Staro 05.07.2019., 11:59   #44851
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Generalno je posljednjih godina design automobila otišao kvragu (kič umjesto pravog design-a), ali ovo što BMW radi je stvarno totalno sranje.
A bili su fino krenuli sa i8/i2 pričom...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 05.07.2019., 12:53   #44852
Garro
Postovi: 2,390
i3 je vrhunac sranja od automobilskog “dizajna”.
Recimo, Lewisov F30 je meni osobno pun pogodak, to-je-to (prednji bočni dio, kako su svjetla uklopljena, je remek djelo), jedino kako bi mogao biti bolji je da je F31 u mineralgrau boji.. G20 je iznutra super, ali izvana ne nadmašuje F30.
Staro 05.07.2019., 13:46   #44853
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Bmw serije 2 - najnovija generacija treša sa ovim bočnim znakovima. Jao meni.
https://photos.app.goo.gl/5QkLgtEQh36JGpB98
- Barney Stinson
Staro 05.07.2019., 13:50   #44854
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,400
izgleda ko krapina tuning, bez uvrede
Staro 05.07.2019., 13:53   #44855
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,299
Zato trash ? Pa to nije ni prvi ni zadnji BMW koji je imao/ce imati znak na bokovima. I u povijesti je bilo modela sa bocnim znakom.
Staro 05.07.2019., 14:06   #44856
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Garro Pregled postova
To da.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 05.07.2019., 14:54   #44857
zgmmax
zgmmax's Avatar
Postovi: 1,673
Ta i3 ima 170ks
Al je bas ruzan. cak je ruzniji i od E60 i E65
Staro 05.07.2019., 14:55   #44858
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,178
Serija 2 tj X2 baš dobro izgleda na cesti, ljepši od X1 5 puta. Ovaj novi 3er je ozbiljan auto fkt.
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro)
DiRT je offline   Reply With Quote
Staro 05.07.2019., 15:48   #44859
Colop
Datum registracije: Sep 2011
Postovi: 1,145
Mineralgrau boja se sviđa samo onome tko je ne mora održavati
Ovaj x2 mi super izgleda , kao što je netko napisao bolje od X1 i X3.
Gledao sam ga neki dan u M opremi na parkingu i baš mi je dobar.
Od ovih ostalih modela X5 mi je lijep, ali to su već preveliki novci.
Poslano sa mog RNE-L21 koristeći Tapatalk
Staro 05.07.2019., 15:49   #44860
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 424
mene na onu ogavnu guzicu BMW-a GT
Bitno je da ima dva ogromna auspuha kao da je ispod haube 1500KS.
I lako moguce je i da su oba fejk auspuha...
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 05.07.2019., 15:52   #44861
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,299
Autor Tumor Pregled postova
Nisu fejk, za sad se BMW suszdrzava od tog trebda Fake maskica koje glume asupuhe a onda auspuh ispod/iza branika pici negdje sasvim u pod i slicno.
Staro 05.07.2019., 16:03   #44862
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,400
nadam se da će naprijed svjetleći bubrezi imat RGB opciju
Staro 05.07.2019., 16:10   #44863
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Ajde, kod trice je to još skoro neprimjetno. Ostatak ergele ... Kroz par godina ćemo ovo vidjeti na cesti ako se trend nastavi:
Staro 05.07.2019., 16:33   #44864
Tumor
Tumor's Avatar
Postovi: 424
Razer Synapse 4.0 release notes:
- added support for BMW kidney RGB ilghting
Staro 05.07.2019., 17:09   #44865
danijel_b
danijel_b's Avatar
Datum registracije: Jun 2004
Lokacija: Oldenburg
Postovi: 497
Evo jedna alternativa
Gesendet von meinem LM-V405 mit Tapatalk
danijel_b je offline   Reply With Quote
Staro 05.07.2019., 17:11   #44866
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Autor Lewis Pregled postova
Evo par fotki sa danasnje kavice i test drivea koleginog G20
Koji paket opreme i motor ima taj G20? Izgleda predobro. Pogotovo dupli i pravi izlazi ispusnih plinova, s rasporedom po jednog na svakoj polovici buta (:
nvm, vidim da si postao da je 330i. steta to je to postao 4cil motor.
Bas me zanima kakav ce bit 330e s 4cil + e-motorom sto se tice L/km ( mijesano )
Staro 05.07.2019., 17:36   #44867
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Naletio jučer na Teslu Model 3 na parkingu lokalnog dućana.
Sasvim pristojno izgleda i uklapa se gabaritima među tipične male limuzine na EU tržištu, dok ne pogledaš unutra pa vidiš onu tepsiju posred auta. To čudo od ekrana više smeta nego što je od koristi. Nakaradno izgleda, pogotovo jer su sve ostale stvari u autu dobro odmjerene.
Uglavnom, daleko bolje izgleda uživo nego na slikama
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
Staro 05.07.2019., 17:38   #44868
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
330i
4cilindra
Cupaj kablove, gasi internet, dosta je
Staro 05.07.2019., 17:55   #44869
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Nemoj odmah na most...
530i ima također 4
330d i 530d imaju 6
340i i 540i imaju 6, uz 100+ konja više
Ako si očekivao da je serija 7 imuna na 4 cilindra...evo ti po prvi put u povijesti, 4 cilindra u 730i
Živjeli dizeli
LCD: BENQ PD3200Q
Zadnje izmijenjeno od: 1v@n. 05.07.2019. u 18:01.
Staro 05.07.2019., 18:00   #44870
Postovi: 33,995
Opoziv Mazge 3 u AUS i USA. Mogla bi i EU uskoro doći na red
https://www.index.hr/vijesti/clanak/...u/2098585.aspx
Staro 05.07.2019., 18:20   #44871
Garro
Postovi: 2,390
Autor Colop Pregled postova
Čuj, vozim VW urbangrey boje, dosta je blizu mineralgrau i to je jedna od najzahvalnijih boja za održavanje.
A općenito X gamu neću komentirati, nema mi lijepog auta osim možda X1. S druge strane, klasična gama mi je dobro pogođena, posebno 4 GC, trica i petica.
Ali što više gledam sveto njemačko trojstvo, Volvo mi je sve draži.
Staro 05.07.2019., 20:13   #44872
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
Autor 1v@n Pregled postova
530i ima također 4
330d i 530d imaju 6
Živjeli dizeli
jebo takav bmw, ta cijela autoindustrija se izgubila u tim nomenklaturama.
tako audi sad stavlja one retardacije, 30, 40, 50 itd i niko ziv ne zna koji je motor unutra.
Staro 05.07.2019., 20:32   #44873
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,007
Pa ko da ti moraš znat, bitno da vlasnik zna.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 05.07.2019., 22:09   #44874
Postovi: 10,113
Kako to mislis "ne mora selo znati sto imas pod haubom"
Staro 05.07.2019., 22:10   #44875
domy_os
domy_os's Avatar
Postovi: 18,871
Mora znati za njegovo dobro.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 05.07.2019., 23:00   #44876
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
meni nije uocpe jasno kako se moglo dozvolit touch ekrane u autu
tipke, gumbovi, botuni, kako god ih nazvali, su superiornijma i sigurnijima za koristenje
pogotovo sto se bez gledanja moze upravaljati komandama
Zadnje izmijenjeno od: pci_e3x. 05.07.2019. u 23:05.
Staro 05.07.2019., 23:07   #44877
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,299
Bitno da su smislili da od nagodinu ce svi elektricni auti ce morati imati neki generator zvuka/buke jer su "pre tihi" pa ih pjesaci ne cuju. a to sto vozac tipka po tabletu 52" incha to nema veze to je sigurno .
Vjerojatno po obicaju samo EU zakon - brinu se u EU parlamentu i koliki nam ususivaci smiju biti snage itd. itd...
Staro 05.07.2019., 23:44   #44878
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,103
Baš s curom komentiram te električne aute neki dan i tu nebulozu s generiranjem zvuka.
Bila je u Japanu i kaže da je to što ne proizvode zvuk dosta smanjilo buku po velikim gradovima i da su postali puno ugodniji za život. Naravno, prometna kultura i vozača i pješaka je na daleko višoj razini.
Nedavno sam se preselio iz kuće, koja je u ulici paralelno uz glavnu cestu... u stan, u istom kvartu, ali koji je odmah na glavnoj cesti i nevjerojatno je koliko mi smeta buka vozila. Radnim danom me ne diže više budilica nego buka izvana, ako je i samo jedan prozor u bilo kojoj poziciji osim zatvorenog.
Sad više cijenim tišinu električnih auta i nadam se da neće biti ništa od tih generatora zvuka, pa ako treba prirodna selekcija rješavati pješake koji bulje u mobitele, so be it.
LCD: BENQ PD3200Q
Staro 05.07.2019., 23:50   #44879
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,299
Mislim da je to gotova stvar od 1.7. svi koji se proizvode/prodaju u EU moraju imati taj generaztor buke/zvuka.
https://www.bug.hr/propisi/od-danas-...iti-buku-10246
Staro 06.07.2019., 00:09   #44880
Postovi: 10,113
To mi je uvijek bilo fascinantno... 30 godina zivio i odrastao uz glavnu ulicu i buku auta. Onih 10 dana godisnje bez buke kad odem na selo, imam problem sa spavanjem zbog previse tisine. Znaci cijelu noc me ne uspiju probuditi ovi sto turiraju cadjare po ulici, ali zato me vrazja macka ulicarka ili susjedov pas koji par puta zalaje redovito scimaju
