Staro 02.04.2019., 13:45   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
PCI Device/USB Controller, Unknown device - missing driver
Nakon instalacije RTX 2080Ti, Sesonic Focus+ Gold 750W PSU i najnoviji BIOS za Z170-A, na skroz stabilnom stroju do sad, Device Manager javlja da nedostaju sl. driveri:
PCI Device
Universal Serial Bus (USB) Controller
Unknown device
Izgleda da je to USB Hub na Dell U2515H monitoru. Kad se isključi USB koji vodi u monitor, onda "missing driveri nestanu". - ipak ne nestaju, nisam dovoljno pažljivo gledao. Nestane samo Unknown device.
Inače USB portovi na monitoru najnormalnije rade. I sve zapravo radi bez greške, ali device manager nalazi ove missing drivere. Interesantno je da na Hardware ID ne pronalazi ništa za nijedan od tih drivera.
Što sam probao;
1. driveri monitora
2. drugi USB port na matičnoj
3. Intel Chipset driveri
4. Intel USB 3.0/3.1 driveri
5. Najnoviji NVIDIA driveri za 2080ti
Ima tko ideju?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 02.04.2019. u 13:54.
estugarda je offline   Reply With Quote
Staro 02.04.2019., 13:47   #2
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,281
jel ima monitor možda kakav cd sa drajverima
Staro 02.04.2019., 13:50   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
I to sam probao...
S neta doduše.
Ali nije trebalo prije ništa takvoga...
Uglavnom, ipak ne nestaju svi "missing driveri" kad odštekam monitor. Krivo sam vidio. Prva dva ostaju.
Dakle ipak nije to.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 02.04.2019. u 14:08.
Staro 02.04.2019., 15:06   #4
D/G
D/G's Avatar
Datum registracije: Feb 2010
Lokacija: Ploče
Postovi: 1,184
..možda nije OS win10 već neki stariji ?
Sa desetkom uvijek dok sam na net-u dobijem kroz update sve drajvere...po potrebi neki poslije toga promjenim po svojoj volji.
Moguće je da BIOS pravi problem, nakon flešanja si prešao sve postavke ? ( ili da nije "beta" ?) , mjenjam ga samo ako mi neki dio hardvera neradi ili se ne prepoznaje.
Staro 02.04.2019., 15:32   #5
ThePornstar
ThePornstar's Avatar
Postovi: 4,402
Autor estugarda Pregled postova
PCI Device
Unknown device
99% driveri od Asmedia USB 3.x kontrolera: link za download (Win 10)
Ako nekim slučajem nije, onda kroz Device Manager izvuci "HW ID" i traži po Googleu od čega je.
I da, fakat, koji OS koristiš?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
ThePornstar je online   Reply With Quote
Staro 02.04.2019., 15:48   #6
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Windows 7.
Instalirao sam i Asmedia 3.0/3.1 driver i Intel 3.0 USB driver. I pojedinačno sam probao.
BIOS sam namjestio kako je i bio prije. Barem mislim. Budem to još pregledao.
Stavljao sam NVMe M.2 disk nedavno, pa sam morao staviti novi BIOS. Uglavnom, nakon toga je sve bilo ok. Sve do danas, kad sam stavio 2080Ti i novo napajanje.
Prvo sam probao naci HW ID, ali nista konkretno ne nalazi google.
PCI Device
PCI\VEN_10DE&DEV_1AD7&SUBSYS_1E0410DE&REV_A1
PCI\VEN_10DE&DEV_1AD7&CC_0C8000
PCI\VEN_10DE&DEV_1AD6&SUBSYS_1E0410DE&REV_A1
PCI\VEN_10DE&DEV_1AD6&CC_0C0330
Unknown Device
PCI\VEN_8086&DEV_A12F&SUBSYS_86941043&REV_31
PCI\VEN_8086&DEV_A12F&CC_0C0330
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 02.04.2019. u 17:33.
Staro 02.04.2019., 17:35   #7
ThePornstar
Postovi: 4,402
@Bubba ti ima u potpisu svoj PCI-z tool pa probaj s njim saznati o čemu se radi. Na spomen ćevapa ćeš imat i njegov premium support
EDIT: prva dva su ti nešto od Endivije, a treći je nešto od Intela (pretpostavljam USB kontroler pa probaj ovo).
EDIT2: sjetio sam se da bi ova nova generacija Nvidie mogla imati Thunderbolt iza pa ako ga imaš - 100% su ova dva PCI uređaja vezana za njega.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Zadnje izmijenjeno od: ThePornstar. 02.04.2019. u 17:44.
Staro 02.04.2019., 17:48   #8
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Da. Ima USB Type-C otraga. Stvarno. Ali kaj to ne bi trebalo sve sa driverom doći? Ako se skine sa NVIDIA stranice?
PCI-Z je zakon tool. Svaka čast Bubbi! U kojoj ćevabdžinici obitava?
Ovo se crveni:
Serial bus controller NVIDIA Corporation USB controller The drivers for this device are not installed. (Code 28) 10DE:1AD6 10DE:1E04 Need device installer. Can be rebalanced.
Serial bus controller ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller USB controller The drivers for this device are not installed. (Code 28) 1B21:1242 1043:8675 Need device installer. Can be rebalanced.
EDIT: Sad sam još jednom preinstalirao Intelove USB drivere i sad je nestao Unknown Device. Ova prva dva su još ostala u Device Manageru.
CPU-z sad pokazuje samo još NVIDIA drivere crveno...tako da je defintivno nešto sa driverima grafe.
Mogao bi biti neki clash USB drivera NVIDIA-e i Intela!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 02.04.2019. u 17:58.
Staro 02.04.2019., 18:03   #9
ThePornstar
Postovi: 4,402
Pročitaj zadnji EDIT u postu iznad
Imaš USB-C, odnosno VirtualLink port na grafi i fali ti driver za njega.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 02.04.2019., 18:06   #10
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Vidio sam taj edit. Skužio sam te. Jedino ne znam gdje da nađem USB-C driver za grafu.
Baš gledam na stranicama. Odvojeno nema, a zadnji driver sam stavio.
...Sad mi je nešto palo na pamet; nikad ne instaliram Geforce Experience. Samo drivere na clean install. Možda je u tome caka.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 02.04.2019., 18:47   #11
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,397
Ima više opcija na "Custom install", to je bio zez vjerojatno.
Staro 02.04.2019., 19:11   #12
Postovi: 23,517
"PCI\VEN_10DE&DEV_1AD6&SUBSYS_1E0410DE&REV_A1" = NVIDIA USB 3.10 eXtensible Host Controller
Nemam sad vremena tražit detaljnije al čini se da nisu izdali drajver za W7,
ko fol "Windows 7 does not support the eXtensible Host Controller Interface (xHCI)".
Ako ti nije "o glavu" ostavi ga tako u Unknown ili eventualno Hide / Disable ako dozvoljava.
Ne treba ti "Experience" ...
Edit: Vidi jel možeš šta izvući iz ovog > https://www.nvidia.com/object/Quadro...er_197.03.html
Staro 02.04.2019., 19:55   #13
ThePornstar
Postovi: 4,402
U Nvidijom setupu odi na Custom Installation i skroz na dnu (ispod PhysXa) imaš USB-C driver za grafu. Nadam se da je isto na Win7
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 02.04.2019., 20:59   #14
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Išao sam na Custom (kao i uvijek) i 99% sve uključio osim Experience-a. Tako da vjerojatno onda nema za W7 drivera.
Stvarno se trude svim silama ubiti W7.
Totalno bezveze.
Uglavnom, sad kad znam što je, neću to više ni pogledati. Uskličnici su OK. Nema tu OCD-a.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 02.04.2019., 22:32   #15
mkey
Lokacija: tu
Postovi: 3,397
Windows 7 ubija vrijeme frende :P
