Staro 05.08.2019., 04:31   #241
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Lenovo HT10 TWS Earphone - Live Up to Expectations
The Lenovo HT10 is the newest true wireless earphones from Lenovo. While the design is more than stunning, it strives to impress with its features that perfectly cut the surrounding sound.
Product Features:
● Qualcomm aptX HD audio technology ensures that wireless Bluetooth enabled devices deliver high definition audio.
● Built-in Bluetooth 5.0 chip, the connection is faster and more stable.
● HiFi surge bass, rich in layers, the sound is more sensation.
● Intelligent noise reduction technology, improves signal-to-noise ratio and achieves lower background.
● 800mAh charging box, supports 48 hours of playing time, 200 hours of standby time.
● Side ear design, fits the ear canal, not easy to fall off.
● Double click any headset multi-function key can wake up the voice assistant.
● IPX5 waterproof, fearless sweat splash.
● Automatically turned on and paired after being taken out of the box.
● 4.5g light, light-hearted wearing experience.
● Supports iPhone/iPad/Huawei batter indicator, easy to know the power.
Using coupon code "LENOVO10" can get 10% discount: https://gearvita.com/lenovo-ht10-tws-earphone.html
Related products:
bluedio hi
sabbat e12
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 14.08.2019., 04:17   #242
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Remax TWS-5 Bluetooth Earphone - Enjoy A Quiet and Wonderful World of Selflessness
Remax TWS-5 adopts hidden form earplugs, which effectively solves the troublesome situation of wired headsets. It is comfortable to wear and does not cause pressure on the ear canal. At the same time, it closely fits the ear canal and is not easy to fall during travel, business and sports. It supports binaural calls, plus high-definition noise reduction, delivers excellent sound quality during calls, achieves effective daily communication.
Product Features:
● Graphene full-frequency 6mm driver unit provides three-frequency balanced sound performance.
● Bluetooth 5.0 connection, wide compatibility, faster data transfer and more stable signal.
● Intelligent touch sensing, easy identification of commands.
● 200mAh split magnetic charging box, easy to access.
● Automatically connect and pair when picked up, easy to use.
● Soft and ergonomic silicone earbuds, comfortable to wear.
Put on the Remax TWS-5, let the outside pressure, noise, and unhappiness leave behind and enjoy the good times that belong to you alone: https://gearvita.com/remax-tws-5-blu...-earphone.html
Related products:
redmi airdots
lenovo ht10
Staro 20.08.2019., 07:28   #243
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi FIIL T1 True Wireless Earphones - Every Time Listening Is An Enjoyment
In the era of true wireless headsets everywhere, Xiaomi FIIL T1 - the first true wireless sports earphones launched by FIIL, with the design concept of "faster, more stable and more free", was sold out as once it was listed, surpasses TWS headset products on the market with overwhelming advantage.
Product Features:
● After the first pairing, automatically connected to the phone once the charging box cover opened, no need of manual operation.
● Realtek low-power Bluetooth chip, combined with Bluetooth 5.0 technology, and applies the three-dimensional circuit LDS antenna technology used by the iPhone, wireless performance is improved in multiaspect.
● 6-hour battery life for both earbuds, 500mAh charging box provides an additional 3 full battery life for both earbuds.
● Hi-Res HD decoding chip, 6mm custom dynamic unit, delivers HiFi level sound quality.
● Single earbud is about 4g, with soft silicone earplugs and specially designed RotateSecure ear wings, comfortable to wear and does not fall off even when strenuous.
● Both earbuds support touch operation, light tap to achieve volume adjustment with left earbud and operation control with right earbud.
● IP65 sports grade waterproof, not afraid of rain wash, fearless sweat erosion.
● Binaural call, built-in noise reduction microphone, DSP technology eliminates environmental noise, achieves high-definition calls even in noisy environments.
The unexpected sound quality of FIIL T1 makes it not like a wireless headset that is dubbed "sports", there are few competitors at this price: https://gearvita.com/xiaomi-fiil-t1-...earphones.html
Related products:
lenovo ht10
sabbat e12
Staro 22.08.2019., 05:50   #244
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Somic SC2000BT Bluetooth Headphone - 38-hour Battery Life, Foldable Design, Dual Mode
The Somic SC2000BT is equipped with Bluetooth 5.0 version, which is twice the transmission speed of the 4.2LE version, and the transmission quality and anti-interference ability are greatly improved, to ensure smooth communication. Not only that, but the power consumption is optimized, resulting in a 38-hour long battery life.
Product Features:
● Built-in 40mm large-sized sound unit, ensures stereo and clear sound output in high fidelity.
● 600mAh battery offers up to 38 hours playtime in wireless mode.
● Equipped with a 3.5mm audio cable, allows a wired connection even when the battery is exhausted.
● Cozy protein leather ear cushions and headband pads, ultra soft and skin-friendly, comfortable to wear.
● All-inclusive large earmuffs, isolates the environmental noise.
● Bluetooth 5.0 chip, strong wireless compatiblity, the connection distance is up to 10m.
● Right buttons control hands-free call and music.
● Rotatable and foldable design for easy storage.
The Somic SC2000BT offers a wide range of color options, including black, twilight blue, and twilight red, the whole body is unified in color tone and presents a matte texture: https://gearvita.com/somic-sc2000bt-...headphone.html
You may also like:
edifier earphones
sabbat x12 pro
Staro 23.08.2019., 05:36   #245
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi LYXQEJ03JY Earphone - Dual Unit Acoustic Architecture, Hybrid Noise Reduction
Xiaomi LYXQEJ03JY collar earphone is the upgraded version of the Xiaomi LYXQEJ01JY necklace earphones, its configuration is higher than the previous two collar earphones. Similar to the previous models, this earphone also adopts the collar and wired design. The biggest difference is the dynamic ring + moving iron dual unit acoustic architecture and two noise reduction intensity adjustment.
Product Features:
● Soft TPE material, not easy to knot and entangle.
● Magnetic suction design, eliminates cumbersome storage steps.
● CSR 8645 Bluetooth chip, supports ACC advanced audio encoding technology and apt-X lossless Bluetooth output, complete audio frequency bandwidth and high fidelity performance.
● Dynamic ring + moving iron dual unit, three-band equalization.
● Hybrid digital noise reduction, strong noise cancellation.
● Sony LDAC support, high-definition sound quality.
● Up to 20 hours long battery life, long-lasting listening.
Coupon code "MISALE10" for 10% discount: https://gearvita.com/xiaomi-lyxqej03...-earphone.html
Related products:
mi airdots
a6 tws
Staro 21.08.2020., 19:25   #246
2 die 4
2 die 4's Avatar
Postovi: 2,241
Danas sam otišao pogledati kaj ima na webu i NOD32 odmah blokirao pristup da je web zaražen nekim trojancem.
Threat found
This web page contains potentially dangerous content.
Threat: JS/Spy.Banker.FX trojan.
Samo upozorenje da se netko ne zaleti.
RedGreenBlue
