Staro 25.05.2019., 17:35   #4321
Postovi: 8,214
Windows 10 May 2019 Update Not Installing on Some AMD Systems
The Windows 10 May 2019 Update does not install on systems powered by AMD Ryzen or AMD Ryzen Threadripper processors with AMD RAID drivers prior to 9.2.0.105 and configured in SATA or NVMe RAID mode. This happens because the AMD RAID drivers on computers with AMD Ryzen or AMD Ryzen Threadripper processors are incompatible with the Windows 10 May 2019 update released three days ago, on May 21 To fix this issue and install/update AMD systems affected by this issue, users have to update the AMD RAID drivers to a version 9.2.0.105 or later which allows the update to be installed even when the drivers are configured in SATA or NVMe RAID mode.
Izvor: BleepingComputer
Staro 28.05.2019., 01:04   #4322
Hombre
Datum registracije: Jan 2011
Lokacija: Ploče
Postovi: 283
Meni piše 1809 64bit bez obzira što svaki dan dignem novu AV definiciju.
Vjerovatno će nas na jugu novosti posjetiti kasnije nego razvijeni sjever
Hombre je offline   Reply With Quote
Staro 28.05.2019., 01:07   #4323
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,279
Post #4317 ako hoces ubrzat
Staro 29.05.2019., 18:19   #4324
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
help please, zna li netko kojim alatom da kloniram m.2 nvme disk? nadogradujem sestrin laptop sa 250 na 512gb i ne da mi se opet reinstalirati sve jer sam to radio prosli tjedan i sad bi volio samo klonirati ali acronis true image 2019 ne podrzava m.2 nvme diskove
znaci treba mi moci napraviti image cijelog nvme diska na externi i moci uspjesno sa externog vratiti na novi nvme
Staro 29.05.2019., 18:21   #4325
nino
nino's Avatar
Postovi: 12,612
Nisam nikad koristio neki drugi soft.
Hdcone by Miray.
Ona ovca u logu 😀
Sent from my CLT-L29 using Tapatalk
Staro 29.05.2019., 18:27   #4326
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
odlicno, tnx...jos jedno pitanje? free verzija sluzi svrsi ili moram uzeti placenu verziju?
Staro 29.05.2019., 19:32   #4327
Postovi: 23,516
M.2 u toj varijanti zna malo zezati,
koju tj. kakvu varijantu true image 2019 si koristio / probao ?
Onu boot i Linux baziranu ili neku drugu ?
Alternativa je da "nađeš" WinPE (baziran na W10 smetju) + true image 2018 ili 2019 "plugin", tada stvar radi jer W10 ima drajver za M.2.
Ako hoćeš, možeš i sam to "iskukićati" samo treba nešto naučiti / savladati.
Staro 29.05.2019., 19:51   #4328
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Da, boot i linux verziju...probat cu veceras sa hdclone, vidim da imaju m.2 support i nadam se da ce upaliti
Staro 29.05.2019., 20:53   #4329
Roso
Roso's Avatar
Postovi: 698
Nisam jos presao na desetku, sli se ne moze iskljuciti update kompletno?
Roso je offline   Reply With Quote
Staro 29.05.2019., 21:09   #4330
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
Moze, upises u search services, nades windows update i disable
Staro 29.05.2019., 21:14   #4331
Roso
Roso's Avatar
Postovi: 698
Pa u čemu je onda problem
Staro 29.05.2019., 21:40   #4332
Postovi: 23,516
Šta se "čudnovato" samo od sebe ponovo upali ...
Staro 29.05.2019., 21:47   #4333
Postovi: 8,212
Postoji task koji ga okine.
Što se tiče pitanja za kloniranje, ja sam radio s acronisom xy puta, nikad problema.
Staro 29.05.2019., 22:20   #4334
domy_os
domy_os's Avatar
Postovi: 18,847
Također, Acronis True Image sve klonira, samo je bitno da je up to date. Novije verzije dolaze i u WinPE varijanti, ali nude još i staru Linux.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 29.05.2019., 22:32   #4335
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,733
meni nece, digao sa sticka acronis 2019 i ne vidi m.2, sve druge do sad sam bez problema
no rijesio sam sa hdclone 9 pro, jedino sto mi je izbacio gresku za jednu od onih windows particija (ne znam tocno koju ali imam onu od 500mb, onu od 100mb i C disk) ali sve radi tako da je dobro, ako pocne sta zezati budem reinstall napravio ali za sad je to to
Staro 30.05.2019., 17:39   #4336
Hombre
Lokacija: Ploče
Postovi: 283
Hajde da i ja ponovo nešto upitam. (Prava sam niškorist jer samo pitam, a ništa ne objašnjavam :-)
Malo sam se obnovio. Ono, novi refubrished kompjuter, isto tako 23" monitor, jedan disk od 6TB da mi smeće koje sakupljam nije na pet različiti diskova od 1TB pa ne znam što se gdje nalazi...
Uglavnom sve je u redi i sve dobro radi, osim onog nevoljnog 38591 umjesto mog imena kao usera u Win 10 ali i tu sam se već ohladio, a došli su i novi problemi koje treba odmah rješavati inače gubim novac i takooooo.
Uglavnom. Stručno pitanje za stvar koja se nekada u DOSu rješavala trenutno ali je pojavom prozora postala teška ili slabo moguća. Imam jedan program koji je pisan u Pythonu i kojeg sam jedan jedini put u životu uspio instalirati dok je sve ostalo prošlo neuspješno ili s porukom da trebam (negdje gdje ne znam gdje) dodati path koji će inicijalnu file dovesti do Pythona da bi program proradio. Radi se o programu za posebne namjene povezanim sa softwerski definiranim radiom i analizatorom frekventnog spektra koji je potreban debilima kao ja i koji se time bave.
Je li moguće, i naravno, ako jeste kako iz bivše kante koja na podu kupi prašinu nekako izvući taj program i prebaciti ga u novi kompjukter jer mi zbilja zdravlje onemogućuje da se vraćam na nešto što je još gore od DOSa.
Staro 30.05.2019., 18:56   #4337
Postovi: 23,516
Novi winsi (pogotovo mislim na W10 smetje) mogli bi te fino izmajmunirati ako misliš koristiti stari program "iz DOS - a" + je tu još i Python.
Možda bi bilo bolje koristiti staru kantu samo za tu namjenu.
Ono šta te mučilo tj. prijavljivalo grešku (da ne može pronaći "put" do Python - a je da nisi dodao "put" (čitaj Path) do njega.
Recimo da je Python "instaliran" u "C:\Python" folderu.
Otvoriš CMD (nemoj da netko pita šta je to), otipkaš SET + Enter,
između ostalog šta će se prikazati tebe interesira parametar koji se zove "Path".
Sad da bi dodao "put" do gore navedenog primjera trebaš ukucati:
Code:
PATH C:\Python;%PATH%
Na taj način ćeš dodati "put" do Python kompajlera i kada se ne nalaziš u tom folderu.
Da bi vidio šta si napravio možeš ponoviti SET komandu.
PS: Ovo bi bilo za 2. razred računalne osnovne škole
Neext ...
Staro 30.05.2019., 20:54   #4338
Hombre
Lokacija: Ploče
Postovi: 283
Ma nije program iz DOSa nego Pyhton što meni izgleda još gore.
Obzirom da taj program ne koristim tako često ipak ga se ne bih htio odreći pa sam pitao jer mi kanta samo smeta i trebam je prodati, a u ovoj selendri je teško naći nekoga tko bi znao napisati neki batch. Napisao sam ih mnogo ali sad jednostavno ne mogu.
Ono za drugi osnovne ne mogu razumjeti jer mi mozak odbija suradnju takvog oblika. Obzirom da svaki čovjek vidi stvari sa svog gledišta barem pokušaj razumjeti da sam od tri prošle godine jednu proveo po specijaliziranim bolnicama za psihijatrijske bolesti i to ne u komadu nego povremeno, na kamate, s tim da mi je rekord u jednoj 5 mjeseci, a od one dvije najmanje jednu sam preležao u krevetu bez ikakve volje za bilo čine uključujući žene, kocku, drogu, novac tj. svime za čime obični ljudi pate i na kraju ono do čega mi uopće nije bilo stalo, a to je život i bio bih zahvalan onome tko bi me došao ubiti. Naravno da sam promijenio mišljenje jer sam u stanju uključiti kompjuter i raditi na njemu ali još uvek se ponekad dogodi da ne mogu jesti i guram hranu u usta i u sebi govorim "moraš jesti jer ćeš umrijeti", a to da umrem mi se trenutno ipak ne sviđa ali mozak neke stvari jednostavno ne želi procesirati bez obzira bile važne ili nevažne tako da taj path jednostavno ne mogu napisati bez obzira koliko htio. Da ze netko zadesi da to ne zna rekao bih mu da je kreten i sredio to za minutu ali kada se radi o meni nisam u stanju (ne reći da sam kreten nego to srediti). Ono što me prošlih dana malo razveselilo je da me zvala prijateljica (baba od 65 godina) da je došao serviser i sredio njezin kompjuter ali da nije u redu jer kad ga isključi ostane svijetlit lampica i ako klinkne na neku od tipki kompjuter je ready za par sekunda i odmah mi je sinulo da je serviser malo dirao žice ali je ona spomenula da ga uredno isključi tako da klikne na sleep..... pa sam je pitao ima li slučajno i izbornik Shutdown na što je ona rekla da ima. Nakon toga je sve bilo mnogo lakše!!!!!!!!
U nekoliko zadnjih dana sam napravio valjda 20 cancel za kojekakve pay site što u pravilu nije teško ali za neke jednostavno ne znaš tko im je probiller jer su lijeni poslati confirmation email, a čak ako i znaš tko je probiller ima neke svoje pod podružnice i trebaju ti sati da u nekoj od njih nađeš taj site i događalo mi se da se čudim zašto je stolna lampa nekako slaba kad ono vani već sunce, a nema ni pola sata da je bilo večer kad sam sjeo pred monitor. I da, stavio sam da mi u desnom donjem kutu ekrana stoji koju verziju Windowsa imam da znam kad će pisati 1905.
O da. Disk koji sam dobio po naljepnici drastično odstupa od onog kako izgleda na fotografiji na web shopu gdje sam ga kupio pa sam malo aktivirao support od WDa pa su prvo nešto muljali ali sam ja ufotkao dva diska jedan pored drugog (imam jedan od 3TB koji je isti kao onaj na njihovom siteu samo što je brojka za TB druga) i iz supporta su mi objasnili da je onaj od 3TB normalni disk dok je ovaj od 6TB koji sam kupio u stvari OEM koji se ne smije prodavati kkrajnjem kupcu, da na njega nemam garanciju WDa i neka s firmom koja mi je to prodala sredim da mi ga zamijene. Nakon što sam poslao mail u kojem sam copy/paste što su mi iz WD poslali javila mi se ženska iz te firme da ne vidi u čemu je problem jer je to samo nova naljepnica dok su tehnički podaci isti
Dođe mi tako ponekad da uzmem bombu ili automatsku pušku i neke stvari sredim brzo i efikasno
Staro 31.05.2019., 12:56   #4339
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,622
Naporno citat u svakom postu od @nikky "Win 10 smece". Evo ja pisem; Win 10 je najbolji. Eto 🙂
Poslano sa Sony XZ3
virty je offline   Reply With Quote
Staro 31.05.2019., 12:59   #4340
Postovi: 23,516
Eto pa nije, sve super, sve radi (samo) ... bez nervoze i uživajte
Staro 02.06.2019., 12:33   #4341
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Od zadnjeg apdejta mi je RAM poblesavio.
https://i.imgur.com/gwQbSED.png
A CPU-z pokazuje 32 Gb
https://i.imgur.com/FBANTAW.png
HWinfo također pokazuje svih 32 Gb
https://i.imgur.com/dbqZM9h.png
Zasto mi windows pokazuje samo 24?
Staro 04.06.2019., 22:21   #4342
Hombre
Lokacija: Ploče
Postovi: 283
A večeras kad sam otišao pogledati kako mi fino skine svaki update Defendera kao iznenađenje se pojavio tekst da je službeno dostupna verzija 1905 i kad budem spreman (hoću) da mogu napraviti update. Inače nisam pobornik zavjera, moje ime, prezime, email, broj mobilnog telefona, broj kreditne kartice (WEB prepaid) i slično nalaze se širom svijeta jer bez toga čovjek neke stvari jednostavno ne može raditi što sam najbolje iskusio na vlastitoj koži kada sam u Pay Pal dao broj fiksnog telefona koji je davno isključen pa kad sam se zbog nečeg u kratkom roku ulogirao nekoliko puta, platio nekoliko sitnih stvari aktivirala se sigurnosna zaštita i kod slijedećeg logiranja me pitao za broj telefona da pošalje lozinku koju trebam ukucati da bih uopće mogao pristupiti mom računu na Pay Pal. Pukom srećom da postoji opcija "Promijenio sam broj telefona" pa sam ukucao svoj mobilni, a nakon što sam pritisnuo Enter za svega par sekunda iz mog mobitela začulo se Morzeovom abecedom SMS u kojem je bio broj da mogu ući na svoj račun.
U (s)vezi s tim sam potpuno imun na to hoće li netko skupljati podatke koje stranice posjećujem, hoću li na marginama monitora imati reklame vezane uz te stranice jer ću reklame svakako imati itd.
Intersira me vrijedi li instalirati update jer vidim da ima sandboxie što mi se sviđa ili da sačekam malo da odleži da se pojavi prvi njegov update na osnovu dojava bijesnih korisnika iako nisam baš power user i na to kako prozori izgledaju i kako se ponašaju ne obraćam previše pozornosti (osim onog podlog username 38591 koji je moju osobnost sveo na nekoliko brojeva iako smo ipak samo brojevi :-)
Staro 04.06.2019., 22:23   #4343
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,279
ako je 1905 neznam što napraviti, ali za 1903 ako si home user dajem zeleno svjetlo
Staro 05.06.2019., 04:06   #4344
Hombre
Lokacija: Ploče
Postovi: 283
Jemaš pravo radi se o 1903.
Još netko?
Staro 05.06.2019., 08:24   #4345
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,544
Autor virty Pregled postova
Poslano sa Sony XZ3
Nikky je power user, to je hendikep.
W10 je za "Average Joe" scenarij dušu dao.
Moguće je BESPLATNO produžiti W10 sigurnosne nadogradnje do 2028!
kopija je online   Reply With Quote
Staro 05.06.2019., 22:11   #4346
Hombre
Lokacija: Ploče
Postovi: 283
Od maloprije sam ponosni korisnik verzije 1903.
Nakon što sam, za svaki slučaj napravio Backup (na SSD traje manje od 4min) odobrio sam Update pa se kompjuter malo razmišljao i počeo DL koji je trajao otprlike 2min. Prvo je brzina DLa skočila na 64MB/s da bi se kasnije ustalila od 35-40MB/s što znači da čak i serveri svemoćnog Microsofta imaju respekt prema 500Mb/s optičkoj liniji i njenom kapacitetu gutanja dok je samo instaliranje trajalo nešto duže. Uglavnom sam, nakon instalacije retartao računalo i nakon toga nikakvi mali zeleni nisu iskočili iz monitora iako sam promjene odmah opazio jer ima default opciju za odgađanje updatea, kad sam otišao pod Security option rekao mi je da Malwarebyte Pro radi uredno i morao sam se malo okrenuti pošto Defender treba uključiti, pokrenuo scan, pokrenuo programe koji svi uredno rade i jedino još da vidim jer mi se po slobodnom prostoru na disku čini da je napravio Windows.old da to bacim u smeće i to bi za sada bilo sve.
Ovo su prvi utisci onako, nabrzaka.
Staro 05.06.2019., 22:21   #4347
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,050
Autor kopija Pregled postova
Windows 10 je i za power usere i za prosječnog korisnika definitivno bolji odabir od Win8, i pogotovo desetljeće starog Win7.
A "smetje" je onima koji vjerojatno nemaju volje naučiti koristiti OS i nove stvari koje nudi i koje su korisne. Možda je nedostatak vremena, možda ignorantnost, a možda i godine
A nekako sumnjam da govore da je Android/iOS/macOS/Linux isto "smetje" zbog čitavog seta problema i nedostataka... ali shvaćam, frustracije
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 05.06.2019. u 22:27.
Staro 06.06.2019., 00:12   #4348
Postovi: 23,516
Ako je tebi uredu da os na tvom stroju sam radi šta hoće i kad hoće, meni nije i neće mi nikad biti.
Normalno bi bilo da pita kad i šta a ne da radi sam na silu.
Eto su neki dobili novi bulid,
jesu li dobili barem skraćeni changelog ?
Jesu malo morgen.
A ti sad traži šta je promjenjeno, premješteno, ugašeno / upaljeno ...
Dakle, gore navedeno skroz krivi "razlozi".
Staro 06.06.2019., 05:59   #4349
Postovi: 10,024
Budem ga instalirao samo da vidim jesu li popravili spajanje na wifi nakon budjenja iz hibernacije. Zadnji major update mi ne spoji komp automatski na wifi kad probudim komp pa moram rucno kliktati.
Iako mi je wifi definiran kao metered connection (tako nekako), to nije sprijecilo winse da potegnu dl. Donekle mi je jasno zasto na poslu i dalje koriste 7icu (jedna malo jaca firma na globalnoj razini).
Staro 06.06.2019., 08:47   #4350
Postovi: 8,212
Koriste sedmicu jer im je tlaka radit upgrade i jer je to projekt koji dođe xyz novaca i treba xyzw vremena a ne zato što to ne žele.
Bar je u corp okruženju puno lakše hendlat smeća iz windowsa.
Autor Nikky Pregled postova
Jesu malo morgen.
Instaliraj linux!
