kn serviseru kad mob vrijedi 100kn.Inace probao sam default kodove ali neprihvaca.
celduce je offline   Reply With Quote
Staro 09.01.2006., 01:53   #2
ćiber_manija
CyberSky
ćiber_manija's Avatar
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Daj probaj 0000 ili 1234 ,ako neide neznam ti dalje pomoći!
Staro 09.01.2006., 13:39   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Originally posted by ćiber_manija
1234
Mislim da je kod 12345, pa probaj i to...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 09.01.2006., 14:04   #4
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Možda nešto odavdje pomogne.
http://snipurl.com/lerd
Staro 11.01.2006., 08:53   #5
miato
(°_°)
miato's Avatar
Postovi: 3,249
defaultni kod je 12345, no ako ga je netko (ili ti sam ) promjenio, neces moci nista napraviti napamet.
Trebat ce ti serijski kabel sa konektorom za tu tvoju nokiju. Svojedobno to je kostalo 70ak kn (pred 2-3 godine ) i program tipa Logomanager
