Staro 15.05.2019., 07:53   #5491
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
It’s crucial to first point out that this is an engineering sample, and one that we have in fact seen several months back. Although this time it’s been paired with a new motherboard, code named AMD Qogir-MTS. It features relatively low clock speed, as expected for an engineering sample. Running at a 3.4 GHz base clock and a 3.7 GHz Turbo. The production units are expected to operate at significantly higher clock speeds than that.
The CPU has been paired with very modest 1600 MHz DDR4 memory and a 500GB HDD. Although, that’s not really the interesting part. The more interesting bit is how this chip compares to AMD’s existing 12 core Ryzen Threadripper 1920X. And it’s actually slightly faster, especially at floating point operations, despite having a slightly lower clock speed and significantly lower memory bandwidth.
This clearly indicates that Zen 2 brings noticeable IPC improvements to the table, enabling the new chips to deliver better performance per clock than their predecessors. This, combined with 7nm’s ability to deliver even higher clock speeds than current 14nm fabrication technology means that we can expect the Ryzen 3000 series to deliver nice single threaded and multi-threaded performance improvements.
https://wccftech.com/amd-12-core-zen...dripper-1920x/
Staro 15.05.2019., 22:05   #5492
trpi
bome nikada nisam iscekivao hardveraj niti se rajcao ali ovo fakat zelim vidjeti sto ce izbaciti koliko ce max jezgri ici na am4 i na koje ploce.
Staro 15.05.2019., 22:10   #5493
Autor trpi Pregled postova
Haha, ipak optimizam prevladao u tebe a bio si malko pesimističan, čak si mislio kao maXonja sve prodat pa preć u plavi tabor
Na kraju ćeš se moći hvaliti sa 4.7+GHz all core bez prelaska na lntel... svesrdno se nadam
Sent from my SM-G965F using Tapatalk
Staro 15.05.2019., 22:48   #5494
trpi
valja i cijene novih vidjeti, ili ce prvim ryzenima skroz potonuti cijene sto nema bas smisla - gdje ce trenutni flagship 2500kn 8core 4ghz 2700x ako novi ryzen 5 bude 8core 4.7ghz? ili koliko ce kostati taj novi ryzen 5.
ako budu uopce bumpali core count. mozda samo frekvencije dignu. ako ce dici oboje i cijene budu ok(za sto bi se morali pozdraviti sa daljnjom prodajom prve generacije) divotica
Staro 16.05.2019., 11:41   #5495
Manuel Calavera
Postovi: 14,584
Potvrđeno još jednom i službeno da sve osim threadrippera (ryzen, epyc, navi) dolazi u Q3 - znači od 7 do kraja 9 mjeseca...
Staro 16.05.2019., 11:46   #5496
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,144
wtf. sta nije receno da ce se krajem maja sve znati, cjene i sve ?
Staro 16.05.2019., 11:59   #5497
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Saznati da, release su uvujek spominjao 7. mjesec
Sent from my ONEPLUS A6013 using Tapatalk
Staro 16.05.2019., 14:32   #5498
Ako sam dobro shvatio, 27.05 bi trebali saznati:
- release date
- točan naziv SKUova
- sve specifikacije (core count, clock, boost...)
Staro 16.05.2019., 16:08   #5499
Manuel Calavera
Postovi: 14,584
Nije nikad službeno rečeno što će točno reći, no zna se da će sigurno biti puno više od onoga u prvom mjesecu. Osobno očekujem ovo što je Brko spomenio, praktično skoro sve info osim samog relesea...
Nejasno je što će biti sa Navijem. U PR najavi se spominjao Navi i za 27.05. no sad ima i taj neki "gaming" event 10/11.06. u kojem se očekuje sigurno Navi. Svejedno se nadam da će bar nešto reći/pokazati o istoj 27.05, jer što im znače ta dva tjedna kasnije... Što imaju imaju, ne mogu ništa promjeniti u tom roku
Staro 17.05.2019., 15:37   #5500
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
E3 2019 "Next Horizon Gaming" (Dr. Lisa Su) - možda će ovdje više pričati o Navi GPU?
Staro 17.05.2019., 17:49   #5501
Ma lako za gaming. To ionako znamo za Navi neće prebit ni top Pascale a kamoli Turinge.
Ryzen zveri su bitne
Staro 17.05.2019., 21:18   #5502
Postovi: 8,219
Skužili su HP-ovci kaj se sprema, pa brže-bolje kupili Cray, dok se još da kupiti za relativno pristojne nofce.
Staro 18.05.2019., 10:35   #5503
Manuel Calavera
Postovi: 14,584
Staro 19.05.2019., 21:51   #5504
Manuel Calavera
Postovi: 14,584
https://videocardz.com/80714/msi-mpg...on-gaming-plus
Bome svaka dosad leakana X570 ima vent na čipsetu
Staro 19.05.2019., 21:57   #5505
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Bio je video neki di je reko lik 90% da ce sve imat :/
Buildzoid
Bez potpisa.
Staro 19.05.2019., 22:06   #5506
sti
Lokacija: Lawl
Postovi: 1,374
Vent se vjerojatno neće paliti dok god je bandwidth dovoljno nizak, odnosno u 99% slučajeva, bar dok se ne pojave PCIE 4 grafe.
Ovo je garant AMD uvjetovao vendorima, da ne bi ugrađivali šrot pasivce na chipset i potencijalno ugrožavali performanse prilikom najvećeg opterećenja.
sti je online   Reply With Quote
Staro 19.05.2019., 22:17   #5507
Manuel Calavera
Postovi: 14,584
Autor sti Pregled postova
Baš sam to htio napisati. AMD radi ove čipsete, a ne As Media, vjerojatno su uvjetovali kao must iz nekog razloga. Vjerovatno ništa posebno ne košta više
Staro 20.05.2019., 11:20   #5508
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,260
Ajoj...opet se vraćamo u neka davna vremena kad su ti nekvalitetni vrištavci hladili NorthBridge
Iskreno se nadam se da će to biti neki pošteni ventovi koji će jedva vrtit, nisam mislio da će nam opet uz sve na pločama biti važno i koliko su glasne.
Slobodno me dodajte na PSN
Staro 20.05.2019., 11:40   #5509
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Pa ja ne mogu više, ko da dolazak boga čekam, a ne procesora
Zadnjih nekoliko dana gledam što ću sve ubaciti u novi komp (i lovim popuste), ali u pm kad mi neke stvari o maticnoj ovise, a ona o procesorima
xGAME je offline   Reply With Quote
Staro 20.05.2019., 12:35   #5510
Pa kupi sve osim matične i proca. Tog barem bude ko salate i po OK cijenama...
Staro 20.05.2019., 14:39   #5511
Gigi1
Postovi: 2,138
Polako stasham hw, imala je alza black friday popuste pred koji dan, uzeo 32gb kit za 170eur i patriotov 3k+ r/w ssd za 52eur
Staro 20.05.2019., 21:16   #5512
Postovi: 8,219
AMD X570 chipset blockdiagram - PCIe 4.0 All The Way
Zlobnici bi rekli da je ovo još samo jedan u nizu dokaza se AMD grije.
Staro 21.05.2019., 07:24   #5513
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 476
Koliko ce uopce trebati da dode novi BIOS za x370 ploce, ne znam kako je bilo sa x470 plocama. Jer razmisljao sam samo novi CPU uzeti i zamjeniti.
Silthrax je offline   Reply With Quote
Staro 21.05.2019., 07:32   #5514
Ne kužim pitanje
Kad je izašao Ryzen 2000 serijal, A320/B350/X370 ploče su na svojim stranicama imale za skinuti BIOS koji podržava nove procesore, i to koji tjedan prije launcha.
B450/X470 su podržavale Ryzen 2000 out of box.
Sad će X570 podržavati out of box seriju 3000, a ove starije će trebati flešati sa postojećim procesorom prije trpanja R3000 na ploču.
Staro 21.05.2019., 07:40   #5515
Manuel Calavera
Postovi: 14,584
Autor Silthrax Pregled postova
Moja ploča još od 3 mjeseca ima 3 biosa za "upcoming processors"
Staro 21.05.2019., 08:41   #5516
Silthrax
Silthrax's Avatar
Lokacija: Gračac
Postovi: 476
Ovo je zadnje za moju plocu bilo: Support new Athlon 2xxGE series APU. I to od 2019/4/24. To je bio update na AGESA 0.0.7.2. a izgleda da je AGESA 0.0.7.2.a za Ryzen 3000 seriju. A prošle godine su u drugom mjesecu vec update stavili za nove CPU.
E da @Manuel gledao sam ti za tvoju ploću tek 10. 5. ti je dosao bio sa 0.0.7.2a. znaci ovo ranije sto ti je bilo "upcoming processors" sa AGESA 0.0.7.2. je za Athlon 2xxGE kao i kod mene za moju.
Staro 21.05.2019., 14:24   #5517
Litra
Litra's Avatar
Lokacija: Zagreb, Dubrava
Postovi: 502
Zadnje izmijenjeno od: Litra. 21.05.2019. u 14:30.
Litra je offline   Reply With Quote
Staro 21.05.2019., 15:17   #5518
MadManBD
MadManBD's Avatar
Postovi: 922
Autor Litra Pregled postova
5ghz 12 core
Staro 21.05.2019., 16:11   #5519
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Pretpostavljam da je svima jasno da je to maksimalan single-core turbo, s all-core turbom negdje na pola puta gledajući base clock
Mogao bi se OCati do 5GHz though.
Staro 21.05.2019., 16:20   #5520
Gigi1
Postovi: 2,138
bit ce k***enja po forumima na cinebenchu
overclocking ce opet postati zabavan(jer ce dva faktora utjecati-IO die i same jezgre), a bez delidanja i gubljena garancije, vjerujem da ce biti i koja spržena wannabe full 12+phase vrm maticna xD
